MURS
Revision as of 13:28, 11 April 2019 by R4002 (Talk | contribs)
Multi Use Radio Service
MURS Frequencies / Channels:
Repeaters are not allowed on the MURS frequencies per FCC rules. This includes duplex and simplex repeaters, also known as "store-and-forward" repeaters. Store-and-forward packet operation is explicitly prohibited. Unattended data transmission (for example, telemetry) is permitted.
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Mount Jackson, Virginia
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Richmond, Virginia (low power, 2w transmitter, around 5w ERP - located in downtown Richmond, VA - antenna is 20 feet above ground level)
Please use MURS channel 2 if possible when setting up a MURS simplex repeater "parrot" or MURS cross band repeater.
It is recommended that MURS simplex repeater and cross-band repeater users use 156.7 Hz or 167.9 Hz as these CTCSS tones are used for interoperability and emergency purposes. Use of default tone 67.0 Hz is not recommended. MURS simplex repeater and MURS GMRS FRS crossband repeater operators should monitor frequency usage in their area to ensure they do not select a PL or DPL (CTCSS or DCS) tone that is used by another MURS, GMRS or FRS user as this would cause heavy interference issues and attract FCC attention.
In other words, don't use carrier squelch aka CSQ, 67.0 Hz CTCSS, 023 DCS/DPL and don't use FRS channel 1 (462.5625 MHz) as a crossband frequency. Don't use 154.570 or 154.600 with CSQ, 67.0 Hz, 71.9 Hz, 74.4 Hz or 77.0 Hz CTCSS tones as these are default tones and are often used by Wal-Mart and similar retail stores on MURS
Emergency preparedness radio and communications guides, including the interoperability guide, recommend programming the MURS and FRS frequencies into radios for compatibility with these systems.
