25.160 MHz | |
25.200 MHz | |
25.240 MHz | |
25.280 MHz | |
25.320 MHz | |
27.430 MHz | |
27.450 MHz | |
27.470 MHz | |
27.555 MHz | Limited to forest product licenses only in certain states, 150 watts maximum power no active licenses on 27.555 MHz |
27.615 MHz | Limited to forest product licenses only in certain states, 150 watts maximum power no active licenses on 27.615 MHz |
27.635 MHz | Limited to forest product licenses only in certain states, 150 watts maximum power no active licenses on 27.635 MHz |
27.655 MHz | Limited to forest product licenses only in certain states, 150 watts maximum power no active licenses on 27.655 MHz |
27.765 MHz | Limited to forest product licenses only in certain states, 150 watts maximum power no active licenses on 27.765 MHz |
27.860 MHz | Limited to forest product licenses only in certain states, 150 watts maximum power no active licenses on 27.86 MHz |
29.710 MHz | |
29.730 MHz | |
29.750 MHz | |
29.770 MHz | |
29.790 MHz | |
30.580 MHz | |
30.600 MHz | |
30.620 MHz | |
30.680 MHz | |
30.720 MHz | |
30.760 MHz | |
30.800 MHz | |
30.880 MHz | |
30.920 MHz | |
30.960 MHz | |
31.000 MHz | |
31.040 MHz | |
31.080 MHz | |
31.120 MHz | |
31.160 MHz | |
31.200 MHz | |
31.240 MHz | |
31.280 MHz | |
31.320 MHz | |
31.360 MHz | |
31.400 MHz | |
31.440 MHz | |
31.480 MHz | |
31.520 MHz | |
31.560 MHz | |
31.600 MHz | |
31.640 MHz | |
31.680 MHz | |
31.720 MHz | |
31.760 MHz | |
31.800 MHz | |
31.840 MHz | |
31.880 MHz | |
31.920 MHz | |
31.960 MHz | |
33.160 MHz | |
33.180 MHz | |
33.200 MHz | |
33.220 MHz | |
33.240 MHz | |
33.260 MHz | |
33.280 MHz | |
33.300 MHz | |
33.320 MHz | |
33.340 MHz | |
33.360 MHz | |
33.380 MHz | |
35.060 MHz | |
35.080 MHz | |
35.100 MHz | |
35.120 MHz | |
35.160 MHz | |
35.280 MHz | |
35.320 MHz | |
35.360 MHz | |
35.400 MHz | |
35.440 MHz | |
35.480 MHz | |
35.520 MHz | |
35.700 MHz | |
35.720 MHz | |
35.740 MHz | |
35.760 MHz | |
35.780 MHz | |
35.820 MHz | |
35.840 MHz | |
35.860 MHz | |
35.880 MHz | |
35.900 MHz | |
35.920 MHz | |
35.940 MHz | |
35.960 MHz | |
35.980 MHz | |
37.440 MHz | |
37.460 MHz | |
37.480 MHz | |
37.500 MHz | |
37.520 MHz | |
37.520 MHz | |
37.560 MHz | |
37.580 MHz | |
37.620 MHz | |
37.640 MHz | |
37.660 MHz | |
37.680 MHz | |
37.700 MHz | |
37.720 MHz | |
37.760 MHz | |
37.780 MHz | |
37.800 MHz | |
37.820 MHz | |
37.840 MHz | |
37.860 MHz | |
37.880 MHz | |
42.960 MHz | |
43.000 MHz | |
43.020 MHz | |
43.060 MHz | |
43.080 MHz | |
43.100 MHz | |
43.120 MHz | |
43.140 MHz | |
43.180 MHz | |
43.280 MHz | |
43.320 MHz | |
43.360 MHz | |
43.400 MHz | |
43.440 MHz | |
43.480 MHz | |
43.520 MHz | |
43.700 MHz | |
43.760 MHz | |
43.780 MHz | |
43.860 MHz | |
43.880 MHz | |
43.900 MHz | |
43.940 MHz | |
44.000 MHz | |
44.020 MHz | |
44.040 MHz | |
44.060 MHz | |
44.080 MHz | |
44.140 MHz | |
44.220 MHz | |
44.240 MHz | |
44.260 MHz | |
44.280 MHz | |
44.300 MHz | |
44.340 MHz | |
44.380 MHz | |
44.420 MHz | |
44.440 MHz | |
44.500 MHz | |
44.520 MHz | |
44.540 MHz | |
44.560 MHz | |
44.580 MHz | BNSF Railroad telemetry datalink system |
44.600 MHz | |
47.440 MHz | |
47.480 MHz | |
47.520 MHz | |
47.560 MHz | |
47.600 MHz | |
47.640 MHz | |
47.680 MHz | |
47.700 MHz | |
47.720 MHz | |
47.740 MHz | |
47.760 MHz | |
47.780 MHz | |
47.800 MHz | |
47.820 MHz | |
47.840 MHz | |
47.860 MHz | |
47.880 MHz | |
47.900 MHz | |
47.920 MHz | |
47.940 MHz | |
47.960 MHz | |
47.980 MHz | |
48.000 MHz | |
48.020 MHz | |
48.040 MHz | |
48.060 MHz | |
48.080 MHz | |
48.100 MHz | |
48.120 MHz | |
48.140 MHz | |
48.160 MHz | |
48.180 MHz | |
48.200 MHz | |
48.220 MHz | |
48.240 MHz | |
48.260 MHz | |
48.280 MHz | |
48.300 MHz | |
48.320 MHz | |
48.340 MHz | |
48.360 MHz | |
48.380 MHz | |
48.400 MHz | |
48.420 MHz | |
48.440 MHz | |
48.480 MHz | |
48.500 MHz | |
48.520 MHz | |
48.540 MHz | |
48.560 MHz | |
48.580 MHz | |
48.600 MHz | |
48.620 MHz | |
48.640 MHz | |
48.660 MHz | |
48.680 MHz | |
48.700 MHz | |
48.720 MHz | |
48.740 MHz | |
48.760 MHz | |
48.780 MHz | |
48.800 MHz | |
48.820 MHz | |
48.840 MHz | |
48.860 MHz | |
48.880 MHz | |
48.900 MHz | |
48.920 MHz | |
48.940 MHz | |
48.960 MHz | |
48.980 MHz | |
49.000 MHz | |
49.020 MHz | |
49.040 MHz | |
49.060 MHz | |
49.080 MHz | |
49.100 MHz | |
49.120 MHz | |
49.140 MHz | |
49.160 MHz | |
49.180 MHz | |
49.200 MHz | |
49.220 MHz | |
49.240 MHz | |
49.260 MHz | |
49.280 MHz | |
49.300 MHz | |
49.320 MHz | |
49.340 MHz | |
49.360 MHz | |
49.380 MHz | |
49.400 MHz | |
49.420 MHz | |
49.440 MHz | |
49.480 MHz | |
49.500 MHz | |
49.520 MHz | |
49.540 MHz | |
49.560 MHz | |
49.580 MHz |
Frequency (MHz) |
72.020 MHz |
72.040 MHz |
72.060 MHz |
72.080 MHz - shared with RC |
72.100 MHz |
72.120 MHz |
72.140 MHz |
72.160 MHz - shared with RC |
72.180 MHz |
72.200 MHz |
72.220 MHz |
72.240 MHz - shared with RC |
72.260 MHz |
72.280 MHz |
72.300 MHz |
72.320 MHz - shared with RC |
72.340 MHz |
72.360 MHz |
72.380 MHz |
72.400 MHz - shared with RC |
152.4725 MHz | |
154.4825 MHz | |
154.490 MHz | |
154.4975 MHz | |
154.515 MHz | |
154.5275 MHz | Mobiles |
154.53375 MHz | Fixed point-to-point data (SCADA, telemetry, etc.) - super narrow band only 6.25 kHz channel |
154.540 MHz | |
154.5475 MHz | |
154.555 MHz | |
154.625 MHz | Fixed stations for paging systems, low power mobile stations also permitted |
157.7325 MHz | |
158.4525 MHz | |
158.460 MHz | |
169.425 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
169.450 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
169.475 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
169.500 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
169.525 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
170.225 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
170.250 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
170.275 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
170.300 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
170.325 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
171.025 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
171.050 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
171.075 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
171.100 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
171.125 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
171.825 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
171.850 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
171.875 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
171.900 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
171.925 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
173.210 MHz | 6.25 kHz channel step from 173.20375 MHz, see note below |
173.225 MHz | note odd channel steps, 15 kHz from 173.21 MHz to 173.225 MHz, then 12.5 kHz steps start |
173.2375 MHz | |
173.250 MHz | |
173.2625 MHz | |
173.275 MHz | |
173.2875 MHz | |
173.300 MHz | |
173.3125 MHz | |
173.325 MHz | |
173.3375 MHz | |
173.350 MHz | |
173.3625 MHz | |
173.375 MHz | end of 12.5 kHz steps - 15 kHz channel step from 173.375 MHz to 173.39 MHz |
173.390 MHz | |
173.39625 MHz | Data, telemetry etc. (SCADA) only - 3 kHz bandwidth, 6.25 kHz channel step from 173.39 MHz |
UHF Band 406-413 MHz
406.125 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
406.175 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
409.675 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
409.725 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
412.625 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
412.675 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
412.725 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
412.775 MHz | Fixed stations, limited to transmitting hydrological or meteorological data |
- 451.18125 MHz
- 451.1875 MHz
- 451.19375 MHz
- 451.28125 MHz
- 451.2875 MHz
- 451.29375 MHz
- 451.30625 MHz
- 451.3125 MHz
- 451.31875 MHz
- 451.35625 MHz
- 451.3625 MHz
- 451.36875 MHz
- 451.38125 MHz
- 451.3875 MHz
- 451.39375 MHz
- 451.40625 MHz
- 451.41875 MHz
- 451.45625 MHz
- 451.4625 MHz
- 451.46875 MHz
- 451.48125 MHz
- 451.4875 MHz
- 451.49375 MHz
- 451.50625 MHz
- 451.5125 MHz
- 451.51875 MHz
- 451.55625 MHz
- 451.5625 MHz
- 451.56875 MHz
- 451.58125 MHz
- 451.5875 MHz
- 451.59375 MHz
- 451.60625 MHz
- 451.6125 MHz
- 451.61875 MHz
- 451.65625 MHz
- 451.6625 MHz
- 451.66875 MHz
- 451.68125 MHz
- 451.6875 MHz
- 451.69375 MHz
- 451.70625 MHz
- 451.7125 MHz
- 451.71875 MHz
- 451.73125 MHz
- 451.7375 MHz
- 451.74375 MHz
- 451.75625 MHz
- 451.7625 MHz
- 451.76875 MHz
- 452.03125 MHz
- 452.0375 MHz
- 452.04375 MHz
- 452.05625 MHz
- 452.0625 MHz
- 452.06875 MHz
- 452.08125 MHz
- 452.0875 MHz
- 452.09375 MHz
- 452.10625 MHz
- 452.1125 MHz
- 452.11875 MHz
- 452.13125 MHz
- 452.1375 MHz
- 452.14375 MHz
- 452.15625 MHz
- 452.1625 MHz
- 452.16875 MHz
- 452.18125 MHz
- 452.1875 MHz
- 452.19375 MHz
- 452.28125 MHz
- 452.2875 MHz
- 452.29375 MHz
- 452.48125 MHz
- 452.4875 MHz
- 452.49375 MHz
- 452.53125 MHz
- 452.5375 MHz
- 452.54375 MHz
- 452.63125 MHz
- 452.6375 MHz
- 452.64375 MHz
- 452.65625 MHz
- 452.6625 MHz
- 452.66875 MHz
- 452.68125 MHz
- 452.6875 MHz
- 452.69375 MHz
- 452.70625 MHz
- 452.7125 MHz
- 452.71875 MHz
- 452.78125 MHz
- 452.7875 MHz
- 452.79375 MHz
- 452.80625 MHz
- 452.8125 MHz
- 452.81875 MHz
- 452.83125 MHz
- 452.8375 MHz
- 452.84375 MHz
- 452.88125 MHz
- 452.8875 MHz
- 452.89375 MHz
- 452.98125 MHz
- 452.9875 MHz
- 452.99375 MHz
- 456.18125 MHz
- 456.1875 MHz
- 456.19375 MHz
- 456.28125 MHz
- 456.2875 MHz
- 456.29375 MHz
- 456.30625 MHz
- 456.3125 MHz
- 456.31875 MHz
- 456.35625 MHz
- 456.3625 MHz
- 456.36875 MHz
- 456.38125 MHz
- 456.3875 MHz
- 456.39375 MHz
- 456.40625 MHz
- 456.41875 MHz
- 456.45625 MHz
- 456.4625 MHz
- 456.46875 MHz
- 456.48125 MHz
- 456.4875 MHz
- 456.49375 MHz
- 456.50625 MHz
- 456.5125 MHz
- 456.51875 MHz
- 456.55625 MHz
- 456.5625 MHz
- 456.56875 MHz
- 456.58125 MHz
- 456.5875 MHz
- 456.59375 MHz
- 456.60625 MHz
- 456.6125 MHz
- 456.61875 MHz
- 456.65625 MHz
- 456.6625 MHz
- 456.66875 MHz
- 456.68125 MHz
- 456.6875 MHz
- 456.69375 MHz
- 456.70625 MHz
- 456.7125 MHz
- 456.71875 MHz
- 456.73125 MHz
- 456.7375 MHz
- 456.74375 MHz
- 456.75625 MHz
- 456.7625 MHz
- 456.76875 MHz
- 457.03125 MHz
- 457.0375 MHz
- 457.04375 MHz
- 457.05625 MHz
- 457.0625 MHz
- 457.06875 MHz
- 457.08125 MHz
- 457.0875 MHz
- 457.09375 MHz
- 457.10625 MHz
- 457.1125 MHz
- 457.11875 MHz
- 457.13125 MHz
- 457.1375 MHz
- 457.14375 MHz
- 457.15625 MHz
- 457.1625 MHz
- 457.16875 MHz
- 457.18125 MHz
- 457.1875 MHz
- 457.19375 MHz
- 457.28125 MHz
- 457.2875 MHz
- 457.29375 MHz
- 457.48125 MHz
- 457.4875 MHz
- 457.49375 MHz
- 457.63125 MHz
- 457.6375 MHz
- 457.64375 MHz
- 457.65625 MHz
- 457.6625 MHz
- 457.66875 MHz
- 457.68125 MHz
- 457.6875 MHz
- 457.69375 MHz
- 457.70625 MHz
- 457.7125 MHz
- 457.71875 MHz
- 457.78125 MHz
- 457.7875 MHz
- 457.79375 MHz
- 457.80625 MHz
- 457.8125 MHz
- 457.81875 MHz
- 457.83125 MHz
- 457.8375 MHz
- 457.84375 MHz
- 457.88125 MHz
- 457.8875 MHz
- 457.89375 MHz
- 457.98125 MHz
- 457.9875 MHz
- 457.99375 MHz
- 462.18125 MHz
- 462.1875 MHz
- 462.19375 MHz
- 462.45625 MHz
- 462.4625 MHz
- 462.46875 MHz
- 462.48125 MHz
- 462.4875 MHz
- 462.49375 MHz
- 462.50625 MHz
- 462.5125 MHz
- 462.51875 MHz
- 467.18125 MHz
- 467.1875 MHz
- 467.19375 MHz
- 467.45625 MHz
- 467.4625 MHz
- 467.46875 MHz
- 467.48125 MHz
- 467.4875 MHz
- 467.49375 MHz
- 467.50625 MHz
- 467.5125 MHz
- 467.51875 MHz
- 451.23125 MHz
- 451.2375 MHz
- 451.24375 MHz
- 451.33125 MHz
- 451.3375 MHz
- 451.34375 MHz
- 451.43125 MHz
- 451.4375 MHz
- 451.44375 MHz
- 451.53125 MHz
- 451.5375 MHz
- 451.54375 MHz
- 451.63125 MHz
- 451.6375 MHz
- 451.64375 MHz
- 452.30625 MHz
- 452.3125 MHz
- 452.31875 MHz
- 452.40625 MHz
- 452.4125 MHz
- 452.41875 MHz
- 452.50625 MHz
- 452.5125 MHz
- 452.51875 MHz
- 452.75625 MHz
- 452.7625 MHz
- 452.76875 MHz
- 452.85625 MHz
- 452.8625 MHz
- 452.86875 MHz
- 456.23125 MHz
- 456.2375 MHz
- 456.24375 MHz
- 456.33125 MHz
- 456.3375 MHz
- 456.34375 MHz
- 456.43125 MHz
- 456.4375 MHz
- 456.44375 MHz
- 456.53125 MHz
- 456.5375 MHz
- 456.54375 MHz
- 456.63125 MHz
- 456.6375 MHz
- 456.64375 MHz
- 457.30625 MHz
- 457.3125 MHz
- 457.31875 MHz
- 457.40625 MHz
- 457.4125 MHz
- 457.41875 MHz
- 457.50625 MHz
- 457.5125 MHz
- 457.51875 MHz
- 457.75625 MHz
- 457.7625 MHz
- 457.76875 MHz
- 457.85625 MHz
- 457.8625 MHz
- 457.86875 MHz
- 462.20625 MHz
- 462.2125 MHz
- 462.21875 MHz
- 462.23125 MHz
- 462.2375 MHz
- 462.24375 MHz
- 462.25625 MHz
- 462.2625 MHz
- 462.26875 MHz
- 462.28125 MHz
- 462.2875 MHz
- 462.29375 MHz
- 462.30625 MHz
- 462.3125 MHz
- 462.31875 MHz
- 462.33125 MHz
- 462.3375 MHz
- 462.34375 MHz
- 462.35625 MHz
- 462.3625 MHz
- 462.36875 MHz
- 462.38125 MHz
- 462.3875 MHz
- 462.39375 MHz
- 462.40625 MHz
- 462.4125 MHz
- 462.41875 MHz
- 462.43125 MHz
- 462.4375 MHz
- 462.44375 MHz
- 467.20625 MHz
- 467.2125 MHz
- 467.21875 MHz
- 467.23125 MHz
- 467.2375 MHz
- 467.24375 MHz
- 467.25625 MHz
- 467.2625 MHz
- 467.26875 MHz
- 467.28125 MHz
- 467.2875 MHz
- 467.29375 MHz
- 467.30625 MHz
- 467.3125 MHz
- 467.31875 MHz
- 467.33125 MHz
- 467.3375 MHz
- 467.34375 MHz
- 467.35625 MHz
- 467.3625 MHz
- 467.36875 MHz
- 467.38125 MHz
- 467.3875 MHz
- 467.39375 MHz
- 467.40625 MHz
- 467.4125 MHz
- 467.41875 MHz
- 467.43125 MHz
- 467.4375 MHz
- 467.44375 MHz
- 461.03125 MHz
- 461.0375 MHz
- 461.04375 MHz
- 461.05625 MHz
- 461.0625 MHz
- 461.06875 MHz
- 461.08125 MHz
- 461.0875 MHz
- 461.09375 MHz
- 461.10625 MHz
- 461.1125 MHz
- 461.11875 MHz
- 461.13125 MHz
- 461.1375 MHz
- 461.14375 MHz
- 461.15625 MHz
- 461.1625 MHz
- 461.16875 MHz
- 461.18125 MHz
- 461.1875 MHz
- 461.19375 MHz
- 461.20625 MHz
- 461.2125 MHz
- 461.21875 MHz
- 461.23125 MHz
- 461.2375 MHz
- 461.24375 MHz
- 461.25625 MHz
- 461.2625 MHz
- 461.26875 MHz
- 461.28125 MHz
- 461.2875 MHz
- 461.29375 MHz
- 461.30625 MHz
- 461.3125 MHz
- 461.31875 MHz
- 461.33125 MHz
- 461.3375 MHz
- 461.34375 MHz
- 461.35625 MHz
- 461.3625 MHz
- 461.36875 MHz
- 462.7625 MHz
- 462.7875 MHz
- 462.8125 MHz
- 462.8375 MHz
- 462.8625 MHz
- 462.8875 MHz
- 462.9125 MHz
- 464.4875 MHz
- 464.48125 MHz
- 464.5125 MHz
- 464.51875 MHz
- 464.53125 MHz
- 464.5375 MHz
- 464.5625 MHz
- 464.56875 MHz
- 466.03125 MHz
- 466.0375 MHz
- 466.04375 MHz
- 466.05625 MHz
- 466.0625 MHz
- 466.06875 MHz
- 466.08125 MHz
- 466.0875 MHz
- 466.09375 MHz
- 466.10625 MHz
- 466.1125 MHz
- 466.11875 MHz
- 466.13125 MHz
- 466.1375 MHz
- 466.14375 MHz
- 466.15625 MHz
- 466.1625 MHz
- 466.16875 MHz
- 466.18125 MHz
- 466.1875 MHz
- 466.19375 MHz
- 466.20625 MHz
- 466.2125 MHz
- 466.21875 MHz
- 466.23125 MHz
- 466.2375 MHz
- 466.24375 MHz
- 466.25625 MHz
- 466.2625 MHz
- 466.26875 MHz
- 466.28125 MHz
- 466.2875 MHz
- 466.29375 MHz
- 466.30625 MHz
- 466.3125 MHz
- 466.31875 MHz
- 466.33125 MHz
- 466.3375 MHz
- 466.34375 MHz
- 466.35625 MHz
- 466.3625 MHz
- 466.36875 MHz
- 467.8625 MHz
- 467.8875 MHz
- 467.9125 MHz
- 469.4875 MHz
- 469.48125 MHz
- 469.5125 MHz
- 469.51875 MHz
- 469.53125 MHz
- 469.5375 MHz
- 469.5625 MHz
- 469.56875 MHz
- 460.90625 MHz
- 460.9125 MHz
- 460.91875 MHz
- 460.93125 MHz
- 460.9375 MHz
- 460.94375 MHz
- 460.95625 MHz
- 460.9625 MHz
- 460.96875 MHz
- 460.98125 MHz
- 460.9875 MHz
- 460.99375 MHz
- 461.00625 MHz
- 461.0125 MHz
- 461.01875 MHz
- 465.90625 MHz
- 465.9125 MHz
- 465.91875 MHz
- 465.93125 MHz
- 465.9375 MHz
- 465.94375 MHz
- 465.95625 MHz
- 465.9625 MHz
- 465.96875 MHz
- 465.98125 MHz
- 465.9875 MHz
- 465.99375 MHz
- 466.00625 MHz
- 466.0125 MHz
- 466.01875 MHz
- one set of 68 channel pairs
- 160 available channel pairs
- 22 available channel pairs
902-928 MHz | 900 MHz ISM band, subject to restrictions of this band, on-site 900 MHz ISM FHSS radios 1 watt power output |
- 151.5125 MHz - Itinerant
- 151.6550 MHz
- 151.6850 MHz
- 151.7150 MHz
- 151.7450 MHz
- 151.7750 MHz
- 151.8050 MHz
- 151.8350 MHz
- 151.8650 MHz
- 151.8950 MHz
- 151.9250 MHz
- 151.9550 MHz - Purple Dot
- 152.8850 MHz
- 152.9000 MHz
- 152.9150 MHz
- 152.9450 MHz
- 153.0050 MHz
- 154.4900 MHz
- 154.5150 MHz
- 154.5400 MHz
- 154.5475 MHz
- 158.4000 MHz - Itinerant
- 158.4075 MHz - Itinerant
- 451.1875 MHz
- 451.2375 MHz
- 451.2875 MHz
- 451.3375 MHz
- 451.4375 MHz
- 451.5375 MHz
- 451.6375 MHz
- 452.3125 MHz
- 452.4125 MHz
- 452.5125 MHz
- 452.5375 MHz
- 452.7625 MHz
- 452.8625 MHz
- 456.1875 MHz
- 456.2375 MHz
- 456.2875 MHz
- 456.3375 MHz
- 456.4375 MHz
- 456.5375 MHz
- 456.6375 MHz
- 457.3125 MHz
- 457.4125 MHz
- 457.5125 MHz
- 457.6375 MHz
- 457.6625 MHz
- 457.7125 MHz
- 457.7375 MHz
- 457.7625 MHz
- 457.8625 MHz
- 461.0375 MHz
- 461.0625 MHz
- 461.0875 MHz
- 461.1125 MHz
- 461.1375 MHz
- 461.1625 MHz
- 461.1875 MHz
- 461.2125 MHz
- 461.2375 MHz
- 461.2625 MHz
- 461.2875 MHz
- 461.3125 MHz
- 461.3375 MHz
- 461.3625 MHz
- 462.1875 MHz
- 462.2125 MHz
- 462.2375 MHz
- 462.2625 MHz
- 462.2875 MHz
- 462.3125 MHz
- 462.3375 MHz
- 462.3625 MHz
- 462.3875 MHz
- 462.4125 MHz
- 462.4375 MHz
- 462.4625 MHz
- 462.4875 MHz
- 462.5125 MHz
- 463.2125 MHz
- 463.2625 MHz
- 463.3125 MHz
- 463.3375 MHz
- 463.3625 MHz
- 463.4125 MHz
- 463.4625 MHz
- 463.5125 MHz
- 463.5625 MHz
- 463.5875 MHz
- 463.6125 MHz
- 463.6375 MHz
- 464.4875 MHz - Itinerant
- 464.5125 MHz - Itinerant
- 464.5375 MHz - Itinerant
- 464.5625 MHz - Itinerant
- 466.0375 MHz
- 466.0625 MHz
- 466.0875 MHz
- 466.1125 MHz
- 466.1375 MHz
- 466.1625 MHz
- 466.1875 MHz
- 466.2125 MHz
- 466.2375 MHz
- 466.2625 MHz
- 466.2875 MHz
- 466.3125 MHz
- 466.3375 MHz
- 466.3625 MHz
- 467.1875 MHz
- 467.2125 MHz
- 467.2375 MHz
- 467.2625 MHz
- 467.2875 MHz
- 467.3125 MHz
- 467.3375 MHz
- 467.3625 MHz
- 467.3875 MHz
- 467.4125 MHz
- 467.4375 MHz
- 467.4625 MHz
- 467.4875 MHz
- 467.5125 MHz
- 467.7875 MHz - 2 watts
- 467.8375 MHz - 2 watts
- 467.8625 MHz - 2 watts
- 467.8875 MHz - 2 watts
- 467.9125 MHz - 2 watts
- 468.2125 MHz
- 468.2625 MHz
- 468.3125 MHz
- 468.3375 MHz
- 468.3625 MHz
- 468.4125 MHz
- 468.4625 MHz
- 468.5125 MHz
- 468.5625 MHz
- 468.5875 MHz
- 468.6125 MHz
- 468.6375 MHz
- 469.4875 MHz - Itinerant
- 469.5125 MHz - Itinerant
- 469.5375 MHz - Itinerant
- 469.5625 MHz - Itinerant
- 464.5500 MHz
- 464.5000 MHz
- 467.9250 MHz
- 467.9000 MHz
- 467.8750 MHz
- 467.8500 MHz
- 469.5500 MHz
- 469.5000 MHz
- 461.0375 MHz
- 461.1125 MHz
- 461.1375 MHz
- 461.2375 MHz
- 467.8125 MHz
- 467.7625 MHz
- 451.8000 MHz
- 456.8000 MHz
- 451.8125 MHz
- 456.8125 MHz
- 151.6250 MHz
- 154.5700 MHz
- 154.6000 MHz
- 151.9550 MHz
- 151.5125 MHz
- 151.5050 MHz
- 151.7000 MHz
- 151.7600 MHz
- 151.8200 MHz
- 151.9400 MHz
- 151.8800 MHz
- 151.9250 MHz
- 151.8050 MHz
- 158.4000 MHz
- 158.4075 MHz
- 151.6550 MHz
- 151.8650 MHz
- 152.9000 MHz
- On Baofeng radios, CTCSS (PL or QT) is set under the R-CTCS and T-CTCS settings (both should be the same for transmit and receive tone squelch). Programming a CTCSS code for transmit only will leave the radio in carrier squelch receive (CSQ) mode, and all signals on a given channel will be heard. For all radios to talk to each other and reduce interference effectively, the R-CTCS and T-CTCS codes must match exactly. For example, if programming radios to use CTCSS tone 123.0 Hz, all radios must have their T-CTCS and R-CTCS set to 123.0HZ.
- On Baofeng radios, DCS (DPL or DQT) is set under the R-DCS and T-DCS settings (both should be the same for transmit and receive code squelch). Programming a DCS code for transmit only will leave the radio in carrier squelch receive (CSQ) mode, and all signals on a given channel will be heard. For all radios to talk to each other and reduce interference effectively, the R-DCS and T-DCS codes must match exactly. For example, if programming radios to use DCS code 243, all radios must have their T-DCS set to D243N and their R-DCS set to D243N. Use of inverted DCS tones is not recommended. D243I is not the same as D243N.
- It is possible to alternate between DCS and CTCSS from one channel to another, but this can quickly become complicated if programming a fleet of radios. For this reason, it is recommended that you stick with one code or tone, or a set of 2-3 codes/tones for an entire channel plan. CTCSS (PL or QT) is preferred over DCS (DPL or DQT).
- Channel 3 - 462.6125 MHz
- Channel 4 - 462.6375 MHz
- Channel 5 - 462.6625 MHz
- Channel 6 - 462.6875 MHz
- Channel 7 - 462.7125 MHz
- Channel 8 - 467.5625 MHz
- Channel 9 - 467.5875 MHz
- Channel 10 - 467.6125 MHz
- Channel 11 - 467.6375 MHz
- Channel 12 - 467.6625 MHz
- Channel 13 - 467.6875 MHz
- Channel 14 - 467.7125 MHz
- Channel 15 - 462.5500 MHz
- Channel 16 - 462.5750 MHz
- Channel 17 - 462.6000 MHz
- Channel 18 - 462.6250 MHz
- Channel 19 - 462.6500 MHz
- Channel 20 - 462.6750 MHz
- Channel 21 - 462.7000 MHz
- Channel 22 - 462.7250 MHz
- Channel 1 - 446.00625 MHz
- Channel 2 - 446.01875 MHz
- Channel 3 - 446.03125 MHz
- Channel 4 - 446.04375 MHz
- Channel 5 - 446.05625 MHz
- Channel 6 - 446.06875 MHz
- Channel 7 - 446.08125 MHz
- Channel 8 - 446.09375 MHz
- Channel 9 - 446.10625 MHz
- Channel 10 - 446.11875 MHz
- Channel 11 - 446.13125 MHz
- Channel 12 - 446.14375 MHz
- Channel 13 - 446.15625 MHz
- Channel 14 - 446.16875 MHz
- Channel 15 - 446.18125 MHz
- Channel 16 - 446.19375 MHz
Retevis RT30
Default Channel Frequency
Retevis RT30
Retevis RT30M
- Channel 15 - 460.3250 CSQ
Retevis RT1-UHF RT1 RT-1
- Channel 12 - 465.5250 MHz 031 DPL
- Channel 13 - 463.5650 MHz 051 DPL
- Channel 14 - 465.7250 MHz 065 DPL
- Channel 15 - 463.7650 MHz 125 DPL
- Channel 16 - 465.9250 MHz 152 DPL
Retevis RT1-VHF RT1 RT-1
- Channel 6 - 144.6750 MHz 023 DPL
- Channel 7 - 144.7750 MHz 023 DPL
Retevis RT-24 FRS 16 channel
Retevis RT-27V MURS VHF
Retevis RT-47V MURS VHF
- Channel 1 - 462.5625 MHz 043 DPL
- Channel 2 - 462.5875 MHz 065 DPL
- Channel 3 - 462.6125 MHz 116 DPL
- Channel 4 - 462.6375 MHz 205 DPL
- Channel 5 - 462.6625 MHz 261 DPL
- Channel 6 - 462.6875 MHz 265 DPL
- Channel 7 - 462.7125 MHz 271 DPL
- Channel 8 - 467.5625 MHz 306 DPL
- Channel 9 - 467.5875 MHz 311 DPL
- Channel 10 - 467.6125 MHz 331 DPL
- Channel 11 - 467.6375 MHz 365 DPL
- Channel 12 - 467.6625 MHz 431 DPL
- Channel 13 - 467.6875 MHz 466 DPL
- Channel 14 - 467.7125 MHz 503 DPL
- Channel 1 - 446.00625 MHz 114 DPL
- Channel 2 - 446.01875 MHz 131 DPL
- Channel 3 - 446.03125 MHz 132 DPL
- Channel 4 - 446.04375 MHz 165 DPL
- Channel 5 - 446.05625 MHz 226 DPL
- Channel 6 - 446.06875 MHz 306 DPL
- Channel 7 - 446.08125 MHz 371 DPL
- Channel 8 - 446.09375 MHz 503 DPL
- Channel 1 - 400.1250 MHz
- Channel 2 - 410.1250 MHz
- Channel 3 - 420.1250 MHz
- Channel 4 - 430.1250 MHz
- Channel 5 - 440.1250 MHz
- Channel 6 - 450.1250 MHz
- Channel 7 - 460.1250 MHz
- Channel 8 - 470.1250 MHz
- Channel 9 - 480.1250 MHz
- Channel 10 - 490.1250 MHz
- Channel 11 - 500.1250 MHz
- Channel 12 - 510.1250 MHz
- Channel 13 - 519.9750 MHz
- Channel 14 - 136.1250 MHz
- Channel 15 - 145.1250 MHz
- Channel 16 - 155.1250 MHz
- Channel 17 - 165.1250 MHz
- Channel 18 - 173.9750 MHz
- Freq 1 - 464.5000 MHz
- Freq 2 - 464.5500 MHz
- Freq 3 - 467.7625 MHz
- Freq 4 - 467.8125 MHz
- Freq 5 - 467.8500 MHz
- Freq 6 - 467.8750 MHz
- Freq 7 - 467.9000 MHz
- Freq 8 - 467.9250 MHz
- Freq 9 - 461.0375 MHz
- Freq 10 - 461.0625 MHz
- Freq 11 - 461.0875 MHz
- Freq 12 - 461.1125 MHz
- Freq 13 - 461.1375 MHz
- Freq 14 - 461.1625 MHz
- Freq 15 - 461.1875 MHz
- Freq 16 - 461.2125 MHz
- Freq 17 - 461.2375 MHz
- Freq 18 - 461.2625 MHz
- Freq 19 - 461.2875 MHz
- Freq 20 - 461.3125 MHz
- Freq 21 - 461.3375 MHz
- Freq 22 - 461.3625 MHz
- Freq 23 - 462.7625 MHz
- Freq 24 - 462.7875 MHz
- Freq 25 - 462.8125 MHz
- Freq 26 - 462.8375 MHz
- Freq 27 - 462.8625 MHz
- Freq 28 - 462.8875 MHz
- Freq 29 - 462.9125 MHz
- Freq 30 - 464.4875 MHz
- Freq 31 - 464.5125 MHz
- Freq 32 - 464.5375 MHz
- Freq 33 - 464.5625 MHz
- Freq 34 - 466.0375 MHz
- Freq 35 - 466.0625 MHz
- Freq 36 - 466.0875 MHz
- Freq 37 - 466.1125 MHz
- Freq 38 - 466.1375 MHz
- Freq 39 - 466.1625 MHz
- Freq 40 - 466.1875 MHz
- Freq 41 - 466.2125 MHz
- Freq 42 - 466.2375 MHz
- Freq 43 - 466.2625 MHz
- Freq 44 - 466.2875 MHz
- Freq 45 - 466.3125 MHz
- Freq 46 - 466.3375 MHz
- Freq 47 - 466.3625 MHz
- Freq 48 - 467.7875 MHz
- Freq 49 - 467.8375 MHz
- Freq 50 - 467.8625 MHz
- Freq 51 - 467.8875 MHz
- Freq 52 - 467.9125 MHz
- Freq 53 - 469.4875 MHz
- Freq 54 - 469.5125 MHz
- Freq 55 - 469.5375 MHz
- Freq 56 - 469.5625 MHz
- Freq 9 - 462.5750 MHz
- Freq 10 - 462.6250 MHz
- Freq 11 - 462.6750 MHz
- Freq 12 - 464.3250 MHz
- Freq 13 - 464.8250 MHz
- Freq 14 - 469.2625 MHz
- Freq 15 - 469.5000 MHz
- Freq 16 - 469.5500 MHz
- Freq 17 - 462.7625 MHz
- Freq 18 - 462.7875 MHz
- Freq 19 - 462.8125 MHz
- Freq 20 - 462.8375 MHz
- Freq 21 - 462.8625 MHz
- Freq 22 - 462.8875 MHz
- Freq 23 - 462.9125 MHz
- Freq 24 - 464.4875 MHz
- Freq 25 - 461.0375 MHz
- Freq 26 - 461.0625 MHz
- Freq 27 - 461.0875 MHz
- Freq 28 - 461.1125 MHz
- Freq 29 - 461.1375 MHz
- Freq 30 - 461.1625 MHz
- Freq 31 - 461.1875 MHz
- Freq 32 - 461.2125 MHz
- Freq 33 - 461.2375 MHz
- Freq 34 - 461.2625 MHz
- Freq 35 - 461.2875 MHz
- Freq 36 - 461.3125 MHz
- Freq 37 - 461.3375 MHz
- Freq 38 - 461.3625 MHz
- Freq 39 - 462.7625 MHz
- Freq 40 - 462.7875 MHz
- Freq 41 - 462.8125 MHz
- Freq 42 - 462.8375 MHz
- Freq 43 - 462.8625 MHz
- Freq 44 - 462.8875 MHz
- Freq 45 - 462.9125 MHz
- Freq 46 - 464.4875 MHz
- Freq 47 - 464.5125 MHz
- Freq 48 - 464.5375 MHz
- Freq 49 - 464.5625 MHz
- Freq 50 - 466.0375 MHz
- Freq 51 - 466.0625 MHz
- Freq 52 - 466.0875 MHz
- Freq 53 - 466.1125 MHz
- Freq 54 - 466.1375 MHz
- Freq 55 - 466.1625 MHz
- Freq 56 - 466.1875 MHz
- Freq 1 - 151.6250 MHz
- Freq 2 - 151.9550 MHz
- Freq 3 - 154.5700 MHz
- Freq 4 - 154.6000 MHz
- Freq 5 - 151.7000 MHz
- Freq 6 - 151.7600 MHz
- Freq 7 - 151.8200 MHz
- Freq 8 - 151.8800 MHz
- Freq 9 - 151.9400 MHz
- Freq 10 - 151.5125 MHz
- Freq 11 - 151.6550 MHz
- Freq 12 - 151.6850 MHz
- Freq 13 - 151.7150 MHz
- Freq 14 - 151.7450 MHz
- Freq 15 - 151.7750 MHz
- Freq 16 - 151.8650 MHz
- Freq 17 - 151.8950 MHz
- Freq 18 - 151.9250 MHz
- Freq 20 - 154.4900 MHz
- Freq 21 - 154.5150 MHz
- Freq 22 - 154.5275 MHz
- Freq 23 - 154.5400 MHz
- Freq 24 - 154.6000 MHz
- Freq 26 - 158.4000 MHz
- Freq 27 - 158.4075 MHz
- Freq 57 - 462.1875 MHz
- Freq 58 - 462.4625 MHz
- Freq 59 - 462.4875 MHz
- Freq 60 - 462.5125 MHz
- Freq 61 - 467.1875 MHz
- Freq 62 - 467.4625 MHz
- Freq 63 - 467.4875 MHz
- Freq 64 - 467.5125 MHz
- Freq 65 - 451.1875 MHz
- Freq 66 - 451.2375 MHz
- Freq 67 - 451.2875 MHz
- Freq 68 - 451.3375 MHz
- Freq 69 - 451.4375 MHz
- Freq 70 - 451.5375 MHz
- Freq 71 - 451.6375 MHz
- Freq 72 - 452.3125 MHz
- Freq 73 - 452.5375 MHz
- Freq 74 - 452.4125 MHz
- Freq 75 - 452.5125 MHz
- Freq 76 - 452.7625 MHz
- Freq 77 - 452.8625 MHz
- Freq 78 - 456.1875 MHz
- Freq 79 - 456.2375 MHz
- Freq 80 - 456.2875 MHz
- Freq 81 - 468.2125 MHz
- Freq 82 - 468.2625 MHz
- Freq 83 - 468.3125 MHz
- Freq 84 - 468.3625 MHz
- Freq 85 - 468.4125 MHz
- Freq 86 - 468.4625 MHz
- Freq 87 - 468.5125 MHz
- Freq 88 - 468.5625 MHz
- Freq 89 - 468.6125 MHz
- Freq 90 - 468.6625 MHz
- Freq 81 - 456.3375 MHz
- Freq 82 - 456.4375 MHz
- Freq 83 - 456.5375 MHz
- Freq 84 - 456.6375 MHz
- Freq 85 - 457.3125 MHz
- Freq 86 - 457.4125 MHz
- Freq 87 - 457.5125 MHz
- Freq 88 - 457.7625 MHz
- Freq 89 - 457.8625 MHz
- Freq 3 - 152.8850 MHz
- Freq 4 - 152.9150 MHz
- Freq 7 - 152.9450 MHz
- Freq 8 - 151.8350 MHz
- Freq 9 - 151.8050 MHz
- Freq 24 - 153.0050 MHz
- Freq 0 - OFF (BLANK)
- Code 1 - 67.0 Hz PL - XZ
- Code 2 - 71.9 Hz PL - XA
- Code 3 - 74.4 Hz PL - WA
- Code 4 - 77.0 Hz PL - XB
- Code 5 - 79.7 Hz PL - WB
- Code 6 - 82.5 Hz PL - YZ
- Code 7 - 85.4 Hz PL - YA
- Code 8 - 88.5 Hz PL - YB
- Code 9 - 91.5 Hz PL - ZZ
- Code 10 - 94.8 Hz PL - ZA
- Code 11 - 97.4 Hz PL - ZB
- Code 12 - 100.0 Hz PL - 1Z
- Code 13 - 103.5 Hz PL - 1A
- Code 14 - 107.2 Hz PL - 1B
- Code 15 - 110.9 Hz PL - 2Z
- Code 16 - 114.8 Hz PL - 2A
- Code 17 - 118.8 Hz PL - 2B
- Code 18 - 123.0 Hz PL - 3Z
- Code 19 - 127.3 Hz PL - 3A
- Code 20 - 131.8 Hz PL - 3B
- Code 21 - 136.5 Hz PL - 4Z
- Code 22 - 141.3 Hz PL - 4A
- Code 23 - 146.2 Hz PL - 4B
- Code 24 - 151.4 Hz PL - 5Z
- Code 25 - 156.7 Hz PL - 5A
- Code 26 - 162.2 Hz PL - 5B
- Code 27 - 167.9 Hz PL - 6Z
- Code 28 - 173.8 Hz PL - 6A
- Code 29 - 179.9 Hz PL - 6B
- Code 30 - 186.2 Hz PL - 7Z
- Code 31 - 192.8 Hz PL - 7A
- Code 32 - 203.5 Hz PL - M1
- Code 33 - 210.7 Hz PL - M2
- Code 34 - 218.1 Hz PL - M3
- Code 35 - 225.7 Hz PL - M4
- Code 36 - 233.6 Hz PL - M5
- Code 37 - 241.8 Hz PL - M6
- Code 38 - 250.3 Hz PL - M7
- Code 39 - 023 DPL
- Code 40 - 025 DPL
- Code 41 - 026 DPL
- Code 42 - 031 DPL
- Code 43 - 032 DPL
- Code 44 - 043 DPL
- Code 45 - 047 DPL
- Code 46 - 051 DPL
- Code 47 - 054 DPL
- Code 48 - 065 DPL
- Code 49 - 071 DPL
- Code 50 - 072 DPL
- Code 51 - 073 DPL
- Code 52 - 074 DPL
- Code 53 - 114 DPL
- Code 54 - 115 DPL
- Code 55 - 116 DPL
- Code 56 - 125 DPL
- Code 57 - 131 DPL
- Code 58 - 132 DPL
- Code 59 - 134 DPL
- Code 60 - 143 DPL
- Code 61 - 152 DPL
- Code 62 - 155 DPL
- Code 63 - 156 DPL
- Code 64 - 162 DPL
- Code 65 - 165 DPL
- Code 66 - 172 DPL
- Code 67 - 174 DPL
- Code 68 - 205 DPL
- Code 69 - 223 DPL
- Code 70 - 226 DPL
- Code 71 - 243 DPL
- Code 72 - 244 DPL
- Code 73 - 245 DPL
- Code 74 - 251 DPL
- Code 75 - 261 DPL
- Code 76 - 263 DPL
- Code 77 - 265 DPL
- Code 78 - 271 DPL
- Code 79 - 306 DPL
- Code 80 - 311 DPL
- Code 81 - 315 DPL
- Code 82 - 331 DPL
- Code 83 - 343 DPL
- Code 84 - 346 DPL
- Code 85 - 351 DPL
- Code 86 - 364 DPL
- Code 87 - 365 DPL
- Code 88 - 371 DPL
- Code 89 - 411 DPL
- Code 90 - 412 DPL
- Code 91 - 413 DPL
- Code 92 - 423 DPL
- Code 93 - 431 DPL
- Code 94 - 432 DPL
- Code 95 - 445 DPL
- Code 96 - 464 DPL
- Code 97 - 465 DPL
- Code 98 - 466 DPL
- Code 99 - 503 DPL
- Code 100 - 506 DPL
- Code 101 - 516 DPL
- Code 102 - 532 DPL
- Code 103 - 546 DPL
- Code 104 - 565 DPL
- Code 105 - 606 DPL
- Code 106 - 612 DPL
- Code 107 - 624 DPL
- Code 108 - 627 DPL
- Code 109 - 631 DPL
- Code 110 - 632 DPL
- Code 111 - 654 DPL
- Code 112 - 662 DPL
- Code 113 - 664 DPL
- Code 114 - 703 DPL
- Code 115 - 712 DPL
- Code 116 - 723 DPL
- Code 117 - 731 DPL
- Code 118 - 732 DPL
- Code 119 - 734 DPL
- Code 120 - 743 DPL
- Code 121 - 754 DPL
- DCS Code 1 - 023 DPL
- DCS Code 2 - 025 DPL
- DCS Code 3 - 026 DPL
- DCS Code 4 - 031 DPL
- DCS Code 5 - 032 DPL
- DCS Code 6 - 043 DPL
- DCS Code 7 - 047 DPL
- DCS Code 8 - 051 DPL
- DCS Code 9 - 054 DPL
- DCS Code 10 - 065 DPL
- DCS Code 11 - 071 DPL
- DCS Code 12 - 072 DPL
- DCS Code 13 - 073 DPL
- DCS Code 14 - 074 DPL
- DCS Code 15 - 114 DPL
- DCS Code 16 - 115 DPL
- DCS Code 17 - 116 DPL
- DCS Code 18 - 125 DPL
- DCS Code 19 - 131 DPL
- DCS Code 20 - 132 DPL
- DCS Code 21 - 134 DPL
- DCS Code 22 - 143 DPL
- DCS Code 23 - 152 DPL
- DCS Code 24 - 155 DPL
- DCS Code 25 - 156 DPL
- DCS Code 26 - 162 DPL
- DCS Code 27 - 165 DPL
- DCS Code 28 - 172 DPL
- DCS Code 29 - 174 DPL
- DCS Code 30 - 205 DPL
- DCS Code 31 - 223 DPL
- DCS Code 32 - 226 DPL
- DCS Code 33 - 243 DPL
- DCS Code 34 - 244 DPL
- DCS Code 35 - 245 DPL
- DCS Code 36 - 251 DPL
- DCS Code 37 - 261 DPL
- DCS Code 38 - 263 DPL
- DCS Code 39 - 265 DPL
- DCS Code 40 - 271 DPL
- DCS Code 41 - 306 DPL
- DCS Code 42 - 311 DPL
- DCS Code 43 - 315 DPL
- DCS Code 44 - 331 DPL
- DCS Code 45 - 343 DPL
- DCS Code 46 - 346 DPL
- DCS Code 47 - 351 DPL
- DCS Code 48 - 364 DPL
- DCS Code 49 - 365 DPL
- DCS Code 50 - 371 DPL
- DCS Code 51 - 411 DPL
- DCS Code 52 - 412 DPL
- DCS Code 53 - 413 DPL
- DCS Code 54 - 423 DPL
- DCS Code 55 - 431 DPL
- DCS Code 56 - 432 DPL
- DCS Code 57 - 445 DPL
- DCS Code 58 - 464 DPL
- DCS Code 59 - 465 DPL
- DCS Code 60 - 466 DPL
- DCS Code 61 - 503 DPL
- DCS Code 62 - 506 DPL
- DCS Code 63 - 516 DPL
- DCS Code 64 - 532 DPL
- DCS Code 65 - 546 DPL
- DCS Code 66 - 565 DPL
- DCS Code 67 - 606 DPL
- DCS Code 68 - 612 DPL
- DCS Code 69 - 624 DPL
- DCS Code 70 - 627 DPL
- DCS Code 71 - 631 DPL
- DCS Code 72 - 632 DPL
- DCS Code 73 - 654 DPL
- DCS Code 74 - 662 DPL
- DCS Code 75 - 664 DPL
- DCS Code 76 - 703 DPL
- DCS Code 77 - 712 DPL
- DCS Code 78 - 723 DPL
- DCS Code 79 - 731 DPL
- DCS Code 80 - 732 DPL
- DCS Code 81 - 734 DPL
- DCS Code 82 - 743 DPL
- DCS Code 83 - 754 DPL
- DCS Code 84 - 036 DPL
- DCS Code 85 - 053 DPL
- DCS Code 86 - 122 DPL
- DCS Code 87 - 145 DPL
- DCS Code 88 - 212 DPL
- DCS Code 89 - 225 DPL
- DCS Code 90 - 246 DPL
- DCS Code 91 - 252 DPL
- DCS Code 92 - 255 DPL
- DCS Code 93 - 266 DPL
- DCS Code 94 - 274 DPL
- DCS Code 95 - 325 DPL
- DCS Code 96 - 332 DPL
- DCS Code 97 - 356 DPL
- DCS Code 98 - 446 DPL
- DCS Code 99 - 452 DPL
- DCS Code 100 - 454 DPL
- DCS Code 101 - 455 DPL
- DCS Code 102 - 462 DPL
- DCS Code 103 - 523 DPL
- DCS Code 104 - 526 DPL
- CTCSS Code 1 - 67.0 Hz
- CTCSS Code 2 - 69.3 Hz
- CTCSS Code 3 - 71.9 Hz
- CTCSS Code 4 - 74.4 Hz
- CTCSS Code 5 - 77.0 Hz
- CTCSS Code 6 - 79.7 Hz
- CTCSS Code 7 - 82.5 Hz
- CTCSS Code 8 - 85.4 Hz
- CTCSS Code 9 - 88.5 Hz
- CTCSS Code 10 - 91.5 Hz
- CTCSS Code 11 - 94.8 Hz
- CTCSS Code 12 - 97.4 Hz
- CTCSS Code 13 - 100.0 Hz
- CTCSS Code 14 - 103.5 Hz
- CTCSS Code 15 - 107.2 Hz
- CTCSS Code 16 - 110.9 Hz
- CTCSS Code 17 - 114.8 Hz
- CTCSS Code 18 - 118.8 Hz
- CTCSS Code 19 - 123.0 Hz
- CTCSS Code 20 - 127.3 Hz
- CTCSS Code 21 - 131.8 Hz
- CTCSS Code 22 - 136.5 Hz
- CTCSS Code 23 - 141.3 Hz
- CTCSS Code 24 - 146.2 Hz
- CTCSS Code 25 - 151.4 Hz
- CTCSS Code 26 - 156.7 Hz
- CTCSS Code 27 - 159.8 Hz
- CTCSS Code 28 - 162.2 Hz
- CTCSS Code 29 - 165.5 Hz
- CTCSS Code 30 - 167.9 Hz
- CTCSS Code 31 - 171.3 Hz
- CTCSS Code 32 - 173.8 Hz
- CTCSS Code 33 - 177.3 Hz
- CTCSS Code 34 - 179.9 Hz
- CTCSS Code 35 - 183.5 Hz
- CTCSS Code 36 - 186.2 Hz
- CTCSS Code 37 - 189.9 Hz
- CTCSS Code 38 - 192.8 Hz
- CTCSS Code 39 - 196.6 Hz
- CTCSS Code 40 - 199.5 Hz
- CTCSS Code 41 - 203.5 Hz
- CTCSS Code 42 - 206.5 Hz
- CTCSS Code 43 - 210.7 Hz
- CTCSS Code 44 - 218.1 Hz
- CTCSS Code 45 - 225.7 Hz
- CTCSS Code 46 - 229.1 Hz
- CTCSS Code 47 - 233.6 Hz
- CTCSS Code 48 - 241.8 Hz
- CTCSS Code 49 - 250.3 Hz
- CTCSS Code 50 - 254.1 Hz
- CTCSS (T-CTCS and R-CTCS)
- 67.0HZ
- 69.3HZ
- 71.9HZ
- 74.4HZ
- 77.0HZ
- 79.7HZ
- 82.5HZ
- 85.4HZ
- 88.5HZ
- 91.5HZ
- 94.8HZ
- 97.4HZ
- 100.0HZ
- 103.5HZ
- 107.2HZ
- 110.9HZ
- 114.8HZ
- 118.8HZ
- 123.0HZ
- 127.3HZ
- 131.8HZ
- 136.5HZ
- 141.3HZ
- 146.2HZ
- 151.4HZ
- 156.7HZ
- 159.8HZ
- 162.2HZ
- 165.5HZ
- 167.9HZ
- 171.3HZ
- 173.8HZ
- 177.3HZ
- 179.9HZ
- 183.5HZ
- 186.2HZ
- 189.9HZ
- 192.8HZ
- 196.6HZ
- 199.5HZ
- 203.5HZ
- 206.5HZ
- 210.7HZ
- 218.1HZ
- 225.7HZ
- 229.1HZ
- 233.6HZ
- 241.8HZ
- 250.3HZ
- 254.1HZ
- DCS 023I decodes as DCS 047
- DCS 025I decodes as DCS 244
- DCS 026I decodes as DCS 464
- DCS 031I decodes as DCS 627
- DCS 032I decodes as DCS 051
- DCS 036I decodes as DCS 172
- DCS 043I decodes as DCS 445
- DCS 047I decodes as DCS 023
- DCS 051I decodes as DCS 032
- DCS 053I decodes as DCS 452
- DCS 054I decodes as DCS 413
- DCS 065I decodes as DCS 271
- DCS 071I decodes as DCS 306
- DCS 072I decodes as DCS 245
- DCS 073I decodes as DCS 506
- DCS 074I decodes as DCS 173
- DCS 114I decodes as DCS 712
- DCS 115I decodes as DCS 152
- DCS 116I decodes as DCS 754
- DCS 122I decodes as DCS 225
- DCS 125I decodes as DCS 365
- DCS 131I decodes as DCS 364
- DCS 132I decodes as DCS 546
- DCS 134I decodes as DCS 223
- DCS 143I decodes as DCS 412
- DCS 145I decodes as DCS 274
- DCS 152I decodes as DCS 115
- DCS 155I decodes as DCS 731
- DCS 156I decodes as DCS 265
- DCS 162I decodes as DCS 503
- DCS 165I decodes as DCS 251
- DCS 172I decodes as DCS 036
- DCS 174I decodes as DCS 074
- DCS 205I decodes as DCS 263
- DCS 212I decodes as DCS 356
- DCS 223I decodes as DCS 134
- DCS 225I decodes as DCS 122
- DCS 226I decodes as DCS 411
- DCS 243I decodes as DCS 351
- DCS 244I decodes as DCS 025
- DCS 245I decodes as DCS 072
- DCS 246I decodes as DCS 523
- DCS 251I decodes as DCS 165
- DCS 252I decodes as DCS 462
- DCS 255I decodes as DCS 446
- DCS 261I decodes as DCS 732
- DCS 263I decodes as DCS 205
- DCS 265I decodes as DCS 156
- DCS 266I decodes as DCS 454
- DCS 271I decodes as DCS 065
- DCS 274I decodes as DCS 145
- DCS 306I decodes as DCS 071
- DCS 311I decodes as DCS 664
- DCS 315I decodes as DCS 423
- DCS 325I decodes as DCS 526
- DCS 331I decodes as DCS 465
- DCS 332I decodes as DCS 455
- DCS 343I decodes as DCS 532
- DCS 346I decodes as DCS 612
- DCS 351I decodes as DCS 243
- DCS 356I decodes as DCS 212
- DCS 365I decodes as DCS 125
- DCS 371I decodes as DCS 734
- DCS 411I decodes as DCS 226
- DCS 412I decodes as DCS 143
- DCS 413I decodes as DCS 054
- DCS 423I decodes as DCS 315
- DCS 431I decodes as DCS 723
- DCS 432I decodes as DCS 516
- DCS 445I decodes as DCS 043
- DCS 446I decodes as DCS 255
- DCS 452I decodes as DCS 053
- DCS 454I decodes as DCS 266
- DCS 455I decodes as DCS 332
- DCS 462I decodes as DCS 252
- DCS 464I decodes as DCS 026
- DCS 465I decodes as DCS 331
- DCS 466I decodes as DCS 662
- DCS 503I decodes as DCS 162
- DCS 506I decodes as DCS 073
- DCS 516I decodes as DCS 432
- DCS 523I decodes as DCS 246
- DCS 546I decodes as DCS 132
- DCS 565I decodes as DCS 703
- DCS 606I decodes as DCS 631
- DCS 612I decodes as DCS 346
- DCS 624I decodes as DCS 632
- DCS 627I decodes as DCS 031
- DCS 631I decodes as DCS 606
- DCS 632I decodes as DCS 624
- DCS 645I decodes as DCS 325
- DCS 654I decodes as DCS 743
- DCS 662I decodes as DCS 466
- DCS 664I decodes as DCS 311
- DCS 703I decodes as DCS 565
- DCS 712I decodes as DCS 431
- DCS 723I decodes as DCS 155
- DCS 731I decodes as DCS 261
- DCS 734I decodes as DCS 371
- DCS 743I decodes as DCS 654
- DCS 754I decodes as DCS 116
*Costco
- VHF:
- 151.6550 MHz
- 151.6850 MHz
- 151.7150 MHz
- 151.7450 MHz
- 151.7750 MHz
- 151.8650 MHz
- 151.8950 MHz
- 151.9250 MHz
- 151.9550 MHz
- 151.9850 MHz
- 152.8850 MHz
- 152.9150 MHz
- 153.0050 MHz
- 154.4900 MHz
- 154.5150 MHz
- 154.5400 MHz
- 468.2125 MHz
- 468.2625 MHz
- 468.3125 MHz
- 468.3625 MHz
- 468.4125 MHz
- 468.4625 MHz
- 468.5125 MHz
- 468.5625 MHz
- 468.6125 MHz
- 468.6625 MHz
- 451.4125 MHz
- 451.5125 MHz
- 451.5375 MHz
- 451.5875 MHz
- 451.6375 MHz
- 451.6625 MHz
- 451.6875 MHz
- 452.7625 MHz
- 456.4125 MHz
- 456.5125 MHz
- 456.6125 MHz
- 456.6875 MHz
- 457.7625 MHz
- 467.7625 MHz
- 467.8125 MHz
- 467.8500 MHz
- 467.8750 MHz
- 467.9000 MHz
- 467.9250 MHz
- 461.0375 MHz 445 DPL
- 467.7625 MHz 743 DPL
- 467.9000 MHz 743 DPL
- 467.8500 MHz Channel 1
- 467.8750 MHz Channel 2
- 467.9000 MHz Channel 3
- 467.9250 MHz Channel 4
- 467.8500 MHz
- 467.8750 MHz
- 467.9000 MHz
- 467.9250 MHz
- 464.5500 MHz - 67.0 Hz PL
- 467.7625 MHz - 107.2 Hz PL
- 467.8125 MHz
- 467.8750 MHz - 343 DPL
- 467.8750 MHz - 411 DPL
- 467.9250 MHz - 67.0 Hz PL
- 467.9250 MHz
- 467.8500 MHz 146.2 Hz PL
- 467.8750 MHz - 100.0 Hz PL
- 467.9000 MHz - 100.0 Hz PL
- 467.9250 MHz - 100.0 Hz PL
- 154.5700 MHz - 110.9 Hz PL
- 154.6000 MHz - 110.9 Hz PL
- 461.0375 MHz
- 461.1125 MHz
- 461.2125 MHz
- 462.7625 MHz
- 462.8125 MHz
- 464.5375 MHz
- 464.5625 MHz
- 466.0375 MHz
- 466.1125 MHz
- 466.1375 MHz
- 469.4875 MHz
- 469.5375 MHz
- 467.9000 MHz - 131 DPL
- 464.5000 MHz - 162.2 Hz PL
- 464.5500 MHz - 162.2 Hz PL
- 464.5500 MHz - 413 DPL
- 467.9000 MHz - 225.7 Hz PL
- 467.9250 MHz - 225.7 Hz PL
- 467.8000 MHz ???? - unknown DCS code / DPL code
- 151.9250 MHz 506 DPL
- 151.8950 MHz 506 DPL
- 151.5050 MHz
- 151.6250 MHz
- 151.7000 MHz
- 151.8200 MHz
- 151.9250 MHz
- 154.5700 MHz
- 154.6000 MHz
- 158.4000 MHz
- 451.8000 MHz
- 451.8125 MHz
- 456.8125 MHz
- 154.5700 MHz - Primary
- 154.6000 MHz - Primary
- 151.8200 MHz
- 151.8800 MHz
- 151.9400 MHz
- 151.6250 MHz
- 151.7600 MHz
- 151.7750 MHz
- 151.8200 MHz
- 151.8350 MHz
- 151.8650 MHz
- 151.9550 MHz
- 461.0375 MHz 172 DPL
- 461.0875 MHz 223 DPL
- 461.1125 MHz 172 DPL
- 461.1875 MHz 172 DPL
- 461.3625 MHz 172 DPL
- 464.5000 MHz 172 DPL
- 469.5000 MHz 172 DPL
