SINCGARS
Revision as of 13:25, 19 September 2019 by R4002 (Talk | contribs)
Two handheld VHF-FM tactical radios Datron HH7700 30-88 MHz (30.000 MHz to 87.975 MHz) in 25 kHz steps, with no frequency hopping capability, the radio below is a vehicle-mounted VHF-FM military tactical radio
Frequency Band
30.000 MHz to 30.550 MHz
32.000 MHz to 33.000 MHz
34.000 MHz to 35.000 MHz
36.000 MHz to 37.000 MHz
38.000 MHz to 39.000 MHz
40.000 MHz to 42.000 MHz
46.600 MHz to 47.000 MHz
49.600 MHz to 50.000 MHz
Commonly used frequencies include, but are certainly not limited to:
30.000 MHz, 30.100 MHz, 30.150 MHz, 30.300 MHz, 30.400 MHz, 30.450 MHz, 30.500 MHz, 32.000 MHz, 32.050 MHz, 32.150 MHz, 32.300 MHz, 32.500 MHz, 32.700 MHz, 34.200 MHz, 34.400 MHz, 34.900 MHz, 35.700 MHz, 36.100 MHz, 36.300 MHz, 36.500 MHz, 36.700 MHz, 38.450 MHz, 38.500 MHz, 38.550 MHz, 38.900 MHz, 39.000 MHz, 40.000 MHz, 40.400 MHz, 40.450 MHz, 40.500 MHz (emergency frequency), 40.550 MHz, 40.600 MHz, 40.700 MHz, 40.750 MHz, 40.900 MHz, 40.950 MHz, 41.800 MHz, 41.900 MHz, 44.000 MHz, 45.000 MHz, 45.700 MHz, 46.600 MHz, 46.650 MHz, 46.700 MHz, 46.750 MHz, 46.800 MHz, 46.850 MHz, 46.900 MHz, 47.000 MHz, 49.700 MHz, 49.750 MHz, 49.850 MHz, 49.900 MHz, 49.950 MHz, 55.550 MHz, 70.700 MHz and many many others.
Background and History
The SCR-300 and similar high-HF/low-VHF radios developed in WWII and the Korean War revolutionized small unit tactics. First the capability for a platoon or similar level unit to communicate with its headquarters or commanding elements and then the capability for each man in a squad for fireteam to communicate with each other in addition to the longer-range communications capability for platoon-to-commander and platoon-to-platoon communications using FM radio have changed the battlespace forever. The basic military backpack radio (and now handheld radio) concept has been copied endlessly, to the point where even militias and guerrilla forces use similar VHF/UHF radios for similar purposes. For example, see Ukraine militia forces using Baofengs (UV-5R, UV-82 and similar VHF/UHF handheld Chinese radios) and fighters in Afghanistan using Icom IC-V8s and other 2 meter / VHF handheld radios for battlefield tactical purposes, often in conjunction with 26-28 MHz CB type equipment or other similar radios/bands.
  • 26.000 MHz - 69.950 MHz (SEM-35 and similar clones/variants used in Europe and elsewhere)
  • 26.000 MHz - 71.950 MHz (PRC-25/PRC-77 variants used in dozens of different countries)
  • 28.000 MHz - 73.950 MHz (PRC-25/PRC-77 variants used in dozens of different countries)
  • 26.000 MHz - 70.000 MHz (Radio Set 3600 - Dutch origin, used in various countries)
  • 26.000 MHz - 70.000 MHz (TRC-552 - French origin, used in Africa, etc. as well)
  • 27.000 MHz - 38.900 MHz (RT-67 and similar clones, based off WWII/Korean era American equipment)
  • 38.000 MHz - 54.900 MHz (RT-68 and similar clones, based off WWII/Korean era American equipment)
  • 47.000 MHz - 59.000 MHz (RT-70 and similar clones, based off WWII/Korean era American equipment)
  • 47.000 MHz - 56.950 MHz (Radio Set 3610 - Dutch origin, used in various countries)
  • 30.000 MHz - 107.975 MHz (Radio Set SPIDER - Dutch origin, used in various countries)
  • 36.000 MHz - 75.975 MHz (Racal TRA-967 and various clones)
  • 37.000 MHz - 47.000 MHz (PRC-349 Clansman portable radio)
  • 36.000 MHz - 57.000 MHz (PRC-350 Clansman portable radio)
  • 30.000 MHz - 79.975 MHz (numerous Russian, Chinese and similar clones/copies)
  • 30.000 MHz - 79.975 MHz (SEM-70 and similar clones/variants used in Europe and elsewhere)
  • 30.000 MHz - 80.000 MHz (PRC-80, made in Israel, exported worldwide)
  • 47.000 MHz - 56.000 MHz (PRC-239 manpack radio, from Italy, exported to Middle East, etc.)
  • 40.000 MHz - 50.000 MHz (PRC-439 manpack radio, from Italy, exported to Middle East, etc.)
  • 30.000 MHz - 50.000 MHz (A-53 portable manpack radio from South Africa)
  • 26.000 MHz - 77.000 MHz (B-56 portable manpack radio/fixed radio from South Africa)
  • 30.000 MHz - 87.875 MHz (HH7700, PRC-7700 and numerous other handheld and manpack radios cover this band)
  • 29.700 MHz - 36.000 MHz (Various COTS VHF low band radios cover this band)
  • 36.000 MHz - 42.000 MHz (Various COTS VHF low band radios cover this band)
  • 42.000 MHz - 50.000 MHz (Various COTS VHF low band radios cover this band)
  • 29.000 MHz - 37.000 MHz (Various COTS VHF low band radios cover this band)
  • 37.000 MHz - 50.000 MHz (Various COTS VHF low band radios cover this band)
Easily acquired and widely available VHF (136-174 MHz), UHF (400-520 MHz or similar bands) and CB/11 meter (26-32 MHz, 25.615 MHz-30.105 MHz or similar bands) has introduced these bands as emerging threats in areas where asymmetric warfare, guerrilla warfare and insurgency tactics are used.
Evolution of military FM radio tactical radio bands: World War II, Korea and Beginning of Vietnam War (roughly 1940-1965)
20.000 MHz to 27.900 MHz Armor Band (tank radio, tank destroyers, tank command nets) 100 kHz (channels 200-279), PRC-8, PRC-8A, SCR-508, SCR-509, SCR-510, SCR-528, SCR-538, etc
27.000 MHz to 38.900 MHz Artillery Band 100 kHz (channels 270-389), PRC-9, PRC-9A, SCR-608, SCR-609, SCR-610, SCR-628
38.000 MHz to 54.900 MHz Infantry Band 100 kHz (channels 380-549), PRC-10, PRC-10A, BC-1000/SCR-300 (partial, 40-48 MHz only)
40.000 MHz to 48.000 MHz Infantry Band (partial) 200 kHz (channels 0-40), SCR-300 (BC-1000) manpack backpack radio
Most of Vietnam War and Cold War (roughly 1965-1980s)
1980s-present
30.000 MHz to 87.975 MHz Tactical Band (30-88 MHz) 150 Hz CTCSS (some radios allow use of other tones) 25 kHz step, single channel SC (fixed frequency) mode or frequency hopping FH (anti-jamming countermeasure) mode
380-430 MHz Intra-Squad Radio (ISR) and Improved Intra Squad Radio (IISR) systems Various frequency steps and modes used for short range communications within squads/fireteams
