Militia Radio Frequencies
Revision as of 12:17, 24 March 2021 by R4002 (Talk | contribs)
  • Channel 9 - 467.5875 MHz - FRS 9 - Tac, Calling/Mutual Aid
  • Channel 13 - 467.6875 MHz - FRS 13 - Tac
  • Channel 32 - 151.8800 MHz - MURS 2 - Command or Safety Channel
  • Channel 33 - 151.9400 MHz - MURS 3 - Primary Patriot Militia Calling or Prepper Frequency Prep
  • Channel 34 - 154.5700 MHz - MURS 4 - Command Blue
  • Channel 35 - 154.6000 MHz - MURS 5 - Command Green
  • MURS 1 - 151.8200 MHz - 88.5 Hz CALL
  • MURS 2 - 151.8800 MHz - 88.5 Hz or 210.7 Hz CTCSS SAFETY tone transmit recommend 210.7 Hz PL
  • MURS 3 - 151.9400 MHz - 88.5 Hz or 141.3 Hz CTCSS PREP tone transmit 141.3 Hz PL
  • MURS 4 - 154.5700 MHz - 88.5 Hz COMMAND/TAC BLUE
  • MURS 5 - 154.6000 MHz - 88.5 Hz COMMAND/TAC GREEN
  • Channel 032 - MURS 2 - 151.8800 MHz - Mode: NFM - Tone: 210.7 Hz - display channel name: MURS 2
  • Channel 033 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: MURS 3
  • Channel 045 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 141.3 - display channel name: MURS 3 CALL - high power setting
  • Channel 124 - MURS 2 - 151.8800 MHz - Mode: NFM - Tone: 210.7 Hz - display channel name: MURS 2 HP - high power setting
  • Channel 125 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: MURS 3 HP - high power setting
  • FRS Channels 1-16 (allows simple interoperability with standard FRS radios and standard militia programmed radios). Tone mode should be set to Tone (not TSQL - unless you are programming radios for a group/unit/team/squad/crew specific channel plan - see links and general information above and example programming plans below).
  • Channel 01 - 462.5625 MHz - FRS Channel 1
  • Channel 02 - 462.5875 MHz - FRS Channel 2
  • Channel 03 - 462.6125 MHz - FRS Channel 3
  • Channel 04 - 462.6375 MHz - FRS Channel 4
  • Channel 05 - 462.6625 MHz - FRS Channel 5
  • Channel 06 - 462.6875 MHz - FRS Channel 6
  • Channel 07 - 462.7125 MHz - FRS Channel 7
  • Channel 08 - 467.5625 MHz - FRS Channel 8
  • Channel 09 - 467.5875 MHz - FRS Channel 9
  • Channel 10 - 467.6125 MHz - FRS Channel 10
  • Channel 11 - 467.6375 MHz - FRS Channel 11
  • Channel 12 - 467.6625 MHz - FRS Channel 12
  • Channel 13 - 467.6875 MHz - FRS Channel 13
  • Channel 14 - 467.7125 MHz - FRS Channel 14
  • Channel 15 - 462.5500 MHz - FRS Channel 15
  • Channel 16 - 462.5750 MHz - FRS Channel 16
  • Example 16-channel intra squad radio inter squad radio plan - using FRS frequencies only - tone type is TSQL (fully toned) and all radios must be programmed identically. Use of full tone squelch will reduce interference from co-channel users but will prevent interoperability with other groups unless their radios are programmed to use the exact same tone squelch. For this reason, users are cautioned to only use full tone squelch (transmit and receive squelch) for communications within their own trusted group. For additional template private (toned) frequency channel plans using FRS frequencies - see the full list here.
  • Channel 01 - 467.6625 MHz - 171.3 Hz CTCSS FRS Channel 12
  • Channel 02 - 467.5625 MHz - 165.5 Hz CTCSS FRS Channel 8
  • Channel 03 - 467.6375 MHz - 171.3 Hz CTCSS FRS Channel 11
  • Channel 04 - 462.7000 MHz - 210.7 Hz CTCSS FRS Channel 21
  • Channel 05 - 467.7125 MHz - 165.5 Hz CTCSS FRS Channel 14
  • Channel 06 - 462.6000 MHz - 210.7 Hz CTCSS FRS Channel 17
  • Channel 07 - 462.6500 MHz - 210.7 Hz CTCSS FRS Channel 19
  • Channel 08 - 467.6125 MHz - 171.3 Hz CTCSS FRS Channel 10
  • Channel 09 - 467.5875 MHz - 199.5 Hz CTCSS FRS Channel 9
  • Channel 10 - 462.5750 MHz - 210.7 Hz CTCSS FRS Channel 16
  • Channel 11 - 462.6750 MHz - 210.7 Hz CTCSS FRS Channel 20
  • Channel 12 - 462.5500 MHz - 210.7 Hz CTCSS FRS Channel 15
  • Channel 13 - 462.5875 MHz - 229.1 Hz CTCSS FRS Channel 2
  • Channel 14 - 462.6875 MHz - 229.1 Hz CTCSS FRS Channel 6
  • Channel 15 - 462.6125 MHz - 225.7 Hz CTCSS FRS Channel 3
  • Channel 16 - 462.7125 MHz - 233.6 Hz CTCSS FRS Channel 7
  • Example 16-channel intra squad radio inter squad radio plan - using business frequencies only - tone type is TSQL (fully toned) and all radios must be programmed identically. Use of full tone squelch will reduce interference from co-channel users but will prevent interoperability with other groups unless their radios are programmed to use the exact same tone squelch. For this reason, users are cautioned to only use full tone squelch (transmit and receive squelch) for communications within their own trusted group. For additional template private (toned) frequency channel plans - see the full list here.
  • Channel 01 - 467.8375 MHz - XXX.X Hz CTCSS
  • Channel 02 - 469.5125 MHz - XXX.X Hz CTCSS
  • Channel 03 - 456.3375 MHz - XXX.X Hz CTCSS
  • Channel 04 - 456.4375 MHz - XXX.X Hz CTCSS
  • Channel 05 - 467.8625 MHz - XXX.X Hz CTCSS
  • Channel 06 - 467.8875 MHz - XXX.X Hz CTCSS
  • Channel 07 - 462.7875 MHz - XXX.X Hz CTCSS
  • Channel 08 - 462.8875 MHz - XXX.X Hz CTCSS
  • Channel 09 - 462.8375 MHz - XXX.X Hz CTCSS
  • Channel 10 - 469.5625 MHz - XXX.X Hz CTCSS
  • Channel 11 - 457.6625 MHz - XXX.X Hz CTCSS
  • Channel 12 - 452.1875 MHz - XXX.X Hz CTCSS
  • Channel 13 - 451.4375 MHz - XXX.X Hz CTCSS
  • Channel 14 - 457.7125 MHz - XXX.X Hz CTCSS
  • Channel 15 - 451.3375 MHz - XXX.X Hz CTCSS
  • Channel 16 - 467.8000 MHz - XXX.X Hz CTCSS
The most commonly used frequencies are 464.550 MHz, 464.500 MHz, 467.925 MHz, 467.900 MHz, 467.875 MHz, 467.850 MHz, 467.8125 MHz, 467.7625 MHz, 469.550 MHz, 469.500 MHz, 451.800 MHz, 456.800 MHz, 451.8125 MHz, 456.8125 MHz, 461.0375 MHz, 461.0625 MHz, and 461.0875 MHz. Avoid using those frequencies if at all possible and monitor the particular frequency use in your area.
