Pirate shortwave broadcasts tend to be on well-known frequencies. This allows listeners to quickly find a pirate station when it comes on the air, as they only have a relatively few number of fixed places to look. Some of the locations on the HF band that are in frequent use as of September 2007 include:
(Updated August 2018)
| 1710 | AM - Mediumwave pirates |
| 1720 | AM - Mediumwave pirates - known as the "AM pirate clear channel" |
| 3375 | AM/USB - used by Amphetamine Radio |
| 3425 | AM - used by The Crystal Ship (also reported on 3430) |
| 3465 | AM - reported used in 2017 |
| 4020 | AM/USB |
| 4025 | AM/USB |
| 4060 | AM/USB |
| 4065 | AM/USB |
| 4080 | AM/USB |
| 4085 | AM/USB |
| 5010 | AM - used by Relay Station |
| 5015 | AM - used by Relay Station |
| 5150 | AM - used by Relay Station |
| 5200 | AM - used by Relay Station |
| 6150 | AM - used by European Pirates |
| 6220 | Used by Mystery Radio in Europe |
| 6750 | AM/SSB - reported in use August 2017 |
| 6770 | AM - used by Old Time Radio and UNID stations |
| 6780 | AM |
| 6790 | AM/USB |
| 6850 | usually AM |
| 6855 | usually AM |
| 6870 | AM/USB |
| 6875 | usually AM - noted use by The Crystal Ship (often 6876 kHz or similar close frequencies) |
| 6880 | usually AM - used by Relay Station (noted use in late 2018) |
| 6888 | usually AM - noted use by Unknown Name Radio Network |
| 6900 | usually AM, although 6900 LSB and 6900 USB are both heavily used by Spanish-speaking "peskies" |
| 6905 | AM - noted use by Unknown Name Radio Network, another commonly use pescadore frequency in LSB mode |
| 6910 | AM/USB - Used by Seven Trees Radio and Clever Name Radio - this is a FEMA and US government/military frequency... |
| 6915 | AM/USB |
| 6920 | AM/USB |
| 6923 | AM/USB, previously used by Amphetamine Radio |
| 6925 | most common frequency - virtually all modes have been heard |
| 6930 | AM/USB |
| 6935 | AM/USB |
| 6940 | AM/USB - noted use by Clever Name Radio |
| 6945 | AM/USB |
| 6950 | AM/USB |
| 6955 | AM/USB |
| 6960 | AM/USB |
| 6969 | LSB - Used by Cold Country Canada |
| 6970 | AM - often used by XFM (also heard on 6975) |
| 6975 | AM - often used by XFM (also heard on 6970) |
| 6995 | AM/SSB - recently (July 2017) used by KUNT |
| 7415 | historically, an extremely active frequency, more recently occupied by WBCQ |
| 7470 | AM - noted use by YHWH religious pirate |
| 15070 | active in the early 1990's by Europirates and pirates in North America, but recently quiet due to the solar cycle low |
6925 kHz is the most used frequency at this time; however, it's important to note that the list will change. Broadcasters will experiment with new frequencies according to the season, and the appearance of utility, military, and broadcast stations on a favorite spot may also force stations to move to new locations.  During periods of minimum solar activity, there has been some movement down to the 3-5 MHz region.
The 43 meter band (6765-7000 kHz) is where most US-based pirates are found, generally clustered around 6925 kHz. Because many pirates use older-generation transmitters, it is not uncommon to find stations on "6925" actually using 6924 kHz to 6926 kHz. AM transmissions operating in the 6925.5 kHz to 6925.9 kHz area are often logged Pirates tend to use 5 kHz steps up to 6975 kHz. However, use "split" or "offset" frequencies is also common, examples include 6912.5 kHz, 6969 kHz, 6929.5 kHz, etc. Offset frequencies (for example, 6876 kHz instead of 6875 kHz can sometimes be due to quirks of transmitting equipment).
The 43 meter band is also heavily used by so-called "peskies" (a play on the Spanish term "pescadores - meaning "fishermen"), stations engaging in two-way radio chatter in Portuguese, Spanish and other languages (including English).  Peskies generally use LSB mode.  6925 kHz LSB is one of the most active peskie frequencies, which can cause serious interference issues for pirates operating in AM mode on 6925 kHz or adjacent frequencies.  The area around 6900 kHz (including 6895 kHz and 6905 kHz) are also heavily used by Spanish-speaking stations in both USB and LSB modes.  Unknown Name Radio Network has recently started using 6900 despite heavy QRM from SSB traffic on or near 6900 kHz.  Other pirates deliberately interfere with pescadore/freebander communications.
Euro-Pirate Radio Frequencies
- 3920-3950
 - 6200-6300
 - 6250 - Used in the 1980s
