VHF LADD
Revision as of 18:51, 23 July 2020 by R4002 (Talk | contribs)
[1]
While these frequencies were originally intended only for use by logging companies, oil exploration and drilling equipment delivery companies, remote base station dispatch (think 'Ice Road Truckers') and other specialized use, the proliferation of inexpensive VHF-FM equipment means their usage has become more widespread and these frequencies have become de facto "interoperability" frequencies in remote areas of Canada. The LADD channels in particular are used by natural resources officers to communicate with logging companies as well as for truck-to-truck, handheld radios for flaggers at loading sites and for other specialized purposes.
Note that the 4 LADD channels are still in regular FM (20 kHz bandwidth) while the 5 LD (Loading Channels) and 35 RR (Resource Road) channels are narrowband FM (NFM or FMN - 11.25 kHz bandwidth). CTCSS (PL) or DCS (DPL) should not be used on any of these frequencies. Receivers must be set for carrier squelch or CSQ mode.
Channel Frequency Remarks/Usage
LADD 1 154.1000 MHz LADD channel 1 - trucking and logging companies, natural resource agencies
LADD 2 158.9400 MHz LADD channel 2 - trucking and logging companies, natural resource agencies
LADD 3 154.3250 MHz LADD channel 3 - trucking and logging companies, natural resource agencies
LADD 4 173.3700 MHz LADD channel 4 - trucking and logging companies, natural resource agencies
LD-1 151.7000 MHz Loading channel 1
LD-2 151.7450 MHz Loading channel 2
LD-3 151.7900 MHz Loading channel 3
LD-4 151.8050 MHz Loading channel 4
LD-5 151.8500 MHz Loading channel 5
RR-01 150.0800 MHz Resource Road channel 1
RR-02 150.1100 MHz Resource Road channel 2
RR-03 150.1400 MHz Resource Road channel 3
RR-04 150.1850 MHz Resource Road channel 4
RR-05 150.2000 MHz Resource Road channel 5
RR-06 150.2450 MHz Resource Road channel 6
RR-07 150.2600 MHz Resource Road channel 7
RR-08 150.3200 MHz Resource Road channel 8
RR-09 150.3650 MHz Resource Road channel 9
RR-10 150.4100 MHz Resource Road channel 10
RR-11 150.4400 MHz Resource Road channel 11
RR-12 150.5000 MHz Resource Road channel 12
RR-13 150.5300 MHz Resource Road channel 13
RR-14 150.5450 MHz Resource Road channel 14
RR-15 150.5600 MHz Resource Road channel 15
RR-16 150.5900 MHz Resource Road channel 16
RR-17 150.6800 MHz Resource Road channel 17
RR-18 150.7100 MHz Resource Road channel 18
RR-19 150.7700 MHz Resource Road channel 19
RR-20 150.8300 MHz Resource Road channel 20
RR-21 151.0100 MHz Resource Road channel 21
RR-22 151.1300 MHz Resource Road channel 22
RR-23 151.1900 MHz Resource Road channel 23
RR-24 151.2200 MHz Resource Road channel 24
RR-25 151.3100 MHz Resource Road channel 25
RR-26 151.3400 MHz Resource Road channel 26
RR-27 151.3700 MHz Resource Road channel 27
RR-28 151.4300 MHz Resource Road channel 28
RR-29 151.4600 MHz Resource Road channel 29
RR-30 151.4900 MHz Resource Road channel 30
RR-31 151.5200 MHz Resource Road channel 31
RR-32 151.5800 MHz Resource Road channel 32
RR-33 151.6100 MHz Resource Road channel 33
RR-34 151.6400 MHz Resource Road channel 34
RR-35 151.6700 MHz Resource Road channel 35
LGRANT1 143.4150 MHz
LGRANT2 143.4150 MHz
LGRANT1 148.4350 MHz
TRUCKSNWT 149.8300 MHz
WEYHEAU 168.8400 MHz
WEYHAEU2 150.6350 MHz
WEYHAEU3 169.5450 MHz
WEYHAEU4 169.1250 MHz
WEYHEAU5 150.2150 MHz
WEYHAEU6 150.7850 MHz
EMERGEN 150.8150 MHz
LAKEMILE 150.9550 MHz
MILLGILL 151.0550 MHz
SLATTON 151.2650 MHz
TANIZUL 151.2950 MHz
SUKUNA 151.32500 MHz
LAKELAND 151.3550 MHz
STUARTLK 151.6850 MHz Stuart Lake
COTNWOOD 151.7150 MHz
MURS1 151.8200 MHz MURS Channel 1
MURS 2 151.8800 MHz MURS Channel 2
MURS 3 151.9400 MHz MHz MURS Channel 3
MURS 4 154.5700 MHz MURS Channel 4
MURS 5 154.6000 MHz MURS Channel 5
LAIRDMNL 151.8350 MHz
HAULRD 151.9250 MHz
POLAR 153.5300 MHz Canadian Forest Products Ltd. - Polar 1 - North Central Roads
POLAR2 151.9850 MHz Canadian Forest Products Ltd. - Polar 2 - Summit & McLeod Road
BCROAD 152.0300 MHz
WHITEFISH 152.1800 MHz
GROUND 152.2700 MHz
KETCHEM 152.3300 MHz
TAKLADISP 152.3600 MHz
WFRASER1 152.3900 MHz
NTAKLA 152.4500 MHz
BOND 152.9750 MHz
LADD and Resource Road VHF radio system base stations can range from 50 watts to 300 watts and may be remotely operated via landline telephone or VoIP technology. Mobile radios with transmit power ranging from 25 watts to 110 watts are used, with 45 watt, 50 watt and 60 watt mobiles commonly found in trucks (for example, the Icom IC-2100, IC-2200H, IC-V8000, Kenwood 2 meter amateur radios, the Alinco DR-135 series, as well as open-band 136-174 MHz Chinese mobiles such as the TYT TH-9000D and similar radios). 1/4 wave NMO antennas are often used when space consideration and rugged heavy duty antennas are needed but 1/2 wave and 5/8 wave VHF antennas are also used for improved gain on the VHF frequencies. Portable radios are also used for flagmen, wide load safety and other purposes on these frequencies.
https://radiofreeq.wordpress.com/2018/08/30/canada-vhf-ladd-channel-list/
