Revision as of 13:53, 5 November 2023 by R4002 (Talk | contribs)
CB Channel Frequency Old Designated Use (Mostly Defunct)
Channel 1 26.965 MHz Stations operating under the same license - “intrastation”
Channel 2 26.975 MHz Stations operating under the same license - “intrastation”
Channel 3 26.985 MHz Stations operating under the same license - “intrastation”
Channel 4 27.005 MHz Stations operating under the same license - “intrastation”
Channel 5 27.015 MHz Stations operating under the same license - “intrastation”
Channel 6 27.025 MHz Stations operating under the same license - “intrastation”
Channel 7 27.035 MHz Stations operating under the same license - “intrastation”
Channel 8 27.055 MHz Stations operating under the same license - “intrastation”
Channel 9 27.065 MHz Emergency channel
Channel 11 27.085 MHz Calling channel
Channel 12 27.105 MHz
Channel 13 27.115 MHz
Channel 14 27.125 MHz
Channel 15 27.135 MHz Stations operating under the same license - “intrastation”
Channel 16 27.155 MHz Stations operating under the same license - “intrastation”
Channel 17 27.165 MHz Stations operating under the same license - “intrastation”
Channel 18 27.175 MHz Stations operating under the same license - “intrastation”
Channel 19 27.185 MHz Trucker channel or road channel
Channel 20 27.205 MHz Stations operating under the same license - “intrastation”
Channel 21 27.215 MHz Stations operating under the same license - “intrastation”
Channel 22 27.225 MHz Stations operating under the same license - “intrastation”
Channel 23 27.255 MHz Stations operating under different licenses - “interstation” - shared with pagers/high power data
FCC Rules Part 95
AM, FM and SSB Modulation in the United States. US FCC CB Radio Service (CBRS) regulations require all CB radios to have AM mode capability. SSB and/or FM are optional. If the radio is equipped with SSB capability, it must at least be able to use the upper side band. SSB CB equipment is capable of LSB and USB. FCC rules allow 4 watt AM carrier power, 4 watt FM power and 12 watt PEP SSB power. Bandwidth limits are 8 kHz for AM mode (8K00A3E), 8 kHz for FM (8K00F3E), and 4 kHz for SSB. SSB with carrier (4K00H3E), SSB with reduced carrier (4K00R3E), and true SSB without carrier (4K00J3E) are allowed.
FM is legal on the CB band FM legal on 11 meters in the USA as of October 28th, 2021), Australia, Asia, FM allowed in Europe and elsewhere. In the Americas, most CB radio communications are in AM mode, with lots of SSB use and some FM use. In many parts of Europe, most CB radio communications are in FM mode, with some AM mode use and SSB use. In the United States, AM is the standard mode. In many European countries, FM is the standard mode and is available throughout Europe.
CB Channel Frequency Remarks
Channel 30 27.305 MHz
Channel 32 27.325 MHz
Channel 33 27.335 MHz
Channel 34 27.345 MHz
Channel 1 27.60125 MHz
Channel 2 27.61125 MHz
Channel 3 27.62125 MHz
Channel 4 27.63125 MHz
Channel 5 27.64125 MHz
Channel 6 27.65125 MHz
Channel 7 27.66125 MHz
Channel 8 27.67125 MHz
Channel 9 27.68125 MHz
Channel 10 27.69125 MHz
Channel 11 27.70125 MHz
Channel 12 27.71125 MHz
Channel 13 27.72125 MHz
Channel 14 27.73125 MHz Base station to base station channel "home base" channel
Channel 15 27.74125 MHz
Channel 16 27.75125 MHz
Channel 17 27.76125 MHz
Channel 18 27.77125 MHz
Channel 19 27.78125 MHz Calling and Road Channel
Channel 20 27.79125 MHz
Channel 21 27.80125 MHz
Channel 22 27.81125 MHz
Channel 23 27.82125 MHz
Channel 24 27.83125 MHz
Channel 25 27.84125 MHz
Channel 26 27.85125 MHz
Channel 27 27.86125 MHz
Channel 28 27.87125 MHz
Channel 29 27.88125 MHz
Channel 30 27.89125 MHz
Channel 31 27.90125 MHz
Channel 32 27.91125 MHz
Channel 33 27.92125 MHz
Channel 34 27.93125 MHz
Channel 35 27.94125 MHz
Channel 36 27.95125 MHz
Channel 37 27.96125 MHz
Channel 38 27.97125 MHz
Channel 39 27.98125 MHz
Channel 40 27.99125 MHz
80 Channel CB radio. DE mode on multi-norm CB radios.
FM modulation only in Germany, Czech Republic and Hungary on channels 41-80. AM, FM and SSB are allowed channels 1-40, while radios are supposed to switch to FM mode only (4 watt power limit) for the 26.565-26.955 MHz portion.
Digital modes allowed on specified channels (26.675 MHz, 26.685 MHz, 26.915 MHz and 26.925 MHz) in Germany - channels 52, 53, 76 and 77. Designated channels 41-80 (channels 1-40 are the US/CEPT standardized channels). Full 80 channel allocation 26.565 MHz to 27.405 MHz or 26.560 MHz to 27.410 MHz. Shared with paging services, fixed links, remote control (RC), on-campus voice and/or data pagers and the fixed service, especially in border areas.
Czech Republic regulations specify that data transmission between CB stations is permitted on channels 24, 25, 52, 53, 76 and 77. F1D, F2D, G1D, G2D, J1D, J2D, A1D and A2D emissions (modes) are permitted. Remote control transmitters are allowed on channels 18 and 23. Czech regulations also specify channel 1 and channel 80 as calling channels using selective calling systems, including tone-based such as DTMF as well as CTCSS and DCS (PL and DPL) with users switching to another channel as soon as possible.
Channel 1 26.965 MHz Calling channel - FM mode
Channel 4 27.005 MHz Recommended AM calling channel - AM mode
Channel 6 27.025 MHz Digital modes permitted - data channel
Channel 7 27.035 MHz Digital modes permitted - data channel
Channel 11 27.085 MHz Internet gateways
Channel 15 27.135 MHz SSB calling channel - USB mode
Channel 16 27.155 MHz SSB activity - LSB and USB
Channel 19 27.185 MHz Trucker channel / road channel - FM mode
Channel 20 27.205 MHz Simplex repeaters - FM mode
Channel 23 27.255 MHz Digital modes permitted - data channel
Channel 24 27.235 MHz Digital modes permitted - data channel
Channel 25 27.245 MHz Digital modes permitted - data channel
Channel 29 27.295 MHz Internet gateways
Channel 30 27.305 MHz Recommended FM calling/DX channel - FM mode
Channel 31 27.315 MHz FM DX calling (see also: 27.305 MHz)
Channel 39 27.395 MHz Internet gateways
Channel 40 27.405 MHz Digital modes permitted - data channel
Channel 41 26.565 MHz DX calling channel - FM mode
Channel 42 26.575 MHz DX calling channel - FM mode
Channel 43 26.585 MHz
Channel 44 26.595 MHz
Channel 45 26.605 MHz
Channel 46 26.615 MHz
Channel 47 26.625 MHz
Channel 48 26.635 MHz
Channel 49 26.645 MHz
Channel 50 26.655 MHz
Channel 51 26.665 MHz
Channel 52 26.675 MHz Digital modes permitted - data channel
Channel 53 26.685 MHz Digital modes permitted - data channel
Channel 54 26.695 MHz
Channel 55 26.705 MHz
Channel 56 26.715 MHz
Channel 57 26.725 MHz
Channel 58 26.735 MHz
Channel 59 26.745 MHz
Channel 60 26.755 MHz
Channel 61 26.765 MHz Internet gateways
Channel 62 26.775 MHz
Channel 63 26.785 MHz
Channel 64 26.795 MHz
Channel 65 26.805 MHz
Channel 66 26.815 MHz
Channel 67 26.825 MHz
Channel 68 26.835 MHz
Channel 69 26.845 MHz
Channel 70 26.855 MHz
Channel 71 26.865 MHz Internet gateways
Channel 72 26.875 MHz
Channel 73 26.885 MHz
Channel 74 26.895 MHz
Channel 75 26.905 MHz
Channel 76 26.915 MHz Digital modes permitted - data channel
Channel 77 26.925 MHz Digital modes permitted - data channel
Channel 78 26.935 MHz
Channel 79 26.945 MHz
Channel 80 26.955 MHz Internet gateways
Italian I2 Band Italy CB I2 34 Channel CB 26.875 MHz - 27.265 MHz
Not to be confused with the Italian 43 MHz VHF low band "VHF CB" band.
Italy permits use of the standard European harmonized CEPT band "mid band FM" as well as the same band plan - identical to the American CB radio allocation - with AM, FM and SSB allowed on the regular 40 channels.
Note that channels 1-23 match the standard CB band plan. Channel 24 (27.245 MHz) is channel 25 on the standard band and channel 25 (27.265 MHz) is channel 26 on the standard band. Channels 26 to 34 are the out of band frequencies, 26.875 MHz to 26.955 MHz. While AM and FM modes are permitted on these frequencies, SSB use is also reported and quite common. Channels 26-34 overlap with German 80 Channel CB channels 72 to 80 and the "low channels".
Channel 24 27.245 MHz
Channel 25 27.265 MHz
Channel 26 26.875 MHz
Channel 27 26.885 MHz
Channel 28 26.895 MHz
Channel 29 26.905 MHz
Channel 30 26.915 MHz
Channel 31 26.925 MHz
Channel 32 26.935 MHz
Channel 33 26.945 MHz
Channel 34 26.955 MHz
27 MHz Marine Channel Frequency
26 MHz AM Public Channels:
Channel 1 26.330 MHz AM and SSB
Channel 2 26.340 MHz AM and SSB
Channel 3 26.350 MHz AM and SSB
Channel 4 26.370 MHz AM and SSB
Channel 5 26.380 MHz AM and SSB
Channel 6 26.390 MHz AM and SSB
Channel 7 26.400 MHz AM and SSB
Channel 8 26.420 MHz AM and SSB
Channel 9 26.430 MHz AM and SSB
Channel 10 26.440 MHz AM and SSB
Channel 11 26.450 MHz Trucker channel/road channel (AM mode)
Channel 12 26.470 MHz AM and SSB
Channel 13 26.480 MHz AM and SSB
Channel 14 26.490 MHz AM and SSB
Channel 15 26.500 MHz AM calling channel
Channel 16 26.520 MHz AM and SSB
Channel 17 26.530 MHz AM and SSB
Channel 18 26.540 MHz AM mode only
Channel 19 26.550 MHz AM mode only
Channel 20 26.570 MHz AM mode only
Channel 21 26.580 MHz AM mode only
Channel 22 26.590 MHz AM mode only
Channel 23 26.620 MHz AM mode only
Channel 24 26.600 MHz AM mode only
Channel 25 26.610 MHz AM and SSB
Channel 26 26.630 MHz AM and SSB
Channel 27 26.640 MHz AM and SSB
Channel 28 26.650 MHz AM and SSB
Channel 29 26.660 MHz AM and SSB
Channel 30 26.670 MHz AM and SSB
Channel 31 26.680 MHz AM and SSB
Channel 32 26.690 MHz AM and SSB
Channel 33 26.700 MHz AM and SSB
Channel 34 26.710 MHz AM and SSB
Channel 35 26.720 MHz SSB calling channel - LSB mode
Channel 36 26.730 MHz AM and SSB
Channel 37 26.740 MHz AM and SSB
Channel 38 26.750 MHz AM and SSB
Channel 39 26.760 MHz AM and SSB
Channel 40 26.770 MHz AM and SSB
Channel 1 26.960 MHz
Channel 2 26.970 MHz
Channel 3 26.980 MHz
Channel 4 27.000 MHz
Channel 5 27.010 MHz
Channel 6 27.020 MHz
Channel 7 27.030 MHz
Channel 8 27.050 MHz
Channel 9 27.060 MHz
Channel 10 27.070 MHz
Channel 11 27.080 MHz
Channel 12 27.100 MHz
Channel 13 27.110 MHz
Channel 14 27.120 MHz
Channel 15 27.130 MHz
Channel 16 27.150 MHz
Channel 17 27.160 MHz
Channel 18 27.170 MHz
Channel 19 27.180 MHz
Channel 20 27.200 MHz
Channel 21 27.210 MHz
Channel 22 27.220 MHz
Channel 23 27.250 MHz
Channel 24 27.230 MHz
Channel 25 27.240 MHz
Channel 26 27.260 MHz
Channel 27 27.270 MHz
Channel 28 27.280 MHz
Channel 29 27.290 MHz
Channel 30 27.300 MHz
Channel 31 27.310 MHz
Channel 32 27.320 MHz
Channel 33 27.330 MHz
Channel 34 27.340 MHz
Channel 36 27.360 MHz
Channel 37 27.370 MHz
Channel 38 27.380 MHz
Channel 39 27.390 MHz
Channel 40 27.400 MHz
For example,
  • dE - Germany - 26.565 MHz - 27.405 MHz - 80 channels, channels 1-40 are AM/FM 4W/4W, same as CE band, channels 41-80 are FM only (4W) 26.565-26.955
Calling frequencies include:
  • 26.962 MHz LSB - Drop Gap 1
  • 26.965 MHz AM - Normal CB 1
  • 26.968 MHz USB - High Gap 1
  • 26.972 MHz LSB - Drop Gap 2
  • 26.975 MHz AM - Normal CB 2
Channel 1 26.968 MHz
Channel 2 26.976 MHz
Channel 3 27.040 MHz
Channel 4 27.080 MHz
Channel 5 27.088 MHz
Channel 6 27.112 MHz
Channel 7 27.120 MHz
Channel 8 27.144 MHz
Channel 26760 26.760 MHz
Channel 26768 26.768 MHz
Channel 26776 26.776 MHz
Channel 26824 26.824 MHz
Channel 26840 26.840 MHz
Channel 26848 26.848 MHz
Channel 26856 26.856 MHz
Channel 26864 26.864 MHz
Channel 26872 26.872 MHz
Channel 26880 26.880 MHz
Channel 26888 26.888 MHz
Channel 26896 26.896 MHz
Channel 26912 26.912 MHz
Channel 26920 26.920 MHz
Channel 26928 26.928 MHz
Channel 26936 26.936 MHz
Channel 26944 26.944 MHz
Channel 27016 27.016 MHz
Channel 27524 27.524 MHz
Channel 27532 27.532 MHz
Channel 27540 27.540 MHz
Channel 27548 27.548 MHz
Channel 27556 27.556 MHz
Channel 27572 27.572 MHz
Channel 27580 27.580 MHz
Channel 27628 27.628 MHz
Channel 27636 27.636 MHz
Channel 27644 27.644 MHz
Channel 27652 27.652 MHz
Channel 27660 27.660 MHz
Channel 27668 27.668 MHz
Channel 27676 27.676 MHz
Channel 27724 27.724 MHz
Channel 27732 27.732 MHz
Channel 27740 27.740 MHz
Channel 27748 27.748 MHz
Channel 27756 27.756 MHz
Channel 27764 27.764 MHz
Channel 27772 27.772 MHz
Channel 27780 27.780 MHz
Channel 27828 27.828 MHz
Channel 27836 27.836 MHz
Channel 27852 27.852 MHz
Channel 27860 27.860 MHz
Channel 27884 27.884 MHz
Channel 27892 27.892 MHz
Channel 27908 27.908 MHz
Channel 27916 27.916 MHz
Channel 27932 27.932 MHz
Channel 27940 27.940 MHz
Channel 27956 27.956 MHz
Channel 27964 27.964 MHz
Channel 27980 27.980 MHz
Channel 27988 27.988 MHz
27310.5 kHz 27.3105 MHz
27334.5 kHz 27.3345 MHz
27338.5 kHz 27.3385 MHz
27342.5 kHz 27.3425 MHz
27346.5 kHz 27.3465 MHz
27350.5 kHz 27.3505 MHz
27354.5 kHz 27.3545 MHz
27358.5 kHz 27.3585 MHz
27362.5 kHz 27.3625 MHz
27366.5 kHz 27.3665 MHz
27370.5 kHz 27.3705 MHz
27378.5 kHz 27.3785 MHz
27382.5 kHz 27.3825 MHz
27386.5 kHz 27.3865 MHz
27388.5 kHz 27.3885 MHz
27398.5 kHz 27.3985 MHz
27404.5 kHz 27.4045 MHz
27418.5 kHz 27.4185 MHz
27426.5 kHz 27.4265 MHz
27434.5 kHz 27.4345 MHz
27442.5 kHz 27.4425 MHz
27452.5 kHz 27.4525 MHz
27458.5 kHz 27.4585 MHz
27466.5 kHz 27.4665 MHz
27470.5 kHz 27.4705 MHz
  • SPECIFICATIONS
  • 25 kHz channel spacing
  • 480 channels
  • FEATURES
  • SPECIFICATIONS
  • 20 channels
  • AM modulation
  • FEATURES
CB Channel Frequency
Channel 19 27.185 MHz
Channel 20 27.205 MHz
Channel 21 27.215 MHz
Channel 22 27.225 MHz
Channel 23 27.255 MHz
Channel 24 27.235 MHz
Channel 25 27.245 MHz
Channel 26 27.265 MHz
Channel 27 27.275 MHz
AM on all channels. SSB only allowed on specified channels. 23 channels, 29.710 MHz - 29.985 MHz. 12.5 kHz channel spacing.
Some channels have multiple designations depending on their intended use. Used by boating clubs, 4x4 groups, farmers, etc. South African 4x4 groups are starting to migrate to VHF/UHF services but a 29 MHz CB appears to still be required equipment for many of these clubs (much like a 27 MHz CB is required by Jeep and 4x4 clubs in the US and UK).
AM and FM modes allowed. Shared with the fixed service. 5 watt power limit (expressed as ERP) Unclear if SSB is permitted. Full allocation band 26.957-27.283 MHz.
Channel frequencies 26.965 MHz - 27.275 MHz. Several VHF and UHF services are allowed in India for two-way radio, making 26 MHz/27 MHz CB radio a bit of a niche, with most two way walkie talkies in India such as the 350 MHz band SRR Short Range Radio. However, so-called multi-norm AM/FM CB radios are beginning to be shipped with the Indian band programmed in as one of the country modes the user may select.
IND08 - Use of wireless equipments intended to be used while in motion or during halts, in the frequency band 26.957 MHz - 27.283 MHz (same as the 27 MHz ISM band), with a maximum Effective Radiated Power (ERP) of 5 Watts has been exempted from licensing requirements.
Channel 1 26.965 MHz
Channel 2 26.975 MHz
Channel 3 26.985 MHz
Channel 4 27.005 MHz
Channel 5 27.015 MHz
Channel 6 27.025 MHz
Channel 7 27.035 MHz
Channel 8 27.055 MHz
Channel 9 27.065 MHz
Channel 10 27.075 MHz
Channel 11 27.085 MHz
Channel 12 27.105 MHz
Channel 13 27.115 MHz
Channel 14 27.125 MHz
Channel 15 27.135 MHz
Channel 16 27.155 MHz
Channel 17 27.165 MHz
Channel 18 27.175 MHz
Channel 41 27.415 MHz
Channel 42 27.425 MHz
Channel 43 27.435 MHz
Channel 44 27.455 MHz
Channel 45 27.465 MHz
Channel 46 27.475 MHz
Channel 47 27.485 MHz
Channel 48 27.505 MHz
Channel 49 27.515 MHz
Channel 50 27.525 MHz
Channel 51 27.535 MHz
Channel 52 27.555 MHz
Channel 53 27.565 MHz
Channel 54 27.575 MHz
Channel 55 27.585 MHz
Channel 56 27.605 MHz
Channel 57 27.615 MHz
Channel 58 27.625 MHz
Channel 59 27.635 MHz
Channel 60 27.655 MHz
Channel 61 27.665 MHz
Channel 62 27.675 MHz
Channel 63 27.685 MHz
Channel 64 27.695 MHz
Channel 65 27.705 MHz
Channel 66 27.715 MHz
Channel 67 27.725 MHz
Channel 68 27.735 MHz
Channel 69 27.745 MHz
Channel 70 27.755 MHz
Channel 71 27.765 MHz
Channel 72 27.775 MHz
Channel 73 27.785 MHz
Channel 74 27.795 MHz
Channel 75 27.805 MHz
Channel 76 27.815 MHz
Channel 77 27.825 MHz
Channel 78 27.835 MHz
Channel 79 27.845 MHz
Channel 80 27.855 MHz
Channel Frequency
Italian I2 CB Band Channel 26 26.875 MHz
Italian I2 CB Band Channel 27 26.885 MHz
Italian I2 CB Band Channel 28 26.895 MHz
Italian I2 CB Band Channel 29 26.905 MHz
Italian I2 CB Band Channel 30 26.915 MHz
Italian I2 CB Band Channel 31 26.925 MHz
Italian I2 CB Band Channel 32 26.935 MHz
Italian I2 CB Band Channel 33 26.945 MHz
Italian I2 CB Band Channel 34 26.955 MHz
Polish (PL) "Zeros" CB Band Channel 1 26.960 MHz
Polish (PL) "Zeros" CB Band Channel 2 26.970 MHz
Polish (PL) "Zeros" CB Band Channel 3 26.980 MHz
Polish (PL) "Zeros" CB Band Channel 4 27.000 MHz
Polish (PL) "Zeros" CB Band Channel 5 27.010 MHz
Polish (PL) "Zeros" CB Band Channel 6 27.020 MHz
Polish (PL) "Zeros" CB Band Channel 7 27.030 MHz
Polish (PL) "Zeros" CB Band Channel 8 27.050 MHz
Polish (PL) "Zeros" CB Band Channel 9 27.060 MHz
Polish (PL) "Zeros" CB Band Channel 10 27.070 MHz
Polish (PL) "Zeros" CB Band Channel 11 27.080 MHz
Polish (PL) "Zeros" CB Band Channel 12 27.100 MHz
Polish (PL) "Zeros" CB Band Channel 13 27.110 MHz
Polish (PL) "Zeros" CB Band Channel 14 27.120 MHz
Polish (PL) "Zeros" CB Band Channel 15 27.130 MHz
Polish (PL) "Zeros" CB Band Channel 16 27.150 MHz
Polish (PL) "Zeros" CB Band Channel 17 27.160 MHz
Polish (PL) "Zeros" CB Band Channel 18 27.170 MHz
Polish (PL) "Zeros" CB Band Channel 19 27.180 MHz
Polish (PL) "Zeros" CB Band Channel 20 27.200 MHz
Polish (PL) "Zeros" CB Band Channel 21 27.210 MHz
Polish (PL) "Zeros" CB Band Channel 22 27.220 MHz
Polish (PL) "Zeros" CB Band Channel 24 27.230 MHz
Polish (PL) "Zeros" CB Band Channel 25 27.240 MHz
Italian I2 CB Band Channel 24 27.245 MHz
Polish (PL) "Zeros" CB Band Channel 23 27.250 MHz
Polish (PL) "Zeros" CB Band Channel 26 27.260 MHz
Italian I2 CB Band Channel 25 27.265 MHz
Polish (PL) "Zeros" CB Band Channel 27 27.270 MHz
Polish (PL) "Zeros" CB Band Channel 28 27.280 MHz
Polish (PL) "Zeros" CB Band Channel 29 27.290 MHz
Polish (PL) "Zeros" CB Band Channel 30 27.300 MHz
Polish (PL) "Zeros" CB Band Channel 31 27.310 MHz
Polish (PL) "Zeros" CB Band Channel 32 27.320 MHz
Polish (PL) "Zeros" CB Band Channel 33 27.330 MHz
Polish (PL) "Zeros" CB Band Channel 34 27.340 MHz
Polish (PL) "Zeros" CB Band Channel 35 27.350 MHz
Polish (PL) "Zeros" CB Band Channel 36 27.360 MHz
Polish (PL) "Zeros" CB Band Channel 37 27.370 MHz
Polish (PL) "Zeros" CB Band Channel 38 27.380 MHz
Polish (PL) "Zeros" CB Band Channel 39 27.390 MHz
Polish (PL) "Zeros" CB Band Channel 40 27.400 MHz
27.405 MHz 26.565 MHz Germany Oschenwang Germany Southern Germany CH40 output/CH41 input (German 80-channel CB) 840 kHz offset
26.515 MHz FM Russia Channel B01 E or C01E FM - CB Repeater 26515 kHz
26.575 MHz FM Poland
26.625 MHz FM Czech Republic
26.635 MHz FM Central Europe Multiple repeaters and Internet links 88.5 Hz CTCSS
26.685 MHz FM Western Russia
26.685 MHz FM Central Europe Multiple repeaters and Internet links
26.695 MHz FM Central Europe Multiple repeaters and Internet links
26.735 MHz FM Central Europe Multiple repeaters and Internet links
26.745 MHz FM Central Europe Multiple repeaters and Internet links
26.755 MHz FM Central Europe - multiple repeaters 88.5 Hz tone, 94.8 Hz tone and 100.0 Hz CTCSS
26.765 MHz FM Central Europe Multiple repeaters and Internet links
26.775 MHz FM Central Europe Simplex repeater - Germany or Czech Republic
26.785 MHz FM Central Europe
26.795 MHz FM Czech Republic
26.805 MHz FM Europe 26.805 MHz FM Simplex Repeater
26.815 MHz FM Central Europe Multiple repeaters and Internet links
26.825 MHz FM Central Europe CB Simplex Repeater 26.825 FM
26.855 MHz FM Central Europe CB Simplex Repeater 26.855 FM
26.865 MHz FM Central Europe CB Simplex Repeater 26.865 FM
26.875 MHz FM Central Europe CSQ (no tone) multiple repeaters on frequency
26.875 MHz FM Central Europe 88.5 Hz tone
26.875 MHz FM Central Europe 100.0 Hz tone
26.885 MHz FM Germany CB Channel 73 Simplex Repeater 26.885MHz FM
26.895 MHz FM Central Europe Multiple repeaters and Internet links
26.945 MHz FM Central Europe Multiple repeaters and Internet links
26.955 MHz FM Russia
26.960 MHz FM Poland Polish CB Radio Channel 1 FM Repeater
26.965 MHz FM Europe CB Repeater Channel 1 FM
26.970 MHz FM Lithuania
27.005 MHz FM Multiple simplex repeaters - Europe / Russia CB Repeater Channel 4 FM
27.025 MHz FM Russia CB Repeater Channel 6 FM
27.030 MHz FM Minsk, Belarus CB Repeater Channel 7R
27.030 MHz FM Shymkent, Kazakhstan CB Repeater Parrot Channel 7R FM
27.035 MHz FM Multiple simplex repeaters - Europe / Russia CB Repeater Channel 7 FM
27.035 MHz FM Sweden Swedish CB Repeater Channel 7 FM
27.040 MHz FM Minsk, Belarus
27.050 MHz FM Russia CB Channel 8R FM 27.050MHz FM
27.055 MHz FM Multiple simplex repeaters on 27.055 MHz Europe CB Channel 8 FM
27.055 MHz FM Germany CB Channel 8 FM Repeater
27.060 MHz FM Kiev, Ukraine Possibly off the air?
27.060 MHz FM Eastern Europe or Russia Multiple locations
27.065 MHz FM Eastern Europe or Russia CB Repeater Channel 9 FM
27.070 MHz FM Unknown location, Russia or Eastern Europe Channel 10R C10R FM 27070 FM repeater
27.075 MHz FM Moscow, Russia CB Repeater Channel 10 FM Channel C10E FM D10E FM
27.090 MHz FM Russia 27 MHz Simplex Repeater
27.100 MHz FM Krasnodar, Russia CB Repeater Channel 12R C12R FM
27.105 MHz FM Ulyanovsk, Russia 4 watt TX power CB Repeater Channel 12 FM
27.110 MHz FM Poland CB Repeater Channel 13R FM Channel 13P
27.110 MHz FM Russia
27.115 MHz FM Russia CB Repeater Channel 13 FM
27.130 MHz FM Russia CB Repeater Channel 15R FM
27.140 MHz FM Eastern Europe
27.150 MHz FM Poland
27.155 MHz FM Central Europe CB Repeater Channel 16 FM
27.170 MHz FM Poland
27.180 MHz FM Multiple sites Eastern Europe/Russia CB Repeater Channel 19R
27.190 MHz FM Russia Russian simplex repeater 27.190MHz FM
27.195 MHz FM Unknown location Eastern Europe or Russia Data, paging and RCRS frequency
27.200 MHz FM Zaykova, Russia
27.200 MHz FM Russia Multiple simplex repeaters CB Channel 20 R
27.205 MHz AM New Zealand CB Repeater AM mode Channel 20 AM repeater 27205 AM
27.220 MHz FM Russia CB Repeater Channel 22 R 27220kHz FM
27.225 MHz AM Southern USA CB Repeater Channel 22 AM
27.235 MHz FM Eastern Europe CB Repeater Channel 24 FM
27.245 MHz FM Eastern Europe CB Repeater Channel 25 FM
27.250 MHz FM Belarus CH 23R 23R FM 27250 kHz FM repeater
27.250 MHz FM Russia Repeater Channel 23R C23R FM
27.260 MHz FM Krivoi Rog (Kryvyi Rih), Ukraine CB Repeater Ukraine Channel 26R
27.265 MHz FM Russia - possibly multiple locations CB Repeater Channel 26 FM
27.265 MHz FM Nordic countries - Northern Europe CB Repeater Channel 26 FM
27.270 MHz FM Saratov, Russia
27.270 MHz FM Kiev, Ukraine 27mhz repeater Ukraine - OFF THE AIR?
27.275 MHz FM Europe Central Europe - Multiple repeaters on 27.275 FM
27.275 MHz FM Sweden Swedish CB Repeater Channel 27 FM
27.275 MHz FM Central or Western Europe CB Repeater Channel 27 FM
27.285 MHz FM Central Europe CB Repeater Channel 28 FM
27.290 MHz FM Minsk, Belarus
27.295 MHz FM Moscow, Russia
27.295 MHz FM Omsk Russia CB Parrot Repeater Omsk Russia 29E FM
27.295 MHz FM Sweden Swedish CB Repeater Channel 29 FM
27.325 MHz FM Central Europe CB Repeater Channel 32 FM
27.350 MHz FM Bobrusk Belarus CB Repeater Belarus 27.350 FM
27.370 MHz FM Western Russia
27.405 MHz FM Russian simplex repeater CB Repeater Channel 40 FM
27.415 MHz FM Russia or Eastern Europe
27.420 MHz FM Unknown location - Europe
27.430 MHz FM Western Russia
27.450 MHz FM Eastern Europe Data link and paging systems also active on this frequency
27.470 MHz FM Eastern Europe
27.490 MHz FM Moscow, Russia Possible cross-band 11M 27MHz cross band to UHF 433MHz
27.505 MHz FM Moscow, Russia
27.580 MHz FM Moscow, Russia
27.605 MHz FM Moscow, Russia
27.630 MHz FM Moscow, Russia
27.635 MHz FM Moscow, Russia
27.635 MHz FM Several locations
27.650 MHz FM Western Europe
27.675 MHz FM Russia
27.675 MHz FM Russia 88.5 Hz tone, likely multiple simplex repeaters on 27.675MHz FM
27.765 MHz FM Germany
27.775 MHz FM Russia 27.775MHz 11M LMR Repeater
27.840 MHz FM Poland 27.840MHz FM Repeater
27.855 MHz FM Central or Eastern Europe Simplex repeater parrot repeater 27MHz
27.875 MHz FM Rostov, Russia Rostov On Don 27.875MHz Channel E2 FM Parrot Repeater 27MHz
does AM radio still exist can you still buy CB radios do people still use CB radios CB radio for emergency emergencies prepper channels 26.96 - 27.41 MHz Citizen Radio Citizens Radio wikipedia CB frequencies on a Baofeng CB channels on a ham radio 26 MHz band what are the CB frequencies CB channel chart CB frequency chart UK USA UHF CB VHF CB HF CB AM CB SSB CB 120 channel CB channel range how far can a CB radio go CB antennas CB radio reviews do truckers still use CB radio 2018 2019 2020 today police CB radio frequencies channels 30 MHz band CB radio channels freeband channels freeband frequencies what is the best freeband radio CB radio police what CB channel do police use? they don't use CB radios and haven't for about 30 years...there are a lot of other users of CB radio though...freebanding frequencies channels prepper 25 MHz band 26 MHz band 27 MHz band 28 MHz 30 MHz band 30.555 MHz 30.105 MHz 25.615 MHz 27.405 MHz 26.955 MHz 26.505 MHz 26.515 MHz 26.510 MHz 26MHz taxi cab radio Uber radio Lyft radio two-way radio system taxicab radio dispatch YL Russia CADS UK 27/81 WPAS 120 channel mod frequency kit Lescomm DigiMax Lite Viagra board Cobra 29 channel kit 240 channel 360 channel 128 channel MB8719 RCI8719 cbradio.nl cbtricks.com EPT3600 board main board CB radio PCB 26.065 MHz 26.505 MHz 27500 kHz 27.500 MHz 27.5 MHz CB radio warfare RCI CRT EPT690010Z EPT6900 Uniden Cobra Galaxy Magnum SR-94C Galaxy DX radios 10kc 10kHz switch A channels secret channels phantom frequencies CB radio prepper frequencies hunting radios CB radio range 27 MHz RC transmitter PB010 PC879 PLL02A UPD858 MC145106 CB repeater CB VHF repeater CB MURS GMRS crossband cross-band GMRS MURS repeater 151.820 MHz 151.880 MHz 151.940 MHz 154.570 MHz 154.600 MHz 151.940 156.7 simplex repeater 27.205 MHz 462.550 - 467.7125 MHz radiobuoy fishnet beacon 26MHz 26.500 MHz 26500 kHz 26.450 MHz 26450 kHz 26MHz NZ CB UK FM 27/97 PR27 27 MHz FM CB can I use ham radio on CB frequencies what is 30 MHz band CB frequencies 10 meter intruders 11 meter taxi cab dispatch 26.285 USB 27.555 USB 27.185 AM 151.880 167.9 repeater 151.940 repeater simplex unlicensed illegal license free freebanders truckers on 25 MHz truckers on 10 meters unlicensed UHF frequencies MURS mobile CB mobile 25.615-30.105 MHz mobile radio handheld walkie talkie BF-888 Baofeng BF-888S BF-88A FRS on BF-888 B-888 work site radios Motorola Kenwood Icom BTECH unlicensed VHF frequencies MURS frequencies what are the CB channels police CB radio speed trap trucker talk CB radio HF truckers on CB channel 19 27.185 MHz 27185 kHz 27,185 27.180 MHz 27.635 MHz CADS WPAS Russian Taxis 24.715 MHz 25.165 MHz 25.615 MHz UK PO PL band 26.960 MHz 27.400 MHz what band is 30 MHz what frequency does military use CB radio channels what are the CB channels? 27.5 - 39.5 MHz 39.475 MHz HF radiotelephone fishery radio fisheries radio fisheries telephone radio 24.265 MHz 29.655 MHz 29.695 MHz 29.699 MHz 29.705 MHz 29.710 MHz bellscb rightchannelradios 26957 26.957 27120 27.120 MHz ISM band IoT bands 26-27 MHz data link transmitter 150 MHz truck radio hunting radio VHF CB radio 30.450 MHz 30.105 MHz 26-32 MHz 26-30 MHz 25-30 MHz 25.91 MHz 25.95 MHz 25.99 MHz 26.470 MHz marine radio CB RCI-2995 27.385 LSB ham radio gear on CB frequencies CB channels on a ham radio Anytone AT-5189 26-33 MHz 33-49 MHz 136-174 MHz 220-260 MHz 240-270 MHz 300-350 MHz 350-390 MHz 400-470 MHz 450-512 MHz 450-520 MHz 600 MHz band 700 MHz band 27.9 MHz 27.900 MHz 20-27.9 MHz 27-38.9 MHz 20-28 mc megacycle 27.8 MHz, 27.4 MHz, 27.41 MHz what are the freeband CB frequencies survivalist CB frequencies emergency frequencies near me emergency channels near me UHF emergency frequency VHF emergency frequency 4125 kHz 4417 kHz 6215 kHz 6200 kHz 6212 kHz 6516 kHz 8255 kHz 8779 kHz 12290 kHz 12359 kHz 11175 kHz 13200 kHz 13137 kHz 16420 kHz 16537 kHz 17302 kHz 18795 kHz 19770 kHz 22060 kHz 22756 kHz 25097 kHz 26.097 MHz R4002 26172 kHz 26.172 MHz 2045 kHz 2638 kHz 2003 kHz 6765 kHz 6770 kHz 2048 kHz 2635 kHz ship-to-shore international frequencies radiotelephone emergency calling frequencies GMDSS DSC 2182 kHz 2187.5 kHz 4207.5 kHz 6312 kHz 8414.4 kHz 12577 kHz 16804.5 kHz 156.525 MHz 156.3 MHz 156.8 MHz 156.800 MHz telegraphy distress safety narrow band direct printing 2174.5 kHz 4177.5 kHz 6268 kHz 8376.5 kHz 12520 kHz 16695 kHz 8291 kHz 16420 kHz 4125kHz 3023 kHz 5680 kHz 8364 kHz 10003 kHz 14993 kHz 19993 kHz 19.993 MHz 10.003 MHz 14.993 MHz 123.025 MHz 123.1 MHz 122.9 MHz 455.5 kHz 458.5 kHz 16805.5 kHz 16805 kHz 25208 kHz 25.208 MHz 26121 kHz 26122 kHz 26.840 MHz
