FM
Frequency Modulation
FM, no static at all...no static at all.
It is rarely used on HF frequencies, with the exception of 27 MHz 11 meter CB operators in many countries - often in conjunction with AM and SSB, amateur radio operators using the FM in the 10 meter band, land mobile radio users operating on a small number of channelized frequencies in the 25 to 30 MHz range and some specialized maritime mobile (marine radio) systems used by fishing fleets, fishery radio networks, etc.
FM mode is also known by its emission designation F3 or F3E.
