Militia Radio Frequencies
new page, placeholder for now.
MURS and FRS form the backbone of the VHF tactical and command networks used by militia groups. The 22 FRS channels are used in addition to the 5 MURS channels. Because FRS is on the UHF band, it performs better for inter squad and intra squad radio compared to VHF. FRS considerably outperforms MURS in urban environments. MURS, however, offers greater range on a watt-for-watt basis. CB and 11 meter frequencies will give the best range (especially in rural areas). Base stations with CB and VHF (MURS) capability are recommended for command and control. Handheld militia radios should be programmed with the 5 MURS channels and the 22 FRS channels at a minimum.
This includes the Baofeng UV-5R series, UV-82 series, UV-82HP, etc.
- 151.9400 MHz - Militia/Patriot VHF Primary/Calling MURS 3 - AmRRON Patriot Nationwide Primary MURS 3 (also FRS 3, CB 3 and 146.42 MHz)
- 154.5700 MHz - Militia/Patriot VHF MURS 4 - Patriot Regional Channel Patriot Militia Secondary Channel
- 154.6000 MHz - Militia/Patriot VHF MURS 5
- 467.5625 MHz - Militia/Patriot UHF FRS 8 - Tactical
- 467.5875 MHz - Militia/Patriot UHF FRS 9
- 467.6125 MHz - Militia/Patriot UHF FRS 10
- 467.6375 MHz - Militia/Patriot UHF FRS 11
- 467.6625 MHz - Militia/Patriot UHF FRS 12
- 467.6875 MHz - Militia/Patriot UHF FRS 13
- 467.7125 MHz - Militia/Patriot UHF FRS 14
- 462.5500 MHz - Militia/Patriot UHF FRS 15 - Tactical
- 462.5750 MHz - Militia/Patriot UHF FRS 16 - Patriot Tactical, Vehicle Coordination
- 462.6000 MHz - Militia/Patriot UHF FRS 17 - Tactical
- 467.5875 MHz - FRS9 - Militia/Patriot UHF FRS Channel 9
- 467.6125 MHz - FRS10 - Militia/Patriot UHF FRS Channel 10
- 467.6375 MHz - FRS11 - Militia/Patriot UHF FRS Channel 11
- 467.6625 MHz - FRS12 - Militia/Patriot UHF FRS Channel 12
- 467.6875 MHz - FRS13 - Militia/Patriot UHF FRS Channel 13
- 467.7125 MHz - FRS14 - Militia/Patriot UHF FRS Channel 14
- 151.880 MHz - MURS 2
- 154.570 MHz - MURS 4
- 154.600 MHz - MURS 5
- 151.655 MHz - VHF Business
- 151.685 MHz - VHF Business
- 151.715 MHz - VHF Business
- 151.745 MHz - VHF Business
- 151.775 MHz - VHF Business
- 151.805 MHz - VHF Business
- 151.835 MHz - VHF Business
- 151.865 MHz - VHF Business
- 151.895 MHz - VHF Business
- 151.925 MHz - VHF Business
- 151.955 MHz - VHF Business
- 152.870 MHz - VHF Business
- 152.885 MHz - VHF Business
- 152.900 MHz - VHF Business
- 152.915 MHz - VHF Business
- 152.930 MHz - VHF Business
- 152.945 MHz - VHF Business
- 152.960 MHz - VHF Business
- 152.975 MHz - VHF Business
- 152.990 MHz - VHF Business
- 153.005 MHz - VHF Business
- 154.4825 MHz - VHF Business
- 154.490 MHz - VHF Business
- 154.4975 MHz - VHF Business
- 154.505 MHz - VHF Business
- 154.515 MHz - VHF Business
- 154.5275 MHz - VHF Business Itinerant
- 154.540 MHz - VHF Business
- 154.5475 MHz - VHF Business
- 154.555 MHz - VHF Business
- 154.625 MHz - VHF Business
- 154.655 MHz - VHF Business
- 158.4075 MHz - VHF Business Itinerant
