MURS
Revision as of 20:58, 14 February 2020 by R4002 (Talk | contribs)
Multi Use Radio Service
MURS Frequencies / Channels:
Common analog voice emissions (generally FM voice) include 11K2F3E, 11K0F3E, 10K0F3E, 9K20F3E and 9K10F3E (Baofeng radios) for MURS channels 1, 2 and 3. 20K0F3E and 16K0F3E are allowed on MURS 4 and 5. Radios used by Wal-Mart, for example, transmit 20K0F3E emission on 154.57 MHz and 154.6 MHz but transmit 11K0F3E on 151.82 MHz, 151.88 MHz and 151.94 MHz. All five MURS frequencies are heavily used by WalMart and Sam's Club stores.
Motorola RMM2050 5 channel MURS radio default channels:
  • Channel 1 - 154.5700 MHz 67.0 Hz PL 20.0 kHz bandwidth [Identified in radio programming as Frequency 1] - MURS 4
  • Channel 2 - 154.6000 MHz 67.0 Hz PL 20.0 kHz bandwidth [Identified in radio programming as Frequency 2] - MURS 5
  • Channel 3 - 151.8200 MHz 67.0 Hz PL 11.25 kHz bandwidth [Identified in radio programming as Frequency 3] - MURS 1
  • Channel 4 - 151.8800 MHz 67.0 Hz PL 11.25 kHz bandwidth [Identified in radio programming as Frequency 4] - MURS 2
  • Channel 5 - 151.9400 MHz 67.0 Hz PL 11.25 kHz bandwidth [Identified in radio programming as Frequency 5] - MURS 3
Motorola CP110M 8 channel MURS radio default channels:
  • Channel 1 - 154.5700 MHz 67.0 Hz PL 20.0 kHz bandwidth [Identified in radio programming as Frequency 2] - MURS 4
  • Channel 2 - 154.6000 MHz 67.0 Hz PL 20.0 kHz bandwidth [Identified in radio programming as Frequency 1] - MURS 5
  • Channel 6 - 154.5700 MHz CSQ 20.0 kHz bandwidth [Identified in radio programming as Frequency 2] - MURS 4
  • Channel 7 - 154.6000 MHz CSQ 20.0 kHz bandwidth [Identified in radio programming as Frequency 1] - MURS 5
  • Channel 8 - 151.8200 MHz CSQ 11.25 kHz bandwidth [Identified in radio programming as Frequency 3] - MURS 1
Motorola RDM2070D 7 channel Wal-Mart MURS radio default channels:
  • Channel 1 - 154.5700 MHz CSQ
  • Channel 2 - 154.6000 MHz CSQ
  • Channel 3 - 151.8200 MHz 136.5 Hz PL
  • Channel 4 - 151.8800 MHz 136.5 Hz PL
  • Channel 5 - 151.9400 MHz 136.5 Hz PL
  • Channel 6 - 154.5700 MHz 136.5 Hz PL
  • Channel 7 - 154.6000 MHz 136.5 Hz PL
Note: Wal-Mart stores will often re-program their radios to use different CTCSS (PL) tones in areas where frequency congestion is an issue. However, a significant number of stores continue to use CSQ (carrier squelch) on 154.570 MHz and 154.600 MHz. Use of non-MURS frequencies by some Wal-Mart (and Sam's Club) stores has also been reported along with use of the 151.820 MHz, 151.880 MHz and 151.940 MHz MURS frequencies with carrier squelch. Like other Motorola MURS radios, the RDM2070 is hard-programmed for wideband 20 kHz FM on 154.57 and 154.6 MHz.
Motorola RDM2020 2 channel MURS radio default channels:
Motorola RDM2080D 8 channel MURS radio default channels:
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Mount Jackson, Virginia (Shenandoah County, VA) very large coverage area
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Richmond, Virginia (low power, 2w transmitter, around 5w ERP - located in downtown Richmond, VA)
  • The Mount Jackson, VA MURS simplex repeater has 50+ mile coverage in the valleys below and even further from higher elevations in the Blue Ridge Mountains and Virginia Piedmont region. Coverage extends into portions of eastern West Virginia. Confirmed active August 2019.
  • The Richmond, VA MURS simplex repeater has considerably less coverage due to its low power transmitter and location in an urban area. Coverage is reliable in downtown Richmond and other areas of the city. Both of these MURS repeaters use MURS ch 2 - 151.880 MHz and CTCSS / PL tone 156.7 Hz for transmit and receive. The Richmond MURS repeater is off-grid power (solar powered with battery backup) to help support emergency communications. Confirmed active February 2020.
  • 151.8200 MHz - Militia/Patriot MURS VHF MURS 1
  • 151.8800 MHz - Militia/Patriot MURS VHF MURS 2
  • 151.9400 MHz - Militia/Patriot MURS VHF Primary/Calling MURS 3 - AmRRON VHF
  • 154.5700 MHz - Militia/Patriot MURS VHF MURS 4
  • 154.6550 MHz - Militia/Patriot VHF BUSINESS 25
Alternate VHF militia plans:
  • 154.5275 MHz - Channel 16 - Operations 16 VHF Itinerant Business
  • 158.4000 MHz - Channel 17 - Operations 17 VHF Itinerant Business
  • 158.4075 MHz - Channel 18 - Operations 18 VHF Itinerant Business
All frequencies should be programmed in NARROWBAND mode. Narrow FM, NFM, NBFM, 12.5 kHz, 12 kHz etc. Wideband 20K 20 kHz or 25 kHz may be used on 154.570 MHz and 154.600 MHz only.
