Revision as of 16:28, 21 September 2018 by R4002 (Talk | contribs)
Pirate shortwave broadcasts tend to be on well-known frequencies. This allows listeners to quickly find a pirate station when it comes on the air, as they only have a relatively few number of fixed places to look. Some of the locations on the HF band that are in frequent use as of September 2007 include:
(Updated September 2018)
3465 kHz AM - reported used in 2017
4020 kHz AM/USB
4025 kHz AM/USB
4060 kHz AM/USB
4065 kHz AM/USB
4080 kHz AM/USB
4085 kHz AM/USB
6220 kHz Used by Mystery Radio in Europe
6770 kHz AM - used by Old Time Radio
6780 kHz AM/USB - including nearby frequencies 6777 kHz, 6777.7 kHz and 6778 kHz
6840 kHz AM
6850 kHz usually AM
6855 kHz usually AM
6870 kHz AM/USB
6915 kHz AM/USB
6920 kHz AM/USB
6925 kHz most common frequency - virtually all modes have been heard +/- 1-2 kHz
6930 kHz AM/USB
6935 kHz AM/USB - Latin American pirates can also be heard here
6945 kHz AM/USB
6950 kHz AM/USB
6955 kHz AM/USB
6960 kHz AM/USB
6965 kHz AM/USB
6969 kHz LSB - Used by Cold Country Canada
6970 kHz AM
6975 kHz AM/USB - often used by XFM (also heard on 6970)
The 43 meter band (6765-7000 kHz) is where most US-based pirates are found, generally clustered around 6925 kHz. Because many pirates use older-generation transmitters, it is not uncommon to find stations on "6925" actually using 6924 kHz to 6926 kHz. AM transmissions operating in the 6924.5 kHz to 6925.9 kHz area are often logged.
Euro-Pirate Radio Frequencies
  • 3920-3950
  • 6200-6300
  • 6250 - Used in the 1980s
