SINCGARS
![](/wiki/images/thumb/9/91/SINCGARS_2.jpg/200px-SINCGARS_2.jpg)
For example:
- Relay Operation:
- Channel 1 - TX and RX 30.150 MHz - mountaintop or other elevated position - connected to Channel 2 radio
- Channel 2 - TX and RX 49.850 MHz - mountaintop or other elevated position - connected to Channel 1 radio
- Repeater Operation:
- Channel 1 - TX 32.375 MHz - mountaintop or other elevated position
- Channel 1 - RX 41.700 MHz - mountaintop or other elevated position
Background and History
Frequency Band | Use | Channel Step/Frequency Spacing |
28.000 MHz to 80.000 MHz | TBY Series (TBY-2, etc.) US Navy USMC US Marine Corps tactical radios 28-80 MHz | Four "bands" - wideband AM receivers, combat radios used for beach landing nets, etc. heavily used in the Pacific |
60.000 MHz to 80.000 MHz | TBS Series "Talk Between Ships" - Ship-to-Ship voice radio 60-80 MC radio - US Navy | Crystal controlled 20 kHz steps - TBS crystals for 65.74 MHz and 72.50 MHz have been found |
20.000 MHz to 27.900 MHz | American Armor Band (tank radio, tank destroyers, tank command nets) (U.S. Army) | 100 kHz (channels 200-279), PRC-8, PRC-8A, SCR-508, SCR-509, SCR-510, SCR-528, SCR-538, etc |
27.000 MHz to 38.900 MHz | American Artillery Band (U.S. Army) | 100 kHz (channels 270-389), PRC-9, PRC-9A, SCR-608, SCR-609, SCR-610, SCR-628 |
38.000 MHz to 54.900 MHz | American Infantry Band (U.S. Army) | 100 kHz (channels 380-549), PRC-10, PRC-10A |
40.000 MHz to 48.000 MHz | American Infantry Band - portable tactical radios - WWII vintage | 200 kHz (channels 0-40), SCR-300 (BC-1000) manpack backpack radio |
3500 kHz to 6000 kHz | SCR-536 Handheld Radio 3.5 MHz to 6.0 MHz the "walkie-talkie" - actually called a Handie-Talkie or HT | Crystal controlled, 360mw AM voice only - short range tactical communications HF AM |
3800 kHz to 6500 kHz | SCR-694 3.8 MHz to 6.5 MHz AM, CW or MCW - portable or vehicle-mounted tactical AM voice, tone or straight CW | Crystal controlled, 10-20 mile range (voice, R/T), 20-40 miles range (tone, W/T) depending on antenna used |
3800 kHz to 5800 kHz | SCR-284 3.8 MHz to 5.8 MHz AM, CW or MCW - transportable or vehicle-mounted tactical AM voice, tone or straight CW | 24 watts transmit power (CW mode, W/T), 17 watts transmit power voice (W/T, AM voice) |
2000 kHz to 8000 kHz | Wireless Set No. 19 - British tank radio 2-8 MHz with very low power VHF "B" set built in, 229-241 MHz | Tank to tank command usage (A set - 2-8 MHz) and very short range tank communications (B set) |
47.000 MHz to 55.400 MHz | American Infantry Band - portable tactical radios - Korea War vintage - PRC-6 | AN/PRC-6 "banana radio" walkie talkie portable single-channel crystal controlled FM radio, 250mw output, 47-55.4 MHz FM |
27.200 MHz to 33.300 MHz | German Armor Tank Radio Panzer Radio Band - sometimes listed as 27.0 MHz - 33.4 MHz or 27.2 MHz - 33.4 MHz | 50 kHz channels - AM voice - this was, by far, the most common tank command/tactical radio band used |
42.000 MHz to 48.300 MHz | German Air-to-Ground Band (see also: 42.0 MHz - 47.8 MHz and 42.1 MHz - 47.8 MHz) | 50 kHz channels - AM voice, close air support and tank command nets |
23.000 MHz to 24.950 MHz | German Self-Propelled Artillery Band | 50 kHz channels - AM voice - similar radios to the 10W.S.c. Panzer tank radios, different frequency range |
28.000 MHz to 33.000 MHz | German Infantry Band (portable radios) | 100 kHz channels, actual coverage 27.8 MHz to 33.2 MHz |
32.000 MHz to 38.000 MHz | German Infantry Band (portable radios) | 100 kHz channels - Feldfu d and KL.Fuspr.d manpack portable infantry radios |
33.800 MHz to 38.000 MHz | German Infantry Band (transportable portable radios - higher power command sets) | 100 kHz channels |
90.000 MHz to 110.000 MHz | German Infantry Band (portable radios) | Low power AM voice radios - tactical short range |
120.000 MHz to 156.000 MHz | German Infantry Band (portable radios) | Low power AM voice radios - tactical short range |
130.000 MHz to 160.000 MHz | German Infantry Band (portable radios) - considered ultra high frequency in the 1940s | Low power AM voice radios - tactical short range |
22.700 MHz to 29.500 MHz | Japanese Type 97 Radio Set Walkie-Talkie 22.7 MHz - 29.5 MHz | Low power AM voice tactical radios (300-400mw, less than 2 mile range) |
19.600 MHz to 30.600 MHz | Japanese Tank Mechanical Set Type TM Model 305 19.6 MHz - 30.6 MHz | 30 watt - 50 watt AM voice mobile tank vehicle radio - 25 mile range |
30.000 MHz to 75.950 MHz | Tactical Band (30-76 MHz) (150 Hz CTCSS "new squelch" system) removes need for manual squelch control | 50 kHz (channelized intent frequency control) PRC-25, PRC-77, VRC-12 and dozens of others |
30.000 MHz to 87.975 MHz | Tactical Band (30-88 MHz) 150 Hz CTCSS (some radios allow use of other tones) | 25 kHz step, single channel SC (fixed frequency) mode, frequency hopping FH or fast frequency hopping FFH (anti-jamming countermeasure) modes |
30 MHz to 512 MHz | Tactical Band (30-88 MHz) combined with VHF/UHF bands, including the airband, VHF marine band, VHF land mobile bands, REMBASS 138.025 MHz to 152.975 MHz (25 kHz steps) | 25 kHz step, single channel SC (fixed frequency) mode or frequency hopping FH (anti-jamming countermeasure) mode, 2.5, 5, 8.33 kHz steps |
380-470 MHz | Intra-Squad Radio (ISR) and Improved Intra Squad Radio (IISR) systems | Various frequency steps and modes used for short range communications within squads/fireteams |
2400-2500 MHz (2.4 GHz) | Intra-Squad Radio (ISR) and Improved Intra Squad Radio (IISR) systems - including the Personal Role Radio (PRR) | Various frequency steps and modes (including spread spectrum and frequency hopping) used for short range communications within squads/fireteams |
Frequency Band |
30.000 MHz to 30.550 MHz |
32.000 MHz to 33.000 MHz |
34.000 MHz to 35.000 MHz |
36.000 MHz to 37.000 MHz |
38.000 MHz to 39.000 MHz |
40.000 MHz to 42.000 MHz |
46.600 MHz to 47.000 MHz |
49.600 MHz to 50.000 MHz |
- 30.000 MHz - 30.560 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate air-to-ground and air-to-air communication systems in this band for tactical and training operations. The federal agencies operate land mobile radio communication systems in this band to support natural resource management and wildlife telemetry.
- 30.560 MHz - 32.000 MHz - Non-Federal and Federal - FIXED, LAND MOBILE - The military agencies operate communication systems in this band for tactical and training operations. The federal agencies operate land mobile radio communication systems in this band to support natural resource management and forest fire fighting. Inter-operable communications are used to support mutual aid response with local public safety agencies. 30.56 MHz to 31.98 MHz (20 kHz steps), allocated for state government (forestry) and business/industrial land mobile services.
- 32.000 MHz - 33.000 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate radio communication systems in this band for networks providing command and control for combat, combat support, and combat service support for tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems for close air support missions. The federal agencies operate land mobile radio communications systems in this band to support land management and to protect natural resources.
- 33.000 MHz - 34.000 MHz - Non-Federal and Federal - FIXED, LAND MOBILE - The federal agencies operate land mobile radio communication systems in this band to support mutual aid response with local public safety agencies. The military agencies operate communication systems in this band for tactical and training operations. They also operate tactical air-to-ground and air-to-air communications systems for close air support missions. 33.02 MHz to 33.98 MHz (20 kHz steps), allocated for local government (33 MHz fire radio band) and some limited business/industrial land mobile services (33.34 MHz, 33.4 MHz, etc.).
- 34.000 MHz - 35.000 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate radio communication systems in this band for networks providing command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems for close air support. The federal agencies operate land mobile radio communication systems in this band to support law enforcement and facilities security management, natural resource management, park security law enforcement at national parks, forests, and wildlife refuge areas.
- 35.000 MHz - 36.000 MHz - Non-Federal and Federal - FIXED, LAND MOBILE - 35.02 MHz to 35.98 MHz land mobile business and industrial radio systems, local paging systems. The military agencies operate communication systems in this band on a non-interference basis for tactical and training operations.
- 36.000 MHz - 37.000 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate radio communication systems in this band for networks providing command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems in this band for military close air support missions. The federal agencies operate land mobile radio communication systems in this band to support national park management, law enforcement, public safety nets, contingencies, and natural resources management.
- 37.000 MHz - 37.500 MHz - Non-Federal and Federal - LAND MOBILE - 37.02 MHz to 37.5 MHz (20 kHz channel steps) public safety, law enforcement, and business/industrial land mobile systems. The military agencies operate radio communication systems for tactical and training operations on a non- interference basis.
- 37.500 MHz - 38.000 MHz - Non-Federal and Federal - LAND MOBILE, RADIO ASTRONOMY - The National Science Foundation uses this band to perform radio astronomy research into continuum observations to study electromagnetic radiation from the planet Jupiter and from the Sun.
- 38.000 MHz - 38.250 MHz - Federal - FIXED, MOBILE, RADIO ASTRONOMY - The military agencies operate radio communication systems in this band for networks providing command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems for close air support missions. The Coast Guard operates ship-to-ship and ship-to-shore communication systems in this band. The National Science Foundation uses this band to perform radio astronomy research into continuum observations to study electromagnetic radiation from the planet Jupiter and from the Sun.
- 38.250 MHz - 39.000 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate communication systems for combat net radio operations to provide command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems for close air support missions. The federal agencies operate land mobile radio communication systems for the operation, protection, and maintenance of national parks, forests, wildlife refuge areas, and to support law enforcement, public safety operations, control of power generation transmission and water facilities, environmental data collection, fish management, and wildlife telemetry programs.
- 39.000 MHz - 40.000 MHz - Non-Federal and Federal - LAND MOBILE - 39.02 MHz to 39.98 MHz (20 kHz channel steps) used for local and state police communications, interoperability and other emergency services. Federal agencies operate land mobile radio communications systems to support public safety responses to local communities. The military agencies operate radio communication systems in this band for networks providing command and control for combat, combat support, and combat service support for tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems for close air support missions.
- 40.000 MHz - 42.000 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate radio communication systems in this band for networks providing command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems for close air support missions. The federal agencies operate land mobile radio communication systems used in the operation, protection, and maintenance of national parks, forests, wildlife refuge areas, and to support public safety operations, environmental data collection, fish management, and wildlife telemetry programs. The federal agencies operate meteor-burst communications systems in this band to provide beyond line-of-sight communications and telemetry. A typical application is the Department of Agriculture transmitting snow fall data from numerous sensors to a central location - the SNOTEL system on 40.67 MHz.
- 42.000 MHz - 43.690 MHz - Non-Federal and Federal - FIXED, LAND MOBILE - 42.00 MHz to 42.94 MHz (20 kHz channel steps) state police radio systems (supplanted or replaced by VHF high band, UHF or 700 MHz/800 MHz digital trunking systems in many states). Business and industrial land mobile systems operate between 42.96 MHz and 43.68 MHz. The military agencies operate radio communication systems for tactical and training operations on a non- interference basis.
- 43.690 MHz - 46.600 MHz - Non-Federal and Federal - FIXED, LAND MOBILE - 43.70 MHz to 46.58 MHz (20 kHz channel steps) public safety, law enforcement, and business/industrial land mobile systems. The military agencies operate radio communication systems for tactical and training operations on a non- interference basis.
- 46.600 MHz - 47.000 MHz - Federal - FIXED, LAND MOBILE - The military agencies operate radio communication systems in this band for combat net radio operations to provide command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air radio communication systems for close air support missions. The federal agencies operate land mobile radio communication systems in this band for contingency response to various national disasters, national resources management, law enforcement, tornado tracking, and various meteorological research programs.
- 47.000 MHz - 49.600 MHz - Non-Federal and Federal - LAND MOBILE - 47.02 MHz to 49.58 MHz (20 kHz channel steps) public safety, law enforcement, and business/industrial land mobile systems. The military agencies operate radio communication systems for tactical and training operations on a non- interference basis. The National Aeronautics and Space Administration (NASA) use this band to research and observe wind shear conditions for spacecraft
- 49.600 MHz - 50.000 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate radio communication systems in this band for combat net radio operations to provide command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air radio communication systems for close air support missions. The federal agencies operate land mobile radio communication systems in this band for contingency response to various national disasters, national resources management, law enforcement, tornado tracking, and various meteorological research programs.
- 50.000 MHz - 54.000 MHz - Non-Federal and Federal - AMATEUR - 6 meter amateur radio band. The military agencies operate radio communication systems for tactical and training operations in this band on a non-interference basis.
- 54.000 MHz - 72.000 MHz - Non-Federal and Federal - BROADCASTING. The military agencies operate radio communication systems for tactical and training operations in this band on a non-interference basis.
- 72.000 MHz - 73.000 MHz - Non-Federal and Federal - FIXED, MOBILE - The military agencies operate radio communication systems for tactical and training operations in this band on a non-interference basis. 72.02 MHz - 72.98 MHz is an operational fixed band for business, industrial users. This band is also shared with the 72 MHz RC frequencies (72.01 MHz to 75.99 MHz).
- 73.000 MHz - 74.600 MHz - Federal - RADIO ASTRONOMY, FIXED, MOBILE - The National Science Foundation uses this band to perform radio astronomy research via continuum observations to identify characteristics of stars, planets, and gases such as their elemental composition, temperature, etc. The military agencies operate radio communication systems for tactical and training operations in this band on a non-interference basis.
- 74.600 MHz - 74.800 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate land mobile radio communication systems used by military aircraft crews. The federal agencies operate portable-to-portable communication and low-power communication systems that are used inside power plant facilities to remotely control devices. The military agencies operate radio communication systems for tactical and training operations in this band on a non-interference basis.
- 74.800 MHz - 75.200 MHz - Federal - AERONAUTICAL RADIONAVIGATION - The Federal Aviation Administration operates Instrument Landing System (ILS) marker beacons in this band to provide navigational guidance information during aircraft approach and landing on 75.0 MHz. 74.8 - 75.2 MHz guard band.
- 75.200 MHz - 75.400 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies use this band for fixed and mobile radio communications. Typical uses are runway light control systems and communication to aircrews. The federal agencies use this band for land mobile radio communications for public safety operations, low power operations to the remote control of mechanical devices, and other uses.
- 75.400 MHz - 76.000 MHz - Non-Federal and Federal - FIXED, MOBILE - The military agencies operate radio communication systems for tactical and training operations in this band on a non-interference basis. 75.4 MHz - 75.98 MHz is an operational fixed band for business, industrial users. This band is also shared with the 75 MHz RC frequencies (75.41 MHz to 75.99 MHz).
- 76.000 MHz - 88.000 MHz - Non-Federal and Federal - BROADCASTING. The military agencies operate radio communication systems for tactical and training operations in this band on a non-interference basis.
- 34.100 MHz - 41.700 MHz Ra120 Swedish manpack portable VHF FM tactical radio, 100 kHz steps
- PRC-6 - 47.00 MHz to 55.40 MHz (crystal controlled, single channel)
- PRC-8 and PRC-8A - 20.00 MHz to 27.90 MHz (100 kHz steps, continuous tuning)
- PRC-9 and PRC-9A - 27.00 MHz to 38.90 MHz (100 kHz steps, continuous tuning)
- PRC-10 and PRC-10A - 38.00 MHz to 54.90 MHz (100 kHz steps, continuous tuning)
- PRC-25 30.00 MHz to 75.95 MHz (50 kHz steps, channelized) - 150 Hz tone squelch
- PRC-77 30.00 MHz to 75.95 MHz (50 kHz steps, channelized) - 150 Hz tone squelch
- VRC-12 30.00 MHz to 75.95 MHz (50 kHz steps, channelized) - 150 Hz tone squelch or carrier squelch
- VRC-8 20.00 MHz to 27.90 MHz (100 kHz steps, continuous tuning) - RT-66 FM transceiver
- VRC-9 27.00 MHz to 38.90 MHz (100 kHz steps, continuous tuning) - RT-67 FM transceiver
- VRC-10 39.00 MHz to 54.90 MHz (100 kHz steps, continuous tuning) - RT-68 FM transceiver
