Revision as of 13:40, 13 June 2023 by R4002 (Talk | contribs)
VHF low band VHF-low
  • 39.4600 MHz - LLAW1D - Simplex (156.7 Hz PL transmit tone only)
  • 39.4600MHz - LLAW1 - Repeater, paired with 45.8600 MHz (input) (156.7 Hz PL)
  • 39.4800 MHz - LFIRE2D - Simplex (156.7 Hz PL transmit tone only)
  • 39.4800 MHz - LFIRE2 - Repeater, paired with 45.8800 MHz (input) (156.7 Hz PL)
  • 45.8600 MHz - LLAW3D - Simplex (156.7 Hz PL transmit tone only)
  • 45.8600 MHz - LLAW3 - Repeater, paired with 39.4600 MHz (input) (156.7 Hz PL)
  • 45.8800 MHz - LFIRE4D - Simplex (156.7 Hz PL transmit tone only)
  • 45.8800 MHz - LFIRE4 - Repeater, paired with 39.4800 MHz (input) (156.7 Hz PL
VHF high band VHF band
  • 155.1600 MHz - VSAR16 or NATSAR - Search and Rescue - simplex CTCSS 127.3 Hz (CSQ receive recommended)
  • 155.3400 MHz - VMED28 - Ambulance to Hospital/Hospital to Hospital, medical interop - HEAR or HEAR340 (various CTCSS tones)
  • 154.2800 MHz - VFIRE21 - Fire Interop - Primary
UHF band
*UHF MED Channels - UHF EMS Channels *Original Channel Plan (25 kHz channels, 12.5 kHz bandwidth)
  • 462.9500 MHz - MED-9 - Calling/Dispatch, repeater paired with 467.9500 MHz
  • 462.9750 MHz - MED-10 - Calling/Dispatch, repeater paired with 467.9750 MHz
  • 463.0000 MHz - MED-1 - EMS Operations, repeater paired with 468.0000 MHz
  • 463.0250 MHz - MED-2 - EMS Operations, repeater paired with 468.0250 MHz
  • 463.0500 MHz - MED-3 - EMS Operations, repeater paired with 468.0500 MHz
  • 463.0750 MHz - MED-4 - EMS Operations, repeater paired with 468.0750 MHz
  • 463.1000 MHz - MED-5 - EMS Operations, repeater paired with 468.1000 MHz
  • 463.1250 MHz - MED-6 - EMS Operations, repeater paired with 468.1250 MHz
  • 463.1500 MHz - MED-7 - EMS Operations, repeater paired with 468.1500 MHz
  • 463.1750 MHz - MED-8 - EMS Operations, repeater paired with 468.1750 MHz
  • 462.9625 MHz - MED-92 - Calling/Dispatch, repeater paired with 467.9625 MHz
  • 462.9875 MHz - MED-102 - Calling/Dispatch, repeater paired with 467.9875 MHz
  • 463.0125 MHz - MED-12 - EMS Operations, repeater paired with 468.0125 MHz
  • 463.0375 MHz - MED-22 - EMS Operations, repeater paired with 468.0375 MHz
  • 463.0625 MHz - MED-32 - EMS Operations, repeater paired with 468.0625 MHz
  • 463.0875 MHz - MED-42 - EMS Operations, repeater paired with 468.0875 MHz
  • 463.1125 MHz - MED-52 - EMS Operations, repeater paired with 468.1125 MHz
  • 463.1375 MHz - MED-62 - EMS Operations, repeater paired with 468.1375 MHz
  • 463.1625 MHz - MED-72 - EMS Operations, repeater paired with 468.1625 MHz
  • 463.1875 MHz - MED-82 - EMS Operations, repeater paired with 468.1875 MHz
  • 462.95625 MHz - MED-91 - EMS Operations, repeater paired with 467.95625 MHz
  • 462.96875 MHz - MED-93 - EMS Operations, repeater paired with 467.96875 MHz
  • 462.98125 MHz - MED-101 - EMS Operations, repeater paired with 467.98125 MHz
  • 462.99375 MHz - MED-103 - EMS Operations, repeater paired with 467.99375 MHz
  • 463.00625 MHz - MED-11 - EMS Operations, repeater paired with 468.00625 MHz
  • 463.01875 MHz - MED-13 - EMS Operations, repeater paired with 468.01875 MHz
  • 463.03125 MHz - MED-21 - EMS Operations, repeater paired with 468.03125 MHz
  • 463.04375 MHz - MED-23 - EMS Operations, repeater paired with 468.04375 MHz
  • 463.05625 MHz - MED-31 - EMS Operations, repeater paired with 468.05625 MHz
  • 463.06875 MHz - MED-33 - EMS Operations, repeater paired with 468.06875 MHz
  • 463.08125 MHz - MED-41 - EMS Operations, repeater paired with 468.08125 MHz
  • 463.09375 MHz - MED-43 - EMS Operations, repeater paired with 468.09375 MHz
  • 463.10625 MHz - MED-51 - EMS Operations, repeater paired with 468.10625 MHz
  • 463.11875 MHz - MED-53 - EMS Operations, repeater paired with 468.11875 MHz
  • 463.13125 MHz - MED-61 - EMS Operations, repeater paired with 468.13125 MHz
  • 463.14375 MHz - MED-63 - EMS Operations, repeater paired with 468.14375 MHz
  • 463.15625 MHz - MED-71 - EMS Operations, repeater paired with 468.15625 MHz
  • 463.16875 MHz - MED-73 - EMS Operations, repeater paired with 468.16875 MHz
  • 463.18125 MHz - MED-81 - EMS Operations, repeater paired with 468.18125 MHz
  • 463.19375 MHz - MED-83 - EMS Operations, repeater paired with 468.19375 MHz
700 MHz band
  • 769.24375 MHz - 7CALL50/7CALL50D - Calling, simplex or repeater (input: 799.24375 MHz) TX 293 NAC, RX F7E NAC
  • 773.25625 MHz - 7CALL70/7CALL70D - Calling (secondary), simplex or repeater (input: 803.25625 MHz) TX 293 NAC, RX F7E NAC
  • 769.14375 MHz - 7TAC51/7TAC51D - General Use, simplex or repeater (input: 799.14375 MHz) TX 293 NAC, RX F7E NAC
  • 769.64375 MHz - 7TAC52/7TAC52D - General Use, simplex or repeater (input: 799.64375 MHz) TX 293 NAC, RX F7E NAC
  • 770.14375 MHz - 7TAC53/7TAC53D - General Use, simplex or repeater (input: 800.14375 MHz) TX 293 NAC, RX F7E NAC
  • 770.64375 MHz - 7TAC54/7TAC54D - General Use, simplex or repeater (input: 800.64375 MHz) TX 293 NAC, RX F7E NAC
  • 769.74375 MHz - 7TAC55/7TAC55D - General Use, simplex or repeater (input: 799.74375 MHz) TX 293 NAC, RX F7E NAC
  • 770.24375 MHz - 7TAC56/7TAC56D - General Use, simplex or repeater (input: 800.24375 MHz) TX 293 NAC, RX F7E NAC
  • 770.99375 MHz - 7TAC57/7TAC57D - General Use, simplex or repeater (input: 800.99375 MHz) TX 293 NAC, RX F7E NAC
  • 770.89375 MHz - 7MOB59/7MOB59D - Mobile Repeater, simplex or repeater (input: 800.89375 MHz) TX 293 NAC, RX F7E NAC
  • 770.39375 MHz - 7LAW61/7LAW61D - Law Enforcement, simplex or repeater (input: 800.39375 MHz) TX 293 NAC, RX F7E NAC
  • 770.49375 MHz - 7LAW62/7LAW62D - Law Enforcement, simplex or repeater (input: 800.49375 MHz) TX 293 NAC, RX F7E NAC
  • 769.89375 MHz - 7FIRE63/7FIRE63D - Fire, simplex or repeater (input: 799.89375 MHz) TX 293 NAC, RX F7E NAC
  • 769.99375 MHz - 7FIRE64/7FIRE64D - Fire, simplex or repeater (input: 799.99375 MHz) TX 293 NAC, RX F7E NAC
  • 769.39375 MHz - 7MED65/7MED65D - EMS, simplex or repeater (input: 799.39375 MHz) TX 293 NAC, RX F7E NAC
  • 769.49375 MHz - 7MED66/7MED66D - EMS, simplex or repeater (input: 799.49375 MHz) TX 293 NAC, RX F7E NAC
  • 770.74375 MHz - 7DATA69/7DATA69D - Data, simplex or repeater (input: 800.74375 MHz) TX 293 NAC, RX F7E NAC
  • 773.10625 MHz - 7TAC71/7TAC71D - General Use, simplex or repeater (input: 803.10625 MHz) TX 293 NAC, RX F7E NAC
  • 773.60625 MHz - 7TAC72/7TAC72D - General Use, simplex or repeater (input: 803.60625 MHz) TX 293 NAC, RX F7E NAC
  • 774.10625 MHz - 7TAC73/7TAC73D - General Use, simplex or repeater (input: 804.10625 MHz) TX 293 NAC, RX F7E NAC
  • 774.60625 MHz - 7TAC74/7TAC74D - General Use, simplex or repeater (input: 804.60625 MHz) TX 293 NAC, RX F7E NAC
  • 773.75625 MHz - 7TAC75/7TAC75D - General Use, simplex or repeater (input: 803.75625 MHz) TX 293 NAC, RX F7E NAC
  • 774.25625 MHz - 7TAC76/7TAC76D - General Use, simplex or repeater (input: 804.25625 MHz) TX 293 NAC, RX F7E NAC
  • 774.85625 MHz - 7TAC77/7TAC77D - General Use, simplex or repeater (input: 804.85625 MHz) TX 293 NAC, RX F7E NAC
  • 774.50625 MHz - 7MOB79/7MOB79D - Mobile Repeater, simplex or repeater (input: 804.50625 MHz) TX 293 NAC, RX F7E NAC
  • 774.00625 MHz - 7LAW81/7LAW81D - Law Enforcement, simplex or repeater (input: 804.00625 MHz) TX 293 NAC, RX F7E NAC
  • 774.35625 MHz - 7LAW82/7LAW82D - Law Enforcement, simplex or repeater (input: 804.35625 MHz) TX 293 NAC, RX F7E NAC
  • 773.50625 MHz - 7FIRE83/7FIRE83D - Fire, simplex or repeater (input: 803.50625 MHz) TX 293 NAC, RX F7E NAC
  • 773.85625 MHz - 7FIRE84/7FIRE84D - Fire, simplex or repeater (input: 803.85625 MHz) TX 293 NAC, RX F7E NAC
  • 773.00625 MHz - 7MED86/7MED86D - EMS, simplex or repeater (input: 803.00625 MHz) TX 293 NAC, RX F7E NAC
  • 773.35625 MHz - 7MED87/7MED87D - EMS, simplex or repeater (input: 803.35625 MHz) TX 293 NAC, RX F7E NAC
  • 774.75625 MHz - 7DATA89/7DATA89D - Data, simplex or repeater (input: 804.75625 MHz) TX 293 NAC, RX F7E NAC
  • 769.13125 MHz - 7AG58/7AG58D - Air-to-Ground, simplex or repeater (input: 799.13125 MHz) TX 293 NAC, RX F7E NAC
  • 769.63125 MHz - 7AG60/7AG60D - Air-to-Ground, simplex or repeater (input: 799.63125 MHz) TX 293 NAC, RX F7E NAC
  • 770.13125 MHz - 7AG67/7AG67D - Air-to-Ground, simplex or repeater (input: 800.13125 MHz) TX 293 NAC, RX F7E NAC
  • 770.63125 MHz - 7AG68/7AG68D - Air-to-Ground, simplex or repeater (input: 800.63125 MHz) TX 293 NAC, RX F7E NAC
  • 773.11875 MHz - 7AG78/7AG78D - Air-to-Ground, simplex or repeater (input: 803.11875 MHz) TX 293 NAC, RX F7E NAC
  • 773.61875 MHz - 7AG80/7AG80D - Air-to-Ground, simplex or repeater (input: 803.61875 MHz) TX 293 NAC, RX F7E NAC
  • 774.11875 MHz - 7AG85/7AG85D - Air-to-Ground, simplex or repeater (input: 804.11875 MHz) TX 293 NAC, RX F7E NAC
  • 774.61875 MHz - 7AG88/7AG88D - Air-to-Ground, simplex or repeater (input: 804.61875 MHz) TX 293 NAC, RX F7E NAC
800 MHz band
  • 851.0125 MHz - 8CALL90D/8CALL90 - Calling, simplex or repeater (input: 806.0125 MHz) both with 156.7 Hz CTCSS
  • 851.5125 MHz - 8TAC91D/8TAC91 - Tac 1, simplex or repeater (input: 806.5125 MHz) both with 156.7 Hz CTCSS
  • 852.0125 MHz - 8TAC92D/8TAC92 - Tac 2, simplex or repeater (input: 807.0125 MHz) both with 156.7 Hz CTCSS
  • 852.5125 MHz - 8TAC93D/8TAC93 - Tac 3, simplex or repeater (input: 807.5125 MHz) both with 156.7 Hz CTCSS
  • 853.0125 MHz - 8TAC94D/8TAC94 - Tac 4, simplex or repeater (input: 808.5125 MHz) both with 156.7 Hz CTCSS
  • 853.4875 MHz - old 800 MHz itinerant channel, may be used for simplex, tactical or talkaround purposes.
UHF band
  • Law Enforcement Plan
  • LE A Calling - 167.0875 MHz
  • LE B Calling - 414.0375 MHz
  • LE 01 Tactical - 162.0875 MHz
  • LE 02 Tactical - 162.2625 MHz
  • LE 03 Tactical - 162.8375 MHz
  • LE 04 Tactical - 163.2875 MHz
  • LE 05 Tactical - 163.4250 MHz
  • LE 06 Tactical - 167.2500 MHz
  • LE 07 Tactical - 167.7500 MHz
  • LE 08 Tactical - 168.1125 MHz
  • LE 09 Tactical - 168.4625 MHz
  • LE 10 Tactical - 418.9875 MHz
  • LE 11 Tactical - 419.1875 MHz
  • LE 12 Tactical - 419.6125 MHz
  • LE 13 Tactical - 414.0625 MHz
  • LE 14 Tactical - 414.3125 MHz
  • LE 15 Tactical - 414.3375 MHz
  • LE 16 Tactical - 409.9875 MHz
  • LE 17 Tactical - 410.1875 MHz
  • LE 18 Tactical - 410.6125 MHz
  • Incident Response Plan
  • NC 1 Calling - 164.7125 MHz
  • NC 2 Calling - 419.2375 MHz
  • IR 01 - 165.2500 MHz
  • IR 02 - 165.9625 MHz
  • IR 03 - 166.5750 MHz
  • IR 04 - 167.3250 MHz
  • IR 05 - 169.5375 MHz
  • IR 06 - 170.0125 MHz
  • IR 07 - 170.4125 MHz
  • IR 08 - 170.6875 MHz
  • IR 09 - 173.0375 MHz
  • IR 10 - 419.4375 MHz
  • IR 11 - 419.6375 MHz
  • IR 12 - 419.8375 MHz
  • IR 13 - 413.1875 MHz
  • IR 14 - 413.2125 MHz
  • IR 15 - 410.2375 MHz
  • IR 16 - 410.4375 MHz
  • IR 17 - 410.6375 MHz
  • IR 18 - 410.8375 MHz
  • 2182 kHz - USB voice - SAR operations - marine distress/calling
  • 3023 kHz - USB voice - SAR operations - marine, military
  • 4125 kHz - USB voice - SAR operations - marine distress/calling
  • 5680 kHz - USB voice - SAR operations
  • 6215 kHz - USB voice - SAR operations - marine distress/calling
  • 8291 kHz - USB voice - SAR operations - marine distress/calling
  • 8364 kHz - USB voice - SAR operations
  • 10003 kHz - USB voice - SAR operations
  • 12290 kHz - USB voice - SAR operations - marine distress/calling
  • 14993 kHz - USB voice - SAR operations
  • 16420 kHz - USB voice - SAR operations - marine distress/calling
  • 19993 kHz - USB voice - SAR operations
  • 40.5000 MHz - FM Guard - FM SINCGARS military emergency use only - Fox Guard or Fox Mike Guard 40.5 MHz
  • 121.5000 MHz - VHF Guard - VHF aircraft emergency use only - Victor Guard 121.5 MHz
  • 243.0000 MHz - UHF Guard - UHF aircraft emergency use only - Uniform Guard 243.0 MHz
  • 155.1600 MHz - SAR Ground Operations (127.3 Hz CTCSS transmit recommended, CSQ receive strongly recommended)
  • 155.3400 MHz - EMS/Medical Support
  • 123.1000 MHz - AM air-to-air (civilian)
  • 282.8000 MHz - AM air-to-air military SAR scene of action working channel
  • 345.0000 MHz - AM military USCG SAR calling
  • 156.8000 MHz - Marine hailing/calling DISTRESS ONLY (VHF marine channel 16)
  • 157.0500 MHz - Ground-to-marine assets SAR working channel (VHF marine channel 21A)
  • 157.0500 MHz - Marine operations, under authority of USCG Sector Commander (VHF marine channel 21A)
  • 157.1500 MHz - Marine operations, under authority of USCG Sector Commander (VHF marine channel 23A)
  • 157.1750 MHz - Ground-to-air SAR working channel (VHF marine channel 83A)
  • 122.8500 MHz - AM air rescue asset coordination
  • 122.9000 MHz - AM air rescue asset coordination
  • 123.0250 MHz - AM air rescue asset coordination
  • 123.0500 MHz - AM air rescue asset coordination
  • 123.0750 MHz - AM air rescue asset coordination - fixed-wing aircraft
  • 156.8500 MHz - SAR Command interop (VHF marine channel 17) - with USCG Sector Commander
  • 410.8375 MHz - IR 12 - SAR Command Federal/Non-Federal repeater (paired with 419.8375 MHz) - 167.9 Hz CTCSS
  • 159.4725 MHz - VTAC14 - SAR Command interop (VHF) - 156.7 Hz CTCSS
  • 453.8625 MHz - UTAC43D - SAR Command interop simplex (UHF) - 156.7 Hz CTCSS
  • 453.8625 MHz - UTAC43 - SAR Command interop repeater (paired with 458.8625 MHz) - 156.7 Hz CTCSS
  • 853.0125 MHz - 8TAC94D - SAR Command interop simplex - 156.7 Hz CTCSS
  • 853.0125 MHz - 8TAC94 - SAR Command interop repeater (paired with 808.0125 MHz) - 156.7 Hz CTCSS
The VHF aircraft band frequencies are in AM mode. The VHF and UHF land mobile frequencies are regular NFM mode. See remarks above regarding CTCSS tones. The A/G air/ground air to ground VHF FM frequencies are assigned on a local/regional basis. These frequencies may be used for other purposes outside their assigned GACC - Geographic Area Coordination Center. In addition to region-specific air-to-ground VHF FM frequencies, specific VHF-AM aircraft - "Victor" - frequencies are assigned to bases - 123.925 MHz, 123.975 MHz and several others are used.
  • 168.6250 MHz - Nationwide AIR GUARD - Must be included for emergency air-to-ground communications - 110.9 Hz CTCSS required
  • 168.6500 MHz - Nationwide Flight Following - National Flight Following frequency, interagency aircraft contact - 110.9 Hz CTCSS required
  • 170.9750 MHz - Command Repeater 1
  • 170.4500 MHz - Command Repeater 2
  • 170.4250 MHz - Command Repeater 3
  • 170.0000 MHz - Command Repeater 4
  • 169.7500 MHz - Command Repeater 5
  • 173.8125 MHz - Command Repeater 6
  • 168.7000 MHz - Command Simplex 1
  • 168.1000 MHz - Command Simplex 2
  • 168.0750 MHz - Command Simplex 3
  • 166.6750 MHz - Command Simplex 4
  • 167.1000 MHz - Command Simplex 5
  • 168.4750 MHz - Command Simplex 6
  • 166.6125 MHz - Air Tactics 1
  • 169.1500 MHz - Air Tactics 2
  • 169.2000 MHz - Air Tactics 3
  • 168.4000 MHz - Air Tactics 4
  • 167.9500 MHz - Air Tactics 5
  • 168.0500 MHz - Tactical 1
  • 168.2000 MHz - Tactical 2
  • 168.6000 MHz - Tactical 3
  • 166.7250 MHz - Tactical 4
  • 166.7750 MHz - Tactical 5
  • 168.2500 MHz - Tactical 6
  • 163.7125 MHz - Intra-Crew Base and Travel Net - Nationwide Mobilization - Handheld Portable Radios Only - NFM or P25 digital
  • 167.1375 MHz - Primary Intra-Crew Net at Incident Scene - Handheld Portable Radios Only - NFM or P25 digital
  • 168.6125 MHz - Secondary Intra-Crew Net at Incident Scene - Handheld Portable Radios Only - NFM or P25 digital
  • 173.6250 MHz - Tertiary Intra-Crew Net at Incident Scene - Handheld Portable Radios Only - NFM or P25 digital
  • 168.3500 MHz - Government Wide Tactical/Simplex
  • 163.1000 MHz - Government Wide Tactical/Simplex
  • 163.7125 MHz - Government Wide Tactical Simplex
  • 167.1375 MHz - Government Wide Tactical Simplex
  • 168.6125 MHz - Government Wide Tactical Simplex
  • 173.6250 MHz - Government Wide Tactical Simplex
  • 168.3500 MHz - Government Wide Tactical Repeater (163.1000 MHz input) - Portable Repeaters
  • 122.9250 MHz - Air A1 - Multicom - Natural Resources Aircraft
  • 122.9000 MHz - Air A2 - Multicom
  • 122.8500 MHz - Air A3 - Multicom
  • 122.7500 MHz - Air A4 - Fixed Wing Aircraft Air to Air
  • 123.0250 MHz - Air A5 - Helicopter Aircraft Air to Air
  • 406.4000 MHz - Logistics 1 (Repeater or simplex)
  • 406.5875 MHz - Logistics 2 (Repeater or simplex)
  • 407.7875 MHz - Logistics 3 (Repeater or simplex)
  • 410.2750 MHz - Logistics 4 (Repeater or simplex)
  • 410.7750 MHz - Logistics 5 (Repeater or simplex)
  • 408.6875 MHz - Logistics 6 (Repeater or simplex)
  • 408.5000 MHz - Logistics 7 (Repeater or simplex)
  • 411.4000 MHz - Logistics 8/ UHF Special Use 1 Simplex
  • 412.2250 MHz - Logistics 9/ UHF Special Use 2 Simplex
Short-Distance Low-Power Service
  • 27.575 MHz 27575 kHz
  • 27.585 MHz 27585 kHz
These frequencies are limited to 5 watt power output, 6 kHz bandwidth. A3E, A2A and A2D emissions are allowed.
  • 6K00A2A - Tone-modulated AM (modulated Morse code, MCW, tone modulated CW). Just like VOR and NDB IDs.
  • 6K00A2D - Data or digital transmission, one or two subcarriers - amplitude shift keying or audio-frequency shift keying over an AM voice radio circuit
  • 6K00A3E - AM voice (full carrier AM with both sidebands), regular AM radiotelephony
The 27.575 MHz and 27.585 MHz frequencies are allocated to provide U.S. Government short range voice radio communications, radio signaling, remote control of objects, devices, telemetry links, data links and other similar purposes. NTIA regulations specifically mention the use of FCC type-accepted Citizen's Band radio equipment - indicating that the federal government expects these frequencies to be used with modified 11 meter CB radio equipment or modified RCRS equipment.
Due to the large amount of freeband CB radio chatter on both 27.575 MHz and 27.585 MHz, these frequencies are rarely used.
NTIA calls these Wide-Area, Common-Use Frequencies. Of them, 163.100 MHz and 168.350 MHz are the most commonly used (both as a repeater pair and for simplex operations). These are effectively federal itinerant frequencies. See the local area common use frequencies below as well.
  • 163.1000 MHz - Simplex or repeater output
  • 168.3500 MHz - Simplex or repeater input
  • 409.0500 MHz - Simplex or repeater output (paired with 418.05 MHz if used for repeater operation)
  • 409.3375 MHz - Simplex or repeater output (paired with 418.3375 MHz if used for repeater operation)
  • 412.8250 MHz - Simplex
  • 412.8375 MHz - Simplex
  • 412.8500 MHz - Simplex
  • 412.8625 MHz - Simplex
  • 418.0500 MHz - Simplex or repeater input (if used as input, output is 409.050 MHz)
  • 418.3375 MHz - Simplex or repeater input (if used as input, output is 409.3375 MHz)
  • 163.7125 MHz - Simplex
  • 168.6125 MHz - Simplex
  • 173.6250 MHz - Repeater output (input: 167.1375 MHz)
  • 407.5250 MHz - Repeater output (input: 416.5250 MHz)
  • 409.0750 MHz - Repeater output (input: 418.0750 MHz)
  • 412.8750 MHz - Simplex
  • 412.8875 MHz - Simplex
  • 412.9000 MHz - Simplex
  • 412.9125 MHz - Simplex
Oil Spill Cleanup
