SINCGARS
Revision as of 18:14, 13 February 2020 by R4002 (Talk | contribs)
Two handheld VHF-FM tactical radios Datron HH7700 30-88 MHz (30.000 MHz to 87.975 MHz) in 25 kHz steps, with no frequency hopping capability, the radio below is a vehicle-mounted VHF-FM military tactical radio
VHF-FM tactical radio system, with frequency-hopping and voice encryption/data encryption capabilities. Operating in the 30.000 to 87.975 MHz frequency band with 25 kHz channel steps. Uses 150.0 Hz CTCSS squelch system. Operates in single-channel (SC) and frequency-hopping (FH) modes for voice and data. Original generation SINCGARS radio such as the RT-1439 VRC set (VRC-87 configuration) and modern radios such as the Harris RT-1523 series offer +/5 kHz and +/- 10 kHz offset frequencies from the standard 25 kHz channels. In other words, de facto 5 kHz channel steps are available for the entire band. However, the offset channels are rarely used for practical purposes.
Most radios include repeater capability (called RETRANS or retransmit in military usage). Compatible with previous-generation FM radios such as the PRC-25, PRC-77, PRC-1077, HH7700 and dozens of other similar tactical handheld, manpack and vehicle-mounted radios operating in the 30-76 MHz (30.00 to 75.95 MHz in the original PRC-25/PRC-77 and VRC-12 channeling) or 30-88 MHz range. NATO military forces and many other military forces use similar frequencies for tactical purposes, almost always with FM voice. The US military fields radios that operate in the 30-174 MHz and 30-512 MHz ranges to support SINCGARS, regular VHF-FM, 136-174 MHz VHF-high band services like VHF marine, aircraft radios, SATCOM and interoperability with other radio systems that use VHF/UHF.
However, certain bands in the 30-50 MHz range (VHF low band) are allocated to exclusive government/military use. There are non-military government users of these frequencies, however most federal government agencies have moved to the 162-174 MHz and/or 406-420 MHz federal bands with the proliferation of trunking systems. There are still some wide-area networks such as the Tennessee Valley Authority's (TVA) base mobile 40 MHz low band VHF FM land mobile system that operates in the 40-42 MHz band using commercial low band equipment, 203.5 Hz and 250.3 Hz CTCSS tones to avoid sky wave skip interference with military traffic utilizing the 150.0 Hz CTCSS tone.
Frequency Band
30.000 MHz to 30.550 MHz
32.000 MHz to 33.000 MHz
34.000 MHz to 35.000 MHz
36.000 MHz to 37.000 MHz
38.000 MHz to 39.000 MHz
40.000 MHz to 42.000 MHz
46.600 MHz to 47.000 MHz
49.600 MHz to 50.000 MHz
It should be noted that military operations in single channel mode are found on any frequency between 30.000 and 87.975 MHz outside the government/military exclusive use bands on a non-interference basis. Use of the 150.0 Hz CTCSS or PL tone squelch allows for frequency sharing with other users. This, combined with the fact that civilian allocations in the 30-50 MHz band use 20 kHz channel steps, compared to the 25 kHz channeling used by military VHF-FM or SINCGARS systems. The 150 Hz tone squelch is close enough to the civilian 151.4 Hz CTCSS tone that many scanners or communications receivers will decode military VHF FM traffic as having 151.4 Hz CTCSS when in reality they are transmitting 150 Hz. Use of 150 Hz also permits the operation of "relay" (repeater) setups using two radios, the appropriate cables and filters and a high elevation location. Relay functionality has been included in FM tactical radios since the SCR-300 (BC-1000) series. It was not, however, heavily used until the Vietnam war. Most battlefield relay sites use RC-292 or similar high performance antennas. The wide frequency range of modern FM radios allows for maximum flexibility in choosing frequency pairs.
The 46.6 MHz - 47.0 MHz and 49.6 MHz - 50.0 MHz bands are shared with low power devices such as cordless phones, low power walkie-talkies and R/C devices. The 46.600 MHz, 46.625 MHz, 46.650 MHz, 46.675 MHz, 46.700 MHz, 46.725 MHz, 46.750 MHz, 46.775 MHz, 46.800 MHz, 46.825 MHz, 46.850 MHz, 46.875 MHz, 46.900 MHz, 46.925 MHz, 46.950 MHz, 46.975 MHz, 47.000 MHz, 49.825 MHz, 49.850 MHz, 49.875 MHz and 49.900 MHz channels overlap with the SINCGARS (or VHF FM aka FM) tactical frequency plan.
Background and History
Evolution of military FM radio tactical radio bands: World War II, Korea and Beginning of Vietnam War (roughly 1940-1965)
20.000 MHz to 27.900 MHz Armor Band (tank radio, tank destroyers, tank command nets) 100 kHz (channels 200-279), PRC-8, PRC-8A, SCR-508, SCR-509, SCR-510, SCR-528, SCR-538, etc
27.000 MHz to 38.900 MHz Artillery Band 100 kHz (channels 270-389), PRC-9, PRC-9A, SCR-608, SCR-609, SCR-610, SCR-628
38.000 MHz to 54.900 MHz Infantry Band 100 kHz (channels 380-549), PRC-10, PRC-10A, BC-1000/SCR-300 (partial, 40-48 MHz only)
40.000 MHz to 48.000 MHz Infantry Band (partial) 200 kHz (channels 0-40), SCR-300 (BC-1000) manpack backpack radio
Most of Vietnam War and Cold War (roughly 1965-1980s)
1980s-present
30.000 MHz to 87.975 MHz Tactical Band (30-88 MHz) 150 Hz CTCSS (some radios allow use of other tones) 25 kHz step, single channel SC (fixed frequency) mode or frequency hopping FH (anti-jamming countermeasure) mode
