Part 15
Revision as of 19:27, 21 July 2022 by R4002 (Talk | contribs)
15.225(a) is of the most interest to hobbyists, the field strength limit of 15,848 microvolts/meter at 30 meters or 84 dBµV/m at a distance of 30 meters is not easy to convert to dBm or better yet, mW or milliwatts, and will be different depending on the antenna used.
RC frequencies:
  • 26.995 MHz
  • 27.045 MHz
  • 27.095 MHz
  • 27.145 MHz
  • 27.195 MHz
  • 27.255 MHz
Part 15 power limit is 10,000 microvolts per meter at 3 meters (10,000 microvolts/meter at 3m) or 10mV/m at 3 meters. 10,000 uV/m at 3m may be converted below:
In other words, 0.0182 milliwatts ERP.
  • 49.850 MHz - Channel 2
  • 49.870 MHz - Channel 3
  • 49.890 MHz - Channel 4
  • 49.875 MHZ - Channel 4
  • 49.850 MHz - Channel 1A
  • 49.870 MHz - Channel 2A
  • 49.830 MHz - Channel 1B
  • 49.890 MHz - Channel 2B
  • 49.845 MHz - Channel X
  • 49.875 MHz - Channel Y
Or,
  • 49.830 MHz - Channel A
  • 49.860 MHz - Channel B
Or,
  • 49.845 MHz - Channel A
  • 49.890 MHz - Channel B
Or,
  • 49.840 MHz - Channel A
  • 49.870 MHz - Channel B
Or,
  • 49.850 MHz - Channel I
  • 49.870 MHz - Channel II
Or,
  • 49.825 MHz - Channel 1
Or,
  • 49.870 MHz - Channel 1
Or,
  • 49.840 MHz - Channel 1
  • 49.860 MHz - Channel 2
Or,
Or,
  • 49.885 MHz - Channel B
Or,
  • 49.875 MHz - Channel B
Or,
Or,
  • 49.850 MHz - Channel X
  • 49.880 MHz - Channel Y
  • 49.870 MHz - Channel 4
  • 49.880 MHz - Channel 5
  • 49.890 MHz - Channel 6
  • 49.835 MHz - Channel A
  • 49.850 MHz - Channel B
  • 49.865 MHz - Channel C
Or,
  • 49.890 MHz - Channel C
  • 49.835 MHz - Channel 1/A
  • 49.860 MHz - Channel 2/B
  • 49.885 MHz - Channel 3/C
See also: ISM and cordless phone systems (900 MHz band, 2.4 GHz band and 5.8 GHz band digital cordless phones may operate under 15.247. Wireless intercoms, full duplex headset comms systems, etc.)
(3) For systems using digital modulation in the 902-928 MHz, 2400-2483.5 MHz, and 5725-5850 MHz bands: 1 Watt. As an alternative to a peak power measurement, compliance with the one Watt limit can be based on a measurement of the maximum conducted output power. Maximum Conducted Output Power is defined as the total transmit power delivered to all antennas and antenna elements averaged across all symbols in the signaling alphabet when the transmitter is operating at its maximum power control level. Power must be summed across all antennas and antenna elements. The average must not include any time intervals during which the transmitter is off or is transmitting at a reduced power level. If multiple modes of operation are possible (e.g., alternative modulation methods), the maximum conducted output power is the highest total transmit power occurring in any mode.
  • 902 MHz - 928 MHz - 50 millivolts/meter at 3 meters
  • 2400 MHz - 2483.5 MHz - 50 millivolts/meter at 3 meters
  • 5725 MHz - 5875 MHz - 50 millivolts/meter at 3 meters
  • 24.0 GHz - 24.25 GHz - 250 millivolts/meter at 3 meters
