(Updated October 2018)
| 3465 kHz | AM - reported used in 2017 |
| 4020 kHz | AM/USB |
| 4025 kHz | AM/USB |
| 4060 kHz | AM/USB |
| 4065 kHz | AM/USB |
| 4080 kHz | AM/USB |
| 4085 kHz | AM/USB |
| 6770 kHz | AM - used by Old Time Radio |
| 6840 kHz | AM |
| 6850 kHz | usually AM |
| 6855 kHz | usually AM |
| 6870 kHz | AM/USB |
| 6885 kHz | AM/USB |
| 6886 kHz | AM/USB - used by Mix Radio International in October 2018 |
| 6890 kHz | AM/USB |
| 6915 kHz | AM/USB |
| 6920 kHz | AM/USB |
| 6930 kHz | AM/USB |
| 6935 kHz | AM/USB - Latin American pirates can also be heard here |
| 6945 kHz | AM/USB |
| 6950 kHz | AM/USB |
| 6955 kHz | AM/USB |
| 6965 kHz | AM/USB |
| 6969 kHz | LSB - Used by Cold Country Canada |
| 6970 kHz | AM |
| 6975 kHz | AM/USB - often used by XFM (also heard on 6970) |
| 7465 kHz | AM - noted use by YHWH religious pirate (September 2018) |
Euro-Pirate Radio Frequencies
- 3920-3950 (75 meters)
- 6250 - Used in the 1980s
