Revision as of 13:34, 10 March 2020 by R4002 (Talk | contribs)
  • 27.490 MHz - Itinerant, may be used as base, mobile and/or part of temporary or portable repeater*
27.555 MHz Only in certain areas for forestry/logging, no current licenses, shared with fixed/mobile/government and freeband CB
27.615 MHz Only in certain areas for forestry/logging, no current licenses, shared with fixed/mobile/government and freeband CB
27.635 MHz Only in certain areas for forestry/logging, no current licenses, shared with fixed/mobile/government and freeband CB
27.655 MHz Only in certain areas for forestry/logging, no current licenses, shared with fixed/mobile/government and freeband CB
27.765 MHz Only in certain areas for forestry/logging, no current licenses, shared with fixed/mobile/government and freeband CB
27.860 MHz Only in certain areas for forestry/logging, no current licenses, shared with fixed/mobile/government and freeband CB
35.180 MHz
72.080 MHz
72.160 MHz
72.240 MHz
72.320 MHz
72.400 MHz
154.45625 MHz Operational fixed (SCADA, data links, telemetry, etc) only
154.46375 MHz Operational fixed (SCADA, data links, telemetry, etc) only
154.47125 MHz Operational fixed (SCADA, data links, telemetry, etc) only
154.47875 MHz Operational fixed (SCADA, data links, telemetry, etc) only
154.505 MHz
154.5275 MHz Mobiles only
154.585 MHz
154.610 MHz
154.625 MHz
154.640 MHz
173.20375 MHz Operational fixed (SCADA, data links, etc) only - narrowband 6.25 kHz channel spacing
173.210 MHz Operational fixed (SCADA, data links, etc) only - narrowband 6.25 kHz channel spacing
173.390 MHz Operational fixed (SCADA, data links, etc) only - narrowband 6.25 kHz channel spacing
173.39625 MHz Operational fixed (SCADA, data links, etc) only - narrowband 6.25 kHz channel spacing
Default Motorola Kenwood Vertex Factory Out Of The Box Channels Frequencies Settings
Motorola CLS1110 and CLS1410 2-watt 1 channel/4 channel UHF radio
  • Channel 1 - 154.5700 MHz 67.0 Hz PL [Frequency 1, Code 1] - 20.0 kHz bandwidth - 20K0F3E emission
  • Channel 2 - 154.6000 MHz 67.0 Hz PL [Frequency 2, Code 1] - 20.0 kHz bandwidth - 20K0F3E emission
  • Channel 3 - 151.8200 MHz 67.0 Hz PL [Frequency 3, Code 1] - 11.25 kHz bandwidth - 11K3F3E emission
  • Channel 4 - 151.8800 MHz 67.0 Hz PL [Frequency 4, Code 1] - 11.25 kHz bandwidth - 11K3F3E emission
  • Channel 5 - 151.9400 MHz 67.0 Hz PL [Frequency 5, Code 1] - 11.25 kHz bandwidth - 11K3F3E emission
