Factory default frequencies
Revision as of 17:15, 5 February 2026 by R4002 (Talk | contribs)
This has been split into its own page due to the length of the Business Radio page. VHF/UHF radio services master list here.
  • Channel 1 - 464.5500 MHz 67.0 Hz PL [Freq 2, Code 1]
  • Channel 2 - 467.9250 MHz 67.0 Hz PL [Freq 8, Code 1]
  • Channel 3 - 467.8500 MHz 67.0 Hz PL [Freq 5, Code 1]
  • Channel 4 - 467.8750 MHz 67.0 Hz PL [Freq 6, Code 1]
  • Channel 5 - 461.0625 MHz 67.0 Hz PL [Freq 10, Code 1]
  • Channel 6 - 461.1125 MHz 67.0 Hz PL [Freq 12, Code 1]
  • Channel 1 - 154.5700 MHz 67.0 Hz PL [Freq 2, Code 1]
  • Channel 2 - 154.6000 MHz 67.0 Hz PL [Freq 1, Code 1]
  • Channel 3 - 151.8200 MHz 67.0 Hz PL [Freq 3, Code 1]
  • Channel 4 - 151.8800 MHz 67.0 Hz PL [Freq 4, Code 1]
  • Channel 5 - 151.9400 MHz 67.0 Hz PL [Freq 5, Code 1]
  • Channel 6 - 154.5700 MHz CSQ [Freq 2, Code 0]
  • Channel 7 - 154.6000 MHz CSQ [Freq 1, Code 0]
  • Channel 8 - 151.8200 MHz CSQ [Freq 3, Code 0]
  • Channel 12 - 464.4875 MHz 79.7 Hz PL [Frequency 30, Code 5]
  • Channel 13 - 464.5375 MHz 85.4 Hz PL [Frequency 32, Code 7]
  • Channel 14 - 466.0375 MHz 91.5 Hz PL [Frequency 34, Code 9]
  • Channel 15 - 466.0875 MHz 97.4 Hz PL [Frequency 36, Code 11]
Lowband 1 - Low 1
Lowband 2 - Low 2
VHF High Band - VHF
700 MHz Band - 700
800 MHz Band - 800
Midland BR180 BIZTALK 4 Channel UHF Business Radio
  • Channel 1 - 464.5500 MHz 67.0 Hz PL - Frequency 55
  • Channel 2 - 467.9250 MHz 67.0 Hz PL - Frequency 85
  • Channel 3 - 467.8500 MHz 67.0 Hz PL - Frequency 79
  • Channel 4 - 467.8750 MHz 67.0 Hz PL - Frequency 81
Note: The BR180 uses a non-standard frequency pool of 99 UHF business band frequencies to choose from
1 451.1875 26 461.0375 51 464.4875 76 467.7875 2 451.2375 27 461.0625 52 464.5000 77 467.8125 3 451.2875 28 461.0875 53 464.5125 78 467.8375 4 451.3375 29 461.1125 54 464.5375 79 467.8500 5 451.4375 30 461.1375 55 464.5500 80 467.8625 6 451.5375 31 461.1625 56 464.5625 81 467.8750 7 451.6375 32 461.1875 57 466.0375 82 467.8875 8 452.3125 33 461.2125 58 466.0625 83 467.9000 9 452.4125 34 461.2375 59 466.0875 84 467.9125 10 452.5125 35 461.2625 60 466.1125 85 467.9250 11 452.5375 36 461.2875 61 466.1375 86 468.2125 12 452.7625 37 461.3125 62 466.1625 87 468.2625 13 452.8625 38 461.3375 63 466.1875 88 468.3125 14 456.1875 39 461.3625 64 466.2125 89 468.3625 15 456.2375 40 462.1875 65 466.2375 90 468.4125 16 456.2875 41 462.4625 66 466.2625 91 468.4625 17 456.3375 42 462.4875 67 466.2875 92 468.5125 18 456.4375 43 462.5125 68 466.3125 93 468.5625 19 456.5375 44 462.7625 69 466.3375 94 468.6125 20 456.6375 45 462.7875 70 466.3625 95 468.6625 21 457.3125 46 462.8125 71 467.1875 96 469.4875 22 457.4125 47 462.8375 72 467.4625 97 469.5125 23 457.5125 48 462.8625 73 467.4875 98 469.5375 24 457.7625 49 462.8875 74 467.5125 99 469.5625 25 457.8625 50 462.9125 75 467.7625
  • Channels 6 - 16 UNPROGRAMMED (by default, may be programmed by end user or dealer)
  • Channel 1 - 446.00625 MHz NFM 97.4 Hz PL
  • Channel 2 - 446.01875 MHz NFM 100.0 Hz PL
  • Channel 3 - 446.03125 MHz NFM 103.5 Hz PL
  • Channel 4 - 446.04375 MHz NFM 107.2 Hz PL
  • Channel 5 - 446.05625 MHz NFM 110.9 Hz PL
  • Channel 6 - 446.06875 MHz NFM 114.8 Hz PL
  • Channel 7 - 446.08125 MHz NFM 118.8 Hz PL
  • Channel 8 - 446.09375 MHz NFM 123.0 Hz PL
  • Channel 9 - 446.00625 MHz NFM 127.3 Hz PL
  • Channel 10 - 446.01875 MHz NFM 131.8 Hz PL
  • Channel 11 - 446.03125 MHz NFM 136.5 Hz PL
  • Channel 12 - 446.04375 MHz NFM 141.3 Hz PL
  • Channel 13 - 446.05625 MHz NFM 146.2 Hz PL
  • Channel 14 - 446.06875 MHz NFM 141.3 Hz PL
  • Channel 15 - 446.08125 MHz NFM 156.7 Hz PL
  • Channel 16 - 446.09375 MHz NFM 159.8 Hz PL
  • Channel 1 - 446.10625 MHz NFM 97.4 Hz PL
  • Channel 2 - 446.11875 MHz NFM 100.0 Hz PL
  • Channel 3 - 446.13125 MHz NFM 103.5 Hz PL
  • Channel 4 - 446.14375 MHz NFM 107.2 Hz PL
  • Channel 5 - 446.15625 MHz NFM 110.9 Hz PL
  • Channel 6 - 446.16875 MHz NFM 114.8 Hz PL
  • Channel 7 - 446.18125 MHz NFM 118.8 Hz PL
  • Channel 8 - 446.19375 MHz NFM 123.0 Hz PL
  • Channel 9 - 446.10625 MHz NFM 127.3 Hz PL
  • Channel 10 - 446.11875 MHz NFM 131.8 Hz PL
  • Channel 11 - 446.13125 MHz NFM 136.5 Hz PL
  • Channel 12 - 446.14375 MHz NFM 141.3 Hz PL
  • Channel 13 - 446.15625 MHz NFM 146.2 Hz PL
  • Channel 14 - 446.16875 MHz NFM 141.3 Hz PL
  • Channel 15 - 446.18125 MHz NFM 156.7 Hz PL
  • Channel 16 - 446.19375 MHz NFM 159.8 Hz PL
  • Channel 1 - 446.003125 MHz Digital - Common ID 85
  • Channel 2 - 446.009375 MHz Digital - Common ID 87
  • Channel 3 - 446.015625 MHz Digital - Common ID 93
  • Channel 4 - 446.021875 MHz Digital - Common ID 95
  • Channel 5 - 446.028125 MHz Digital - Common ID 117
  • Channel 6 - 446.034375 MHz Digital - Common ID 119
  • Channel 7 - 446.040625 MHz Digital - Common ID 125
  • Channel 8 - 446.046875 MHz Digital - Common ID 129
  • Channel 9 - 446.053125 MHz Digital - Common ID 213
  • Channel 10 - 446.059375 MHz Digital - Common ID 215
  • Channel 11 - 446.065625 MHz Digital - Common ID 221
  • Channel 12 - 446.071875 MHz Digital - Common ID 223
  • Channel 13 - 446.078125 MHz Digital - Common ID 245
  • Channel 14 - 446.084375 MHz Digital - Common ID 247
  • Channel 15 - 446.090625 MHz Digital - Common ID 253
  • Channel 16 - 446.096875 MHz Digital - Common ID 254
  • Channel 1 - 446.103125 MHz Digital - Common ID 85
  • Channel 2 - 446.109375 MHz Digital - Common ID 87
  • Channel 3 - 446.115625 MHz Digital - Common ID 93
  • Channel 4 - 446.121875 MHz Digital - Common ID 95
  • Channel 5 - 446.128125 MHz Digital - Common ID 117
  • Channel 6 - 446.134375 MHz Digital - Common ID 119
  • Channel 7 - 446.140625 MHz Digital - Common ID 125
  • Channel 8 - 446.146875 MHz Digital - Common ID 129
  • Channel 9 - 446.153125 MHz Digital - Common ID 213
  • Channel 10 - 446.159375 MHz Digital - Common ID 215
  • Channel 11 - 446.165625 MHz Digital - Common ID 221
  • Channel 12 - 446.171875 MHz Digital - Common ID 223
  • Channel 13 - 446.178125 MHz Digital - Common ID 245
  • Channel 14 - 446.184375 MHz Digital - Common ID 247
  • Channel 15 - 446.190625 MHz Digital - Common ID 253
  • Channel 16 - 446.196875 MHz Digital - Common ID 254
  • Channel 1 - 464.5500 MHz 67.0 Hz PL [Freq 2, QT Tone 1]
  • Channel 2 - 467.9250 MHz 67.0 Hz PL [Freq 8, QT Tone 1]
  • Channel 3 - 461.0375 MHz 67.0 Hz PL [Freq 9, QT Tone 1]
  • Channel 4 - 461.0625 MHz 67.0 Hz PL [Freq 10, QT Tone 1]
  • Channel 5 - 461.0875 MHz 67.0 Hz PL [Freq 11, QT Tone 1]
  • Channel 6 - 461.1125 MHz 67.0 Hz PL [Freq 12, QT Tone 1]
  • Channel 7 - 461.1375 MHz 67.0 Hz PL [Freq 13, QT Tone 1]
  • Channel 8 - 461.1625 MHz 67.0 Hz PL [Freq 14, QT Tone 1]
  • Channel 9 - 464.5000 MHz 67.0 Hz PL [Freq 1, QT Tone 1]
  • Channel 10 - 467.7625 MHz 67.0 Hz PL [Freq 3, QT Tone 1]
  • Channel 11 - 467.8125 MHz 67.0 Hz PL [Freq 4, QT Tone 1]
  • Channel 12 - 467.8500 MHz 67.0 Hz PL [Freq 5, QT Tone 1]
  • Channel 13 - 467.8750 MHz 67.0 Hz PL [Freq 6, QT Tone 1]
  • Channel 14 - 467.9000 MHz 67.0 Hz PL [Freq 7, QT Tone 1]
  • Channel 15 - 461.1875 MHz 67.0 Hz PL [Freq 15, QT Tone 1]
Wouxun KG-S86B Business Radio
CONNECOM GD100 and GD900
CONNECOM GD800
Default channel programming
  • Channel 9 - 464.5500 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 10 - 464.5000 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 11 - 467.7625 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 12 - 467.8125 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 13 - 467.8500 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 14 - 467.8750 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 15 - 467.9000 MHz NFM - 67.0 Hz CTCSS TX/RX
  • Channel 16 - 467.9250 MHz NFM - 67.0 Hz CTCSS TX/RX
Ritron JOBCOM JMX D Series VHF radios
  • JMX-111D Jobcom 1 watt 1 channel
  • JMX-141D Jobcom 1.5 watt 10 channel
  • JMX-146D Jobcom 2 watt 10 channel
  • JMX-144D Jobcom 4 watt 10 channel
  • Frequency Code 00 - DELETE
  • Frequency Code 01 - 154.6000 MHz - MURS 4 Green Dot (25 kHz bandwidth)
  • Frequency Code 02 - 154.5700 MHz - MURS 5 Blue Dot (25 kHz bandwidth)
  • Frequency Code 03 - 151.6250 MHz - Red Dot
  • Frequency Code 04 - 151.9550 MHz - Purple Dot
  • Frequency Code 05 - 151.9250 MHz
  • Frequency Code 06 - 154.5400 MHz
  • Frequency Code 07 - 154.5150 MHz
  • Frequency Code 08 - 151.6550 MHz
  • Frequency Code 09 - 151.6850 MHz
  • Frequency Code 10 - 151.7150 MHz
  • Frequency Code 11 - 151.7750 MHz
  • Frequency Code 12 - 151.805
  • Frequency Code 13 - 151.835
  • Frequency Code 14 - 151.895
  • Frequency Code 15 - 154.490
  • Frequency Code 16 - 151.655
  • Frequency Code 17 - 151.745
  • Frequency Code 18 - 151.865
  • Frequency Code 19 - 151.8200 MHz - MURS 1
  • Frequency Code 20 - 151.8800 MHz - MURS 2
  • Frequency Code 21 - 151.9400 MHz - MURS 3
  • Frequency Code 22 - 154.6000 MHz - MURS 4 Green Dot (12.5 kHz bandwidth)
  • Frequency Code 23 - 154.5700 MHz - MURS 5 Blue Dot (12.5 kHz bandwidth)
  • Frequency Code 24 - 151.7000 MHz
  • Frequency Code 25 - 151.7000 MHz
  • Frequency Code 26 - 158.4000 MHz
Ritron JOBCOM JMX D Series UHF radios
  • JMX-441D Jobcom 1 watt 10 channel
  • JMX-446D Jobcom 2 watt 10 channel
  • JMX-444D Jobcom 3 watt 10 channel
  • Frequency Code 01 - 467.7625 MHz
  • Frequency Code 02 - 467.8125 MHz
  • Frequency Code 03 - 464.5500 MHz
  • Frequency Code 10 - 462.5750 MHz - FRS 16 White Dot
  • Frequency Code 11 - 462.6250 MHz - FRS 18 Black Dot
  • Frequency Code 12 - 462.6750 MHz - FRS 20 Orange Dot
  • Frequency Code 21 - 462.7000 MHz - FRS 21
  • Frequency Code 22 - 464.5000 MHz
  • Frequency Code 74 -
  • Frequency Code 75 - 469.5125 MHz
  • Frequency Code 76 - 469.5375 MHz
  • Frequency Code 77 - 469.5625 MHz
KidDesigns Walkie Talkies
  • Power Output: 0.133mW
  • Emission: 11K0F3E
  • FCC ID IAJ-210
  • Power Output: 7mW
  • Emission: 11K0F3E
  • FCC ID IAJ-212C7A
  • Power Output: 3.2mW
  • Emission: 11K0F3E
  • FCC ID IAJ-212C7B
  • Power Output: 4.2mW
  • Emission: 4K26F3E
  • FCC ID IAJ-216
  • Channel 51 - 462.6375 MHz 032 DCS
  • Channel 52 - 462.6875 MHz 051 DCS
  • Channel 53 - 467.5625 MHz 071 DCS
  • Channel 54 - 467.6125 MHz 074 DCS
  • Channel 55 - 467.6625 MHz 116 DCS
  • Channel 56 - 467.7125 MHz 132 DCS
  • Channel 57 - 462.5750 MHz 152 DCS
  • Channel 58 - 462.6250 MHz 162 DCS
  • Channel 59 - 462.6750 MHz 174 DCS
  • Channel 60 - 462.7250 MHz 226 DCS
  • Channel 61 - User configurable (user selects from channel 1-22 and then either selects no squelch, CTCSS code 1-38 or DCS code 1-83).
Cobra RX380 Series FRS Radios
Cobra RX380
SAMCOM 20 Channel UHF Radios
FCC ID 2AIOQ-FPCN30AA
  • CH01 - 462.5500 MHz D226 [FRS Channel 15 - D226N | 226 DCS]
  • CH02 - 462.5750 MHz D243 [FRS Channel 16 - D243N | 243 DCS]
  • CH03 - 462.6000 MHz D244 [FRS Channel 17 - D244N | 244 DCS]
  • CH04 - 462.6250 MHz D245 [FRS Channel 18 - D245N | 245 DCS]
  • CH05 - 462.6500 MHz D246 [FRS Channel 19 - D246N | 246 DCS]
  • CH06 - 462.6750 MHz D251 [FRS Channel 20 - D251N | 251 DCS]
  • CH07 - 462.7000 MHz D252 [FRS Channel 21 - D252N | 252 DCS]
  • CH08 - 462.7250 MHz D255 [FRS Channel 22 - D255N | 255 DCS]
  • CH09 - 462.5625 MHz D261 [FRS Channel 1 - D261N | 261 DCS]
  • CH10 - 462.5875 MHz D332 [FRS Channel 2 - D332N | 332 DCS]
  • CH11 - 462.6125 MHz D265 [FRS Channel 3 - D265N | 265 DCS]
  • CH12 - 462.6375 MHz D266 [FRS Channel 4 - D266N | 266 DCS]
  • CH13 - 462.6625 MHz D271 [FRS Channel 5 - D271N | 271 DCS]
  • CH14 - 462.6875 MHz D274 [FRS Channel 6 - D274N | 274 DCS]
  • CH15 - 462.6500 MHz D306 [FRS Channel 19 - D306N | 306 DCS]
  • CH16 - 462.5500 MHz D311 [FRS Channel 15 - D311N | 311 DCS]
  • CH17 - 462.7000 MHz D315 [FRS Channel 21 - D315N | 315 DCS]
  • CH18 - 462.6625 MHz D325 [FRS Channel 5 - D325N | 325 DCS]
  • CH19 - 462.5625 MHz D331 [FRS Channel 1 - D331N | 331 DCS]
  • CH0 - 462.7125 MHz D225 [FRS Channel 7 - D225N | 225 DCS]
Radioditty GA-2S
  • Channel 8 - 462.5500 MHz
  • Channel 10 - 462.6000 MHz
  • Channel 11 - 462.6250 MHz
  • Channel 12 - 462.6500 MHz
  • Channel 13 - 462.6750 MHz
  • Channel 14 - 462.7000 MHz
  • Channel 15 - 462.7250 MHz
  • VFO F1 - 400.5250 MHz FM [CSQ]
  • VFO F2 - 226.0000 MHz FM [CSQ]
  • VFO F3 - 469.5250 MHz FM [CSQ]
  • Channel 1 - 136.4250 MHz FM CSQ
  • Channel 2 - 150.4250 MHz FM 159.8 Hz PL
  • Channel 3 - 173.9450 MHz FM CSQ
  • Channel 4 - 220.4250 MHz FM CSQ
  • Channel 5 - 240.4250 MHz FM D023N 023 DPL
  • Channel 6 - 259.9450 MHz FM CSQ
  • Channel 7 - 400.4250 MHz FM CSQ
  • Channel 8 - 435.4250 MHz FM CSQ
  • Channel 9 - 469.4250 MHz FM CSQ
  • Channel 10 - 136.4250 MHz NFM 67.0 Hz PL
  • Channel 11 - 150.4250 MHz NFM 254.1 Hz PL
  • Channel 12 - 173.9450 MHz NFM D023N 023 DPL
  • Channel 13 - 220.4250 MHz NFM 67.0 Hz
  • Channel 14 - 240.4250 MHz NFM 254.1 Hz PL
  • Channel 15 - 259.9450 MHz NFM D023N 023 DPL
  • Channel 16 - 400.4250 MHz NFM 67.0 Hz PL
  • Channel 17 - 435.4250 MHz NFM 254.1 Hz PL
  • Channel 18 - 469.4250 MHz NFM D023N 023 DPL
TXPro TX-680AV VHF
VHF version 136-174 MHz
FCC ID: 2AS4FEPCOTX680AV
Retevis RT10
Zone 1
Zone 2
Zone 3
Retevis RT30
Default Channel Frequency
Retevis RT30
Retevis RT30M
  • Channel 15 - 460.3250 CSQ
Retevis RT1-UHF RT1 RT-1
Retevis RT1-VHF RT1 RT-1
  • Channel 15 - 462.5625 MHz 026 DPL 026 DCS D026N - FRS Channel 1
  • Channel 16 - 467.5625 MHz 026 DPL 026 DCS D026N - FRS Channel 8
  • Channel 1 - 462.5625 MHz 043 DPL D043N - FRS Channel 1
  • Channel 2 - 462.5875 MHz 065 DPL D065N - FRS Channel 2
  • Channel 3 - 462.6125 MHz 116 DPL D116N - FRS Channel 3
  • Channel 4 - 462.6375 MHz 205 DPL D205N - FRS Channel 4
  • Channel 5 - 462.6625 MHz 261 DPL D261N - FRS Channel 5
  • Channel 6 - 462.6875 MHz 265 DPL D265N - FRS Channel 6
  • Channel 7 - 462.7125 MHz 271 DPL D271N - FRS Channel 7
  • Channel 8 - 467.5625 MHz 306 DPL D306N - FRS Channel 8
  • Channel 9 - 467.5875 MHz 311 DPL D311N - FRS Channel 9
  • Channel 10 - 467.6125 MHz 331 DPL D331N - FRS Channel 10
  • Channel 11 - 467.6375 MHz 365 DPL D365N - FRS Channel 11
  • Channel 12 - 467.6625 MHz 431 DPL D431N - FRS Channel 12
  • Channel 13 - 467.6875 MHz 466 DPL D466N - FRS Channel 13
  • Channel 14 - 467.7125 MHz 503 DPL D503N - FRS Channel 14
  • Channel 1 - 446.00625 MHz 114 DPL D114N - PMR446 Channel 1
  • Channel 2 - 446.01875 MHz 131 DPL D131N - PMR446 Channel 2
  • Channel 3 - 446.03125 MHz 132 DPL D132N - PMR446 Channel 3
  • Channel 4 - 446.04375 MHz 165 DPL D165N - PMR446 Channel 4
  • Channel 5 - 446.05625 MHz 226 DPL D226N - PMR446 Channel 5
  • Channel 6 - 446.06875 MHz 306 DPL D306N - PMR446 Channel 6
  • Channel 7 - 446.08125 MHz 371 DPL D371N - PMR446 Channel 7
  • Channel 8 - 446.09375 MHz 503 DPL D503N - PMR446 Channel 8
HN5RV01 firmware version
Baofeng UV-5R8W
  • Channel 1 - 400.1250 MHz
  • Channel 2 - 410.1250 MHz
  • Channel 3 - 420.1250 MHz
  • Channel 4 - 430.1250 MHz
  • Channel 5 - 440.1250 MHz
  • Channel 6 - 450.1250 MHz
  • Channel 7 - 460.1250 MHz
  • Channel 8 - 470.1250 MHz
  • Channel 9 - 480.1250 MHz
  • Channel 10 - 490.1250 MHz
  • Channel 11 - 500.1250 MHz
  • Channel 12 - 510.1250 MHz
  • Channel 13 - 519.9750 MHz
  • Channel 14 - 136.1250 MHz
  • Channel 15 - 145.1250 MHz
  • Channel 16 - 155.1250 MHz
  • Channel 17 - 165.1250 MHz
  • Channel 18 - 173.9750 MHz
Baofeng UV-98 UV98Pro
  • Freq 1 - 464.5000 MHz
  • Freq 2 - 464.5500 MHz
  • Freq 3 - 467.7625 MHz
  • Freq 4 - 467.8125 MHz
  • Freq 5 - 467.8500 MHz
  • Freq 6 - 467.8750 MHz
  • Freq 7 - 467.9000 MHz
  • Freq 8 - 467.9250 MHz
  • Freq 9 - 461.0375 MHz
  • Freq 10 - 461.0625 MHz
  • Freq 11 - 461.0875 MHz
  • Freq 12 - 461.1125 MHz
  • Freq 13 - 461.1375 MHz
  • Freq 14 - 461.1625 MHz
  • Freq 15 - 461.1875 MHz
  • Freq 16 - 461.2125 MHz
  • Freq 17 - 461.2375 MHz
  • Freq 18 - 461.2625 MHz
  • Freq 19 - 461.2875 MHz
  • Freq 20 - 461.3125 MHz
  • Freq 21 - 461.3375 MHz
  • Freq 22 - 461.3625 MHz
  • Freq 23 - 462.7625 MHz
  • Freq 24 - 462.7875 MHz
  • Freq 25 - 462.8125 MHz
  • Freq 26 - 462.8375 MHz
  • Freq 27 - 462.8625 MHz
  • Freq 28 - 462.8875 MHz
  • Freq 29 - 462.9125 MHz
  • Freq 30 - 464.4875 MHz
  • Freq 31 - 464.5125 MHz
  • Freq 32 - 464.5375 MHz
  • Freq 33 - 464.5625 MHz
  • Freq 34 - 466.0375 MHz
  • Freq 35 - 466.0625 MHz
  • Freq 36 - 466.0875 MHz
  • Freq 37 - 466.1125 MHz
  • Freq 38 - 466.1375 MHz
  • Freq 39 - 466.1625 MHz
  • Freq 40 - 466.1875 MHz
  • Freq 41 - 466.2125 MHz
  • Freq 42 - 466.2375 MHz
  • Freq 43 - 466.2625 MHz
  • Freq 44 - 466.2875 MHz
  • Freq 45 - 466.3125 MHz
  • Freq 46 - 466.3375 MHz
  • Freq 47 - 466.3625 MHz
  • Freq 48 - 467.7875 MHz
  • Freq 49 - 467.8375 MHz
  • Freq 50 - 467.8625 MHz
  • Freq 51 - 467.8875 MHz
  • Freq 52 - 467.9125 MHz
  • Freq 53 - 469.4875 MHz
  • Freq 54 - 469.5125 MHz
  • Freq 55 - 469.5375 MHz
  • Freq 56 - 469.5625 MHz
  • Freq 9 - 462.5750 MHz
  • Freq 10 - 462.6250 MHz
  • Freq 11 - 462.6750 MHz
  • Freq 12 - 464.3250 MHz
  • Freq 13 - 464.8250 MHz
  • Freq 14 - 469.2625 MHz
  • Freq 15 - 469.5000 MHz
  • Freq 16 - 469.5500 MHz
  • Freq 17 - 462.7625 MHz
  • Freq 18 - 462.7875 MHz
  • Freq 19 - 462.8125 MHz
  • Freq 20 - 462.8375 MHz
  • Freq 21 - 462.8625 MHz
  • Freq 22 - 462.8875 MHz
  • Freq 23 - 462.9125 MHz
  • Freq 23 - 461.0375 MHz
  • Freq 25 - 461.0625 MHz
  • Freq 26 - 461.0875 MHz
  • Freq 27 - 461.1125 MHz
  • Freq 28 - 461.1375 MHz
  • Freq 29 - 461.1625 MHz
  • Freq 30 - 461.1875 MHz
  • Freq 31 - 461.2125 MHz
  • Freq 32 - 461.2375 MHz
  • Freq 33 - 461.2625 MHz
  • Freq 34 - 461.2875 MHz
  • Freq 35 - 461.3125 MHz
  • Freq 36 - 461.3375 MHz
  • Freq 37 - 461.3625 MHz
  • Freq 38 - 467.7875 MHz
  • Freq 39 - 467.8375 MHz
  • Freq 40 - 467.8625 MHz
  • Freq 41 - 467.8875 MHz
  • Freq 42 - 467.9125 MHz
  • Freq 43 - 464.4875 MHz
  • Freq 44 - 464.5125 MHz
  • Freq 45 - 464.5375 MHz
  • Freq 46 - 464.5625 MHz
  • Freq 47 - 466.0375 MHz
  • Freq 48 - 466.0625 MHz
  • Freq 49 - 466.0875 MHz
  • Freq 50 - 466.1125 MHz
  • Freq 51 - 466.1375 MHz
  • Freq 52 - 466.1625 MHz
  • Freq 53 - 466.1875 MHz
  • Freq 54 - 466.2125 MHz
  • Freq 55 - 466.2375 MHz
  • Freq 56 - 466.2625 MHz
  • Freq 1 - 151.6250 MHz
  • Freq 2 - 151.9550 MHz
  • Freq 3 - 154.5700 MHz
  • Freq 4 - 154.6000 MHz
  • Freq 5 - 151.7000 MHz
  • Freq 6 - 151.7600 MHz
  • Freq 7 - 151.8200 MHz
  • Freq 8 - 151.8800 MHz
  • Freq 9 - 151.9400 MHz
  • Freq 10 - 151.5125 MHz
  • Freq 11 - 151.6550 MHz
  • Freq 12 - 151.6850 MHz
  • Freq 13 - 151.7150 MHz
  • Freq 14 - 151.7450 MHz
  • Freq 15 - 151.7750 MHz
  • Freq 16 - 151.8650 MHz
  • Freq 17 - 151.8950 MHz
  • Freq 18 - 151.9250 MHz
  • Freq 20 - 154.4900 MHz
  • Freq 21 - 154.5150 MHz
  • Freq 22 - 154.5275 MHz
  • Freq 23 - 154.5400 MHz
  • Freq 24 - 154.6000 MHz
  • Freq 26 - 158.4000 MHz
  • Freq 27 - 158.4075 MHz
  • Freq 57 - 462.1875 MHz
  • Freq 58 - 462.4625 MHz
  • Freq 59 - 462.4875 MHz
  • Freq 60 - 462.5125 MHz
  • Freq 61 - 467.1875 MHz
  • Freq 62 - 467.4625 MHz
  • Freq 63 - 467.4875 MHz
  • Freq 64 - 467.5125 MHz
  • Freq 65 - 451.1875 MHz
  • Freq 66 - 451.2375 MHz
  • Freq 67 - 451.2875 MHz
  • Freq 68 - 451.3375 MHz
  • Freq 69 - 451.4375 MHz
  • Freq 70 - 451.5375 MHz
  • Freq 71 - 451.6375 MHz
  • Freq 72 - 452.3125 MHz
  • Freq 73 - 452.5375 MHz
  • Freq 74 - 452.4125 MHz
  • Freq 75 - 452.5125 MHz
  • Freq 76 - 452.7625 MHz
  • Freq 77 - 452.8625 MHz
  • Freq 78 - 456.1875 MHz
  • Freq 79 - 456.2375 MHz
  • Freq 80 - 456.2875 MHz
  • Freq 81 - 468.2125 MHz
  • Freq 82 - 468.2625 MHz
  • Freq 83 - 468.3125 MHz
  • Freq 84 - 468.3625 MHz
  • Freq 85 - 468.4125 MHz
  • Freq 86 - 468.4625 MHz
  • Freq 87 - 468.5125 MHz
  • Freq 88 - 468.5625 MHz
  • Freq 89 - 468.6125 MHz
  • Freq 90 - 468.6625 MHz
  • Freq 81 - 456.3375 MHz
  • Freq 82 - 456.4375 MHz
  • Freq 83 - 456.5375 MHz
  • Freq 84 - 456.6375 MHz
  • Freq 85 - 457.3125 MHz
  • Freq 86 - 457.4125 MHz
  • Freq 87 - 457.5125 MHz
  • Freq 88 - 457.7625 MHz
  • Freq 89 - 457.8625 MHz
  • Freq 3 - 152.8850 MHz
  • Freq 4 - 152.9150 MHz
  • Freq 7 - 152.9450 MHz
  • Freq 8 - 151.8350 MHz
  • Freq 9 - 151.8050 MHz
  • Freq 24 - 153.0050 MHz
  • Freq 0 - OFF (BLANK)
