Revision as of 12:02, 18 December 2019 by R4002 (Talk | contribs)
Do I need a license to transmit on 151.625 MHz? Yes, you do. You need a license to use all the business band frequencies, including 151.625 MHz, 151.505 MHz, 158.400 MHz, 151.955 MHz, 151.760 MHz, etc. Only the 22 FRS frequencies, the 5 MURS frequencies and the 40 CB channels do not require a license. Getting a business license for the Itinerant channels is extremely easy.
  • 152.9000 MHz - Motorola RDX default channel 19
Note that 30.000 to 87.975 MHz is shared with the SINCGARS VHF FM military land mobile communications system, which operates in either frequency hopping FH mode or single channel SC mode. This is often referred to as "FM" within the military. 30 to 88 MHz in 25 kHz steps. While the military usually stays in the military/government sub-bands (29.80-30.55 MHz, 32-33 MHz, 34-35 MHz, 36-37 MHz, 38-39 MHz, 40-42 MHz, 46.6-47 MHz and 49.6-50 MHz they can also be found in the land mobile sub-bands using 25 kHz steps and 150 Hz CTCSS tone. Military operations in the United States use both FH and SC mode with or without voice encryption. These channels are often referred to as “FM” or “Fox Mike”. For example, 38.500 MHz would be called “FM 38.50” or “38.50 FM”
27.555 MHz Only in certain areas for forestry/logging, no current licenses, shared with fixed/mobile/government and freeband CB
27.615 MHz Only in certain areas for forestry/logging, no current licenses, shared with fixed/mobile/government and freeband CB
27.635 MHz Only in certain areas for forestry/logging, no current licenses, shared with fixed/mobile/government and freeband CB
27.655 MHz Only in certain areas for forestry/logging, no current licenses, shared with fixed/mobile/government and freeband CB
27.765 MHz Only in certain areas for forestry/logging, no current licenses, shared with fixed/mobile/government and freeband CB
27.860 MHz Only in certain areas for forestry/logging, no current licenses, shared with fixed/mobile/government and freeband CB
35.180 MHz
72.080 MHz
72.160 MHz
72.240 MHz
72.320 MHz
72.400 MHz
154.45625 MHz Operational fixed (SCADA, data links, telemetry, etc) only
154.46375 MHz Operational fixed (SCADA, data links, telemetry, etc) only
154.47125 MHz Operational fixed (SCADA, data links, telemetry, etc) only
154.47875 MHz Operational fixed (SCADA, data links, telemetry, etc) only
154.505 MHz
154.5275 MHz Mobiles only
154.585 MHz
154.610 MHz
154.625 MHz
154.640 MHz
157.470-157.725 MHz 7.5 kHz steps, 157.5225 MHz to 157.725 MHz mobile/input freqs from old Taxicab Radio Service
173.20375 MHz Operational fixed (SCADA, data links, etc) only - narrowband 6.25 kHz channel spacing
173.210 MHz Operational fixed (SCADA, data links, etc) only - narrowband 6.25 kHz channel spacing
173.390 MHz Operational fixed (SCADA, data links, etc) only - narrowband 6.25 kHz channel spacing
173.39625 MHz Operational fixed (SCADA, data links, etc) only - narrowband 6.25 kHz channel spacing
