High HF and VHF/UHF Land mobile radio service authorized under Part 90 (Land Mobile Radio Services) of the FCC rules. FCC eligibility verbiage states: Persons primarily engaged in any of the following activities are eligible to hold authorizations in the Industrial/Business Pool to provide commercial mobile radio service as defined in part 20 of this chapter or to operate stations for transmission of communications necessary to such activities of the licensee: (1) The operation commercial of business activity; (2) The operation of educational, philanthropic, or ecclesiastical institutions; (3) Clergy activities; or (4) The operation of hospitals, clinics, or medical associations. The FCC has allocated a massive amount of frequencies for the Business/Industrial Radio Service (commonly referred to as "Business Radio" or "Business Radio Service"). The FCC allows use of frequencies in the 2000 to 25000 kHz (2-25 MHz) band for business purposes, only if frequencies above 25 MHz will not satisfy the requirements of the user, in other words, in special cases only.
25.020 MHz | Oil companies, oil spill cleanup operations |
25.040 MHz | Oil companies, oil spill cleanup operations |
25.060 MHz | Oil companies, oil spill cleanup operations |
25.080 MHz | Oil companies, oil spill cleanup operations |
25.100 MHz | Oil companies, oil spill cleanup operations |
25.120 MHz | Oil companies, oil spill cleanup operations |
25.140 MHz | Oil companies, oil spill cleanup operations |
25.160 MHz | Oil companies, oil spill cleanup operations |
25.180 MHz | Oil companies, oil spill cleanup operations |
25.200 MHz | Oil companies, oil spill cleanup operations |
25.220 MHz | Oil companies, oil spill cleanup operations |
25.240 MHz | Oil companies, oil spill cleanup operations |
25.260 MHz | Oil companies, oil spill cleanup operations |
25.280 MHz | Oil companies, oil spill cleanup operations |
25.300 MHz | Oil companies, oil spill cleanup operations |
25.320 MHz | Oil companies, oil spill cleanup operations |
27.430 MHz | suffers from freeband CB QRM |
27.450 MHz | suffers from freeband CB QRM |
27.470 MHz | suffers from freeband CB QRM |
27.490 MHz | Itinerant use only - suffers from freeband CB QRM |
27.510 MHz | Mobile use only, 2 watts maximum power, suffers from freeband CB QRM |
27.530 MHz | Mobile use only, 2 watts maximum power, suffers from freeband CB QRM |
29.710 MHz | |
29.730 MHz | |
29.750 MHz | |
29.770 MHz | |
29.790 MHz | |
29.710 MHz | |
29.730 MHz | |
30.580 MHz | |
30.600 MHz | |
30.620 MHz | |
30.660 MHz | Geophysical stations only, secondary allocation |
30.680 MHz | |
30.700 MHz | Geophysical stations only, secondary allocation |
30.720 MHz | |
30.740 MHz | Geophysical stations only, secondary allocation |
30.760 MHz | |
30.780 MHz | Geophysical stations only, secondary allocation |
30.800 MHz | |
30.820 MHz | Geophysical stations only, secondary allocation |
30.880 MHz | |
30.920 MHz | |
30.960 MHz | |
31.000 MHz | |
31.040 MHz | |
31.080 MHz | |
31.120 MHz | |
31.160 MHz | |
31.200 MHz | |
31.240 MHz | |
31.280 MHz | |
31.320 MHz | |
31.360 MHz | |
31.400 MHz | |
31.440 MHz | |
31.480 MHz | |
31.520 MHz | |
31.560 MHz | |
31.600 MHz | |
31.640 MHz | |
31.680 MHz | |
31.720 MHz | |
31.760 MHz | |
31.800 MHz | |
31.840 MHz | |
31.880 MHz | |
31.920 MHz | |
31.960 MHz | |
33.160 MHz | |
33.180 MHz | |
33.200 MHz | |
33.220 MHz | |
33.240 MHz | |
33.260 MHz | |
33.280 MHz | |
33.300 MHz | |
33.320 MHz | |
33.340 MHz | |
33.360 MHz | |
33.380 MHz | |
35.060 MHz | |
35.080 MHz | |
35.100 MHz | |
35.120 MHz | |
35.160 MHz | |
35.180 MHz | |
35.280 MHz | |
35.320 MHz | |
35.360 MHz | |
35.400 MHz | |
35.440 MHz | |
35.480 MHz | |
35.520 MHz | |
35.700 MHz | |
35.720 MHz | |
35.740 MHz | |
35.760 MHz | |
35.780 MHz | |
35.820 MHz | |
35.840 MHz | |
35.860 MHz | |
35.880 MHz | |
35.900 MHz | |
35.920 MHz | |
35.940 MHz | |
35.960 MHz | |
35.980 MHz | |
36.250 MHz | Oil companies, oil spill cleanup operations, shared with federal/military use, often paired with 41.71 MHz |
37.440 MHz | |
37.460 MHz | |
37.480 MHz | |
37.500 MHz | |
37.520 MHz | |
37.520 MHz | |
37.560 MHz | |
37.580 MHz | |
37.620 MHz | |
37.640 MHz | |
37.660 MHz | |
37.680 MHz | |
37.700 MHz | |
37.720 MHz | |
37.760 MHz | |
37.780 MHz | |
37.800 MHz | |
37.820 MHz | |
37.840 MHz | |
37.860 MHz | |
37.880 MHz | |
41.710 MHz | Oil companies, oil spill cleanup operations, shared with federal/military use, often paired with 36.25 MHz |
42.960 MHz | |
43.000 MHz | |
43.020 MHz | |
43.060 MHz | |
43.080 MHz | |
43.100 MHz | |
43.120 MHz | |
43.140 MHz | |
43.180 MHz | |
43.280 MHz | |
43.320 MHz | |
43.360 MHz | |
43.400 MHz | |
43.440 MHz | |
43.480 MHz | |
43.520 MHz | |
43.700 MHz | |
43.760 MHz | |
43.780 MHz | |
43.860 MHz | |
43.880 MHz | |
43.900 MHz | |
43.940 MHz | |
44.000 MHz | |
44.020 MHz | |
44.040 MHz | |
44.060 MHz | |
44.080 MHz | |
44.100 MHz | |
44.140 MHz | |
44.220 MHz | |
44.240 MHz | |
44.260 MHz | |
44.280 MHz | |
44.300 MHz | |
44.340 MHz | |
44.380 MHz | |
44.420 MHz | nationwide Red Cross disaster response |
44.440 MHz | |
44.500 MHz | |
44.520 MHz | |
44.540 MHz | |
44.560 MHz | |
44.600 MHz | |
47.440 MHz | |
47.480 MHz | |
47.520 MHz | |
47.560 MHz | |
47.600 MHz | |
47.640 MHz | |
47.680 MHz | |
47.700 MHz | |
47.720 MHz | |
47.740 MHz | |
47.760 MHz | |
47.780 MHz | |
47.800 MHz | |
47.820 MHz | |
47.840 MHz | |
47.860 MHz | |
47.880 MHz | |
47.900 MHz | |
47.920 MHz | |
47.940 MHz | |
47.960 MHz | |
47.980 MHz | |
48.000 MHz | |
48.020 MHz | |
48.040 MHz | |
48.060 MHz | |
48.080 MHz | |
48.100 MHz | |
48.120 MHz | |
48.140 MHz | |
48.160 MHz | |
48.180 MHz | |
48.200 MHz | |
48.220 MHz | |
48.240 MHz | |
48.260 MHz | |
48.280 MHz | |
48.300 MHz | |
48.320 MHz | |
48.340 MHz | |
48.360 MHz | |
48.380 MHz | |
48.400 MHz | |
48.420 MHz | |
48.440 MHz | |
48.480 MHz | |
48.500 MHz | |
48.520 MHz | |
48.540 MHz | |
48.560 MHz | |
48.580 MHz | |
48.600 MHz | |
48.620 MHz | |
48.640 MHz | |
48.660 MHz | |
48.680 MHz | |
48.700 MHz | |
48.720 MHz | |
48.740 MHz | |
48.760 MHz | |
48.780 MHz | |
48.800 MHz | |
48.820 MHz | |
48.840 MHz | |
48.860 MHz | |
48.880 MHz | |
48.900 MHz | |
48.920 MHz | |
48.940 MHz | |
48.960 MHz | |
48.980 MHz | |
49.000 MHz | |
49.020 MHz | |
49.040 MHz | |
49.060 MHz | |
49.080 MHz | |
49.100 MHz | |
49.120 MHz | |
49.140 MHz | |
49.160 MHz | |
49.180 MHz | |
49.200 MHz | |
49.220 MHz | |
49.240 MHz | |
49.260 MHz | |
49.280 MHz | |
49.300 MHz | |
49.320 MHz | |
49.340 MHz | |
49.360 MHz | |
49.380 MHz | |
49.400 MHz | |
49.420 MHz | |
49.440 MHz | |
49.480 MHz | |
49.500 MHz | |
49.520 MHz | |
49.540 MHz | |
49.560 MHz | |
49.580 MHz |
Frequency (MHz) |
72.020 MHz |
72.040 MHz |
72.060 MHz |
72.080 MHz |
72.100 MHz |
72.120 MHz |
72.140 MHz |
72.160 MHz |
72.180 MHz |
72.200 MHz |
72.220 MHz |
72.240 MHz |
72.260 MHz |
72.280 MHz |
72.300 MHz |
72.320 MHz |
72.340 MHz |
72.360 MHz |
72.380 MHz |
72.400 MHz |
72.420 MHz |
72.440 MHz |
72.460 MHz |
72.480 MHz |
72.500 MHz |
72.520 MHz |
72.540 MHz |
72.560 MHz |
72.580 MHz |
72.600 MHz |
72.620 MHz |
72.640 MHz |
72.660 MHz |
72.680 MHz |
72.700 MHz |
72.720 MHz |
72.740 MHz |
72.760 MHz |
72.780 MHz |
72.800 MHz |
72.820 MHz |
72.840 MHz |
72.860 MHz |
72.880 MHz |
72.900 MHz |
72.920 MHz |
72.940 MHz |
72.960 MHz |
72.980 MHz |
75.420 MHz |
75.460 MHz |
75.500 MHz |
75.540 MHz |
75.580 MHz |
75.620 MHz |
75.640 MHz |
75.660 MHz |
75.680 MHz |
75.700 MHz |
75.720 MHz |
75.740 MHz |
75.760 MHz |
75.780 MHz |
75.800 MHz |
75.820 MHz |
75.840 MHz |
75.860 MHz |
75.880 MHz |
75.900 MHz |
75.920 MHz |
75.940 MHz |
75.960 MHz |
75.980 MHz |
150.815-150.9875 MHz | 7.5 kHz steps |
152.2625-152.465 MHz | 7.5 kHz steps, old Taxicab Radio Service base/repeater output frequencies |
154.45625 MHz | Operational fixed (SCADA, data links, etc) only |
154.46375 MHz | Operational fixed (SCADA, data links, etc) only |
154.47125 MHz | Operational fixed (SCADA, data links, etc) only |
154.47875 MHz | Operational fixed (SCADA, data links, etc) only |
154.4825-154.4975 MHz | 7.5 kHz steps |
154.505 MHz | |
154.515 MHz | |
154.5275 MHz | Mobiles only |
154.540-154.555 MHz | 7.5 kHz steps |
154.585 MHz | |
154.610 MHz | |
154.625 MHz | |
154.640 MHz | |
157.470-157.725 MHz | 7.5 kHz steps |
158.1125-158.460 MHz | 7.5 kHz steps |
159.480-160.2075 MHz | 7.5 kHz steps |
160.215-161.610 MHz | 7.5 kHz steps, Railroad Use Only |
173.20375 MHz | Operational fixed (SCADA, data links, etc) only |
173.210 MHz | Operational fixed (SCADA, data links, etc) only |
173.225-173.375 MHz | 12.5 kHz steps |
173.390 MHz | Operational fixed (SCADA, data links, etc) only |
173.39625 MHz | Operational fixed (SCADA, data links, etc) only |
