Letter beacon
Letter Beacon D on 5153.7 kHz
  • Cluster beacons
Location of letter beacons
ID letter Location
C Moscow, RUS
D Odessa, UKR
O Moscow, RUS
P Kaliningrad, RUS
S Arkhangelsk, RUS
Z Mukachevo, UKR
ID letter Location
A Astrakhan, RUS (tentative)
C Moscow, RUS
D Sevastopol, UKR
F Vladivostok, RUS
M Magadan, RUS
P Kaliningrad, RUS
S Severomorsk, RUS
ID letter Location
L Tirana, ALB (defunct)
R Izhevsk (Ustinov), RUS
P Kaliningrad, RUS
V Khiva, UZB
Types of letter beacons
Cluster beacons
F +0.2 7039.2, 10872.2, 16332.2
A few solitary beacons, like "R" on 4325.9 and 5465.9 kHz, operate exactly like the cluster beacons, sending only their single letter identifier. (20)
R (20) 4325.9, 5465.9
C RIW 8000
L inactive
W inactive
FSK beacons
K 9043
U
ENIGMA designation
ENIGMA ID Description
MX Cluster beacons
Similar systems
On September 7, 2010 a beacon was heard on 9111.7 kHz at 1546 UTC. It sent a slow marker "A", which did not sound like a Russian beacon (MX). It sounded like somebody was playing with the key sending letters "A" and "M". Transmission lasted untill at least 1630 UTC. (19)
Notes & References
  4. Spooks mailing list.
  10. William I. Orr, W6SAI: "TThe Cluster Beacons Revisited; An Inside Look at Nine Puzzling Channels", Popular Communications, CQ Communications, Inc, ISSN 0733-3315, February 1985, pages 38-40.
WP
