Part 15
Revision as of 15:48, 6 April 2023 by R4002 (Talk | contribs)
Not to be confused with ISM (Part 18 of the FCC rules), various license-free Part 95 services, Short Range Devices (SRD or SRDs) or Low Power Devices (LPD or LPDs).
RC frequencies:
  • 26.995 MHz
  • 27.045 MHz
  • 27.095 MHz
  • 27.145 MHz
  • 27.195 MHz
  • 27.255 MHz
  • 49.850 MHz - Channel 2
  • 49.870 MHz - Channel 3
  • 49.890 MHz - Channel 4
  • 49.875 MHZ - Channel 4
  • 49.850 MHz - Channel 1A
  • 49.870 MHz - Channel 2A
  • 49.830 MHz - Channel 1B
  • 49.890 MHz - Channel 2B
  • 49.845 MHz - Channel X
  • 49.875 MHz - Channel Y
Or,
  • 49.830 MHz - Channel A
  • 49.860 MHz - Channel B
Or,
  • 49.845 MHz - Channel A
  • 49.890 MHz - Channel B
Or,
  • 49.840 MHz - Channel A
  • 49.870 MHz - Channel B
Or,
  • 49.850 MHz - Channel I
  • 49.870 MHz - Channel II
Or,
  • 49.825 MHz - Channel 1
Or,
  • 49.870 MHz - Channel 1
Or,
  • 49.840 MHz - Channel 1
  • 49.860 MHz - Channel 2
Or,
Or,
  • 49.885 MHz - Channel B
Or,
  • 49.875 MHz - Channel B
Or,
Or,
  • 49.850 MHz - Channel X
  • 49.880 MHz - Channel Y
  • 49.870 MHz - Channel 4
  • 49.880 MHz - Channel 5
  • 49.890 MHz - Channel 6
  • 49.835 MHz - Channel A
  • 49.850 MHz - Channel B
  • 49.865 MHz - Channel C
Or,
  • 49.890 MHz - Channel C
  • 49.835 MHz - Channel 1/A
  • 49.860 MHz - Channel 2/B
  • 49.885 MHz - Channel 3/C
See also: ISM, cordless phone systems (900 MHz band, 2.4 GHz band and 5.8 GHz band digital cordless phones may operate under 15.247. Wireless intercoms, full duplex headset comms systems, long-range telemetry, non Part 95 remote control, datalink, video backhaul systems for UAV systems, drones, etc.). Line of sight (air to ground) radio links on 900 MHz are capable of very long range, often 40 km or more.
  • 902 MHz - 928 MHz - 50 millivolts/meter at 3 meters or 50mV/m at 3 meters (50,000 microvolts/meter at 3 meters)
  • 2400 MHz - 2483.5 MHz - 50 millivolts/meter at 3 meters or 50mV/m at 3 meters (50,000 microvolts/meter at 3 meters)
  • 5725 MHz - 5875 MHz - 50 millivolts/meter at 3 meters or 50mV/m at 3 meters (50,000 microvolts/meter at 3 meters)
  • 24.0 GHz - 24.25 GHz - 250 millivolts/meter at 3 meters or 250mV/m at 3 meters (250,000 microvolts/meter at 3 meters)
(b) [Reserved]
