Part 15
Part 15 is one of the sections of FCC regulations (47 C.F.R.) dealing with unlicensed low-power radio operation. The FCC defines these low-power transmitters as intentional radiators. See also: Part 15 beacons. Operation in several bands is allowed:
Many toy R/C transmitters operate under this section of Part 15 and not Part 95. There are others that operate under Part 95. Cheaper equipment operates under the Part 15 limits while other equipment will transmit much higher power (4 watts or 25 watts) if accepted for Part 95 Radio Control Radio Service (RCRS) operation. Toy RC transmitters, some wireless computer mice and other very short range devices generally use 27.145 MHz but may technically use any frequency between 26.980 MHz and 27.280 MHz. This band is shared with the CB radio service (26.960 MHz to 27.410 MHz) and the ISM band (26.957 MHz to 27.283 MHz).
See also: the RC Radio Service, the CB Radio Service, and high power datalink systems that use 26-27 MHz
This band is not used for R/C purposes in the United States. It is used for alarm systems, very short range sensor systems and other purposes. Short-range or toy R/C devices use 27 MHz, 49 MHz or 2.4 GHz in the United States.
§ 15.229 Operation within the band 40.66-40.70 MHz. (a) Unless operating pursuant to the provisions in § 15.231, the field strength of any emissions within this band shall not exceed 1,000 microvolts/meter at 3 meters. The 40.660 MHz to 40.700 MHz band is heavily used for short range devices (SRDs) and RC model control in Europe and elsewhere. It is not used for R/C purposes in the United States.
This section applies to cordless telephones. 43.71 MHz to 44.49 MHz (43.72 MHz to 44.48 MHz), 46.60 MHz to 46.98 MHz (46.61 MHz to 46.97 MHz), 48.75 MHz to 49.51 MHz (48.76 MHz to 49.50 MHz and 49.66 MHz to 50.0 MHz (49.67 MHz to 49.9 MHz). Note that the frequencies overlap with the VHF low band business radio band, the military bands, the 49 MHz RC 49 MHz remote control device frequencies and 49 MHz short range devices (walkie-talkies, baby monitors, etc.) The original 10 channel cordless phones used the 46.600 MHz - 47.000 MHz and 49.650 MHz to 50.000 MHz ranges only (46.610 MHz - 46.970 MHz and 46.670 MHz - 49.990 MHz).
49 MHz devices, frequencies used and discussion.
Even current-generation new production baby monitors are available that use the 49 MHz frequencies. Many models offer 2 channels to avoid interference with other nearby monitors. These devices remain in use despite the availability of 900 MHz/2.4 GHz, WiFi based, DECT 1.9 GHz or 5.8 MHz band audio monitors or audio/video combination devices. Analog baby monitors offer low RF radiation exposure due to their use of the VHF 49 MHz frequencies and excellent audio quality from true FM modulation within their service range. 49MHz monitor transmitters generally provide 300-600 feet range (high quality signal) depending on obstructions, antenna location/height and frequency congestion.
This equipment provides preppers and militia users with a unique short-range low probability of intercept (LPI) radio communications capability that higher-power VHF/UHF services like FRS, GMRS, MURS doesn't provide. The Radio Shack / Realistic TRC-503, TRC-512 and similar 49 MHz walkie talkies specs appear to indicate 16K0F3E emission for voice / 16K0F3D for tone emission.
- 49.850 MHz - Channel 2
- 49.870 MHz - Channel 3
- 49.890 MHz - Channel 4
- 49.875 MHZ - Channel 4
Modern equipment generally uses 2 switchable channels. Some of these transmitters use a simple 16.6xxx MHz crystal with a frequency tripler circuit (16.610 MHz x3 = 49.830 MHz - 16.61415 MHz x3 = 49.8425 MHz, 16.615 MHz x3 = 49.845 MHz, 16.616 MHz x3 = 49.848 MHz, 16.61667 MHz x3 = 49.850 MHz, 16.620 MHz x3 = 49.860 MHz etc.) and simple FM modulation. Frequency steps, channel plans and channel spacing is random and channel labeling or naming is arbitrary, including:
- 49.845 MHz - Channel X
- 49.875 MHz - Channel Y
Or,
- 49.830 MHz - Channel A
- 49.860 MHz - Channel B
Or,
- 49.845 MHz - Channel A
- 49.890 MHz - Channel B
Or,
- 49.840 MHz - Channel A
- 49.870 MHz - Channel B
Or,
- 49.850 MHz - Channel I
- 49.870 MHz - Channel II
Or,
- 49.825 MHz - Channel 1
Or,
- 49.870 MHz - Channel 1
- 49.890 MHz - Channel 2
Or,
- 49.840 MHz - Channel 1
- 49.860 MHz - Channel 2
Or,
- 49.842 MHz - Channel 1 (49.8425 MHz or 49.843 MHz offset)
- 49.860 MHz - Channel 2 (49.8625 MHz or 49.863 MHz offset)
Or,
- 49.885 MHz - Channel B
Or,
- 49.875 MHz - Channel B
Or,
- 49.876 MHz - Channel B (specifically designed to operate off-center channel - 49.876 MHz per FCC ID documentation)
Or,
- 49.870 MHz - Channel A (actually closer to 49.885, 49.8875 or 49.890 MHz)
- 49.810 MHz - Channel B (actually closer to 49.825 or 49.830 MHz)
15 kHz wide band AM modulation appears to be used. According to the schematic provided with the authorization paperwork, the device in question uses two crystals for frequency generation - 16.610 MHz x3 (for 49.830 MHz) for Channel B and 16.630 MHz x3 (for 49.890 MHz) for Channel A
- 49.870 MHz - Channel 4
- 49.880 MHz - Channel 5
- 49.890 MHz - Channel 6
- 49.835 MHz - Channel A
- 49.850 MHz - Channel B
- 49.865 MHz - Channel C
Or,
- 49.890 MHz - Channel C
- 49.835 MHz - Channel 1/A
- 49.860 MHz - Channel 2/B
- 49.885 MHz - Channel 3/C
Sometimes frequencies may be off by several kHz. For example, 49.845 MHz may be closer to 49.840 MHz, 49.847 MHz or even 49.850 MHz, 49.860 MHz may be closer to 49.855 MHz, 49.8625 MHz, 49.865 MHz, etc. Apparently some manufacturers did/do this intentionally, likely to reduce interference issues. Certain name-brand baby monitors, for example, purposely operate off-frequency. For example, FCC authorization documents indicate a baby monitor system designed to operate on 49.862 MHz (49.8625 MHz). Another baby monitor features two channels, 49.840 MHz and 49.876 MHz. Third party testing and circuit designs specify 49.876 MHz instead of 49.875 MHz or 49.880 MHz. The specifications also call for a 25 kHz wide channel (20K0F3E FM voice). Another single channel design uses 49.87125 MHz (appears to be closer to 49.872 MHz than 49.871 MHz) instead of 49.870 MHz or 49.875 MHz.
