Factory default frequencies
Revision as of 00:16, 5 February 2026 by R4002 (Talk | contribs)
This has been split into its own page due to the length of the Business Radio page.
  • Channel 1 - 154.5700 MHz 67.0 Hz PL [Freq 2, Code 1]
  • Channel 2 - 154.6000 MHz 67.0 Hz PL [Freq 1, Code 1]
  • Channel 3 - 151.8200 MHz 67.0 Hz PL [Freq 3, Code 1]
  • Channel 4 - 151.8800 MHz 67.0 Hz PL [Freq 4, Code 1]
  • Channel 5 - 151.9400 MHz 67.0 Hz PL [Freq 5, Code 1]
  • Channel 6 - 154.5700 MHz CSQ [Freq 2, Code 0]
  • Channel 7 - 154.6000 MHz CSQ [Freq 1, Code 0]
  • Channel 8 - 151.8200 MHz CSQ [Freq 3, Code 0]
  • Channel 12 - 464.4875 MHz 79.7 Hz PL [Frequency 30, Code 5]
  • Channel 13 - 464.5375 MHz 85.4 Hz PL [Frequency 32, Code 7]
  • Channel 14 - 466.0375 MHz 91.5 Hz PL [Frequency 34, Code 9]
  • Channel 15 - 466.0875 MHz 97.4 Hz PL [Frequency 36, Code 11]
Lowband 1 - Low 1
Lowband 2 - Low 2
VHF High Band - VHF
700 MHz Band - 700
800 MHz Band - 800
  • Channels 6 - 16 UNPROGRAMMED (by default, may be programmed by end user or dealer)
  • Channel 1 - 446.00625 MHz NFM 97.4 Hz PL
  • Channel 2 - 446.01875 MHz NFM 100.0 Hz PL
  • Channel 3 - 446.03125 MHz NFM 103.5 Hz PL
  • Channel 4 - 446.04375 MHz NFM 107.2 Hz PL
  • Channel 5 - 446.05625 MHz NFM 110.9 Hz PL
  • Channel 6 - 446.06875 MHz NFM 114.8 Hz PL
  • Channel 7 - 446.08125 MHz NFM 118.8 Hz PL
  • Channel 8 - 446.09375 MHz NFM 123.0 Hz PL
  • Channel 9 - 446.00625 MHz NFM 127.3 Hz PL
  • Channel 10 - 446.01875 MHz NFM 131.8 Hz PL
  • Channel 11 - 446.03125 MHz NFM 136.5 Hz PL
  • Channel 12 - 446.04375 MHz NFM 141.3 Hz PL
  • Channel 13 - 446.05625 MHz NFM 146.2 Hz PL
  • Channel 14 - 446.06875 MHz NFM 141.3 Hz PL
  • Channel 15 - 446.08125 MHz NFM 156.7 Hz PL
  • Channel 16 - 446.09375 MHz NFM 159.8 Hz PL
  • Channel 1 - 446.10625 MHz NFM 97.4 Hz PL
  • Channel 2 - 446.11875 MHz NFM 100.0 Hz PL
  • Channel 3 - 446.13125 MHz NFM 103.5 Hz PL
  • Channel 4 - 446.14375 MHz NFM 107.2 Hz PL
  • Channel 5 - 446.15625 MHz NFM 110.9 Hz PL
  • Channel 6 - 446.16875 MHz NFM 114.8 Hz PL
  • Channel 7 - 446.18125 MHz NFM 118.8 Hz PL
  • Channel 8 - 446.19375 MHz NFM 123.0 Hz PL
  • Channel 9 - 446.10625 MHz NFM 127.3 Hz PL
  • Channel 10 - 446.11875 MHz NFM 131.8 Hz PL
  • Channel 11 - 446.13125 MHz NFM 136.5 Hz PL
  • Channel 12 - 446.14375 MHz NFM 141.3 Hz PL
  • Channel 13 - 446.15625 MHz NFM 146.2 Hz PL
  • Channel 14 - 446.16875 MHz NFM 141.3 Hz PL
  • Channel 15 - 446.18125 MHz NFM 156.7 Hz PL
  • Channel 16 - 446.19375 MHz NFM 159.8 Hz PL
  • Channel 1 - 446.003125 MHz Digital - Common ID 85
  • Channel 2 - 446.009375 MHz Digital - Common ID 87
  • Channel 3 - 446.015625 MHz Digital - Common ID 93
  • Channel 4 - 446.021875 MHz Digital - Common ID 95
  • Channel 5 - 446.028125 MHz Digital - Common ID 117
  • Channel 6 - 446.034375 MHz Digital - Common ID 119
  • Channel 7 - 446.040625 MHz Digital - Common ID 125
  • Channel 8 - 446.046875 MHz Digital - Common ID 129
  • Channel 9 - 446.053125 MHz Digital - Common ID 213
  • Channel 10 - 446.059375 MHz Digital - Common ID 215
  • Channel 11 - 446.065625 MHz Digital - Common ID 221
  • Channel 12 - 446.071875 MHz Digital - Common ID 223
  • Channel 13 - 446.078125 MHz Digital - Common ID 245
  • Channel 14 - 446.084375 MHz Digital - Common ID 247
  • Channel 15 - 446.090625 MHz Digital - Common ID 253
  • Channel 16 - 446.096875 MHz Digital - Common ID 254
  • Channel 1 - 446.103125 MHz Digital - Common ID 85
  • Channel 2 - 446.109375 MHz Digital - Common ID 87
  • Channel 3 - 446.115625 MHz Digital - Common ID 93
  • Channel 4 - 446.121875 MHz Digital - Common ID 95
  • Channel 5 - 446.128125 MHz Digital - Common ID 117
  • Channel 6 - 446.134375 MHz Digital - Common ID 119
  • Channel 7 - 446.140625 MHz Digital - Common ID 125
  • Channel 8 - 446.146875 MHz Digital - Common ID 129
  • Channel 9 - 446.153125 MHz Digital - Common ID 213
  • Channel 10 - 446.159375 MHz Digital - Common ID 215
  • Channel 11 - 446.165625 MHz Digital - Common ID 221
  • Channel 12 - 446.171875 MHz Digital - Common ID 223
  • Channel 13 - 446.178125 MHz Digital - Common ID 245
  • Channel 14 - 446.184375 MHz Digital - Common ID 247
  • Channel 15 - 446.190625 MHz Digital - Common ID 253
  • Channel 16 - 446.196875 MHz Digital - Common ID 254
  • Channel 1 - 464.5500 MHz 67.0 Hz PL [Freq 2, QT Tone 1]
  • Channel 2 - 467.9250 MHz 67.0 Hz PL [Freq 8, QT Tone 1]
  • Channel 3 - 461.0375 MHz 67.0 Hz PL [Freq 9, QT Tone 1]
  • Channel 4 - 461.0625 MHz 67.0 Hz PL [Freq 10, QT Tone 1]
  • Channel 5 - 461.0875 MHz 67.0 Hz PL [Freq 11, QT Tone 1]
  • Channel 6 - 461.1125 MHz 67.0 Hz PL [Freq 12, QT Tone 1]
  • Channel 7 - 461.1375 MHz 67.0 Hz PL [Freq 13, QT Tone 1]
  • Channel 8 - 461.1625 MHz 67.0 Hz PL [Freq 14, QT Tone 1]
  • Channel 9 - 464.5000 MHz 67.0 Hz PL [Freq 1, QT Tone 1]
  • Channel 10 - 467.7625 MHz 67.0 Hz PL [Freq 3, QT Tone 1]
  • Channel 11 - 467.8125 MHz 67.0 Hz PL [Freq 4, QT Tone 1]
  • Channel 12 - 467.8500 MHz 67.0 Hz PL [Freq 5, QT Tone 1]
  • Channel 13 - 467.8750 MHz 67.0 Hz PL [Freq 6, QT Tone 1]
  • Channel 14 - 467.9000 MHz 67.0 Hz PL [Freq 7, QT Tone 1]
  • Channel 15 - 461.1875 MHz 67.0 Hz PL [Freq 15, QT Tone 1]
Wouxun KG-S86B Business Radio
CONNECOM GD100 and GD900
CONNECOM GD800
Default channel programming
  • Channel 9 - 464.5500 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 10 - 464.5000 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 11 - 467.7625 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 12 - 467.8125 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 13 - 467.8500 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 14 - 467.8750 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 15 - 467.9000 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 16 - 467.9250 MHz NFM - 67.0 Hz CTCSS TX/RX
Ritron JOBCOM JMX D Series VHF radios
  • JMX-111D Jobcom 1 watt 1 channel
  • JMX-141D Jobcom 1.5 watt 10 channel
  • JMX-146D Jobcom 2 watt 10 channel
  • JMX-144D Jobcom 4 watt 10 channel
  • Frequency Code 00 - DELETE
  • Frequency Code 01 - 154.6000 MHz - MURS 4 Green Dot (25 kHz bandwidth)
  • Frequency Code 02 - 154.5700 MHz - MURS 5 Blue Dot (25 kHz bandwidth)
  • Frequency Code 03 - 151.6250 MHz - Red Dot
  • Frequency Code 04 - 151.9550 MHz - Purple Dot
  • Frequency Code 21 - 151.9400 MHz - MURS 3
  • Frequency Code 22 - 154.6000 MHz - MURS 4 Green Dot (12.5 kHz bandwidth)
  • Frequency Code 23 - 154.5700 MHz - MURS 5 Blue Dot (12.5 kHz bandwidth)
  • Frequency Code 24 - 151.7000 MHz
  • Frequency Code 25 - 151.7000 MHz
  • Frequency Code 26 - 158.4000 MHz
Ritron JOBCOM JMX D Series UHF radios
  • JMX-441D Jobcom 1 watt 10 channel
  • JMX-446D Jobcom 2 watt 10 channel
  • JMX-444D Jobcom 3 watt 10 channel
  • Frequency Code 01 - 467.7625 MHz
  • Frequency Code 10 - 462.5750 MHz - FRS 16 White Dot
  • Frequency Code 11 - 462.6250 MHz - FRS 18 Black Dot
  • Frequency Code 12 - 462.6750 MHz - FRS 20 Orange Dot
  • Frequency Code 21 - 462.7000 MHz - FRS 21
  • Frequency Code 22 - 464.5000 MHz
  • Frequency Code 76 - 469.5375 MHz
  • Frequency Code 77 - 469.5625 MHz
KidDesigns Walkie Talkies
  • Power Output: 0.133mW
  • Emission: 11K0F3E
  • FCC ID IAJ-210
  • Power Output: 7mW
  • Emission: 11K0F3E
  • FCC ID IAJ-212C7A
  • Power Output: 3.2mW
  • Emission: 11K0F3E
  • FCC ID IAJ-212C7B
  • Power Output: 4.2mW
  • Emission: 4K26F3E
  • FCC ID IAJ-216
  • Channel 51 - 462.6375 MHz 032 DCS
  • Channel 52 - 462.6875 MHz 051 DCS
  • Channel 53 - 467.5625 MHz 071 DCS
  • Channel 54 - 467.6125 MHz 074 DCS
  • Channel 55 - 467.6625 MHz 116 DCS
  • Channel 56 - 467.7125 MHz 132 DCS
  • Channel 57 - 462.5750 MHz 152 DCS
  • Channel 58 - 462.6250 MHz 162 DCS
  • Channel 59 - 462.6750 MHz 174 DCS
  • Channel 60 - 462.7250 MHz 226 DCS
  • Channel 61 - User configurable (user selects from channel 1-22 and then either selects no squelch, CTCSS code 1-38 or DCS code 1-83).
Cobra RX380 Series FRS Radios
Cobra RX380
SAMCOM 20 Channel UHF Radios
FCC ID 2AIOQ-FPCN30AA
  • CH01 - 462.5500 MHz D226 [FRS Channel 15 - D226N | 226 DCS]
  • CH02 - 462.5750 MHz D243 [FRS Channel 16 - D243N | 243 DCS]
  • CH03 - 462.6000 MHz D244 [FRS Channel 17 - D244N | 244 DCS]
  • CH04 - 462.6250 MHz D245 [FRS Channel 18 - D245N | 245 DCS]
  • CH05 - 462.6500 MHz D246 [FRS Channel 19 - D246N | 246 DCS]
  • CH06 - 462.6750 MHz D251 [FRS Channel 20 - D251N | 251 DCS]
  • CH07 - 462.7000 MHz D252 [FRS Channel 21 - D252N | 252 DCS]
  • CH08 - 462.7250 MHz D255 [FRS Channel 22 - D255N | 255 DCS]
  • CH09 - 462.5625 MHz D261 [FRS Channel 1 - D261N | 261 DCS]
  • CH10 - 462.5875 MHz D332 [FRS Channel 2 - D332N | 332 DCS]
  • CH11 - 462.6125 MHz D265 [FRS Channel 3 - D265N | 265 DCS]
  • CH12 - 462.6375 MHz D266 [FRS Channel 4 - D266N | 266 DCS]
  • CH13 - 462.6625 MHz D271 [FRS Channel 5 - D271N | 271 DCS]
  • CH14 - 462.6875 MHz D274 [FRS Channel 6 - D274N | 274 DCS]
  • CH15 - 462.6500 MHz D306 [FRS Channel 19 - D306N | 306 DCS]
  • CH16 - 462.5500 MHz D311 [FRS Channel 15 - D311N | 311 DCS]
  • CH17 - 462.7000 MHz D315 [FRS Channel 21 - D315N | 315 DCS]
  • CH18 - 462.6625 MHz D325 [FRS Channel 5 - D325N | 325 DCS]
  • CH19 - 462.5625 MHz D331 [FRS Channel 1 - D331N | 331 DCS]
  • CH0 - 462.7125 MHz D225 [FRS Channel 7 - D225N | 225 DCS]
Radioditty GA-2S
  • Channel 8 - 462.5500 MHz
  • Channel 10 - 462.6000 MHz
  • Channel 11 - 462.6250 MHz
  • Channel 12 - 462.6500 MHz
  • Channel 13 - 462.6750 MHz
  • Channel 14 - 462.7000 MHz
  • Channel 15 - 462.7250 MHz
  • VFO F1 - 400.5250 MHz FM [CSQ]
  • VFO F2 - 226.0000 MHz FM [CSQ]
  • VFO F3 - 469.5250 MHz FM [CSQ]
  • Channel 1 - 136.4250 MHz FM CSQ
  • Channel 2 - 150.4250 MHz FM 159.8 Hz PL
  • Channel 3 - 173.9450 MHz FM CSQ
  • Channel 4 - 220.4250 MHz FM CSQ
  • Channel 5 - 240.4250 MHz FM D023N 023 DPL
  • Channel 6 - 259.9450 MHz FM CSQ
  • Channel 7 - 400.4250 MHz FM CSQ
  • Channel 8 - 435.4250 MHz FM CSQ
  • Channel 9 - 469.4250 MHz FM CSQ
  • Channel 10 - 136.4250 MHz NFM 67.0 Hz PL
  • Channel 11 - 150.4250 MHz NFM 254.1 Hz PL
  • Channel 12 - 173.9450 MHz NFM D023N 023 DPL
  • Channel 13 - 220.4250 MHz NFM 67.0 Hz
  • Channel 14 - 240.4250 MHz NFM 254.1 Hz PL
  • Channel 15 - 259.9450 MHz NFM D023N 023 DPL
  • Channel 16 - 400.4250 MHz NFM 67.0 Hz PL
  • Channel 17 - 435.4250 MHz NFM 254.1 Hz PL
  • Channel 18 - 469.4250 MHz NFM D023N 023 DPL
TXPro TX-680AV VHF
VHF version 136-174 MHz
FCC ID: 2AS4FEPCOTX680AV
Retevis RT10
Zone 1
Zone 2
Zone 3
Retevis RT30
Default Channel Frequency
Retevis RT30
Retevis RT30M
  • Channel 15 - 460.3250 CSQ
Retevis RT1-UHF RT1 RT-1
Retevis RT1-VHF RT1 RT-1
  • Channel 15 - 462.5625 MHz 026 DPL 026 DCS D026N - FRS Channel 1
  • Channel 16 - 467.5625 MHz 026 DPL 026 DCS D026N - FRS Channel 8
  • Channel 1 - 462.5625 MHz 043 DPL D043N - FRS Channel 1
  • Channel 2 - 462.5875 MHz 065 DPL D065N - FRS Channel 2
  • Channel 3 - 462.6125 MHz 116 DPL D116N - FRS Channel 3
  • Channel 4 - 462.6375 MHz 205 DPL D205N - FRS Channel 4
  • Channel 5 - 462.6625 MHz 261 DPL D261N - FRS Channel 5
  • Channel 6 - 462.6875 MHz 265 DPL D265N - FRS Channel 6
  • Channel 7 - 462.7125 MHz 271 DPL D271N - FRS Channel 7
  • Channel 8 - 467.5625 MHz 306 DPL D306N - FRS Channel 8
  • Channel 9 - 467.5875 MHz 311 DPL D311N - FRS Channel 9
  • Channel 10 - 467.6125 MHz 331 DPL D331N - FRS Channel 10
  • Channel 11 - 467.6375 MHz 365 DPL D365N - FRS Channel 11
  • Channel 12 - 467.6625 MHz 431 DPL D431N - FRS Channel 12
  • Channel 13 - 467.6875 MHz 466 DPL D466N - FRS Channel 13
  • Channel 14 - 467.7125 MHz 503 DPL D503N - FRS Channel 14
  • Channel 1 - 446.00625 MHz 114 DPL D114N - PMR446 Channel 1
  • Channel 2 - 446.01875 MHz 131 DPL D131N - PMR446 Channel 2
  • Channel 3 - 446.03125 MHz 132 DPL D132N - PMR446 Channel 3
  • Channel 4 - 446.04375 MHz 165 DPL D165N - PMR446 Channel 4
  • Channel 5 - 446.05625 MHz 226 DPL D226N - PMR446 Channel 5
  • Channel 6 - 446.06875 MHz 306 DPL D306N - PMR446 Channel 6
  • Channel 7 - 446.08125 MHz 371 DPL D371N - PMR446 Channel 7
  • Channel 8 - 446.09375 MHz 503 DPL D503N - PMR446 Channel 8
HN5RV01 firmware version
Baofeng UV-5R8W
  • Channel 1 - 400.1250 MHz
  • Channel 2 - 410.1250 MHz
  • Channel 3 - 420.1250 MHz
  • Channel 4 - 430.1250 MHz
  • Channel 5 - 440.1250 MHz
  • Channel 6 - 450.1250 MHz
  • Channel 7 - 460.1250 MHz
  • Channel 8 - 470.1250 MHz
  • Channel 9 - 480.1250 MHz
  • Channel 10 - 490.1250 MHz
  • Channel 11 - 500.1250 MHz
  • Channel 12 - 510.1250 MHz
  • Channel 13 - 519.9750 MHz
  • Channel 14 - 136.1250 MHz
  • Channel 15 - 145.1250 MHz
  • Channel 16 - 155.1250 MHz
  • Channel 17 - 165.1250 MHz
  • Channel 18 - 173.9750 MHz
Baofeng UV-98 UV98Pro
  • Freq 1 - 464.5000 MHz
  • Freq 2 - 464.5500 MHz
  • Freq 3 - 467.7625 MHz
  • Freq 4 - 467.8125 MHz
  • Freq 5 - 467.8500 MHz
  • Freq 6 - 467.8750 MHz
  • Freq 7 - 467.9000 MHz
  • Freq 8 - 467.9250 MHz
  • Freq 9 - 461.0375 MHz
  • Freq 10 - 461.0625 MHz
  • Freq 11 - 461.0875 MHz
  • Freq 12 - 461.1125 MHz
  • Freq 13 - 461.1375 MHz
  • Freq 14 - 461.1625 MHz
  • Freq 15 - 461.1875 MHz
  • Freq 16 - 461.2125 MHz
  • Freq 17 - 461.2375 MHz
  • Freq 18 - 461.2625 MHz
  • Freq 19 - 461.2875 MHz
  • Freq 20 - 461.3125 MHz
  • Freq 21 - 461.3375 MHz
  • Freq 22 - 461.3625 MHz
  • Freq 23 - 462.7625 MHz
  • Freq 24 - 462.7875 MHz
  • Freq 25 - 462.8125 MHz
  • Freq 26 - 462.8375 MHz
  • Freq 27 - 462.8625 MHz
  • Freq 28 - 462.8875 MHz
  • Freq 29 - 462.9125 MHz
  • Freq 30 - 464.4875 MHz
  • Freq 31 - 464.5125 MHz
  • Freq 32 - 464.5375 MHz
  • Freq 33 - 464.5625 MHz
  • Freq 34 - 466.0375 MHz
  • Freq 35 - 466.0625 MHz
  • Freq 36 - 466.0875 MHz
  • Freq 37 - 466.1125 MHz
  • Freq 38 - 466.1375 MHz
  • Freq 39 - 466.1625 MHz
  • Freq 40 - 466.1875 MHz
  • Freq 41 - 466.2125 MHz
  • Freq 42 - 466.2375 MHz
  • Freq 43 - 466.2625 MHz
  • Freq 44 - 466.2875 MHz
  • Freq 45 - 466.3125 MHz
  • Freq 46 - 466.3375 MHz
  • Freq 47 - 466.3625 MHz
  • Freq 48 - 467.7875 MHz
  • Freq 49 - 467.8375 MHz
  • Freq 50 - 467.8625 MHz
  • Freq 51 - 467.8875 MHz
  • Freq 52 - 467.9125 MHz
  • Freq 53 - 469.4875 MHz
  • Freq 54 - 469.5125 MHz
  • Freq 55 - 469.5375 MHz
  • Freq 56 - 469.5625 MHz
  • Freq 9 - 462.5750 MHz
  • Freq 10 - 462.6250 MHz
  • Freq 11 - 462.6750 MHz
  • Freq 12 - 464.3250 MHz
  • Freq 13 - 464.8250 MHz
  • Freq 14 - 469.2625 MHz
  • Freq 15 - 469.5000 MHz
  • Freq 16 - 469.5500 MHz
  • Freq 17 - 462.7625 MHz
  • Freq 18 - 462.7875 MHz
  • Freq 19 - 462.8125 MHz
  • Freq 20 - 462.8375 MHz
  • Freq 21 - 462.8625 MHz
  • Freq 22 - 462.8875 MHz
  • Freq 23 - 462.9125 MHz
  • Freq 23 - 461.0375 MHz
  • Freq 25 - 461.0625 MHz
  • Freq 26 - 461.0875 MHz
  • Freq 27 - 461.1125 MHz
  • Freq 28 - 461.1375 MHz
  • Freq 29 - 461.1625 MHz
  • Freq 30 - 461.1875 MHz
  • Freq 31 - 461.2125 MHz
  • Freq 32 - 461.2375 MHz
  • Freq 33 - 461.2625 MHz
  • Freq 34 - 461.2875 MHz
  • Freq 35 - 461.3125 MHz
  • Freq 36 - 461.3375 MHz
  • Freq 37 - 461.3625 MHz
  • Freq 38 - 467.7875 MHz
  • Freq 39 - 467.8375 MHz
  • Freq 40 - 467.8625 MHz
  • Freq 41 - 467.8875 MHz
  • Freq 42 - 467.9125 MHz
  • Freq 43 - 464.4875 MHz
  • Freq 44 - 464.5125 MHz
  • Freq 45 - 464.5375 MHz
  • Freq 46 - 464.5625 MHz
  • Freq 47 - 466.0375 MHz
  • Freq 48 - 466.0625 MHz
  • Freq 49 - 466.0875 MHz
  • Freq 50 - 466.1125 MHz
  • Freq 51 - 466.1375 MHz
  • Freq 52 - 466.1625 MHz
  • Freq 53 - 466.1875 MHz
  • Freq 54 - 466.2125 MHz
  • Freq 55 - 466.2375 MHz
  • Freq 56 - 466.2625 MHz
  • Freq 1 - 151.6250 MHz
  • Freq 2 - 151.9550 MHz
  • Freq 3 - 154.5700 MHz
  • Freq 4 - 154.6000 MHz
  • Freq 5 - 151.7000 MHz
  • Freq 6 - 151.7600 MHz
  • Freq 7 - 151.8200 MHz
  • Freq 8 - 151.8800 MHz
  • Freq 9 - 151.9400 MHz
  • Freq 10 - 151.5125 MHz
  • Freq 11 - 151.6550 MHz
  • Freq 12 - 151.6850 MHz
  • Freq 13 - 151.7150 MHz
  • Freq 14 - 151.7450 MHz
  • Freq 15 - 151.7750 MHz
  • Freq 16 - 151.8650 MHz
  • Freq 17 - 151.8950 MHz
  • Freq 18 - 151.9250 MHz
  • Freq 20 - 154.4900 MHz
  • Freq 21 - 154.5150 MHz
  • Freq 22 - 154.5275 MHz
  • Freq 23 - 154.5400 MHz
  • Freq 24 - 154.6000 MHz
  • Freq 26 - 158.4000 MHz
  • Freq 27 - 158.4075 MHz
  • Freq 57 - 462.1875 MHz
  • Freq 58 - 462.4625 MHz
  • Freq 59 - 462.4875 MHz
  • Freq 60 - 462.5125 MHz
  • Freq 61 - 467.1875 MHz
  • Freq 62 - 467.4625 MHz
  • Freq 63 - 467.4875 MHz
  • Freq 64 - 467.5125 MHz
  • Freq 65 - 451.1875 MHz
  • Freq 66 - 451.2375 MHz
  • Freq 67 - 451.2875 MHz
  • Freq 68 - 451.3375 MHz
  • Freq 69 - 451.4375 MHz
  • Freq 70 - 451.5375 MHz
  • Freq 71 - 451.6375 MHz
  • Freq 72 - 452.3125 MHz
  • Freq 73 - 452.5375 MHz
  • Freq 74 - 452.4125 MHz
  • Freq 75 - 452.5125 MHz
  • Freq 76 - 452.7625 MHz
  • Freq 77 - 452.8625 MHz
  • Freq 78 - 456.1875 MHz
  • Freq 79 - 456.2375 MHz
  • Freq 80 - 456.2875 MHz
  • Freq 81 - 468.2125 MHz
  • Freq 82 - 468.2625 MHz
  • Freq 83 - 468.3125 MHz
  • Freq 84 - 468.3625 MHz
  • Freq 85 - 468.4125 MHz
  • Freq 86 - 468.4625 MHz
  • Freq 87 - 468.5125 MHz
  • Freq 88 - 468.5625 MHz
  • Freq 89 - 468.6125 MHz
  • Freq 90 - 468.6625 MHz
  • Freq 81 - 456.3375 MHz
  • Freq 82 - 456.4375 MHz
  • Freq 83 - 456.5375 MHz
  • Freq 84 - 456.6375 MHz
  • Freq 85 - 457.3125 MHz
  • Freq 86 - 457.4125 MHz
  • Freq 87 - 457.5125 MHz
  • Freq 88 - 457.7625 MHz
  • Freq 89 - 457.8625 MHz
  • Freq 3 - 152.8850 MHz
  • Freq 4 - 152.9150 MHz
  • Freq 7 - 152.9450 MHz
  • Freq 8 - 151.8350 MHz
  • Freq 9 - 151.8050 MHz
  • Freq 24 - 153.0050 MHz
  • Freq 0 - OFF (BLANK)
