Revision as of 20:51, 14 February 2020 by R4002 (Talk | contribs)
[1]
Future Section
The origins of CB can be traced further back, to World War II. Both the US and Germany developed mobile two-way radios for use in tanks, trucks and other vehicles that used similar frequency ranges, power output levels, and the familiar 9 foot long 1/4 wave "whip" antenna associated with CB. These frequencies the 20.0 MHz - 27.9 MHz and 27.0 MHz - 38.9 MHz ranges (SCR-508 and SCR-608 tank and artillery radios) and the 27.2 MHz - 33.4 MHz range (Germany, standard 10W.S.c Panzer radio transmitter).
The complete German UKW "ultra short wave", another way of saying VHF was known as the Fu 5 or FuG 5. US Army documentation indicates a transmitter power output of 6.5 watts on normal mode and 10 watts maximum output on high power mode. Maximum power setting / high power was obtained by pressing red push-button switch marked "Oberstrich" (power increase). High power was only to be used when tuning the whip antenna or in emergencies.
For American FM sets (SCR-508, SCR-510, SCR-528, SCR-608, SCR-610, SCR-628, etc.) the output power is the FM power.  FM transmits at 100% modulation all the time so there is only one power rating.  If the “20 watt” rating is PEP power than the carrier power is closer to the 5 watt or 6 watt transmit power range.  This is almost identical to modern CB radios.
This improved radio set was known as the Fu 6 or FuG 6. The German high-HF/low-VHF AM/CW networks provided a communication range of 2-3 km on low power (6 watts) and 4-6 km on high power (10 watts).
German AM equipment operated at 50 kHz channel steps (27.200 MHz, 27.250 MHz, 27.300 MHz, 27.350 MHz, 27.400 MHz, 27.450 MHz...up To 33.300 MHz, 33.350 MHz, 33.400 MHz. Radio displays indicated every every 100 kHz with a mark halfway between to show the 50 kHz channel in-between. Frequency readout was provided in a x100 kHz notation - so 27.500 MHz (27500 kHz) would appear as 275 on the display, 29.700 MHz would appear as 297 on the display, etc. "Split" channels in between were indicated by a line halfway between the 100 kHz steps, so 27.850 MHz would appear as a line halfway between channel 278 (27.800 MHz) and channel 279) (27.900 MHz). Note in the paragraph below that the American systems used the exact same method for channel designation!
The American equipment provided 280 channels for the armor (tank) band radios operating from 20 MHz to 27.9 MHz FM and 120 channels for the artillery band radios operating from 27 MHz to 38.9 MHz FM. Compare this to the 124 channels available for German tank radios operating from 27.2 MHz to 33.4 MHz AM.
Like the United States and other countries, the German Army operated various versions of these radios, including automatic relay equipment (compare the American SCR-300/BC-1000 VHF-FM 40-48 MHz manpack radio with the German KL.Fuspr.d VHF-AM 32-38 MHz manpack portable radio. Reconnaissance and artillery networks used 24-25 MHz and 23-24.95 MHz AM/CW systems similar in operation to the 27.2 - 33.4 MHz panzer tank communications systems. Later radios provided close air support capability with the 42 MHz - 48.3 MHz command radios. Most German AM voice equipment used channel numbering systems. The 50 kHz / 100 kHz steps were not universal across different bands. The 23-25 MHz 12 meter/11 meter land mobile systems used 47.5 kHz channel steps.
Frequency Remarks
27.470 MHz 5 active licenses
25.950 MHz 5 active licenses
25.200 MHz 0 active licenses
25.160 MHz 0 active licenses
25.120 MHz 0 active licenses
CB Channel Frequency Remarks
Channel 2 26.975 MHz
Channel 5 27.015 MHz
Channel 7 27.035 MHz
Channel 12 27.105 MHz
Channel 15 27.135 MHz
Channel 18 27.175 MHz
Channel 22 27.225 MHz
Channel 27 27.275 MHz
Channel 29 27.295 MHz
Channel 32 27.325 MHz
Channel 33 27.335 MHz
Channel 34 27.345 MHz
Channel 36 27.365 MHz
FM (Frequency Modulation)
Channel 1 27.60125 MHz
Channel 2 27.61125 MHz
Channel 3 27.62125 MHz
Channel 4 27.63125 MHz
Channel 5 27.64125 MHz
Channel 6 27.65125 MHz
Channel 7 27.66125 MHz
Channel 8 27.67125 MHz
Channel 9 27.68125 MHz
Channel 10 27.69125 MHz
Channel 11 27.70125 MHz
Channel 12 27.71125 MHz
Channel 13 27.72125 MHz
Channel 14 27.73125 MHz
Channel 15 27.74125 MHz
Channel 16 27.75125 MHz
Channel 17 27.76125 MHz
Channel 18 27.77125 MHz
Channel 19 27.78125 MHz
Channel 20 27.79125 MHz
Channel 21 27.80125 MHz
Channel 22 27.81125 MHz
Channel 23 27.82125 MHz
Channel 24 27.83125 MHz
Channel 25 27.84125 MHz
Channel 26 27.85125 MHz
Channel 27 27.86125 MHz
Channel 28 27.87125 MHz
Channel 29 27.88125 MHz
Channel 30 27.89125 MHz
Channel 31 27.90125 MHz
Channel 32 27.91125 MHz
Channel 33 27.92125 MHz
Channel 34 27.93125 MHz
Channel 35 27.94125 MHz
Channel 36 27.95125 MHz
Channel 37 27.96125 MHz
Channel 38 27.97125 MHz
Channel 39 27.98125 MHz
Channel 40 27.99125 MHz
Channel 41 26.565 MHz
Channel 42 26.575 MHz
Channel 43 26.585 MHz
Channel 44 26.595 MHz
Channel 45 26.605 MHz
Channel 46 26.615 MHz
Channel 47 26.625 MHz
Channel 48 26.635 MHz
Channel 49 26.645 MHz
Channel 50 26.655 MHz
Channel 51 26.665 MHz
Channel 52 26.675 MHz
Channel 53 26.685 MHz
Channel 54 26.695 MHz
Channel 55 26.705 MHz
Channel 56 26.715 MHz
Channel 57 26.725 MHz
Channel 58 26.735 MHz
Channel 59 26.745 MHz
Channel 60 26.755 MHz
Channel 61 26.765 MHz
Channel 62 26.775 MHz
Channel 63 26.785 MHz
Channel 64 26.795 MHz
Channel 65 26.805 MHz
Channel 66 26.815 MHz
Channel 67 26.825 MHz
Channel 68 26.835 MHz
Channel 69 26.845 MHz
Channel 70 26.855 MHz
Channel 71 26.865 MHz
Channel 72 26.875 MHz
Channel 73 26.885 MHz
Channel 74 26.895 MHz
Channel 75 26.905 MHz
Channel 76 26.915 MHz
Channel 77 26.925 MHz
Channel 78 26.935 MHz
Channel 79 26.945 MHz
Channel 80 26.955 MHz
26 MHz AM Public Channels:
Channel 1 26.330 MHz
Channel 2 26.340 MHz
Channel 3 26.350 MHz
Channel 4 26.370 MHz
Channel 5 26.380 MHz
Channel 6 26.390 MHz
Channel 7 26.400 MHz
Channel 8 26.420 MHz
Channel 9 26.430 MHz
Channel 10 26.440 MHz
Channel 11 26.450 MHz
Channel 12 26.470 MHz
Channel 13 26.480 MHz
Channel 14 26.490 MHz
Channel 15 26.500 MHz
Channel 16 26.520 MHz
Channel 17 26.530 MHz
Channel 18 26.540 MHz
Channel 19 26.550 MHz
Channel 20 26.570 MHz
Channel 21 26.580 MHz
Channel 22 26.590 MHz
Channel 23 26.620 MHz
Channel 24 26.600 MHz
Channel 25 26.610 MHz
Channel 26 26.630 MHz
Channel 27 26.640 MHz
Channel 28 26.650 MHz
Channel 29 26.660 MHz
Channel 30 26.670 MHz
Channel 31 26.680 MHz
Channel 32 26.690 MHz
Channel 33 26.700 MHz
Channel 34 26.710 MHz
Channel 35 26.720 MHz
Channel 36 26.730 MHz
Channel 37 26.740 MHz
Channel 38 26.750 MHz
Channel 39 26.760 MHz
Channel 40 26.770 MHz
Channel 1 26.960 MHz
Channel 2 26.970 MHz
Channel 3 26.980 MHz
Channel 4 27.000 MHz
Channel 5 27.010 MHz
Channel 6 27.020 MHz
Channel 7 27.030 MHz
Channel 8 27.050 MHz
Channel 9 27.060 MHz
Channel 10 27.070 MHz
Channel 11 27.080 MHz
Channel 12 27.100 MHz
Channel 13 27.110 MHz
Channel 14 27.120 MHz
Channel 15 27.130 MHz
Channel 16 27.150 MHz
Channel 17 27.160 MHz
Channel 18 27.170 MHz
Channel 19 27.180 MHz
Channel 20 27.200 MHz
Channel 21 27.210 MHz
Channel 22 27.220 MHz
Channel 23 27.250 MHz
Channel 24 27.230 MHz
Channel 25 27.240 MHz
Channel 26 27.260 MHz
Channel 27 27.270 MHz
Channel 28 27.280 MHz
Channel 29 27.290 MHz
Channel 30 27.300 MHz
Channel 31 27.310 MHz
Channel 32 27.320 MHz
Channel 33 27.330 MHz
Channel 34 27.340 MHz
Channel 36 27.360 MHz
Channel 37 27.370 MHz
Channel 38 27.380 MHz
Channel 39 27.390 MHz
Channel 40 27.400 MHz
For example,
Band A Channel Frequency
Channel 1 25.615 MHz
Channel 2 25.625 MHz
Channel 3 25.635 MHz
Channel 3A 25.645 MHz
Channel 4 25.655 MHz
Channel 5 26.665 MHz
Channel 6 25.675 MHz
Channel 7 25.685 MHz
Channel 7A 25.695 MHz
Channel 8 25.705 MHz
Channel 9 25.715 MHz
Channel 10 25.725 MHz
Channel 11 25.735 MHz
Channel 11A 25.745 MHz
Channel 12 25.755 MHz
Channel 13 25.755 MHz
Channel 14 25.775 MHz
Channel 15 25.785 MHz
Channel 15A 25.795 MHz
Channel 16 25.805 MHz
Channel 17 25.815 MHz
Channel 18 25.825 MHz
Channel 19 25.835 MHz
Channel 19A 25.845 MHz
Channel 20 25.855 MHz
Channel 21 25.865 MHz
Channel 22 25.875 MHz
Channel 23 25.905 MHz
Channel 24 25.885 MHz
Channel 25 25.895 MHz
Channel 26 25.915 MHz
Channel 27 25.925 MHz
Channel 28 25.935 MHz
Channel 29 25.945 MHz
Channel 30 25.955 MHz
Channel 31 25.965 MHz
Channel 32 25.975 MHz
Channel 33 25.985 MHz
Channel 34 25.995 MHz
Channel 35 26.005 MHz
Channel 36 26.015 MHz
Channel 37 26.025 MHz
Channel 38 26.035 MHz
Channel 39 26.045 MHz
Channel 40 26.055 MHz
Channel 40A 26.065 MHz
Band B Channel Frequency
Channel 1 26.065 MHz
Channel 2 26.075 MHz
Channel 3 26.085 MHz
Channel 3A 26.095 MHz
Channel 4 26.105 MHz
Channel 5 26.115 MHz
Channel 6 26.125 MHz
Channel 7 26.135 MHz
Channel 7A 26.145 MHz
Channel 8 26.155 MHz
Channel 9 26.165 MHz
Channel 10 26.175 MHz
Channel 11 26.185 MHz
Channel 11A 26.195 MHz
Channel 12 26.205 MHz
Channel 13 26.215 MHz
Channel 14 26.225 MHz
Channel 15 26.235 MHz
Channel 15A 26.245 MHz
Channel 16 26.255 MHz
Channel 17 26.265 MHz
Channel 18 26.275 MHz
Channel 19 26.285 MHz
Channel 19A 26.295 MHz
Channel 20 26.305 MHz
Channel 21 26.315 MHz
Channel 22 26.325 MHz
Channel 23 26.355 MHz
Channel 24 26.335 MHz
Channel 25 26.345 MHz
Channel 26 26.365 MHz
Channel 27 26.375 MHz
Channel 28 26.385 MHz
Channel 29 26.395 MHz
Channel 30 26.405 MHz
Channel 31 26.415 MHz
Channel 32 26.425 MHz
Channel 33 26.435 MHz
Channel 34 26.445 MHz
Channel 35 26.455 MHz
Channel 36 26.465 MHz
Channel 37 26.475 MHz
Channel 38 26.485 MHz
Channel 39 26.495 MHz
Channel 40 26.505 MHz
Channel 40A 26.515 MHz
Band C Channel Frequency
Channel 1 26.515 MHz
Channel 2 26.525 MHz
Channel 3 26.535 MHz
Channel 3A 26.545 MHz
Channel 4 26.555 MHz
Channel 5 26.565 MHz
Channel 6 26.575 MHz
Channel 7 26.585 MHz
Channel 7A 26.595 MHz
Channel 8 26.605 MHz
Channel 9 26.615 MHz
Channel 10 26.625 MHz
Channel 11 26.635 MHz
Channel 11A 26.645 MHz
Channel 12 26.655 MHz
Channel 13 26.655 MHz
Channel 14 26.675 MHz
Channel 15 26.685 MHz
Channel 15A 26.695 MHz
Channel 16 26.705 MHz
Channel 17 26.715 MHz
Channel 18 26.725 MHz
Channel 19 26.735 MHz
Channel 19A 26.745 MHz
Channel 20 26.755 MHz
Channel 21 26.765 MHz
Channel 22 26.775 MHz
Channel 23 26.805 MHz
Channel 24 26.785 MHz
Channel 25 26.795 MHz
Channel 26 26.815 MHz
Channel 27 26.825 MHz
Channel 28 26.835 MHz
Channel 29 26.845 MHz
Channel 30 26.855 MHz
Channel 31 26.865 MHz
Channel 32 26.875 MHz
Channel 33 26.885 MHz
Channel 34 26.895 MHz
Channel 35 26.905 MHz
Channel 36 26.915 MHz
Channel 37 26.925 MHz
Channel 38 26.935 MHz
Channel 39 26.945 MHz
Channel 40 26.955 MHz
Channel 40A 26.965 MHz
Band D Channel Frequency
Channel 3A 26.995 MHz
Channel 7A 27.045 MHz
Channel 11A 27.095 MHz
Channel 15A 27.145 MHz
Channel 19A 27.195 MHz
Channel 40A 27.415 MHz
Band E Channel Frequency
Channel 1 27.415 MHz
Channel 2 27.425 MHz
Channel 3 27.435 MHz
Channel 3A 27.445 MHz
Channel 4 27.455 MHz
Channel 5 27.465 MHz
Channel 6 27.475 MHz
Channel 7 27.485 MHz
Channel 7A 27.495 MHz
Channel 8 27.505 MHz
Channel 9 27.515 MHz
Channel 10 27.525 MHz
Channel 11 27.535 MHz
Channel 11A 27.545 MHz
Channel 12 27.555 MHz
Channel 13 27.565 MHz
Channel 14 27.575 MHz
Channel 15 27.585 MHz
Channel 15A 27.595 MHz
Channel 16 27.605 MHz
Channel 17 27.615 MHz
Channel 18 27.625 MHz
Channel 19 27.635 MHz
Channel 19A 27.645 MHz
Channel 20 27.655 MHz
Channel 21 27.665 MHz
Channel 22 27.675 MHz
Channel 23 27.705 MHz
Channel 24 27.685 MHz
Channel 25 27.695 MHz
Channel 26 27.715 MHz
Channel 27 27.735 MHz
Channel 28 27.735 MHz
Channel 29 27.745 MHz
Channel 30 27.755 MHz
Channel 31 27.765 MHz
Channel 32 27.775 MHz
Channel 33 27.785 MHz
Channel 34 27.795 MHz
Channel 35 27.805 MHz
Channel 36 27.815 MHz
Channel 37 27.825 MHz
Channel 38 27.835 MHz
Channel 39 27.845 MHz
Channel 40 27.855 MHz
Channel 40A 27.865 MHz
Band F Channel Frequency
Channel 1 27.865 MHz
Channel 2 27.875 MHz
Channel 3 27.885 MHz
Channel 3A 27.895 MHz
Channel 4 27.905 MHz
Channel 5 27.915 MHz
Channel 6 27.925 MHz
Channel 7 27.935 MHz
Channel 7A 27.945 MHz
Channel 8 27.955 MHz
Channel 9 27.965 MHz
Channel 10 27.975 MHz
Channel 11 27.985 MHz
Channel 11A 27.995 MHz
Channel 12 28.005 MHz
Channel 13 28.015 MHz
Channel 14 28.025 MHz
Channel 15 28.035 MHz
Channel 15A 28.045 MHz
Channel 16 28.055 MHz
Channel 17 28.065 MHz
Channel 18 28.075 MHz
Channel 19 28.085 MHz
Channel 19A 28.095 MHz
Channel 20 28.105 MHz
Channel 21 28.115 MHz
Channel 22 28.125 MHz
Channel 23 28.155 MHz
Channel 24 28.135 MHz
Channel 25 28.145 MHz
Channel 26 28.165 MHz
Channel 27 28.175 MHz
Channel 28 28.185 MHz
Channel 29 28.195 MHz
Channel 30 28.205 MHz
Channel 31 28.215 MHz
Channel 32 28.225 MHz
Channel 33 28.235 MHz
Channel 34 28.245 MHz
Channel 35 28.255 MHz
Channel 36 28.265 MHz
Channel 37 28.275 MHz
Channel 38 28.285 MHz
Channel 39 28.295 MHz
Channel 40 28.305 MHz
Channel 40A 28.315 MHz
Channel 1 26.968 MHz
Channel 2 26.976 MHz
Channel 3 27.040 MHz
Channel 4 27.080 MHz
Channel 5 27.088 MHz
Channel 6 27.112 MHz
Channel 7 27.120 MHz
Channel 8 27.144 MHz
Channel 26760 26.760 MHz
Channel 26768 26.768 MHz
Channel 26776 26.776 MHz
Channel 26824 26.824 MHz
Channel 26840 26.840 MHz
Channel 26848 26.848 MHz
Channel 26856 26.856 MHz
Channel 26864 26.864 MHz
Channel 26872 26.872 MHz
Channel 26880 26.880 MHz
Channel 26888 26.888 MHz
Channel 26896 26.896 MHz
Channel 26912 26.912 MHz
Channel 26920 26.920 MHz
Channel 26928 26.928 MHz
Channel 26936 26.936 MHz
Channel 26944 26.944 MHz
Channel 27016 27.016 MHz
Channel 27524 27.524 MHz
Channel 27532 27.532 MHz
Channel 27540 27.540 MHz
Channel 27548 27.548 MHz
Channel 27556 27.556 MHz
Channel 27572 27.572 MHz
Channel 27580 27.580 MHz
Channel 27628 27.628 MHz
Channel 27636 27.636 MHz
Channel 27644 27.644 MHz
Channel 27652 27.652 MHz
Channel 27660 27.660 MHz
Channel 27668 27.668 MHz
Channel 27676 27.676 MHz
Channel 27724 27.724 MHz
Channel 27732 27.732 MHz
Channel 27740 27.740 MHz
Channel 27748 27.748 MHz
Channel 27756 27.756 MHz
Channel 27764 27.764 MHz
Channel 27772 27.772 MHz
Channel 27780 27.780 MHz
Channel 27828 27.828 MHz
Channel 27836 27.836 MHz
Channel 27852 27.852 MHz
Channel 27860 27.860 MHz
Channel 27884 27.884 MHz
Channel 27892 27.892 MHz
Channel 27908 27.908 MHz
Channel 27916 27.916 MHz
Channel 27932 27.932 MHz
Channel 27940 27.940 MHz
Channel 27956 27.956 MHz
Channel 27964 27.964 MHz
Channel 27980 27.980 MHz
Channel 27988 27.988 MHz
27310.5 kHz 27.3105 MHz
27334.5 kHz 27.3345 MHz
27338.5 kHz 27.3385 MHz
27342.5 kHz 27.3425 MHz
27346.5 kHz 27.3465 MHz
27350.5 kHz 27.3505 MHz
27354.5 kHz 27.3545 MHz
27358.5 kHz 27.3585 MHz
27362.5 kHz 27.3625 MHz
27366.5 kHz 27.3665 MHz
27370.5 kHz 27.3705 MHz
27378.5 kHz 27.3785 MHz
27382.5 kHz 27.3825 MHz
27386.5 kHz 27.3865 MHz
27388.5 kHz 27.3885 MHz
27398.5 kHz 27.3985 MHz
27404.5 kHz 27.4045 MHz
27418.5 kHz 27.4185 MHz
27426.5 kHz 27.4265 MHz
27434.5 kHz 27.4345 MHz
27442.5 kHz 27.4425 MHz
27452.5 kHz 27.4525 MHz
27458.5 kHz 27.4585 MHz
27466.5 kHz 27.4665 MHz
27470.5 kHz 27.4705 MHz
  • SPECIFICATIONS
  • 25 kHz channel spacing
  • 480 channels
  • FEATURES
  • SPECIFICATIONS
  • 20 channels
  • AM modulation
  • FEATURES
IND08 - Use of wireless equipments intended to be used while in motion or during halts, in the frequency band 26.957 MHz - 27.283 MHz, with a maximum Effective Radiated Power ( ERP) of 5 Watts has been exempted from licensing requirements.
Channel 41 27.415 MHz
Channel 42 27.425 MHz
Channel 43 27.435 MHz
Channel 44 27.455 MHz
Channel 45 27.465 MHz
Channel 46 27.475 MHz
Channel 47 27.485 MHz
Channel 48 27.505 MHz
Channel 49 27.515 MHz
Channel 50 27.525 MHz
Channel 51 27.535 MHz
Channel 52 27.555 MHz
Channel 53 27.565 MHz
Channel 54 27.575 MHz
Channel 55 27.585 MHz
Channel 56 27.605 MHz
Channel 57 27.615 MHz
Channel 58 27.625 MHz
Channel 59 27.635 MHz
Channel 60 27.655 MHz
Channel 61 27.665 MHz
Channel 62 27.675 MHz
Channel 63 27.685 MHz
Channel 64 27.695 MHz
Channel 65 27.705 MHz
Channel 66 27.715 MHz
Channel 67 27.725 MHz
Channel 68 27.735 MHz
Channel 69 27.745 MHz
Channel 70 27.755 MHz
Channel 71 27.765 MHz
Channel 72 27.775 MHz
Channel 73 27.785 MHz
Channel 74 27.795 MHz
Channel 75 27.805 MHz
Channel 76 27.815 MHz
Channel 77 27.825 MHz
Channel 78 27.835 MHz
Channel 79 27.845 MHz
Channel 80 27.855 MHz
27.600 MHz 27.800 MHz Jamaica, FM mode Optional CTCSS PL 88.5 Hz - part of 4 linked FM CB 11m repeaters with +200 kHz offset - likely off the air
27.620 MHz 27.820 MHz Jamaica, FM mode Optional CTCSS PL 88.5 Hz - part of 4 linked FM CB 11m repeaters with +200 kHz offset - likely off the air
27.640 MHz 27.840 MHz Jamaica, FM mode Optional CTCSS PL 88.5 Hz - part of 4 linked FM CB 11m repeaters with +200 kHz offset - likely off the air
27.660 MHz 27.860 MHz Jamaica, FM mode Optional CTCSS PL 88.5 Hz - part of 4 linked FM CB 11m repeaters with +200 kHz offset - likely off the air
Below is a list of confirmed [as of December 2019] CB repeaters and their location (if known).
26.575 MHz Germany
26.675 MHz
26.685 MHz Western Russia
26.915 MHz
26.925 MHz
26.970 MHz Lithuania
26.985 MHz Tver, Russia
27.000 MHz Kiev, Ukraine
27.030 MHz Minsk, Belarus
27.040 MHz Minsk, Belarus
27.060 MHz Kiev, Ukraine
27.075 MHz Eastern Russia
27.100 MHz Krasnodar, Russia
27.105 MHz Astana, Kazakhstan
27.110 MHz Poland
27.110 MHz Russia
27.135 MHz Moscow, Russia
27.150 MHz Poland
27.165 MHz Issyk, Kazakhstan
27.170 MHz Poland
27.175 MHz Taraz, Kazakhstan
27.190 MHz
27.200 MHz Zaykova, Russia
27.215 MHz Almaty, Kazakhstan
27.220 MHz
27.230 MHz
27.235 MHz
27.250 MHz Belarus
27.270 MHz Saratov, Russia
27.270 MHz Kiev, Ukraine
27.290 MHz Minsk, Belarus
27.295 MHz Tyumen, Russia
27.300 MHz
27.305 MHz Western Europe
27.325 MHz
27.335 MHz Almaty, Kazakhstan
27.370 MHz Western Russia
27.430 MHz
27.450 MHz
27.470 MHz
27.505 MHz Moscow, Russia
27.580 MHz Moscow, Russia
27.605 MHz Moscow, Russia
27.630 MHz Moscow, Russia
27.635 MHz Moscow, Russia
27.650 MHz Western Europe
27.675 MHz Russia
27.765 MHz Germany
27.840 MHz Poland
27.875 MHz Rostov, Russia
does AM radio still exist can you still buy CB radios do people still use CB radios CB radio for emergency emergencies prepper channels 26.96 - 27.41 MHz Citizen Radio Citizens Radio wikipedia CB frequencies on a Baofeng CB channels on a ham radio 26 MHz band what are the CB frequencies CB channel chart CB frequency chart UK USA UHF CB VHF CB HF CB AM CB SSB CB 120 channel CB channel range how far can a CB radio go CB antennas CB radio reviews do truckers still use CB radio 2018 2019 2020 today police CB radio frequencies channels 30 MHz band CB radio channels freeband channels freeband frequencies what is the best freeband radio CB radio police what CB channel do police use? they don't use CB radios and haven't for about 30 years...there are a lot of other users of CB radio though...freebanding frequencies channels prepper 25 MHz band 26 MHz band 27 MHz band 28 MHz 30 MHz band 30.555 MHz 30.105 MHz 25.615 MHz 27.405 MHz 26.955 MHz 26.505 MHz 26.515 MHz 26.510 MHz 26MHz taxi cab radio Uber radio Lyft radio two-way radio system taxicab radio dispatch YL Russia CADS UK 27/81 WPAS 120 channel mod frequency kit Lescomm DigiMax Lite Viagra board Cobra 29 channel kit 240 channel 360 channel 128 channel MB8719 RCI8719 cbradio.nl cbtricks.com EPT3600 board main board CB radio PCB 26.065 MHz 26.505 MHz 27500 kHz 27.500 MHz 27.5 MHz CB radio warfare RCI CRT EPT690010Z EPT6900 Uniden Cobra Galaxy Magnum SR-94C Galaxy DX radios 10kc 10kHz switch A channels secret channels phantom frequencies CB radio prepper frequencies hunting radios CB radio range 27 MHz RC transmitter PB010 PC879 PLL02A UPD858 MC145106 CB repeater CB VHF repeater CB MURS GMRS crossband cross-band GMRS MURS repeater 151.820 MHz 151.880 MHz 151.940 MHz 154.570 MHz 154.600 MHz 151.940 156.7 simplex repeater 27.205 MHz 462.550 - 467.7125 MHz radiobuoy fishnet beacon 26MHz 26.500 MHz 26500 kHz 26.450 MHz 26450 kHz 26MHz NZ CB UK FM 27/97 PR27 27 MHz FM CB can I use ham radio on CB frequencies what is 30 MHz band CB frequencies 10 meter intruders 11 meter taxi cab dispatch 26.285 USB 27.555 USB 27.185 AM 151.880 167.9 repeater 151.940 repeater simplex unlicensed illegal license free freebanders truckers on 25 MHz truckers on 10 meters unlicensed UHF frequencies MURS mobile CB mobile 25.615-30.105 MHz mobile radio handheld walkie talkie BF-888 Baofeng BF-888S BF-88A FRS on BF-888 B-888 work site radios Motorola Kenwood Icom BTECH unlicensed VHF frequencies MURS frequencies what are the CB channels police CB radio speed trap trucker talk CB radio HF truckers on CB channel 19 27.185 MHz 27185 kHz 27,185 27.180 MHz 27.635 MHz CADS WPAS Russian Taxis 24.715 MHz 25.165 MHz 25.615 MHz UK PO PL band 26.960 MHz 27.400 MHz what band is 30 MHz what frequency does military use CB radio channels what are the CB channels? 27.5 - 39.5 MHz 39.475 MHz HF radiotelephone fishery radio fisheries radio fisheries telephone radio 24.265 MHz 29.655 MHz 29.695 MHz 29.699 MHz 29.705 MHz 29.710 MHz bellscb rightchannelradios 26957 26.957 27120 27.120 MHz ISM band IoT bands 26-27 MHz data link transmitter 150 MHz truck radio hunting radio VHF CB radio 30.450 MHz 30.105 MHz 26-32 MHz 26-30 MHz 25-30 MHz 25.91 MHz 25.95 MHz 25.99 MHz 26.470 MHz marine radio CB RCI-2995 27.385 LSB ham radio gear on CB frequencies CB channels on a ham radio Anytone AT-5189 26-33 MHz 33-49 MHz 136-174 MHz 220-260 MHz 240-270 MHz 300-350 MHz 350-390 MHz 400-470 MHz 450-512 MHz 450-520 MHz 600 MHz band 700 MHz band
