Future Section
The origins of CB can be traced further back, to World War II. Both the US and Germany developed mobile two-way radios for use in tanks, trucks and other vehicles that used similar frequency ranges, power output levels, and the familiar 9 foot long 1/4 wave "whip" antenna associated with CB. These frequencies the 20.0 MHz - 27.9 MHz and 27.0 MHz - 38.9 MHz ranges (SCR-508 and SCR-608 tank and artillery radios) and the 27.2 MHz - 33.4 MHz range (Germany, standard 10W.S.c Panzer radio transmitter).
The complete German UKW "ultra short wave", another way of saying VHF was known as the Fu 5 or FuG 5. Later German tank radios transmitted high power levels (20 watts vs. 6 watts / 10 watts) - sources differ, but indications are these are peak or average power levels - very close To today’s 4 watt AM carrier power CB radios. If carrier power (aka “deadkey”) power is indicated - at 100% modulation the PEP or peak (aka “swing”) power levels for a 4 watt radio would be 16 watts, for a 6 watt radio would be 24 watts, for a 10 watt radio would be 40 watts and for a 20 watt radio would be 80 watts. It’s possible that nominal power levels were neither carrier or peak power - but instead were an average power reading. For American FM sets (SCR-508, SCR-510, SCR-528, SCR-608, SCR-610, SCR-628, etc.) the output power is the FM power. FM transmits at 100% modulation all the time so there is only one power rating. If the “20 watt” rating is PEP power than the carrier power is closer to the 5 watt or 6 watt transmit power range. This is almost identical to modern CB radios.
This improved radio set was known as the Fu 6 or FuG 6. The German high-HF/low-VHF AM/CW networks provided a communication range of 2-3 km on low power (6 watts) and 4-6 km on high power (10 watts).
German AM equipment operated at 50 kHz channel steps (27.200 MHz, 27.250 MHz, 27.300 MHz...up To 33.300 MHz, 33.350 MHz, 33.400 MHz. Radio displays indicated every every 100 kHz with a mark halfway between to show the 50 kHz channel in-between. Frequency readout was provided in a x100 kHz notation - so 27.500 MHz (27500 kHz) would appear as 275 on the display. Note in the paragraph below that the American systems used the exact same method for channel designation!
The American equipment provided 280 channels for the armor (tank) band radios operating from 20 MHz to 27.9 MHz FM and 120 channels for the artillery band radios operating from 27 MHz to 38.9 MHz FM. Compare this to the 124 channels available for German tank radios operating from 27.2 MHz to 33.4 MHz AM.
Like the United States and other countries, the German Army operated various versions of these radios, including automatic relay equipment (compare the American SCR-300/BC-1000 VHF-FM 40-48 MHz manpack radio with the German KL.Fuspr.d VHF-AM 32-38 MHz manpack portable radio. Reconnaissance and artillery networks used 24-25 MHz and 23-24.95 MHz AM/CW systems similar in operation to the 27.2 - 33.4 MHz panzer tank communications systems. Later radios provided close air support capability with the 42 MHz - 48.3 MHz command radios. Most German AM voice equipment used channel numbering systems. The 50 kHz / 100 kHz steps were not universal across different bands. The 23-25 MHz 12 meter/11 meter land mobile systems used 47.5 kHz channel steps.
| Frequency | Remarks |
| Channel 2 | 26.975 MHz | |
| Channel 5 | 27.015 MHz | |
| Channel 7 | 27.035 MHz | |
| Channel 12 | 27.105 MHz | |
| Channel 15 | 27.135 MHz | |
| Channel 18 | 27.175 MHz | |
| Channel 22 | 27.225 MHz | |
| Channel 27 | 27.275 MHz | |
| Channel 29 | 27.295 MHz | |
| Channel 32 | 27.325 MHz | |
| Channel 33 | 27.335 MHz | |
| Channel 34 | 27.345 MHz | |
| Channel 36 | 27.365 MHz | |
FM (Frequency Modulation)
| Channel 1 | 27.60125 MHz |
| Channel 2 | 27.61125 MHz |
| Channel 3 | 27.62125 MHz |
| Channel 4 | 27.63125 MHz |
| Channel 5 | 27.64125 MHz |
| Channel 6 | 27.65125 MHz |
| Channel 7 | 27.66125 MHz |
| Channel 8 | 27.67125 MHz |
| Channel 9 | 27.68125 MHz |
| Channel 10 | 27.69125 MHz |
| Channel 11 | 27.70125 MHz |
| Channel 12 | 27.71125 MHz |
| Channel 13 | 27.72125 MHz |
| Channel 14 | 27.73125 MHz |
| Channel 15 | 27.74125 MHz |
| Channel 16 | 27.75125 MHz |
| Channel 17 | 27.76125 MHz |
| Channel 18 | 27.77125 MHz |
| Channel 19 | 27.78125 MHz |
| Channel 20 | 27.79125 MHz |
| Channel 21 | 27.80125 MHz |
| Channel 22 | 27.81125 MHz |
| Channel 23 | 27.82125 MHz |
| Channel 24 | 27.83125 MHz |
| Channel 25 | 27.84125 MHz |
| Channel 26 | 27.85125 MHz |
| Channel 27 | 27.86125 MHz |
| Channel 28 | 27.87125 MHz |
| Channel 29 | 27.88125 MHz |
| Channel 30 | 27.89125 MHz |
| Channel 31 | 27.90125 MHz |
| Channel 32 | 27.91125 MHz |
| Channel 33 | 27.92125 MHz |
| Channel 34 | 27.93125 MHz |
| Channel 35 | 27.94125 MHz |
| Channel 36 | 27.95125 MHz |
| Channel 37 | 27.96125 MHz |
| Channel 38 | 27.97125 MHz |
| Channel 39 | 27.98125 MHz |
| Channel 40 | 27.99125 MHz |
| Channel 41 | 26.565 MHz |
| Channel 42 | 26.575 MHz |
| Channel 43 | 26.585 MHz |
| Channel 44 | 26.595 MHz |
| Channel 45 | 26.605 MHz |
| Channel 46 | 26.615 MHz |
| Channel 47 | 26.625 MHz |
| Channel 48 | 26.635 MHz |
| Channel 49 | 26.645 MHz |
| Channel 50 | 26.655 MHz |
| Channel 51 | 26.665 MHz |
| Channel 52 | 26.675 MHz |
| Channel 53 | 26.685 MHz |
| Channel 54 | 26.695 MHz |
| Channel 55 | 26.705 MHz |
| Channel 56 | 26.715 MHz |
| Channel 57 | 26.725 MHz |
| Channel 58 | 26.735 MHz |
| Channel 59 | 26.745 MHz |
| Channel 60 | 26.755 MHz |
| Channel 61 | 26.765 MHz |
| Channel 62 | 26.775 MHz |
| Channel 63 | 26.785 MHz |
| Channel 64 | 26.795 MHz |
| Channel 65 | 26.805 MHz |
| Channel 66 | 26.815 MHz |
| Channel 67 | 26.825 MHz |
| Channel 68 | 26.835 MHz |
| Channel 69 | 26.845 MHz |
| Channel 70 | 26.855 MHz |
| Channel 71 | 26.865 MHz |
| Channel 72 | 26.875 MHz |
| Channel 73 | 26.885 MHz |
| Channel 74 | 26.895 MHz |
| Channel 75 | 26.905 MHz |
| Channel 76 | 26.915 MHz |
| Channel 77 | 26.925 MHz |
| Channel 78 | 26.935 MHz |
| Channel 79 | 26.945 MHz |
| Channel 80 | 26.955 MHz |
26 MHz AM Public Channels:
| Channel 1 | 26.330 MHz |
| Channel 2 | 26.340 MHz |
| Channel 3 | 26.350 MHz |
| Channel 4 | 26.370 MHz |
| Channel 5 | 26.380 MHz |
| Channel 6 | 26.390 MHz |
| Channel 7 | 26.400 MHz |
| Channel 8 | 26.420 MHz |
| Channel 9 | 26.430 MHz |
| Channel 10 | 26.440 MHz |
| Channel 11 | 26.450 MHz |
| Channel 12 | 26.470 MHz |
| Channel 13 | 26.480 MHz |
| Channel 14 | 26.490 MHz |
| Channel 15 | 26.500 MHz |
| Channel 16 | 26.520 MHz |
| Channel 17 | 26.530 MHz |
| Channel 18 | 26.540 MHz |
| Channel 19 | 26.550 MHz |
| Channel 20 | 26.570 MHz |
| Channel 21 | 26.580 MHz |
| Channel 22 | 26.590 MHz |
| Channel 23 | 26.620 MHz |
| Channel 24 | 26.600 MHz |
| Channel 25 | 26.610 MHz |
| Channel 26 | 26.630 MHz |
| Channel 27 | 26.640 MHz |
| Channel 28 | 26.650 MHz |
| Channel 29 | 26.660 MHz |
| Channel 30 | 26.670 MHz |
| Channel 31 | 26.680 MHz |
| Channel 32 | 26.690 MHz |
| Channel 33 | 26.700 MHz |
| Channel 34 | 26.710 MHz |
| Channel 35 | 26.720 MHz |
| Channel 36 | 26.730 MHz |
| Channel 37 | 26.740 MHz |
| Channel 38 | 26.750 MHz |
| Channel 39 | 26.760 MHz |
| Channel 40 | 26.770 MHz |
| Channel 1 | 26.960 MHz |
| Channel 2 | 26.970 MHz |
| Channel 3 | 26.980 MHz |
| Channel 4 | 27.000 MHz |
| Channel 5 | 27.010 MHz |
| Channel 6 | 27.020 MHz |
| Channel 7 | 27.030 MHz |
| Channel 8 | 27.050 MHz |
| Channel 9 | 27.060 MHz |
| Channel 10 | 27.070 MHz |
| Channel 11 | 27.080 MHz |
| Channel 12 | 27.100 MHz |
| Channel 13 | 27.110 MHz |
| Channel 14 | 27.120 MHz |
| Channel 15 | 27.130 MHz |
| Channel 16 | 27.150 MHz |
| Channel 17 | 27.160 MHz |
| Channel 18 | 27.170 MHz |
| Channel 19 | 27.180 MHz |
| Channel 20 | 27.200 MHz |
| Channel 21 | 27.210 MHz |
| Channel 22 | 27.220 MHz |
| Channel 23 | 27.250 MHz |
| Channel 24 | 27.230 MHz |
| Channel 25 | 27.240 MHz |
| Channel 26 | 27.260 MHz |
| Channel 27 | 27.270 MHz |
| Channel 28 | 27.280 MHz |
| Channel 29 | 27.290 MHz |
| Channel 30 | 27.300 MHz |
| Channel 31 | 27.310 MHz |
| Channel 32 | 27.320 MHz |
| Channel 33 | 27.330 MHz |
| Channel 34 | 27.340 MHz |
| Channel 36 | 27.360 MHz |
| Channel 37 | 27.370 MHz |
| Channel 38 | 27.380 MHz |
| Channel 39 | 27.390 MHz |
| Channel 40 | 27.400 MHz |
For example,
| Band A Channel | Frequency |
| Channel 1 | 25.615 MHz |
| Channel 2 | 25.625 MHz |
| Channel 3 | 25.635 MHz |
| Channel 3A | 25.645 MHz |
| Channel 4 | 25.655 MHz |
| Channel 5 | 26.665 MHz |
| Channel 6 | 25.675 MHz |
| Channel 7 | 25.685 MHz |
| Channel 7A | 25.695 MHz |
| Channel 8 | 25.705 MHz |
| Channel 9 | 25.715 MHz |
| Channel 10 | 25.725 MHz |
| Channel 11 | 25.735 MHz |
| Channel 11A | 25.745 MHz |
| Channel 12 | 25.755 MHz |
| Channel 13 | 25.755 MHz |
| Channel 14 | 25.775 MHz |
| Channel 15 | 25.785 MHz |
| Channel 15A | 25.795 MHz |
| Channel 16 | 25.805 MHz |
| Channel 17 | 25.815 MHz |
| Channel 18 | 25.825 MHz |
| Channel 19 | 25.835 MHz |
| Channel 19A | 25.845 MHz |
| Channel 20 | 25.855 MHz |
| Channel 21 | 25.865 MHz |
| Channel 22 | 25.875 MHz |
| Channel 23 | 25.905 MHz |
| Channel 24 | 25.885 MHz |
| Channel 25 | 25.895 MHz |
| Channel 26 | 25.915 MHz |
| Channel 27 | 25.925 MHz |
| Channel 28 | 25.935 MHz |
| Channel 29 | 25.945 MHz |
| Channel 30 | 25.955 MHz |
| Channel 31 | 25.965 MHz |
| Channel 32 | 25.975 MHz |
| Channel 33 | 25.985 MHz |
| Channel 34 | 25.995 MHz |
| Channel 35 | 26.005 MHz |
| Channel 36 | 26.015 MHz |
| Channel 37 | 26.025 MHz |
| Channel 38 | 26.035 MHz |
| Channel 39 | 26.045 MHz |
| Channel 40 | 26.055 MHz |
| Channel 40A | 26.065 MHz |
| Band B Channel | Frequency |
| Channel 1 | 26.065 MHz |
| Channel 2 | 26.075 MHz |
| Channel 3 | 26.085 MHz |
| Channel 3A | 26.095 MHz |
| Channel 4 | 26.105 MHz |
| Channel 5 | 26.115 MHz |
| Channel 6 | 26.125 MHz |
| Channel 7 | 26.135 MHz |
| Channel 7A | 26.145 MHz |
| Channel 8 | 26.155 MHz |
| Channel 9 | 26.165 MHz |
| Channel 10 | 26.175 MHz |
| Channel 11 | 26.185 MHz |
| Channel 11A | 26.195 MHz |
| Channel 12 | 26.205 MHz |
| Channel 13 | 26.215 MHz |
| Channel 14 | 26.225 MHz |
| Channel 15 | 26.235 MHz |
| Channel 15A | 26.245 MHz |
| Channel 16 | 26.255 MHz |
| Channel 17 | 26.265 MHz |
| Channel 18 | 26.275 MHz |
| Channel 19 | 26.285 MHz |
| Channel 19A | 26.295 MHz |
| Channel 20 | 26.305 MHz |
| Channel 21 | 26.315 MHz |
| Channel 22 | 26.325 MHz |
| Channel 23 | 26.355 MHz |
| Channel 24 | 26.335 MHz |
| Channel 25 | 26.345 MHz |
| Channel 26 | 26.365 MHz |
| Channel 27 | 26.375 MHz |
| Channel 28 | 26.385 MHz |
| Channel 29 | 26.395 MHz |
| Channel 30 | 26.405 MHz |
| Channel 31 | 26.415 MHz |
| Channel 32 | 26.425 MHz |
| Channel 33 | 26.435 MHz |
| Channel 34 | 26.445 MHz |
| Channel 35 | 26.455 MHz |
| Channel 36 | 26.465 MHz |
| Channel 37 | 26.475 MHz |
| Channel 38 | 26.485 MHz |
| Channel 39 | 26.495 MHz |
| Channel 40 | 26.505 MHz |
| Channel 40A | 26.515 MHz |
| Band C Channel | Frequency |
| Channel 1 | 26.515 MHz |
| Channel 2 | 26.525 MHz |
| Channel 3 | 26.535 MHz |
| Channel 3A | 26.545 MHz |
| Channel 4 | 26.555 MHz |
| Channel 5 | 26.565 MHz |
| Channel 6 | 26.575 MHz |
| Channel 7 | 26.585 MHz |
| Channel 7A | 26.595 MHz |
| Channel 8 | 26.605 MHz |
| Channel 9 | 26.615 MHz |
| Channel 10 | 26.625 MHz |
| Channel 11 | 26.635 MHz |
| Channel 11A | 26.645 MHz |
| Channel 12 | 26.655 MHz |
| Channel 13 | 26.655 MHz |
| Channel 14 | 26.675 MHz |
| Channel 15 | 26.685 MHz |
| Channel 15A | 26.695 MHz |
| Channel 16 | 26.705 MHz |
| Channel 17 | 26.715 MHz |
| Channel 18 | 26.725 MHz |
| Channel 19 | 26.735 MHz |
| Channel 19A | 26.745 MHz |
| Channel 20 | 26.755 MHz |
| Channel 21 | 26.765 MHz |
| Channel 22 | 26.775 MHz |
| Channel 23 | 26.805 MHz |
| Channel 24 | 26.785 MHz |
| Channel 25 | 26.795 MHz |
| Channel 26 | 26.815 MHz |
| Channel 27 | 26.825 MHz |
| Channel 28 | 26.835 MHz |
| Channel 29 | 26.845 MHz |
| Channel 30 | 26.855 MHz |
| Channel 31 | 26.865 MHz |
| Channel 32 | 26.875 MHz |
| Channel 33 | 26.885 MHz |
| Channel 34 | 26.895 MHz |
| Channel 35 | 26.905 MHz |
| Channel 36 | 26.915 MHz |
| Channel 37 | 26.925 MHz |
| Channel 38 | 26.935 MHz |
| Channel 39 | 26.945 MHz |
| Channel 40 | 26.955 MHz |
| Channel 40A | 26.965 MHz |
| Band D Channel | Frequency |
| Channel 3A | 26.995 MHz |
| Channel 7A | 27.045 MHz |
| Channel 11A | 27.095 MHz |
| Channel 15A | 27.145 MHz |
| Channel 19A | 27.195 MHz |
| Channel 40A | 27.415 MHz |
| Band E Channel | Frequency |
| Channel 1 | 27.415 MHz |
| Channel 2 | 27.425 MHz |
| Channel 3 | 27.435 MHz |
| Channel 3A | 27.445 MHz |
| Channel 4 | 27.455 MHz |
| Channel 5 | 27.465 MHz |
| Channel 6 | 27.475 MHz |
| Channel 7 | 27.485 MHz |
| Channel 7A | 27.495 MHz |
| Channel 8 | 27.505 MHz |
| Channel 9 | 27.515 MHz |
| Channel 10 | 27.525 MHz |
| Channel 11 | 27.535 MHz |
| Channel 11A | 27.545 MHz |
| Channel 12 | 27.555 MHz |
| Channel 13 | 27.565 MHz |
| Channel 14 | 27.575 MHz |
| Channel 15 | 27.585 MHz |
| Channel 15A | 27.595 MHz |
| Channel 16 | 27.605 MHz |
| Channel 17 | 27.615 MHz |
| Channel 18 | 27.625 MHz |
| Channel 19 | 27.635 MHz |
| Channel 19A | 27.645 MHz |
| Channel 20 | 27.655 MHz |
| Channel 21 | 27.665 MHz |
| Channel 22 | 27.675 MHz |
| Channel 23 | 27.705 MHz |
| Channel 24 | 27.685 MHz |
| Channel 25 | 27.695 MHz |
| Channel 26 | 27.715 MHz |
| Channel 27 | 27.735 MHz |
| Channel 28 | 27.735 MHz |
| Channel 29 | 27.745 MHz |
| Channel 30 | 27.755 MHz |
| Channel 31 | 27.765 MHz |
| Channel 32 | 27.775 MHz |
| Channel 33 | 27.785 MHz |
| Channel 34 | 27.795 MHz |
| Channel 35 | 27.805 MHz |
| Channel 36 | 27.815 MHz |
| Channel 37 | 27.825 MHz |
| Channel 38 | 27.835 MHz |
| Channel 39 | 27.845 MHz |
| Channel 40 | 27.855 MHz |
| Channel 40A | 27.865 MHz |
| Band F Channel | Frequency |
| Channel 1 | 27.865 MHz |
| Channel 2 | 27.875 MHz |
| Channel 3 | 27.885 MHz |
| Channel 3A | 27.895 MHz |
| Channel 4 | 27.905 MHz |
| Channel 5 | 27.915 MHz |
| Channel 6 | 27.925 MHz |
| Channel 7 | 27.935 MHz |
| Channel 7A | 27.945 MHz |
| Channel 8 | 27.955 MHz |
| Channel 9 | 27.965 MHz |
| Channel 10 | 27.975 MHz |
| Channel 11 | 27.985 MHz |
| Channel 11A | 27.995 MHz |
| Channel 12 | 28.005 MHz |
| Channel 13 | 28.015 MHz |
| Channel 14 | 28.025 MHz |
| Channel 15 | 28.035 MHz |
| Channel 15A | 28.045 MHz |
| Channel 16 | 28.055 MHz |
| Channel 17 | 28.065 MHz |
| Channel 18 | 28.075 MHz |
| Channel 19 | 28.085 MHz |
| Channel 19A | 28.095 MHz |
| Channel 20 | 28.105 MHz |
| Channel 21 | 28.115 MHz |
| Channel 22 | 28.125 MHz |
| Channel 23 | 28.155 MHz |
| Channel 24 | 28.135 MHz |
| Channel 25 | 28.145 MHz |
| Channel 26 | 28.165 MHz |
| Channel 27 | 28.175 MHz |
| Channel 28 | 28.185 MHz |
| Channel 29 | 28.195 MHz |
| Channel 30 | 28.205 MHz |
| Channel 31 | 28.215 MHz |
| Channel 32 | 28.225 MHz |
| Channel 33 | 28.235 MHz |
| Channel 34 | 28.245 MHz |
| Channel 35 | 28.255 MHz |
| Channel 36 | 28.265 MHz |
| Channel 37 | 28.275 MHz |
| Channel 38 | 28.285 MHz |
| Channel 39 | 28.295 MHz |
| Channel 40 | 28.305 MHz |
| Channel 40A | 28.315 MHz |
| Channel 1 | 26.968 MHz |
| Channel 2 | 26.976 MHz |
| Channel 3 | 27.040 MHz |
| Channel 4 | 27.080 MHz |
| Channel 5 | 27.088 MHz |
| Channel 6 | 27.112 MHz |
| Channel 7 | 27.120 MHz |
| Channel 8 | 27.144 MHz |
| 27310.5 kHz | 27.3105 MHz |
| 27334.5 kHz | 27.3345 MHz |
| 27338.5 kHz | 27.3385 MHz |
| 27342.5 kHz | 27.3425 MHz |
| 27346.5 kHz | 27.3465 MHz |
| 27350.5 kHz | 27.3505 MHz |
| 27354.5 kHz | 27.3545 MHz |
| 27358.5 kHz | 27.3585 MHz |
| 27362.5 kHz | 27.3625 MHz |
| 27366.5 kHz | 27.3665 MHz |
| 27370.5 kHz | 27.3705 MHz |
| 27378.5 kHz | 27.3785 MHz |
| 27382.5 kHz | 27.3825 MHz |
| 27386.5 kHz | 27.3865 MHz |
| 27388.5 kHz | 27.3885 MHz |
| 27398.5 kHz | 27.3985 MHz |
| 27404.5 kHz | 27.4045 MHz |
| 27418.5 kHz | 27.4185 MHz |
| 27426.5 kHz | 27.4265 MHz |
| 27434.5 kHz | 27.4345 MHz |
| 27442.5 kHz | 27.4425 MHz |
| 27452.5 kHz | 27.4525 MHz |
| 27458.5 kHz | 27.4585 MHz |
| 27466.5 kHz | 27.4665 MHz |
| 27470.5 kHz | 27.4705 MHz |
- SPECIFICATIONS
- 25 kHz channel spacing
- 480 channels
- FEATURES
- SPECIFICATIONS
- 20 channels
- AM modulation
- FEATURES
IND08 - Use of wireless equipments intended to be used while in motion or during halts, in the frequency band 26.957 MHz - 27.283 MHz, with a maximum Effective Radiated Power ( ERP) of 5 Watts has been exempted from licensing requirements.
| Channel 41 | 27.415 MHz |
| Channel 42 | 27.425 MHz |
| Channel 43 | 27.435 MHz |
| Channel 44 | 27.455 MHz |
| Channel 45 | 27.465 MHz |
| Channel 46 | 27.475 MHz |
| Channel 47 | 27.485 MHz |
| Channel 48 | 27.505 MHz |
| Channel 49 | 27.515 MHz |
| Channel 50 | 27.525 MHz |
| Channel 51 | 27.535 MHz |
| Channel 52 | 27.555 MHz |
| Channel 53 | 27.565 MHz |
| Channel 54 | 27.575 MHz |
| Channel 55 | 27.585 MHz |
| Channel 56 | 27.605 MHz |
| Channel 57 | 27.615 MHz |
| Channel 58 | 27.625 MHz |
| Channel 59 | 27.635 MHz |
| Channel 60 | 27.655 MHz |
| Channel 61 | 27.665 MHz |
| Channel 62 | 27.675 MHz |
| Channel 63 | 27.685 MHz |
| Channel 64 | 27.695 MHz |
| Channel 65 | 27.705 MHz |
| Channel 66 | 27.715 MHz |
| Channel 67 | 27.725 MHz |
| Channel 68 | 27.735 MHz |
| Channel 69 | 27.745 MHz |
| Channel 70 | 27.755 MHz |
| Channel 71 | 27.765 MHz |
| Channel 72 | 27.775 MHz |
| Channel 73 | 27.785 MHz |
| Channel 74 | 27.795 MHz |
| Channel 75 | 27.805 MHz |
| Channel 76 | 27.815 MHz |
| Channel 77 | 27.825 MHz |
| Channel 78 | 27.835 MHz |
| Channel 79 | 27.845 MHz |
| Channel 80 | 27.855 MHz |
| 27.600 MHz | 27.800 MHz | Jamaica, FM mode | Optional CTCSS PL 88.5 Hz - part of 4 linked FM CB 11m repeaters with +200 kHz offset - likely off the air |
| 27.620 MHz | 27.820 MHz | Jamaica, FM mode | Optional CTCSS PL 88.5 Hz - part of 4 linked FM CB 11m repeaters with +200 kHz offset - likely off the air |
| 27.640 MHz | 27.840 MHz | Jamaica, FM mode | Optional CTCSS PL 88.5 Hz - part of 4 linked FM CB 11m repeaters with +200 kHz offset - likely off the air |
| 27.660 MHz | 27.860 MHz | Jamaica, FM mode | Optional CTCSS PL 88.5 Hz - part of 4 linked FM CB 11m repeaters with +200 kHz offset - likely off the air |
Below is a list of confirmed [as of December 2019] CB repeaters and their location (if known).
| 26.575 MHz | Germany | ||
| 26.675 MHz | |||
| 26.915 MHz | |||
| 26.925 MHz | |||
| 26.970 MHz | Lithuania | ||
| 27.110 MHz | Poland | ||
| 27.110 MHz | Russia | ||
| 27.150 MHz | Poland | ||
| 27.170 MHz | Poland | ||
| 27.190 MHz | |||
| 27.220 MHz | |||
| 27.230 MHz | |||
| 27.235 MHz | |||
| 27.250 MHz | Belarus | ||
| 27.300 MHz | |||
| 27.325 MHz | |||
| 27.430 MHz | |||
| 27.450 MHz | |||
| 27.470 MHz | |||
| 27.675 MHz | Russia | ||
| 27.765 MHz | Germany | ||
| 27.840 MHz | Poland | ||
does AM radio still exist can you still buy CB radios do people still use CB radios CB radio for emergency emergencies prepper channels 26.96 - 27.41 MHz Citizen Radio Citizens Radio wikipedia CB frequencies on a Baofeng CB channels on a ham radio 26 MHz band what are the CB frequencies CB channel chart CB frequency chart UK USA UHF CB VHF CB HF CB AM CB SSB CB 120 channel CB channel range how far can a CB radio go CB antennas CB radio reviews do truckers still use CB radio 2018 2019 2020 today police CB radio frequencies channels 30 MHz band CB radio channels freeband channels freeband frequencies what is the best freeband radio CB radio police what CB channel do police use? they don't use CB radios and haven't for about 30 years...there are a lot of other users of CB radio though...freebanding frequencies channels prepper 25 MHz band 26 MHz band 27 MHz band 28 MHz 30 MHz band 30.555 MHz 30.105 MHz 25.615 MHz 27.405 MHz 26.955 MHz 26.505 MHz 26.515 MHz 26.510 MHz 26MHz taxi cab radio Uber radio Lyft radio two-way radio system taxicab radio dispatch YL Russia CADS UK 27/81 WPAS 120 channel mod frequency kit Lescomm DigiMax Lite Viagra board Cobra 29 channel kit 240 channel 360 channel 128 channel MB8719 RCI8719 cbradio.nl cbtricks.com EPT3600 board main board CB radio PCB 26.065 MHz 26.505 MHz 27500 kHz 27.500 MHz 27.5 MHz CB radio warfare RCI CRT EPT690010Z EPT6900 Uniden Cobra Galaxy Magnum SR-94C Galaxy DX radios 10kc 10kHz switch A channels secret channels phantom frequencies CB radio prepper frequencies hunting radios CB radio range 27 MHz RC transmitter PB010 PC879 PLL02A UPD858 MC145106 CB repeater CB VHF repeater CB MURS GMRS crossband cross-band GMRS MURS repeater 151.820 MHz 151.880 MHz 151.940 MHz 154.570 MHz 154.600 MHz 151.940 156.7 simplex repeater 27.205 MHz 462.550 - 467.7125 MHz radiobuoy fishnet beacon 26MHz 26.500 MHz 26500 kHz 26.450 MHz 26450 kHz 26MHz NZ CB UK FM 27/97 PR27 27 MHz FM CB can I use ham radio on CB frequencies what is 30 MHz band CB frequencies 10 meter intruders 11 meter taxi cab dispatch 26.285 USB 27.555 USB 27.185 AM 151.880 167.9 repeater 151.940 repeater simplex unlicensed illegal license free freebanders truckers on 25 MHz truckers on 10 meters unlicensed UHF frequencies MURS mobile CB mobile 25.615-30.105 MHz mobile radio handheld walkie talkie BF-888 Baofeng BF-888S BF-88A FRS on BF-888 B-888 work site radios Motorola Kenwood Icom BTECH unlicensed VHF frequencies MURS frequencies what are the CB channels police CB radio speed trap trucker talk CB radio HF truckers on CB channel 19 27.185 MHz 27185 kHz 27,185 27.180 MHz 27.635 MHz CADS WPAS Russian Taxis 24.715 MHz 25.165 MHz 25.615 MHz UK PO PL band 26.960 MHz 27.400 MHz what band is 30 MHz what frequency does military use CB radio channels what are the CB channels? 27.5 - 39.5 MHz 39.475 MHz HF radiotelephone fishery radio fisheries radio fisheries telephone radio 24.265 MHz 29.655 MHz 29.695 MHz 29.699 MHz 29.705 MHz 29.710 MHz bellscb rightchannelradios 26957 26.957 27120 27.120 MHz ISM band IoT bands 26-27 MHz data link transmitter 150 MHz truck radio hunting radio VHF CB radio 30.450 MHz 30.105 MHz 26-32 MHz 26-30 MHz 25-30 MHz 25.91 MHz 25.95 MHz 25.99 MHz 26.470 MHz marine radio CB RCI-2995 27.385 LSB ham radio gear on CB frequencies CB channels on a ham radio Anytone AT-5189 26-33 MHz 33-49 MHz 136-174 MHz 220-260 MHz 240-270 MHz 300-350 MHz 350-390 MHz 400-470 MHz 450-512 MHz 450-520 MHz 600 MHz band 700 MHz band
