Amateur radio
Revision as of 18:37, 14 June 2022 by R4002 (Talk | contribs)
hamateurszzz hamsexy dot com eham dot net et cetera hams don't like CBers. Hammies hamateurs HF frequencies listed below. Several VHF/UHF allocations worldwide. Exact band limits vary from country to country, with 2 meters generally being 144-146 MHz and 70cm generally being centered around 432 MHz or 440 MHz, the US bands of 144-148 MHz and 420-450 MHz are generally larger than allocations in other countries.
Amateur radio has secondary allocation in many bands.
Amateur Radio Bands MF/HF
  • 50-54 MHz - 6 meter band (50-51 MHz or 50-52 MHz in some countries)
  • 144-148 MHz - 2 meter band (144-146 MHz only in many countries)
  • 222-225 MHz - 1.25 meter band (220-225 MHz in some areas), only available in some countries
  • 902-902 MHz - 33cm band or 900 MHz band (shared with Part 15 services, cordless phones, long-haul WiFi and telemetry links, long range drone remote control systems and backhaul video/data links, along with many other services in the USA, not available in many areas). Shared with ISM services and many other systems, center frequency 915 MHz.
  • 2400-2500 MHz - 2.4 GHz or 2.45 GHz band. 2.4 GHz to 2.5 GHz shared with Part 15, WiFi, data links, RC remote control systems, drone remote control and telemetry systems, video senders, and about six dozen other services, including Part 18 ISM devices (center frequency: 2450 MHz or 2.45 MHz).
