SINCGARS
Revision as of 20:14, 19 December 2018 by R4002 (Talk | contribs)
VHF-FM tactical radio system, with frequency-hopping and voice encryption/data encryption capabilities. Operating in the 30.000 to 87.975 MHz frequency band with 25 kHz channel steps. Uses 150.0 Hz CTCSS squelch system. Operates in single-channel (SC) and frequency-hopping (FH) modes for voice and data. Most radios include repeater capability (called RETRANS or retransmit in military usage). Compatible with previous-generation FM radios such as the PRC-25, PRC-77, PRC-1077, HH7700 and dozens of other similar tactical handheld, manpack and vehicle-mounted radios operating in the 30-76 MHz or 30-88 MHz range. NATO military forces and many other military forces use similar frequencies for tactical purposes, almost always with FM voice. The US military fields radios that operate in the 30-174 MHz and 30-512 MHz ranges to support SINCGARS, regular VHF-FM, 136-174 MHz VHF-high band services like VHF marine, aircraft radios, SATCOM and interoperability with other radio systems that use VHF/UHF.
30.000 MHz to 30.550 MHz 32.000 MHz to 33.000 MHz 34.000 MHz to 35.000 MHz 36.000 MHz to 37.000 MHz 38.000 MHz to 39.000 MHz 40.000 MHz to 42.000 MHz 46.600 MHz to 47.000 MHz 49.600 MHz to 50.000 MHz
