SINCGARS
| Frequency Band |
| 30.000 MHz to 30.550 MHz |
| 32.000 MHz to 33.000 MHz |
| 34.000 MHz to 35.000 MHz |
| 36.000 MHz to 37.000 MHz |
| 38.000 MHz to 39.000 MHz |
| 40.000 MHz to 42.000 MHz |
| 46.600 MHz to 47.000 MHz |
| 49.600 MHz to 50.000 MHz |
Commonly used frequencies include, but are certainly not limited to:
30.000 MHz, 30.100 MHz, 30.150 MHz, 30.300 MHz, 30.400 MHz, 30.450 MHz, 30.500 MHz, 32.000 MHz, 32.050 MHz, 32.150 MHz, 32.300 MHz, 32.500 MHz, 32.700 MHz, 34.200 MHz, 34.400 MHz, 34.900 MHz, 35.700 MHz, 36.100 MHz, 36.300 MHz, 36.500 MHz, 36.700 MHz, 38.450 MHz, 38.500 MHz, 38.550 MHz, 38.900 MHz, 39.000 MHz, 40.000 MHz, 40.400 MHz, 40.450 MHz, 40.500 MHz, 40.550 MHz, 40.600 MHz, 40.700 MHz, 40.750 MHz, 40.900 MHz, 40.950 MHz, 41.800 MHz, 41.900 MHz, 44.000 MHz, 45.000 MHz, 45.450 MHz, 45.700 MHz, 46.600 MHz, 46.650 MHz, 46.700 MHz, 46.750 MHz, 46.800 MHz, 46.850 MHz, 46.900 MHz, 46.950 MHz, 47.000 MHz, 49.700 MHz, 49.725 MHz, 49.750 MHz, 49.800 MHz, 49.825 MHz, 49.850 MHz, 49.875 MHz, 49.900 MHz, 49.925 MHz, 49.950 MHz, 49.975 MHz, 55.550 MHz, 70.700 MHz and many many others.
34.900 MHz is often used for convoy communications by National Guard units. 40.500 MHz is the FM emergency channel - akin to 121.500 MHz / 243.000 MHz (40.5 MHz * 3 = 121.5 MHz, 40.5 MHz * 6 = 243 MHz). However, 40.50 MHz is not nearly as heavily monitored as 121.5 MHz or 243.0 MHz.
Background and History
The SCR-300 and similar high-HF/low-VHF radios developed in WWII and the Korean War revolutionized small unit tactics. First the capability for a platoon or similar level unit to communicate with its headquarters or commanding elements and then the capability for each man in a squad for fireteam to communicate with each other in addition to the longer-range communications capability for platoon-to-commander and platoon-to-platoon communications using FM radio have changed the battlespace forever. The basic military backpack radio (and now handheld radio) concept has been copied endlessly, to the point where even militias and guerrilla forces use similar VHF/UHF radios for similar purposes. For example, see Ukraine militia forces using Baofengs (UV-5R, UV-82 and similar VHF/UHF handheld Chinese radios) and fighters in Afghanistan using Icom IC-V8s and other 2 meter / VHF handheld radios for battlefield tactical purposes, often in conjunction with 26-28 MHz CB type equipment or other similar radios/bands.
- 26.000 MHz - 69.950 MHz SEM-35 and similar clones/variants used in Europe and elsewhere
- 26.000 MHz - 71.950 MHz PRC-25/PRC-77 variants used in dozens of different countries
- 28.000 MHz - 73.950 MHz PRC-25/PRC-77 variants used in dozens of different countries
- 26.000 MHz - 70.000 MHz Radio Set 3600 - Dutch origin, used in various countries
- 26.000 MHz - 70.000 MHz TRC-552 - French origin, used in Africa, etc. as well
- 47.000 MHz - 56.000 MHz PRC-239 manpack radio, from Italy, exported to Middle East, etc.
- 40.000 MHz - 50.000 MHz PRC-439 manpack radio, from Italy, exported to Middle East, etc.
Evolution of military FM radio tactical radio bands: World War II, Korea and Beginning of Vietnam War (roughly 1940-1965)
| 20.000 MHz to 27.900 MHz | Armor Band (tank radio, tank destroyers, tank command nets) | 100 kHz (channels 200-279), PRC-8, PRC-8A, SCR-508, SCR-509, SCR-510, SCR-528, SCR-538, etc |
| 27.000 MHz to 38.900 MHz | Artillery Band | 100 kHz (channels 270-389), PRC-9, PRC-9A, SCR-608, SCR-609, SCR-610, SCR-628 |
| 38.000 MHz to 54.900 MHz | Infantry Band | 100 kHz (channels 380-549), PRC-10, PRC-10A, BC-1000/SCR-300 (partial, 40-48 MHz only) |
| 40.000 MHz to 48.000 MHz | Infantry Band (partial) | 200 kHz (channels 0-40), SCR-300 (BC-1000) manpack backpack radio |
Most of Vietnam War and Cold War (roughly 1965-1980s)
| 30.000 MHz to 75.950 MHz | Tactical Band (30-76 MHz) (150 Hz CTCSS "new squelch" system) removes need for manual squelch control | 50 kHz (channelized intent frequency control) PRC-25, PRC-77, VRC-12 and dozens of others |
1980s-present
| 30.000 MHz to 87.975 MHz | Tactical Band (30-88 MHz) 150 Hz CTCSS (some radios allow use of other tones) | 25 kHz step, single channel SC (fixed frequency) mode or frequency hopping FH (anti-jamming countermeasure) mode |
| 30 MHz to 512 MHz | Tactical Band (30-88 MHz) combined with VHF/UHF bands, including the airband, VHF marine band, VHF land mobile bands | 25 kHz step, single channel SC (fixed frequency) mode or frequency hopping FH (anti-jamming countermeasure) mode, 2.5, 5, 8.33 kHz steps |
| 2400-2500 MHz (2.4 GHz) | Intra-Squad Radio (ISR) and Improved Intra Squad Radio (IISR) systems | Various frequency steps and modes (including spread spectrum and frequency hopping) used for short range communications within squads/fireteams |
