VHF marine
VHF Marine Band, marine radio, VHF radio, or even "VHF marine CB" to some people. Worldwide allocation 156-162 MHz. Several country-specific variations. In some parts of the USA, parts of the marine band is allocated to other services (either on a primary or secondary basis). Mixture of simplex and half-duplex (split-channel) allocations. Some channels used as repeaters in certain countries (Australia, New Zealand), as links to landline telephone system (defunct now) or crossband to other marine allocations such as 27 MHz or HF marine.
Land mobile users of these frequencies are still licensed as Radio Service Code PC - Public Coast Stations, Auctioned. A licensed user will acquire a block of frequencies as well as a market area. This practice is common in areas where the VHF high band is used for wide-area trunking systems, often for public safety or law enforcement purposes. The 160.2 MHz to 161.64 MHz portion is allocated for use by railroad systems in the United States and Canada (NFM voice and NXDN digital voice/data).
| Channel | Frequency | Purpose/Use (USA) |
| 00 | 156.000 MHz | Not allocated for marine use in the United States |
| 01 | 156.050 MHz | VTS/Port Ops/Commercial, New Orleans/Lower Mississippi River area only |
| 02 | 156.100 MHz | Not allocated for marine use in the United States |
| 03 | 156.150 MHz | Not allocated for marine use in the United States |
| 04 | 156.200 MHz | Not allocated for marine use in the United States |
| 05 | 156.250 MHz | VTS/Port Ops/Commercial, Houston, Seattle, and New Orleans/Lower Mississippi River areas only |
| 06 | 156.300 MHz | Intership Safety |
| 07 | 156.350 MHz | Commercial |
| 08 | 156.400 MHz | Commercial (Intership only) |
| 09 | 156.450 MHz | Boater Calling (Commercial/Non-Commercial) |
| 10 | 156.500 MHz | Commercial |
| 11 | 156.550 MHz | Commercial, VTS in certain areas |
| 12 | 156.600 MHz | Port Ops, VTS in certain areas |
| 13 | 156.650 MHz | Bridge-to-bridge/Intership Navigation Safety |
| 14 | 156.700 MHz | Port Ops, VTS in certain areas |
| 15 | 156.750 MHz | Environmental (Receive Only), US Government Use, Class C EPIRBs |
| 16 | 156.800 MHz | International Distress, Safety and Calling. USCG, coast stations, and ships maintain watch on this channel |
| 17 | 156.850 MHz | State and/or Local Government Maritime Control |
| 18 | 156.900 MHz | Commercial |
| 19 | 156.950 MHz | Commercial |
| 20 | 157.000 MHz | Port Ops |
| 21 | 157.050 MHz | US Coast Guard Only |
| 22 | 157.100 MHz | US Coast Guard Liaison and Safety Information Broadcasts |
| 23 | 157.150 MHz | US Coast Guard Only |
| 24 | 157.200 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 25 | 157.250 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 26 | 157.300 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 27 | 157.350 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 28 | 157.400 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 29 | 157.450 MHz | Not allocated for marine use in the United States |
| 60 | 156.025 MHz | Not allocated for marine use in the United States |
| 61 | 156.075 MHz | Not allocated for marine use in the United States |
| 62 | 156.125 MHz | Not allocated for marine use in the United States |
| 63 | 156.175 MHz | VTS/Port Ops/Commercial, New Orleans/Lower Mississippi River area only |
| 64 | 156.225 MHz | Not allocated for marine use in the United States |
| 65 | 156.275 MHz | Port Ops |
| 66 | 156.325 MHz | Port Ops |
| 67 | 156.375 MHz | Commercial (Intership Only) |
| 68 | 156.425 MHz | Non-Commercial, Recreational Boaters |
| 69 | 156.475 MHz | Non-Commercial, Recreational Boaters |
| 70 | 156.525 MHz | DSC (No voice transmissions permitted) |
| 71 | 156.575 MHz | Non-Commercial, Recreational Boaters |
| 72 | 156.625 MHz | Non-Commercial (Intership Only), Recreational Boaters |
| 73 | 156.675 MHz | Port Ops |
| 74 | 156.725 MHz | Port Ops |
| 75 | 156.775 MHz | Guard Band For Channel 16 156.8 MHz - Not allocated for use in USA |
| 76 | 156.825 MHz | Guard Band For Channel 16 156.8 MHz - Not allocated for use in USA |
| 77 | 156.875 MHz | Port Ops (Intership Only) |
| 78 | 156.925 MHz | Non-Commercial, Recreational Boaters |
| 79 | 156.975 MHz | Commercial. Non-Commercial in Great Lakes only. |
| 80 | 157.025 MHz | Commercial. Non-Commercial in Great Lakes only. |
| 81 | 157.075 MHz | US Coast Guard/US Government Only/Environmental Protection |
| 82 | 157.125 MHz | US Coast Guard Only |
| 83 | 157.175 MHz | US Coast Guard Only |
| 84 | 157.225 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 85 | 157.275 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 86 | 157.325 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 87 | 157.375 MHz | VHF Digital Small Message Services (VDSMS), Analog Voice Also Permitted |
| 88 | 157.425 MHz | Commercial/Non-Commercial (Intership Only), Recreational Boaters |
| AIS 1 87B | 161.975 MHz | Automatic Identification System (AIS Channel 1/Channel 87B) |
| AIS 2 88B | 162.025 MHz | Automatic Identification System (AIS Channel 2/Channel 88B) |
| AIS 3 75 / 75A / 1075 | 156.775 MHz | Automatic Identification System (AIS Channel 3/Channel 75) |
| AIS 4 76 / 76A / 1076 | 156.825 MHz | Automatic Identification System (AIS Channel 4/Channel 76) |
| WX 1 | 162.400 MHz | NOAA Weather Radio (Receive Only) |
| WX 2 | 162.425 MHz | NOAA Weather Radio (Receive Only) |
| WX 3 | 162.450 MHz | NOAA Weather Radio (Receive Only) |
| WX 4 | 162.475 MHz | NOAA Weather Radio (Receive Only) |
| WX 5 | 162.500 MHz | NOAA Weather Radio (Receive Only) |
| WX 6 | 162.525 MHz | NOAA Weather Radio (Receive Only) |
| WX 7 | 162.550 MHz | NOAA Weather Radio (Receive Only) |
| Channel | Frequency | Purpose/Use |
| 00 | 156.000 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 29 | 157.450 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 30 | 157.500 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 31 | 157.550 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 32 | 157.600 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 33 | 157.650 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 34 | 157.700 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 35 | 157.750 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 36 | 157.800 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 37 | 157.850 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 38A | 157.900 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 38B | 162.500 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 39 | 157.950 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 40 | 158.000 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 41 | 158.050 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 42 | 158.100 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 43 | 158.150 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 44 | 158.200 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 45 | 158.250 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 46 | 158.300 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 47 | 158.350 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 48 | 158.400 MHz | Private Ship to Ship/Ship to Shore Simplex |
| 49 | 158.450 MHz | Private Ship to Ship/Ship to Shore Simplex |
| M1 (UK) or M | 157.850 MHz | Private Marina Channel (private marinas, yacht clubs, etc), UK only - channel 37 |
| M2 (UK) | 161.425 MHz | Private Marina Channel (private marinas, yacht clubs, etc), UK only |
| M3 (UK) | 161.225 MHz | Private Marina Channel (private marinas, yacht clubs, etc), UK only |
| P1 (UK) | 161.350 MHz | On board ship comms only (low power) |
| P2 (UK) | 161.450 MHz | On board ship comms only (low power) |
| P1 (Nordic) | 155.500 MHz | Private Marina/Yacht club channel, Nordic countries only |
| P2 (Nordic) | 155.525 MHz | Private Marina/Yacht club channel, Nordic countries only |
| P3 (Nordic) | 155.650 MHz | Private Marina/Yacht club channel, Nordic countries only |
| P4 (Nordic) | 155.625 MHz | Private Fishing Trawler channel, Nordic countries only |
| P5 (Nordic) | 155.775 MHz | Private Fishing Trawler channel, Nordic countries only |
| P6 (Nordic) | 155.825 MHz | Private Fishing Trawler channel, Nordic countries only |
| P1 (Denmark) | 155.375 MHz | Private Channel, Denmark only |
| P2 (Denmark) | 155.575 MHz | Private Channel, Denmark only |
| P3 (Denmark) | 155.450 MHz | Private Channel, Denmark only |
| P4 (Denmark) | 155.800 MHz | Private Channel, Denmark only |
10 MHz offset (international plan) 10.225 MHz offset (US and Canada channel plan). Input frequencies may be used for simplex purposes as well. International channel plan frequencies interfere with US-allocated GMRS and FRS frequencies. Frequencies are shared with UHF business band in the United States. Elsewhere, other UHF on-board radio systems may be used, including PMR446 or other dedicated systems generally in the 400-512 MHz UHF range.
| Channel | Frequency (repeater output or simplex) | Frequency (repeater input or simplex) |
| 1 (International) | 457.5250 MHz | 467.5250 MHz |
| 2 (International) | 457.5375 MHz | 467.5375 MHz |
| 3 (International) | 457.5500 MHz | 467.5500 MHz |
| 4 (International) | 457.5625 MHz | 467.5625 MHz |
| 5 (International) | 457.5750 MHz | 467.5750 MHz |
| 1 (USA, Canada) | 457.5250 MHz | 467.7500 MHz |
| 2 (USA, Canada) | 457.5375 MHz | 467.7625 MHz |
| 3 (USA, Canada) | 457.5500 MHz | 467.7750 MHz |
| 4 (USA, Canada) | 457.5625 MHz | 467.7875 MHz |
| 5 (USA, Canada) | 457.5750 MHz | 467.8000 MHz |
| 6 (USA, Canada) | 457.5875 MHz | 467.8125 MHz |
| 7 (USA, Canada) | 457.6000 MHz | 467.8250 MHz |
| 8 (USA, Canada) | 457.6125 MHz | 467.8375 MHz |
VHF marine band equipment
