MURS
Multi Use Radio Service
MURS Frequencies / Channels:
Common analog voice emissions (generally FM voice) include 11K2F3E, 11K0F3E, 10K0F3E, 9K20F3E and 9K10F3E (Baofeng radios) for MURS channels 1, 2 and 3. 20K0F3E and 16K0F3E are allowed on MURS 4 and 5. Radios used by Wal-Mart, for example, transmit 20K0F3E emission on 154.57 MHz and 154.6 MHz but transmit 11K0F3E on 151.82 MHz, 151.88 MHz and 151.94 MHz. All five MURS frequencies are heavily used by WalMart and Sam's Club stores.
- Are the "color dot" frequencies license free or part of MURS? Yes and no. Only the Blue Dot and Green Dot channels are license free and part of MURS. The other color dot frequencies, star frequencies, etc. require FCC Part 90 Business Radio licenses to operate on. You must have a license to use 151.625 MHz, 151.955 MHz, 467.925 MHz, 467.850 MHz, 467.7625 MHz, 464.500 MHz and 464.550 MHz, for example.
- Are Baofeng radios legal? This is a gray area. If you use the MURS or FRS frequencies you should be good to go. Make sure to use narrowband mode on the MURS and FRS/GMRS frequencies.
- Are MURS channels part of the CB radio service? Legally and technically, yes.
Motorola RMM2050 5 channel MURS radio default channels:
- Channel 1 - 154.5700 MHz 67.0 Hz PL 20.0 kHz bandwidth [Identified in radio programming as Frequency 1] - MURS 4
- Channel 2 - 154.6000 MHz 67.0 Hz PL 20.0 kHz bandwidth [Identified in radio programming as Frequency 2] - MURS 5
- Channel 3 - 151.8200 MHz 67.0 Hz PL 11.25 kHz bandwidth [Identified in radio programming as Frequency 3] - MURS 1
- Channel 4 - 151.8800 MHz 67.0 Hz PL 11.25 kHz bandwidth [Identified in radio programming as Frequency 4] - MURS 2
- Channel 5 - 151.9400 MHz 67.0 Hz PL 11.25 kHz bandwidth [Identified in radio programming as Frequency 5] - MURS 3
Motorola CP110M 8 channel MURS radio default channels:
- Channel 1 - 154.5700 MHz 67.0 Hz PL 20.0 kHz bandwidth [Identified in radio programming as Frequency 2] - MURS 4
- Channel 2 - 154.6000 MHz 67.0 Hz PL 20.0 kHz bandwidth [Identified in radio programming as Frequency 1] - MURS 5
- Channel 6 - 154.5700 MHz CSQ 20.0 kHz bandwidth [Identified in radio programming as Frequency 2] - MURS 4
- Channel 7 - 154.6000 MHz CSQ 20.0 kHz bandwidth [Identified in radio programming as Frequency 1] - MURS 5
- Channel 8 - 151.8200 MHz CSQ 11.25 kHz bandwidth [Identified in radio programming as Frequency 3] - MURS 1
Motorola RDM2070D 7 channel Wal-Mart MURS radio default channels:
- Channel 1 - 154.5700 MHz CSQ
- Channel 2 - 154.6000 MHz CSQ
- Channel 3 - 151.8200 MHz 136.5 Hz PL
- Channel 4 - 151.8800 MHz 136.5 Hz PL
- Channel 5 - 151.9400 MHz 136.5 Hz PL
- Channel 6 - 154.5700 MHz 136.5 Hz PL
- Channel 7 - 154.6000 MHz 136.5 Hz PL
Note: Wal-Mart stores will often re-program their radios to use different CTCSS (PL) tones in areas where frequency congestion is an issue. However, a significant number of stores continue to use CSQ (carrier squelch) on 154.570 MHz and 154.600 MHz. Use of non-MURS frequencies by some Wal-Mart (and Sam's Club) stores has also been reported along with use of the 151.820 MHz, 151.880 MHz and 151.940 MHz MURS frequencies with carrier squelch. Like other Motorola MURS radios, the RDM2070 is hard-programmed for wideband 20 kHz FM on 154.57 and 154.6 MHz.
Motorola RDM2020 2 channel MURS radio default channels:
Motorola RDM2080D 8 channel MURS radio default channels:
- 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Mount Jackson, Virginia (Shenandoah County, VA) very large coverage area
- 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Richmond, Virginia (low power, 2w transmitter, around 5w ERP - located in downtown Richmond, VA)
- The Mount Jackson, VA MURS simplex repeater has 50+ mile coverage in the valleys below and even further from higher elevations in the Blue Ridge Mountains and Virginia Piedmont region. Coverage extends into portions of eastern West Virginia. Confirmed active August 2019.
- The Richmond, VA MURS simplex repeater has considerably less coverage due to its low power transmitter and location in an urban area. Coverage is reliable in downtown Richmond and other areas of the city. Both of these MURS repeaters use MURS ch 2 - 151.880 MHz and CTCSS / PL tone 156.7 Hz for transmit and receive. The Richmond MURS repeater is off-grid power (solar powered with battery backup) to help support emergency communications. Confirmed active February 2020.
- 151.8200 MHz - Militia/Patriot MURS VHF MURS 1
- 151.8800 MHz - Militia/Patriot MURS VHF MURS 2
- 151.9400 MHz - Militia/Patriot MURS VHF Primary/Calling MURS 3 - AmRRON VHF
- 154.5700 MHz - Militia/Patriot MURS VHF MURS 4
- 154.6000 MHz - Militia/Patriot MURS VHF MURS 5
- 154.6550 MHz - Militia/Patriot VHF BUSINESS 25
Alternate VHF militia plans:
- 151.8200 MHz - Channel 1 - Operations MURS 1
- 151.8800 MHz - Channel 2 - Operations MURS 2
- 151.9400 MHz - Channel 3 - Calling Primary / Operations MURS 3
- 154.5700 MHz - Channel 4 - Operations MURS 4
- 154.6000 MHz - Channel 5 - Operations MURS 5
- 151.9100 MHz - Channel 6 - Operations VHF 6 Business Band
- 154.5550 MHz - Channel 7 - Operations VHF 7 Business Band
- 154.6250 MHz - Channel 8 - Operations VHF 8 Business Band
- 151.5950 MHz - Channel 9 - Operations VHF 9 Business Band
- 151.5050 MHz - Channel 10 - Operations 10 VHF Itinerant Business
- 151.5125 MHz - Channel 11 - Operations 11 VHF Itinerant Business
- 151.6250 MHz - Channel 12 - Operations 12 VHF Itinerant Business
- 151.6400 MHz - Channel 13 - Operations 13 VHF Itinerant Business
- 151.7000 MHz - Channel 14 - Operations 14 VHF Itinerant Business
- 151.7600 MHz - Channel 15 - Operations 15 VHF Itinerant Business
Alternate frequency plans simply put the channels in order by frequency, including the MURS frequencies i.e. 151.775 MHz, 151.805 MHz, 151.820 MHz, 151.835 MHz, 151.865 MHz, 151.880 MHz, 151.895 MHz, 151.925 MHz, 151.940 MHz, 151.955 MHz, etc.. Given the variation in channel identifier schemes and channel numbering plans, its best to either refer to a channel by its frequency or a pre-planned channel number / identifier within a given militia unit. The same could be said for 26 MHz / 27 MHz AM/SSB CB 11 meter freeband frequencies and the UHF channels.
All frequencies should be programmed in NARROWBAND mode. Narrow FM, NFM, NBFM, 12.5 kHz, 12 kHz etc. Wideband 20K 20 kHz or 25 kHz may be used on 154.570 MHz and 154.600 MHz only.
