Revision as of 12:36, 14 April 2020 by R4002 (Talk | contribs)
2 MHz - 25 MHz, below 25000 kHz below 25 MHz
  • 5900 kHz - 5950 kHz
  • 7300 kHz - 7350 kHz
  • 9400 kHz - 9500 kHz
  • 11600 kHz - 11650 kHz
  • 12050 kHz - 12100 kHz
  • 13800 kHz - 13870 kHz
  • 15600 kHz - 15800 kHz
25.020 MHz
25.040 MHz
25.060 MHz
25.080 MHz
25.100 MHz
25.120 MHz
25.140 MHz
25.160 MHz
25.180 MHz
25.200 MHz
25.220 MHz
25.240 MHz
25.260 MHz
25.280 MHz
25.300 MHz
25.320 MHz
27.430 MHz
27.450 MHz
27.470 MHz
27.490 MHz Itinerant use only
29.710 MHz
35.180 MHz
44.420 MHz
72.080 MHz
72.160 MHz
72.240 MHz
72.320 MHz
72.400 MHz
152.4725 MHz
154.4825 MHz
154.490 MHz
154.4975 MHz
154.5275 MHz Mobiles
154.540 MHz
154.5475 MHz
154.555 MHz
154.610 MHz
154.640 MHz Mobiles
157.7325 MHz
158.4525 MHz
158.460 MHz
  • Group B - Group B frequencies are available for non-voice operations on a primary basis. Voice operations will be permitted on a secondary basis. Base, mobile or operational fixed stations will be authorized on Group B frequencies. Fixed stations may be licensed as mobile. Maximum height for fixed stations is 20 feet above ground. Base or fixed stations have a maximum power output of 6 watts. Portable or mobile stations have a maximum power output of 2 watts. The vast majority of these frequencies are used for simplex purposes only.
  • 451.1875 MHz/456.1875 MHz
  • 451.2875 MHz/456.2875 MHz
  • 451.3125 MHz/456.3125 MHz
  • 451.3625 MHz/456.3125 MHz
  • 451.3875 MHz/456.3875 MHz
  • 451.4625 MHz/456.4625 MHz
  • 451.4875 MHz/456.4875 MHz
  • 451.5625 MHz/456.5625 MHz
  • 451.5875 MHz/456.5875 MHz
  • 451.6125 MHz/456.6125 MHz
  • 451.6625 MHz/456.6626 MHz
  • 451.6875 MHz/456.6875 MHz
  • 451.7125 MHz/456.7125 MHz
  • 451.7375 MHz/456.7375 MHz
  • 451.7625 MHz/456.7625 MHz
  • 452.0375 MHz/457.0375 MHz
  • 452.0625 MHz/457.0625 MHz
  • 452.0875 MHz/457.0875 MHz
  • 452.1125 MHz/457.1125 MHz
  • 452.1375 MHz/457.1375 MHz
  • 452.1625 MHz/457.1625 MHz
  • 452.1875 MHz/457.1875 MHz
  • 452.2875 MHz/457.2875 MHz
  • 452.4875 MHz/457.4875 MHz
  • 452.5375 MHz (not paired)
  • 452.6375 MHz/457.6375 MHz
  • 452.6625 MHz/457.6625 MHz
  • 452.6875 MHz/457.6875 MHz
  • 452.7125 MHz/457.7125 MHz
  • 452.7875 MHz/457.7875 MHz
  • 452.8125 MHz/457.8125 MHz
  • 452.8375 MHz/457.8375 MHz
  • 452.8875 MHz/457.8875 MHz
  • 452.9875 MHz/457.9875 MHz
  • 462.1875 MHz/467.1875 MHz
  • 462.4625 MHz/467.4625 MHz
  • 462.4875 MHz/467.4875 MHz
  • 462.5125 MHz/467.5125 MHz
  • 451.2375 MHz/456.2375 MHz
  • 451.3375 MHz/456.3375 MHz
  • 451.4375 MHz/456.4375 MHz
  • 451.5375 MHz/456.5375 MHz
  • 451.6375 MHz/456.6375 MHz
  • 452.3125 MHz/457.3125 MHz
  • 452.4125 MHz/457.4125 MHz
  • 452.5125 MHz/457.5125 MHz
  • 452.7625 MHz/457.7625 MHz
  • 452.8625 MHz/457.8625 MHz
  • 462.2125 MHz/467.2125 MHz
  • 462.2375 MHz/467.2375 MHz
  • 462.2625 MHz/467.2625 MHz
  • 462.2875 MHz/467.2875 MHz
  • 462.3125 MHz/467.3125 MHz
  • 462.3375 MHz/467.3375 MHz
  • 462.3625 MHz/467.3625 MHz
  • 462.3875 MHz/467.3875 MHz
  • 462.4125 MHz/467.4125 MHz
  • 462.4375 MHz/467.4375 MHz
  • 461.0375 MHz/466.0375 MHz
  • 461.0625 MHz/466.0625 MHz
  • 461.0875 MHz/466.0875 MHz
  • 461.1125 MHz/466.1125 MHz
  • 461.1375 MHz/466.1375 MHz
  • 461.1625 MHz/466.1625 MHz
  • 461.1875 MHz/466.1875 MHz
  • 461.2125 MHz/466.2125 MHz
  • 461.2375 MHz/466.2375 MHz
  • 461.2625 MHz/466.2625 MHz
  • 461.2875 MHz/466.2875 MHz
  • 461.3125 MHz/466.3125 MHz
  • 461.3375 MHz/466.3375 MHz
  • 461.3625 MHz/466.3625 MHz
  • 462.7625 MHz (not paired)
  • 462.7875 MHz (not paired)
  • 462.8125 MHz (not paired)
  • 462.8375 MHz (not paired)
  • 462.8625 MHz/467.8625 MHz
  • 462.8875 MHz/467.8875 MHz
  • 462.9125 MHz/467.9125 MHz
  • 464.4875 MHz/469.4875 MHz
  • 464.5125 MHz/469.5125 MHz
  • 464.5375 MHz/469.5375 MHz
  • 464.5625 MHz/469.5625 MHz
  • 460.9125 MHz/465.9125 MHz
  • 460.9375 MHz/465.9375 MHz
  • 460.9625 MHz/465.9625 MHz
  • 460.9875 MHz/465.9875 MHz
  • 461.0125 MHz/466.0125 MHz
  • 151.5125 MHz - Itinerant
  • 151.6550 MHz
  • 151.6850 MHz
  • 151.7150 MHz
  • 151.7450 MHz
  • 151.7750 MHz
  • 151.8050 MHz
  • 151.8350 MHz
  • 151.8650 MHz
  • 151.8950 MHz
  • 151.9250 MHz
  • 151.9550 MHz - Purple Dot
  • 152.8850 MHz
  • 152.9000 MHz
  • 152.9150 MHz
  • 152.9450 MHz
  • 153.0050 MHz
  • 154.4900 MHz
  • 154.5150 MHz
  • 154.5400 MHz
  • 154.5475 MHz
  • 158.4000 MHz - Itinerant
  • 158.4075 MHz - Itinerant
  • 451.1875 MHz
  • 451.2375 MHz
  • 451.2875 MHz
  • 451.3375 MHz
  • 451.4375 MHz
  • 451.5375 MHz
  • 451.6375 MHz
  • 452.3125 MHz
  • 452.4125 MHz
  • 452.5125 MHz
  • 452.5375 MHz
  • 452.7625 MHz
  • 452.8625 MHz
  • 456.1875 MHz
  • 456.2375 MHz
  • 456.2875 MHz
  • 456.3375 MHz
  • 456.4375 MHz
  • 456.5375 MHz
  • 456.6375 MHz
  • 457.3125 MHz
  • 457.4125 MHz
  • 457.5125 MHz
  • 457.6375 MHz
  • 457.6625 MHz
  • 457.7125 MHz
  • 457.7375 MHz
  • 457.7625 MHz
  • 457.8625 MHz
  • 461.0375 MHz
  • 461.0625 MHz
  • 461.0875 MHz
  • 461.1125 MHz
  • 461.1375 MHz
  • 461.1625 MHz
  • 461.1875 MHz
  • 461.2125 MHz
  • 461.2375 MHz
  • 461.2625 MHz
  • 461.2875 MHz
  • 461.3125 MHz
  • 461.3375 MHz
  • 461.3625 MHz
  • 462.1875 MHz
  • 462.4625 MHz
  • 462.4875 MHz
  • 462.5125 MHz
  • 464.4875 MHz - Itinerant
  • 464.5125 MHz - Itinerant
  • 464.5375 MHz - Itinerant
  • 464.5625 MHz - Itinerant
  • 466.0375 MHz
  • 466.0625 MHz
  • 466.0875 MHz
  • 466.1125 MHz
  • 466.1375 MHz
  • 466.1625 MHz
  • 466.1875 MHz
  • 466.2125 MHz
  • 466.2375 MHz
  • 466.2625 MHz
  • 466.2875 MHz
  • 466.3125 MHz
  • 466.3375 MHz
  • 466.3625 MHz
  • 467.1875 MHz
  • 467.4625 MHz
  • 467.4875 MHz
  • 467.5125 MHz
  • 468.2125 MHz
  • 468.2625 MHz
  • 468.3125 MHz
  • 468.3375 MHz
  • 468.3625 MHz
  • 468.4125 MHz
  • 468.4625 MHz
  • 468.5125 MHz
  • 468.5625 MHz
  • 468.5875 MHz
  • 468.6125 MHz
  • 468.6375 MHz
  • 469.4875 MHz - Itinerant
  • 469.5125 MHz - Itinerant
  • 469.5375 MHz - Itinerant
  • 469.5625 MHz - Itinerant
Motorola RDM2070D VHF MURS
Motorola RDM2020 VHF MURS
Motorola RDM2080D VHF MURS
Retevis RT-68 FRS 16 channel
  • Channel 1 - 400.1250 MHz
  • Channel 2 - 410.1250 MHz
  • Channel 3 - 420.1250 MHz
  • Channel 4 - 430.1250 MHz
  • Channel 5 - 440.1250 MHz
  • Channel 6 - 450.1250 MHz
  • Channel 7 - 460.1250 MHz
  • Channel 8 - 470.1250 MHz
  • Channel 9 - 480.1250 MHz
  • Channel 10 - 490.1250 MHz
  • Channel 11 - 500.1250 MHz
  • Channel 12 - 510.1250 MHz
  • Channel 13 - 519.9750 MHz
  • Channel 14 - 136.1250 MHz
  • Channel 15 - 145.1250 MHz
  • Channel 16 - 155.1250 MHz
  • Channel 17 - 165.1250 MHz
  • Channel 18 - 173.9750 MHz
  • Freq 1 - 464.5000 MHz
  • Freq 2 - 464.5500 MHz
  • Freq 3 - 467.7625 MHz
  • Freq 4 - 467.8125 MHz
  • Freq 5 - 467.8500 MHz
  • Freq 6 - 467.8750 MHz
  • Freq 7 - 467.9000 MHz
  • Freq 8 - 467.9250 MHz
  • Freq 9 - 461.0375 MHz
  • Freq 10 - 461.0625 MHz
  • Freq 11 - 461.0875 MHz
  • Freq 12 - 461.1125 MHz
  • Freq 13 - 461.1375 MHz
  • Freq 14 - 461.1625 MHz
  • Freq 15 - 461.1875 MHz
  • Freq 16 - 461.2125 MHz
  • Freq 17 - 461.2375 MHz
  • Freq 18 - 461.2625 MHz
  • Freq 19 - 461.2875 MHz
  • Freq 20 - 461.3125 MHz
  • Freq 21 - 461.3375 MHz
  • Freq 22 - 461.3625 MHz
  • Freq 23 - 462.7625 MHz
  • Freq 24 - 462.7875 MHz
  • Freq 25 - 462.8125 MHz
  • Freq 26 - 462.8375 MHz
  • Freq 27 - 462.8625 MHz
  • Freq 28 - 462.8875 MHz
  • Freq 29 - 462.9125 MHz
  • Freq 30 - 464.4875 MHz
  • Freq 31 - 464.5125 MHz
  • Freq 32 - 464.5375 MHz
  • Freq 33 - 464.5625 MHz
  • Freq 34 - 466.0375 MHz
  • Freq 35 - 466.0625 MHz
  • Freq 36 - 466.0875 MHz
  • Freq 37 - 466.1125 MHz
  • Freq 38 - 466.1375 MHz
  • Freq 39 - 466.1625 MHz
  • Freq 40 - 466.1875 MHz
  • Freq 41 - 466.2125 MHz
  • Freq 42 - 466.2375 MHz
  • Freq 43 - 466.2625 MHz
  • Freq 44 - 466.2875 MHz
  • Freq 45 - 466.3125 MHz
  • Freq 46 - 466.3375 MHz
  • Freq 47 - 466.3625 MHz
  • Freq 48 - 467.7875 MHz
  • Freq 49 - 467.8375 MHz
  • Freq 50 - 467.8625 MHz
  • Freq 51 - 467.8875 MHz
  • Freq 52 - 467.9125 MHz
  • Freq 53 - 469.4875 MHz
  • Freq 54 - 469.5125 MHz
  • Freq 55 - 469.5375 MHz
  • Freq 56 - 469.5625 MHz
  • Freq 9 - 462.5750 MHz
  • Freq 10 - 462.6250 MHz
  • Freq 11 - 462.6750 MHz
  • Freq 12 - 464.3250 MHz
  • Freq 13 - 464.8250 MHz
  • Freq 14 - 469.2625 MHz
  • Freq 15 - 469.5000 MHz
  • Freq 16 - 469.5500 MHz
  • Freq 17 - 462.7625 MHz
  • Freq 18 - 462.7875 MHz
  • Freq 19 - 462.8125 MHz
  • Freq 20 - 462.8375 MHz
  • Freq 21 - 462.8625 MHz
  • Freq 22 - 462.8875 MHz
  • Freq 23 - 462.9125 MHz
  • Freq 24 - 464.4875 MHz
  • Freq 25 - 461.0375 MHz
  • Freq 26 - 461.0625 MHz
  • Freq 27 - 461.0875 MHz
  • Freq 28 - 461.1125 MHz
  • Freq 29 - 461.1375 MHz
  • Freq 30 - 461.1625 MHz
  • Freq 31 - 461.1875 MHz
  • Freq 32 - 461.2125 MHz
  • Freq 33 - 461.2375 MHz
  • Freq 34 - 461.2625 MHz
  • Freq 35 - 461.2875 MHz
  • Freq 36 - 461.3125 MHz
  • Freq 37 - 461.3375 MHz
  • Freq 38 - 461.3625 MHz
  • Freq 39 - 462.7625 MHz
  • Freq 40 - 462.7875 MHz
  • Freq 41 - 462.8125 MHz
  • Freq 42 - 462.8375 MHz
  • Freq 43 - 462.8625 MHz
  • Freq 44 - 462.8875 MHz
  • Freq 45 - 462.9125 MHz
  • Freq 46 - 464.4875 MHz
  • Freq 47 - 464.5125 MHz
  • Freq 48 - 464.5375 MHz
  • Freq 49 - 464.5625 MHz
  • Freq 50 - 466.0375 MHz
  • Freq 51 - 466.0625 MHz
  • Freq 52 - 466.0875 MHz
  • Freq 53 - 466.1125 MHz
  • Freq 54 - 466.1375 MHz
  • Freq 55 - 466.1625 MHz
  • Freq 56 - 466.1875 MHz
  • Freq 1 - 151.6250 MHz
  • Freq 2 - 151.9550 MHz
  • Freq 3 - 154.5700 MHz
  • Freq 4 - 154.6000 MHz
  • Freq 5 - 151.7000 MHz
  • Freq 6 - 151.7600 MHz
  • Freq 7 - 151.8200 MHz
  • Freq 8 - 151.8800 MHz
  • Freq 9 - 151.9400 MHz
  • Freq 10 - 151.5125 MHz
  • Freq 11 - 151.6550 MHz
  • Freq 12 - 151.6850 MHz
  • Freq 13 - 151.7150 MHz
  • Freq 14 - 151.7450 MHz
  • Freq 15 - 151.7750 MHz
  • Freq 16 - 151.8650 MHz
  • Freq 17 - 151.8950 MHz
  • Freq 18 - 151.9250 MHz
  • Freq 20 - 154.4900 MHz
  • Freq 21 - 154.5150 MHz
  • Freq 22 - 154.5275 MHz
  • Freq 23 - 154.5400 MHz
  • Freq 24 - 154.6000 MHz
  • Freq 26 - 158.4000 MHz
  • Freq 27 - 158.4075 MHz
  • Freq 57 - 462.1875 MHz
  • Freq 58 - 462.4625 MHz
  • Freq 59 - 462.4875 MHz
  • Freq 60 - 462.5125 MHz
  • Freq 61 - 467.1875 MHz
  • Freq 62 - 467.4625 MHz
  • Freq 63 - 467.4875 MHz
  • Freq 64 - 467.5125 MHz
  • Freq 65 - 451.1875 MHz
  • Freq 66 - 451.2375 MHz
  • Freq 67 - 451.2875 MHz
  • Freq 68 - 451.3375 MHz
  • Freq 69 - 451.4375 MHz
  • Freq 70 - 451.5375 MHz
  • Freq 71 - 451.6375 MHz
  • Freq 72 - 452.3125 MHz
  • Freq 73 - 452.5375 MHz
  • Freq 74 - 452.4125 MHz
  • Freq 75 - 452.5125 MHz
  • Freq 76 - 452.7625 MHz
  • Freq 77 - 452.8625 MHz
  • Freq 78 - 456.1875 MHz
  • Freq 79 - 456.2375 MHz
  • Freq 80 - 456.2875 MHz
  • Freq 81 - 468.2125 MHz
  • Freq 82 - 468.2625 MHz
  • Freq 83 - 468.3125 MHz
  • Freq 84 - 468.3625 MHz
  • Freq 85 - 468.4125 MHz
  • Freq 86 - 468.4625 MHz
  • Freq 87 - 468.5125 MHz
  • Freq 88 - 468.5625 MHz
  • Freq 89 - 468.6125 MHz
  • Freq 90 - 468.6625 MHz
  • Freq 81 - 456.3375 MHz
  • Freq 82 - 456.4375 MHz
  • Freq 83 - 456.5375 MHz
  • Freq 84 - 456.6375 MHz
  • Freq 85 - 457.3125 MHz
  • Freq 86 - 457.4125 MHz
  • Freq 87 - 457.5125 MHz
  • Freq 88 - 457.7625 MHz
  • Freq 89 - 457.8625 MHz
  • Freq 3 - 152.8850 MHz
  • Freq 4 - 152.9150 MHz
  • Freq 7 - 152.9450 MHz
  • Freq 8 - 151.8350 MHz
  • Freq 9 - 151.8050 MHz
  • Freq 24 - 153.0050 MHz
  • Code 1 - 67.0 Hz PL - XZ
  • Code 2 - 71.9 Hz PL - XA
  • Code 3 - 74.4 Hz PL - WA
  • Code 4 - 77.0 Hz PL - XB
  • Code 5 - 79.7 Hz PL - WB
  • Code 6 - 82.5 Hz PL - YZ
  • Code 7 - 85.4 Hz PL - YA
  • Code 8 - 88.5 Hz PL - YB
  • Code 9 - 91.5 Hz PL - ZZ
  • Code 10 - 94.8 Hz PL - ZA
  • Code 11 - 97.4 Hz PL - ZB
  • Code 12 - 100.0 Hz PL - 1Z
  • Code 13 - 103.5 Hz PL - 1A
  • Code 14 - 107.2 Hz PL - 2Z
  • Code 15 - 110.9 Hz PL - 2Z
  • Code 16 - 114.8 Hz PL - 2A
  • Code 17 - 118.8 Hz PL - 2B
  • Code 18 - 123.0 Hz PL - 3Z
  • Code 19 - 127.3 Hz PL - 3A
  • Code 20 - 131.8 Hz PL - 3B
  • Code 21 - 136.5 Hz PL - 4Z
  • Code 22 - 141.3 Hz PL - 4A
  • Code 23 - 146.2 Hz PL - 4B
  • Code 24 - 151.4 Hz PL - 5Z
  • Code 25 - 156.7 Hz PL - 5A
  • Code 26 - 162.2 Hz PL - 5B
  • Code 27 - 167.9 Hz PL - 6Z
  • Code 28 - 173.8 Hz PL - 6A
  • Code 29 - 179.9 Hz PL - 6B
  • Code 30 - 186.2 Hz PL - 7Z
  • Code 31 - 192.8 Hz PL - 7A
  • Code 32 - 203.5 Hz PL - M1
  • Code 33 - 210.7 Hz PL - M2
  • Code 34 - 218.1 Hz PL - M3
  • Code 35 - 225.7 Hz PL - M4
  • Code 36 - 233.6 Hz PL - M5
  • Code 37 - 241.8 Hz PL - M6
  • Code 38 - 250.3 Hz PL - M7
  • Code 39 - 023 DPL
  • Code 40 - 025 DPL
  • Code 41 - 026 DPL
  • Code 42 - 031 DPL
  • Code 43 - 032 DPL
  • Code 44 - 043 DPL
  • Code 45 - 047 DPL
  • Code 46 - 051 DPL
  • Code 47 - 054 DPL
  • Code 48 - 065 DPL
  • Code 49 - 071 DPL
  • Code 50 - 072 DPL
  • Code 51 - 073 DPL
  • Code 52 - 074 DPL
  • Code 53 - 114 DPL
  • Code 54 - 115 DPL
  • Code 55 - 116 DPL
  • Code 56 - 125 DPL
  • Code 57 - 131 DPL
  • Code 58 - 132 DPL
  • Code 59 - 134 DPL
  • Code 60 - 143 DPL
  • Code 61 - 152 DPL
  • Code 62 - 155 DPL
  • Code 63 - 156 DPL
  • Code 64 - 162 DPL
  • Code 65 - 165 DPL
  • Code 66 - 172 DPL
  • Code 67 - 174 DPL
  • Code 68 - 205 DPL
  • Code 69 - 223 DPL
  • Code 70 - 226 DPL
  • Code 71 - 243 DPL
  • Code 72 - 244 DPL
  • Code 73 - 245 DPL
  • Code 74 - 251 DPL
  • Code 75 - 261 DPL
  • Code 76 - 263 DPL
  • Code 77 - 265 DPL
  • Code 78 - 271 DPL
  • Code 79 - 306 DPL
  • Code 80 - 311 DPL
  • Code 81 - 315 DPL
  • Code 82 - 331 DPL
  • Code 83 - 343 DPL
  • Code 84 - 346 DPL
  • Code 85 - 351 DPL
  • Code 86 - 364 DPL
  • Code 87 - 365 DPL
  • Code 88 - 371 DPL
  • Code 89 - 411 DPL
  • Code 90 - 412 DPL
  • Code 91 - 413 DPL
  • Code 92 - 423 DPL
  • Code 93 - 431 DPL
  • Code 94 - 432 DPL
  • Code 95 - 445 DPL
  • Code 96 - 464 DPL
  • Code 97 - 465 DPL
  • Code 98 - 466 DPL
  • Code 99 - 503 DPL
  • Code 100 - 506 DPL
  • Code 101 - 516 DPL
  • Code 102 - 532 DPL
  • Code 103 - 546 DPL
  • Code 104 - 565 DPL
  • Code 105 - 606 DPL
  • Code 106 - 612 DPL
  • Code 107 - 624 DPL
  • Code 108 - 627 DPL
  • Code 109 - 631 DPL
  • Code 110 - 632 DPL
  • Code 111 - 654 DPL
  • Code 112 - 662 DPL
  • Code 113 - 664 DPL
  • Code 114 - 703 DPL
  • Code 115 - 712 DPL
  • Code 116 - 723 DPL
  • Code 117 - 731 DPL
  • Code 118 - 732 DPL
  • Code 119 - 734 DPL
  • Code 120 - 743 DPL
  • Code 121 - 754 DPL
  • Freq 0 - OFF (BLANK)
  • VHF:
  • 151.6550 MHz
  • 151.6850 MHz
  • 151.7150 MHz
  • 151.7450 MHz
  • 151.7750 MHz
  • 151.8650 MHz
  • 151.8950 MHz
  • 151.9250 MHz
  • 151.9550 MHz
  • 151.9850 MHz
  • 152.8850 MHz
  • 152.9150 MHz
  • 153.0050 MHz
  • 154.4900 MHz
  • 154.5150 MHz
  • 154.5400 MHz
  • 468.2125 MHz
  • 468.2625 MHz
  • 468.3125 MHz
  • 468.3625 MHz
  • 468.4125 MHz
  • 468.4625 MHz
  • 468.5125 MHz
  • 468.5625 MHz
  • 468.6125 MHz
  • 468.6625 MHz
  • 451.4125 MHz
  • 451.5125 MHz
  • 451.5375 MHz
  • 451.5875 MHz
  • 451.6375 MHz
  • 451.6625 MHz
  • 451.6875 MHz
  • 452.7625 MHz
  • 456.4125 MHz
  • 456.5125 MHz
  • 456.6125 MHz
  • 456.6875 MHz
  • 457.7625 MHz
  • 467.7625 MHz
  • 467.8125 MHz
  • 467.8500 MHz
  • 467.8750 MHz
  • 467.9000 MHz
  • 467.9250 MHz
  • 467.8500 MHz Channel 1
  • 467.8750 MHz Channel 2
  • 467.9000 MHz Channel 3
  • 467.9250 MHz Channel 4
  • 467.8500 MHz
  • 467.8750 MHz
  • 467.9000 MHz
  • 467.9250 MHz
  • 461.0375 MHz
  • 461.1125 MHz
  • 461.2125 MHz
  • 462.7625 MHz
  • 462.8125 MHz
  • 464.5375 MHz
  • 464.5625 MHz
  • 466.0375 MHz
  • 466.1125 MHz
  • 466.1375 MHz
  • 469.4875 MHz
  • 469.5375 MHz
  • 467.8000 MHz
  • 467.8500 MHz
  • 467.1875 MHz 306 DPL
  • 467.4625 MHz 244 DPL
  • 151.6250 MHz 179.9 Hz PL
  • 151.9550 MHz 179.9 Hz PL
  • 151.9250 MHz 506 DPL
  • 151.8950 MHz 506 DPL
  • 151.6250 MHz 74.4 Hz PL
  • 151.8050 MHz 77.0 Hz PL
  • 151.8050 MHz 172 DPL
  • 151.8050 MHz 311 DPL
  • 151.8050 MHz 624 DPL
  • 151.8350 MHz 74.4 Hz PL
  • 151.9550 MHz 74.4 Hz PL
  • 151.9550 MHz 77.0 Hz PL
  • 154.5150 MHz 74.4 Hz PL
  • 154.5150 MHz 172 DPL
  • 154.5400 MHz 74.4 Hz PL
  • 154.5400 MHz 311 DPL
  • 154.5700 MHz 624 DPL
  • 154.6000 MHz 74.4 Hz PL
  • 154.6000 MHz 85.4 Hz PL
  • 154.6000 MHz 172 DPL
  • 154.6000 MHz 624 DPL
  • 151.5050
  • 151.6250
  • 151.7000
  • 151.8200
  • 151.9250
  • 154.5700
  • 154.6000
  • 158.4000
  • 451.8000
  • 451.8125
  • 456.8125
  • 151.6250 MHz
  • 151.7600 MHz
  • 151.7750 MHz
  • 151.8200 MHz
  • 151.8350 MHz
  • 151.8650 MHz
  • 151.8800 MHz
  • 151.9400 MHz
  • 151.9550 MHz
  • 151.9550 MHz
  • 461.0375 MHz 172 DPL
  • 461.0875 MHz 223 DPL
  • 461.1125 MHz 172 DPL
  • 461.3625 MHz 172 DPL
  • 464.5000 MHz 172 DPL
  • 469.5000 MHz 172 DPL
