SINCGARS
Revision as of 17:25, 21 April 2023 by R4002 (Talk | contribs)
For example:
  • Relay Operation:
  • Repeater Operation:
Background and History
60.000 MHz to 80.000 MHz TBS "Talk Between Ships" - VHF 60-80 MC 60-80 MHz Ship to Ship voice radio 60-80 MC radio - US Navy AM mode 50w output VHF Crystal controlled 60-80 MHz AM voice unknown channel spacing - TBS radio crystals for 65.74 MHz and 72.50 MHz have been found
27.000 MHz to 38.900 MHz American Artillery Band (U.S. Army) - note 27.0 MHz, 27.1 MHz, 27.2 MHz up to 27.9 MHz overlap 100 kHz (channels 270-389), PRC-9, PRC-9A, SCR-608, SCR-609, SCR-610, SCR-628
38.000 MHz to 54.900 MHz American Infantry Band (U.S. Army) - note 38.0 MHz, 38.1 MHz, 38.2 MHz up to 38.9 MHz overlap 100 kHz (channels 380-549), PRC-10, PRC-10A
40.000 MHz to 48.000 MHz American Infantry Band - portable VHF FM tactical radios - WWII vintage 200 kHz - channel 0 = 40.0 MHz, channel 40 = 48.0 MHz, SCR-300 (BC-1000) manpack backpack radio
42.000 MHz to 48.300 MHz German Air-to-Ground Band (see also: 42.0 MHz - 47.8 MHz and 42.1 MHz - 47.8 MHz) 50 kHz channels - AM voice with FM characteristics, close air support and tank command nets
20.000 MHz to 52.000 MHz Soviet / Eastern Bloc USSR R-111 (low band: 20-36 MHz, high band: 36-52 MHz) High power (75w) Russian FM tank radio
20.000 MHz to 22.375 MHz Soviet / Eastern Bloc USSR R-113 (25 kHz channel steps, 96 channels) Medium power (16w) Russian FM tank radio
20.000 MHz to 51.500 MHz Soviet / Eastern Bloc USSR R-123 R-123M (low band: 20-35.75 MHz, high band: 35.75-51.5 MHz) Medium power (20w) Russian FM tank radio
20.000 MHz to 69.975 MHz Yugoslavian tank radio - exported widely, 25 kHz channel steps) Medium power (30w) FM tank radio
20.000 MHz to 49.975 MHz Chinese FM tank radio (example Type 889 radio) - widely exported - 25 kHz channel steps Chinese clone of Russian 20-50 MHz tank radios (such as the R-113 or P-113) - FM voice, 25 kHz channels 3w low 20w high RF power
30.000 MHz to 75.950 MHz Tactical Band (30-76 MHz) (150 Hz CTCSS "new squelch" system) removes need for manual squelch control 50 kHz (channelized intent frequency control) PRC-25, PRC-77, VRC-12 family using the RT-246/VRC RT-246A RT-542 RT-542/VRC RT-542A/VRC radio sets - AN/VRC-12, VRC-43, VRC-44, VRC-45, VRC-46, VRC-47, VRC-48, VRC-49 Jeep radios, etc. and dozens of others
30 MHz to 512 MHz Tactical Band (30-88 MHz) combined with VHF/UHF bands, including the airband, VHF marine band, VHF land mobile bands, REMBASS 138.025 MHz to 152.975 MHz (25 kHz steps) - sometimes listed as 30-511.99 MHz or 30.000 MHz to 511.995 MHz 25 kHz step, single channel SC (fixed frequency) mode or frequency hopping FH (anti-jamming countermeasure) mode, 2.5, 5, 8.33 kHz steps
2400-2500 MHz (2.4 GHz) Intra-Squad Radio (ISR) and Improved Intra Squad Radio (IISR) systems - including the Personal Role Radio (PRR) Various frequency steps and modes (including spread spectrum and frequency hopping) used for short range communications within squads/fireteams
Frequency Band
30.000 MHz to 30.550 MHz
32.000 MHz to 33.000 MHz
34.000 MHz to 35.000 MHz
36.000 MHz to 37.000 MHz
38.000 MHz to 39.000 MHz
40.000 MHz to 42.000 MHz
46.600 MHz to 47.000 MHz
49.600 MHz to 50.000 MHz
For additional information, see the Business Radio (Business Band) land mobile radio service page - including the VHF low band subsection.
  • 40.000 MHz - 42.000 MHz - Federal - FIXED, MOBILE, LAND MOBILE - The military agencies operate radio communication systems in this band for networks providing command and control for combat, combat support, and combat service support as part of tactical and training operations. They also operate tactical air-to-ground and air-to-air communication systems for close air support missions. The federal agencies operate land mobile radio communication systems used in the operation, protection, and maintenance of national parks, forests, wildlife refuge areas, and to support public safety operations, environmental data collection, fish management, and wildlife telemetry programs. The federal agencies operate meteor-burst communications systems in this band to provide beyond line-of-sight communications and telemetry. A typical application is the Department of Agriculture transmitting snow fall data from numerous sensors to a central location - the SNOTEL system on 40.67 MHz.
Confirmed 30-88 MHz and 30-50 MHz FM Military Frequencies In Use North America USA
Some of these are active enough to operate basically as de facto VHF low band beacons.
Most military bases have a few VHF FM frequencies that are used for range control, aircraft control or advisory and other purposes. These are published frequencies and are not tactical in nature. The tactical frequencies are changed on a regular basis and often either the LMR (UHF P25 trunking systems in the 380-399.9 MHz range), frequency hopping (30-88 MHz range). Aircraft communications will be found in the UHF band, plus the 137-144 MHz and 148-150.8 MHz military VHF AM band (which is shared with military land mobile users). Many military bases will have their control tower simulcast on UHF airband (225-400 MHz) with VHF airband (usually 126.200 MHz) and sometimes a FM frequency (VHF low band).
Work still in progress, list will be forthcoming.
  • 30.000 MHz FM CSQ - Default frequency (tone OFF) - also used for radio tests and training
  • 30.000 MHz FM 150 Hz - Default frequency - often used for radio tests, training
  • 30.000 MHz FM 150.0 Hz - Convoy operations
  • 30.025 MHz FM 150 Hz - Air to air communications, helicopters - extensive use
  • 30.050 MHz FM 150.0 Hz - Fort McCoy, Wisconsin - Air to air
  • 30.100 MHz FM 150.0 Hz - Air to air communications, helicopters - New York and New Jersey areas
  • 30.150 MHz FM 150.0 Hz - Quantico Marine Corps Base Virginia - Air to ground
  • 30.150 MHz FM 150.0 Hz - Air to air communications, helicopters, Washington D.C. area
  • 30.300 MHz FM 150.0 Hz - Air to air communications, helicopters - extensive use
  • 30.300 MHz FM 150.0 Hz - Fort Hood, Texas operations
  • 30.450 MHz FM 150.0 Hz - Fort Hood, Texas Range Control Primary 30.45 FM 30.450 MHz FM
  • 30.500 MHz FM 150.0 Hz - Joint Base Lewis-McChord - Gray Army Airfield - Air Operations
  • 30.500 MHz FM 150.0 Hz - Fort McCoy, Wisconsin - Air to air
  • 30.500 MHz FM 150.0 Hz - Fort Sill, Oklahoma - Range Control Alternate
  • 30.600 MHz FM 150.0 Hz - Air to air communications, helicopters
  • 30.700 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 30.800 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 31.000 MHz FM 150.0 Hz - Convoy operations
  • 31.100 MHz FM 150.0 Hz - Air to air, helicopters
  • 31.200 MHz FM 150.0 Hz - Air to air, helicopters
  • 31.500 MHz FM 150.0 Hz - Convoy operations
  • 31.700 MHz FM 150.0 Hz - Convoy operations
  • 32.050 MHz FM 150.0 Hz - Raptor Net
  • 32.100 MHz FM 150.0 Hz - Range control
  • 32.225 MHz FM 150.0 Hz - Convoy use, motor pool, air to air
  • 32.300 MHz FM 150.0 Hz - Convoy use, motor pool, air to air
  • 32.325 MHz FM 150.0 Hz - Convoy use, motor pool, air to air
  • 32.600 MHz FM 150.0 Hz - Joint Base Lewis-McChord - Gray Army Airfield - Air National Guard Operations 32.600 MHz FM
  • 32.700 MHz FM 150.0 Hz - Joint Base Lewis-McChord - Washington State
  • 32.700 MHz FM 150.0 Hz - Convoy operations
  • 32.750 MHz FM 150.0 Hz - Convoy operations
  • 32.825 MHz FM 150.0 Hz - Fort Rucker, Alabama - Lowe Army Heliport
  • 33.000 MHz FM 150.0 Hz - Medevac
  • 34.050 MHz FM 150.0 Hz - Convoy operations
  • 34.100 MHz FM 150.0 Hz - Fort Belvoir, Virginia - Air Traffic Control
  • 34.100 MHz FM 150.0 Hz - Fort Pickett, Virginia - Range Control
  • 34.100 MHz FM 150.0 Hz - Vermont National Guard
  • 34.150 MHz FM 150.0 Hz - Convoy operations
  • 34.200 MHz FM 150.0 Hz - Canadian Forces Gagetown Training Area - New Brunswick
  • 34.600 MHz FM 150.0 Hz - Joint Base Lewis-McChord - Washington State
  • 34.600 MHz FM 150.0 Hz - Air to ground coordination
  • 34.700 MHz FM 150.0 Hz - Camp Lejeune Range Control Primary - BLACKBURN
  • 34.800 MHz FM 150.0 Hz - Fort Eustis, Virginia - Aircraft Advisory
  • 34.900 MHz FM 150.0 Hz - National Guard - Disaster Response Common
  • 34.900 MHz FM 150.0 Hz - Virginia National Guard
  • 35.000 MHz FM 150.0 Hz - Medevac
  • 36.100 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 36.100 MHz FM 150.0 Hz - Fort Pickett, Virginia - Range Control
  • 36.500 MHz FM 150.0 Hz - Butts Army Air Field - Colorado
  • 36.500 MHz FM 150.0 Hz - Fort Hood, Texas air operations SHORTHORN TOWER
  • 36.525 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 36.600 MHz FM CSQ - YSD Radio Beacon ("YSD" in Morse Code + long tone burst) Canadian Forces Base Suffield 36.600 MHz FM CFD Suffield
  • 36.650 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 36.700 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 36.800 MHz FM 150.0 Hz - National Guard Helicopter operations near San Antonio, Texas
  • 36.900 MHz FM 150.0 Hz - Martindale Army Heliport, San Antonio, Texas 36.900 MHz FM
  • 37.100 MHz FM CSQ - Fort Pickett, Virginia
  • 37.100 MHz FM 150.0 Hz - Fort Pickett, Virginia
  • 38.275 MHz FM CSQ - Queen Beatrix Airport (Aruba) Air Traffic Control simulcast
  • 38.300 MHz FM 150.0 Fort Hood, Texas Range Control Alternate 38.300 MHz FM (Primary: 30.450 MHz FM)
  • 38.350 MHz FM 150.0 Hz - Butts Army Air Field - Air Traffic Control
  • 38.450 MHz FM 150.0 Hz - Joint Base Lewis-McChord - PMSV Metro (also on 134.100 MHz FM)
  • 38.450 MHz FM 150.0 Hz - Camp Lejeune Operations
  • 38.500 MHz FM 150.0 Hz - Camp Edwards (MA) Range Operations
  • 38.500 MHz FM 150.0 Hz - Fort McCoy, Wisconson - Tower - Secondary
  • 38.500 MHz FM 150.0 Hz - Fort A.P. Hill, Virginia Range Control Primary 38.50 MHz FM
  • 38.500 MHz FM 150.0 Hz - Fort Sill, Oklahoma - Range Control Primary
  • 38.700 MHz FM 150.0 Hz - Fort Eustis, Virginia - Range Control
  • 38.700 MHz FM 150.0 Hz - Quantico Marine Corps Base Virginia - Range Control
  • 38.750 MHz FM 150.0 Hz - Air to air - helicopters
  • 38.800 MHz FM 150.0 Hz - Fort Liberty (Fort Bragg) Range ops
  • 38.850 MHz FM 150.0 Hz - Camp Lejeune Range Control Retrans (Relay) Frequency (see also 40.100 MHz FM)
  • 38.900 MHz FM 150.0 Hz - Medevac
  • 38.900 MHz FM 150.0 Hz - Camp Shelby, Mississippi Range Control
  • 38.900 MHz FM 150.0 Hz - Fort Hood, Texas air operations - LONGHORN GROUND
  • 38.925 MHz FM 150.0 Hz - Fort Liberty (Fort Bragg) North Carolina
  • 38.950 MHz FM 150.0 Hz - Rhode Island National Guard
  • 40.000 MHz FM 150.0 Hz - Air to air communications, helicopters
  • 40.100 MHz FM 150.0 Hz - Quantico Marine Corps Base Virginia - Air to air
  • 40.100 MHz FM 150.0 Hz - Camp Lejeune Range Control Secondary - BLACKBURN
  • 40.100 MHz FM 150.0 Hz - Camp Lejeune Range Control Retrans (Repeater) Frequency (see also 38.850 MHz FM)
  • 40.200 MHz FM 150.0 Hz - Fort Hood, Texas
  • 40.200 MHz FM 150.0 Hz - Virginia National Guard
  • 40.300 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 40.300 MHz FM 150.0 Hz - Fort Gregg-Adams (Fort Lee), Virginia Range Control 40.300 MHz FM
  • 40.350 MHz FM 150.0 Hz - Fort Eustis, Virginia - Base Operations
  • 40.500 MHz FM 150.0 Hz - FM Emergency Frequency 40.50 MHz FM 40.500MHz FM
  • 40.550 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 41.000 MHz FM 150.0 Hz - Quantico Marine Corps Base Virginia - Air to ground operations
  • 41.000 MHz FM 150.0 Hz - Air to air communications, helicopters, Washington D.C. area
  • 41.100 MHz FM 150.0 Hz - Quantico Marine Corps Base Virginia - Air to ground operations
  • 41.200 MHz FM 150.0 Hz - Fort Hood, Texas air operations LONGHORN TOWER
  • 41.350 MHz FM 150.0 Hz - Fort McCoy, Wisconsin - Range Control Alternate
  • 41.500 MHz FM 150.0 Hz - Joint Base Lewis-McChord - Operations (also on 138.600 MHz AM VHF and 395.225 MHz UHF)
  • 41.525 MHz FM 150.0 Hz - Fort Gregg-Adams (Fort Lee), Virginia Air to Air 41.525MHz FM
  • 41.600 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 41.700 MHz FM 150.0 Hz - Fort McCoy, Wisconson - Tower Primary
  • 41.800 MHz FM 150.0 Hz - RETRANS - patched with 49.900 MHz FM with repeater beep
  • 41.900 MHz FM 150.0 Hz - Fort McCoy, Wisconsin - Range Control Primary
  • 41.950 MHz FM 150.0 Hz - Marine Corps Combat Center Twentynine Palms Base Operations - BEARMAT
  • 41.950 MHz FM 150.0 Hz - Quantico Marine Corps Base Virginia - Tower
  • 45.100 MHz FM 150.0 Hz - Range Control
  • 45.450 MHz FM 150.0 Hz - Convoy operations
  • 46.650 MHz FM 150.0 Hz - Quantico Marine Corps base Virginia
  • 46.700 MHz FM 150.0 Hz - Quantico Marine Corps base Virginia
  • 46.750 MHz FM 150.0 Hz - Fort Liberty (Fort Bragg) North Carolina Range ops
  • 46.750 MHz FM 150.0 Hz - Quantico Marine Corps Base Virginia
  • 46.800 MHz FM 150.0 Hz - Fort McCoy, Wisconsin - Medical Alternate
  • 46.800 MHz FM 150.0 Hz - Quantico Marine Corps Base Virginia
  • 46.900 MHz FM 150.0 Hz - Camp Robinson
  • 46.950 MHz FM 150.0 Hz - Fort Liberty (Fort Bragg) North Carolina Range ops
  • 47.000 MHz FM 150.0 Hz - Fort Sill, Oklahoma - Range Control
  • 47.000 MHz FM 150.0 Hz - Rhode Island National Guard
  • 49.700 MHz FM 150.0 Hz - Fort Sill, Oklahoma - Range operations
  • 49.700 MHz FM 150.0 Hz - Rhode Island National Guard
  • 49.725 MHz FM 150.0 Hz - Virginia Air National Guard Operations - Richmond Virginia Area
  • 49.725 MHz FM 150.0 Hz - Massachusetts National Guard
  • 49.800 MHz FM 150.0 Hz - Fort McCoy, Wisconsin
  • 49.850 MHz FM 150.0 Hz - Fort McCoy, Wisconsin - Medical Primary
  • 49.900 MHz FM 150.0 Hz - Canadian Forces Base Suffield Alberta, Canada - Range Control 49.9 MHz FM 49.900 MHz FM
  • 49.900 MHz FM 150.0 Hz - Massachusetts National Guard
  • 49.900 MHz FM 150.0 Hz - Rhode Island National Guard
  • 49.900 MHz FM 150.0 Hz - Fort Hood, Texas
  • 49.900 MHz FM 150.0 Hz - RETRANS - patched with 41.8 MHz FM with repeater beep
  • 49.925 MHz FM 150.0 Hz - Massachusetts National Guard
  • 49.950 MHz FM 150.0 Hz - Convoy operations
  • 49.975 MHz FM 150.0 Hz - Massachusetts National Guard
  • 50.750 MHz FM 150.0 Hz - Butts Army Air Field - Colorado PMSV Metro
  • 51.000 MHz FM 150.0 Hz - Convoy ops (also a popular surplus military radio ham radio freq.)
  • 51.500 MHz FM 150.0 Hz - Air to air communications, helicopters
  • 52.750 MHz FM 150.0 Hz - Fort Belvoir, Virginia - Air National Guard Ops
