SINCGARS
Revision as of 19:14, 20 September 2019 by R4002 (Talk | contribs)
Two handheld VHF-FM tactical radios Datron HH7700 30-88 MHz (30.000 MHz to 87.975 MHz) in 25 kHz steps, with no frequency hopping capability, the radio below is a vehicle-mounted VHF-FM military tactical radio
Frequency Band
30.000 MHz to 30.550 MHz
32.000 MHz to 33.000 MHz
34.000 MHz to 35.000 MHz
36.000 MHz to 37.000 MHz
38.000 MHz to 39.000 MHz
40.000 MHz to 42.000 MHz
46.600 MHz to 47.000 MHz
49.600 MHz to 50.000 MHz
It should be noted that military operations in single channel mode are found on any frequency between 30.000 and 87.975 MHz outside the government/military exclusive use bands on a non-interference basis. Use of the 150.0 Hz CTCSS or PL tone squelch allows for frequency sharing with other users. This, combined with the fact that civilian allocations in the 30-50 MHz band use 20 kHz channel steps, compared to the 25 kHz channeling used by military VHF-FM or SINCGARS systems. The 150 Hz tone squelch is close enough to the civilian 151.4 Hz CTCSS tone that many scanners or communications receivers will decode military VHF FM traffic as having 151.4 Hz CTCSS when in reality they are transmitting 150 Hz. Use of 150 Hz also permits the operation of "relay" (repeater) setups using two radios, the appropriate cables and filters and a high elevation location. Relay functionality has been included in FM tactical radios since the SCR-300 (BC-1000) series. It was not, however, heavily used until the Vietnam war. Most battlefield relay sites use RC-292 or similar high performance antennas. The wide frequency range of modern FM radios allows for maximum flexibility in choosing frequency pairs.
Commonly used frequencies include, but are certainly not limited to:
30.000 MHz, 30.100 MHz, 30.150 MHz, 30.300 MHz, 30.400 MHz, 30.450 MHz, 30.500 MHz, 32.000 MHz, 32.050 MHz, 32.100 MHz, 32.150 MHz, 32.250 MHz, 32.300 MHz, 32.500 MHz, 32.700 MHz, 34.200 MHz, 34.300 MHz, 34.400 MHz, 34.700 MHz, 34.850 MHz, 34.900 MHz, 35.700 MHz, 36.100 MHz, 36.300 MHz, 36.500 MHz, 36.700 MHz, 37.500 MHz, 37.700 MHz, 38.000 MHz, 38.350 MHz, 38.450 MHz, 38.500 MHz, 38.550 MHz, 38.800 MHz, 38.900 MHz, 39.000 MHz, 40.000 MHz, 40.200 MHz, 40.400 MHz, 40.450 MHz, 40.500 MHz, 40.550 MHz, 40.600 MHz, 40.700 MHz, 40.750 MHz, 40.900 MHz, 40.950 MHz, 41.800 MHz, 41.900 MHz, 44.000 MHz, 44.400 MHz, 44.600 MHz, 45.000 MHz, 45.450 MHz, 45.600 MHz, 45.700 MHz, 46.600 MHz, 46.650 MHz, 46.700 MHz, 46.750 MHz, 46.800 MHz, 46.850 MHz, 46.900 MHz, 46.950 MHz, 47.000 MHz, 49.700 MHz, 49.725 MHz, 49.750 MHz, 49.800 MHz, 49.825 MHz, 49.850 MHz, 49.875 MHz, 49.900 MHz, 49.925 MHz, 49.950 MHz, 49.975 MHz, 55.550 MHz, 70.700 MHz and many many others.
34.900 MHz is often used for convoy communications by National Guard units. 40.500 MHz is the FM emergency channel - akin to 121.500 MHz / 243.000 MHz (40.5 MHz * 3 = 121.5 MHz, 40.5 MHz * 6 = 243 MHz). However, 40.50 MHz is not nearly as heavily monitored as 121.5 MHz or 243.0 MHz.
Background and History
  • 26.000 MHz - 69.950 MHz SEM-35 and similar clones/variants used in Europe and elsewhere
  • 26.000 MHz - 71.950 MHz PRC-25/PRC-77 variants used in dozens of different countries
  • 28.000 MHz - 73.950 MHz PRC-25/PRC-77 variants used in dozens of different countries
  • 26.000 MHz - 70.000 MHz Radio Set 3600 - Dutch origin, used in various countries
  • 26.000 MHz - 70.000 MHz TRC-552 - French origin, used in Africa, etc. as well
  • 47.000 MHz - 56.000 MHz PRC-239 manpack radio, from Italy, exported to Middle East, etc.
  • 40.000 MHz - 50.000 MHz PRC-439 manpack radio, from Italy, exported to Middle East, etc.
Evolution of military FM radio tactical radio bands: World War II, Korea and Beginning of Vietnam War (roughly 1940-1965)
20.000 MHz to 27.900 MHz Armor Band (tank radio, tank destroyers, tank command nets) 100 kHz (channels 200-279), PRC-8, PRC-8A, SCR-508, SCR-509, SCR-510, SCR-528, SCR-538, etc
27.000 MHz to 38.900 MHz Artillery Band 100 kHz (channels 270-389), PRC-9, PRC-9A, SCR-608, SCR-609, SCR-610, SCR-628
38.000 MHz to 54.900 MHz Infantry Band 100 kHz (channels 380-549), PRC-10, PRC-10A, BC-1000/SCR-300 (partial, 40-48 MHz only)
40.000 MHz to 48.000 MHz Infantry Band (partial) 200 kHz (channels 0-40), SCR-300 (BC-1000) manpack backpack radio
Most of Vietnam War and Cold War (roughly 1965-1980s)
1980s-present
30.000 MHz to 87.975 MHz Tactical Band (30-88 MHz) 150 Hz CTCSS (some radios allow use of other tones) 25 kHz step, single channel SC (fixed frequency) mode or frequency hopping FH (anti-jamming countermeasure) mode
