AmRRON
American Redoubt Radio Operators Network also: The American Preparedness Radio Network (TAPRN)
Emergency radio monitoring/frequency plan prepper redoubter patriot militia emergency radio preparedness project for licensed and unlicensed users, following the 3 rule:
Monitor channel 3 for 3 minutes every 15 minutes at the top of the hour (:00), bottom of the hour (:30) and quarter past/quarter to (:15 and :45). Combination of channel 3 on the CB, FRS and MURS unlicensed services with specified frequencies in the various MF, HF, VHF and UHF amateur radio bands as well. Primary VHF amateur frequency is 146.420 MHz.
- CB radio channel 3 - 26.985 MHz
- MURS channel 3 - 151.940 MHz
- FRS channel 3 - 462.6125 MHz
- 2 meter amateur band ham radio - 146.420 MHz
Carrier squelch or CSQ receive is required. Transmitting CTCSS or PL is ok. See the pages for the three respective services for more information. Transmit CTCSS PL tone 67.0 Hz recommended on FRS channel 1 - 462.5625 MHz. Transmit CTCSS PL tone 141.3 Hz recommended on FRS channel 20 - 462.675 MHz.
From the AmRRON website:
Make Contact In 3 – 2 – 1
- 3 (Turn your radio on and set it to Channel 3)
- 2 (Attempt to broadcast for approximately 2 minutes)
- 1 (Attempt again every 1 HOUR, on the hour, to save batteries)
Script: Simply use your ARN or AmRRON call sign, preceded by the word, “AmRRON”. So if your call sign is Tango-67, you would say “This is AmRRON Tango Six Seven.” *If you do not have an ARN Call Sign, then your call sign is “AmRRON…” and the initials of your first and last name (or just your last name).
Example: “This is AmRRON JULIET SIERRA” (if you do not know the phonetic alphabet, you could simply say “This is AmRRON J.S.”) Just get the job done.
If you must communicate “in the blind” (attempt to reach ANY AmRRON member who may be monitoring), then you can use the unknown party (or Hailing) call-sign of “X-Ray.”
Example: “AmRRON X-Ray, this is AmRRON Juliet Sierra. Does anyone copy?”
If there is a real emergency, you could also monitor CH3 to give assistance to others in need. To save batteries, monitor for 5 minutes on each side of the hour, to increase the chances of hearing another “Redoubter” who may be communicating using the “Make Contact In 3-2-1” method.
Remember, when making contact with someone you don’t know, always proceed with caution. You should always assume that all transmissions made are being monitored by other operators who may not transmit or reply back to you - even if you are making a general call.
Frequencies:
- 151.9400 MHz - Militia/Patriot VHF Primary/Calling MURS 3 - AmRRON Patriot Nationwide Primary MURS 3
- 154.5700 MHz - Militia/Patriot VHF MURS 4 - Patriot Regional Channel Patriot Militia Secondary Channel
- 154.6000 MHz - Militia/Patriot VHF MURS 5
- 462.6125 MHz - Militia/Patriot UHF FRS 3 - UHF Primary/Calling FRS 3 - AmRRON
- 467.5625 MHz - Militia/Patriot UHF FRS 8 - Tactical
- 467.5875 MHz - Militia/Patriot UHF FRS 9
- 467.6125 MHz - Militia/Patriot UHF FRS 10
- 467.6375 MHz - Militia/Patriot UHF FRS 11
- 467.6625 MHz - Militia/Patriot UHF FRS 12
- 467.6875 MHz - Militia/Patriot UHF FRS 13
- 467.7125 MHz - Militia/Patriot UHF FRS 14
- 462.5500 MHz - Militia/Patriot UHF FRS 15 - Tactical
- 462.5750 MHz - Militia/Patriot UHF FRS 16 - Patriot Tactical, Vehicle Coordination
- 462.6000 MHz - Militia/Patriot UHF FRS 17 - Tactical
- 467.5875 MHz - FRS9 - Militia/Patriot UHF FRS Channel 9
- 467.6125 MHz - FRS10 - Militia/Patriot UHF FRS Channel 10
- 467.6375 MHz - FRS11 - Militia/Patriot UHF FRS Channel 11
- 467.6625 MHz - FRS12 - Militia/Patriot UHF FRS Channel 12
- 467.6875 MHz - FRS13 - Militia/Patriot UHF FRS Channel 13
- 467.7125 MHz - FRS14 - Militia/Patriot UHF FRS Channel 14
- 151.880 MHz - MURS 2
- 154.570 MHz - MURS 4
- 154.600 MHz - MURS 5
- 151.655 MHz - VHF Business
- 151.685 MHz - VHF Business
- 151.715 MHz - VHF Business
- 151.745 MHz - VHF Business
- 151.775 MHz - VHF Business
- 151.805 MHz - VHF Business
- 151.835 MHz - VHF Business
- 151.865 MHz - VHF Business
- 151.895 MHz - VHF Business
- 151.925 MHz - VHF Business
- 151.955 MHz - VHF Business
- 152.870 MHz - VHF Business
- 152.885 MHz - VHF Business
- 152.900 MHz - VHF Business
- 152.915 MHz - VHF Business
- 152.930 MHz - VHF Business
- 152.945 MHz - VHF Business
- 152.960 MHz - VHF Business
- 152.975 MHz - VHF Business
- 152.990 MHz - VHF Business
- 153.005 MHz - VHF Business
- 154.4825 MHz - VHF Business
- 154.490 MHz - VHF Business
- 154.4975 MHz - VHF Business
- 154.505 MHz - VHF Business
- 154.515 MHz - VHF Business
- 154.5275 MHz - VHF Business Itinerant
- 154.540 MHz - VHF Business
- 154.5475 MHz - VHF Business
- 154.555 MHz - VHF Business
- 154.625 MHz - VHF Business
- 154.655 MHz - VHF Business
- 158.4075 MHz - VHF Business Itinerant
Links:
- [1] AmRRON Channel 3 Project
- [2] AmRRON/TAPRN About Page
- [3] AmRRON and TAPRN Local Prepper Redoubt Radio Nets and Frequencies
- [4] AmRRON and TAPRN Subregional Prepper Redoubt Radio Nets and Frequencies
- [5] AmRRON and TAPRN Regional and National Prepper Redoubt Radio Nets and Frequencies
