| 24.890 MHz to 24.990 MHz | 24890 kHz to 24990 kHz | Amateur Radio Ham Radio 12 Meter Band 12 Meters 12m |
| 28.000 MHz to 29.700 MHz | 28000 kHz to 29700 kHz | Amateur Radio Ham Radio 10 Meter Band 10 Meters 10m |
| 30.560 MHz to 31.980 MHz | 30560 kHz to 31980 kHz | Business/Industrial Radio Service and Forestry Radio Systems (20 kHz steps, FM mode) |
| Frequency | Remarks |
| 25.200 MHz | 0 active licenses, one marine license for 25.2085 MHz 25208.5 kHz data FSK NBDP WPTM574 |
| Channel 2 | 26.975 MHz | |
| Channel 5 | 27.015 MHz | |
| Channel 7 | 27.035 MHz | |
| Channel 12 | 27.105 MHz | |
| Channel 15 | 27.135 MHz | |
| Channel 18 | 27.175 MHz | |
| Channel 22 | 27.225 MHz | |
| Channel 27 | 27.275 MHz | |
| Channel 29 | 27.295 MHz | |
| Channel 32 | 27.325 MHz | |
| Channel 33 | 27.335 MHz | |
| Channel 34 | 27.345 MHz | |
FM (Frequency Modulation)
| Channel 1 | 27.60125 MHz |
| Channel 2 | 27.61125 MHz |
| Channel 3 | 27.62125 MHz |
| Channel 4 | 27.63125 MHz |
| Channel 5 | 27.64125 MHz |
| Channel 6 | 27.65125 MHz |
| Channel 7 | 27.66125 MHz |
| Channel 8 | 27.67125 MHz |
| Channel 9 | 27.68125 MHz |
| Channel 10 | 27.69125 MHz |
| Channel 11 | 27.70125 MHz |
| Channel 12 | 27.71125 MHz |
| Channel 13 | 27.72125 MHz |
| Channel 14 | 27.73125 MHz |
| Channel 15 | 27.74125 MHz |
| Channel 16 | 27.75125 MHz |
| Channel 17 | 27.76125 MHz |
| Channel 18 | 27.77125 MHz |
| Channel 19 | 27.78125 MHz |
| Channel 20 | 27.79125 MHz |
| Channel 21 | 27.80125 MHz |
| Channel 22 | 27.81125 MHz |
| Channel 23 | 27.82125 MHz |
| Channel 24 | 27.83125 MHz |
| Channel 25 | 27.84125 MHz |
| Channel 26 | 27.85125 MHz |
| Channel 27 | 27.86125 MHz |
| Channel 28 | 27.87125 MHz |
| Channel 29 | 27.88125 MHz |
| Channel 30 | 27.89125 MHz |
| Channel 31 | 27.90125 MHz |
| Channel 32 | 27.91125 MHz |
| Channel 33 | 27.92125 MHz |
| Channel 34 | 27.93125 MHz |
| Channel 35 | 27.94125 MHz |
| Channel 36 | 27.95125 MHz |
| Channel 37 | 27.96125 MHz |
| Channel 38 | 27.97125 MHz |
| Channel 39 | 27.98125 MHz |
| Channel 40 | 27.99125 MHz |
| Channel 41 | 26.565 MHz |
| Channel 42 | 26.575 MHz |
| Channel 43 | 26.585 MHz |
| Channel 44 | 26.595 MHz |
| Channel 45 | 26.605 MHz |
| Channel 46 | 26.615 MHz |
| Channel 47 | 26.625 MHz |
| Channel 48 | 26.635 MHz |
| Channel 49 | 26.645 MHz |
| Channel 50 | 26.655 MHz |
| Channel 51 | 26.665 MHz |
| Channel 52 | 26.675 MHz |
| Channel 53 | 26.685 MHz |
| Channel 54 | 26.695 MHz |
| Channel 55 | 26.705 MHz |
| Channel 56 | 26.715 MHz |
| Channel 57 | 26.725 MHz |
| Channel 58 | 26.735 MHz |
| Channel 59 | 26.745 MHz |
| Channel 60 | 26.755 MHz |
| Channel 61 | 26.765 MHz |
| Channel 62 | 26.775 MHz |
| Channel 63 | 26.785 MHz |
| Channel 64 | 26.795 MHz |
| Channel 65 | 26.805 MHz |
| Channel 66 | 26.815 MHz |
| Channel 67 | 26.825 MHz |
| Channel 68 | 26.835 MHz |
| Channel 69 | 26.845 MHz |
| Channel 70 | 26.855 MHz |
| Channel 71 | 26.865 MHz |
| Channel 72 | 26.875 MHz |
| Channel 73 | 26.885 MHz |
| Channel 74 | 26.895 MHz |
| Channel 75 | 26.905 MHz |
| Channel 76 | 26.915 MHz |
| Channel 77 | 26.925 MHz |
| Channel 78 | 26.935 MHz |
| Channel 79 | 26.945 MHz |
| Channel 80 | 26.955 MHz |
26 MHz AM Public Channels:
| Channel 1 | 26.330 MHz |
| Channel 2 | 26.340 MHz |
| Channel 3 | 26.350 MHz |
| Channel 4 | 26.370 MHz |
| Channel 5 | 26.380 MHz |
| Channel 6 | 26.390 MHz |
| Channel 7 | 26.400 MHz |
| Channel 8 | 26.420 MHz |
| Channel 9 | 26.430 MHz |
| Channel 10 | 26.440 MHz |
| Channel 11 | 26.450 MHz |
| Channel 12 | 26.470 MHz |
| Channel 13 | 26.480 MHz |
| Channel 14 | 26.490 MHz |
| Channel 15 | 26.500 MHz |
| Channel 16 | 26.520 MHz |
| Channel 17 | 26.530 MHz |
| Channel 18 | 26.540 MHz |
| Channel 19 | 26.550 MHz |
| Channel 20 | 26.570 MHz |
| Channel 21 | 26.580 MHz |
| Channel 22 | 26.590 MHz |
| Channel 23 | 26.620 MHz |
| Channel 24 | 26.600 MHz |
| Channel 25 | 26.610 MHz |
| Channel 26 | 26.630 MHz |
| Channel 27 | 26.640 MHz |
| Channel 28 | 26.650 MHz |
| Channel 29 | 26.660 MHz |
| Channel 30 | 26.670 MHz |
| Channel 31 | 26.680 MHz |
| Channel 32 | 26.690 MHz |
| Channel 33 | 26.700 MHz |
| Channel 34 | 26.710 MHz |
| Channel 35 | 26.720 MHz |
| Channel 36 | 26.730 MHz |
| Channel 37 | 26.740 MHz |
| Channel 38 | 26.750 MHz |
| Channel 39 | 26.760 MHz |
| Channel 40 | 26.770 MHz |
| Channel 1 | 26.960 MHz |
| Channel 2 | 26.970 MHz |
| Channel 3 | 26.980 MHz |
| Channel 4 | 27.000 MHz |
| Channel 5 | 27.010 MHz |
| Channel 6 | 27.020 MHz |
| Channel 7 | 27.030 MHz |
| Channel 8 | 27.050 MHz |
| Channel 9 | 27.060 MHz |
| Channel 10 | 27.070 MHz |
| Channel 11 | 27.080 MHz |
| Channel 12 | 27.100 MHz |
| Channel 13 | 27.110 MHz |
| Channel 14 | 27.120 MHz |
| Channel 15 | 27.130 MHz |
| Channel 16 | 27.150 MHz |
| Channel 17 | 27.160 MHz |
| Channel 18 | 27.170 MHz |
| Channel 19 | 27.180 MHz |
| Channel 20 | 27.200 MHz |
| Channel 21 | 27.210 MHz |
| Channel 22 | 27.220 MHz |
| Channel 23 | 27.250 MHz |
| Channel 24 | 27.230 MHz |
| Channel 25 | 27.240 MHz |
| Channel 26 | 27.260 MHz |
| Channel 27 | 27.270 MHz |
| Channel 28 | 27.280 MHz |
| Channel 29 | 27.290 MHz |
| Channel 30 | 27.300 MHz |
| Channel 31 | 27.310 MHz |
| Channel 32 | 27.320 MHz |
| Channel 33 | 27.330 MHz |
| Channel 34 | 27.340 MHz |
| Channel 36 | 27.360 MHz |
| Channel 37 | 27.370 MHz |
| Channel 38 | 27.380 MHz |
| Channel 39 | 27.390 MHz |
| Channel 40 | 27.400 MHz |
For example,
The related Superstar 120 and Superstar 121 style radios (120 channel radios) use the same form factor with either LOW-MID-HIGH band switch or C-D-E covering 26.515 MHz to 27.855 MHz. Modified CB radios with additional channels may or may not follow the alphanumeric band + channel designation system, depending on the particular modification and radio in question. Many modern modification kits or extra channel expansion kits aim to track the same channel plan to provide for interoperability between modified 40 channel CB radios and 10 meter radios that have been converted to the 11 meter band. Not all legal 40 channel CB radios are capable of operating outside of the legal band but many are, and a thriving market for channel expansion kits and modifications continues to exist for those who wish to use "traditional" type CB radios and still have access to additional channels/frequencies. Because of this, and antenna considerations, the most active 11 meter frequencies tend to be the low channels (26.515 MHz to 26.955 MHz) and the high channels (27.415 MHz to 27.855 MHz) - with the frequencies closest to the legal 40 CB channels generally being more popular (again due to antenna tuning considerations).
| Channel 1 | 26.968 MHz |
| Channel 2 | 26.976 MHz |
| Channel 3 | 27.040 MHz |
| Channel 4 | 27.080 MHz |
| Channel 5 | 27.088 MHz |
| Channel 6 | 27.112 MHz |
| Channel 7 | 27.120 MHz |
| Channel 8 | 27.144 MHz |
| 27310.5 kHz | 27.3105 MHz |
| 27334.5 kHz | 27.3345 MHz |
| 27338.5 kHz | 27.3385 MHz |
| 27342.5 kHz | 27.3425 MHz |
| 27346.5 kHz | 27.3465 MHz |
| 27350.5 kHz | 27.3505 MHz |
| 27354.5 kHz | 27.3545 MHz |
| 27358.5 kHz | 27.3585 MHz |
| 27362.5 kHz | 27.3625 MHz |
| 27366.5 kHz | 27.3665 MHz |
| 27370.5 kHz | 27.3705 MHz |
| 27378.5 kHz | 27.3785 MHz |
| 27382.5 kHz | 27.3825 MHz |
| 27386.5 kHz | 27.3865 MHz |
| 27388.5 kHz | 27.3885 MHz |
| 27398.5 kHz | 27.3985 MHz |
| 27404.5 kHz | 27.4045 MHz |
| 27418.5 kHz | 27.4185 MHz |
| 27426.5 kHz | 27.4265 MHz |
| 27434.5 kHz | 27.4345 MHz |
| 27442.5 kHz | 27.4425 MHz |
| 27452.5 kHz | 27.4525 MHz |
| 27458.5 kHz | 27.4585 MHz |
| 27466.5 kHz | 27.4665 MHz |
| 27470.5 kHz | 27.4705 MHz |
Unlike the Japanese 27 MHz fisheries radio systems (which uses direct frequencies as to reference the channels), this system uses a channelized system with integer channel numbering. Straight channel numbering sequence (channel 1 - 27.500 MHz, channel 2 - 27.525 MHz, channel 3 - 27.550 MHz, channel 3 - 27.575 MHz, channel 5 - 27.600 MHz, etc. through to 39.425 MHz (channel 477) , 39.450 MHz (channel 478) and 39.475 MHz as channel 480) for a total of 480 channels. Radios appear to come with channels 221 [xxxx MHz], 231 [xxxxxx MHz], 236 [xxxx MHz] and 238 [xxxxxxxxx MHz] as "dual watch" channels (likely for calling purposes).
- SPECIFICATIONS
- 25 kHz channel spacing
- 480 channels
- FEATURES
| Channel | Frequency (MHz) | Designated Use China Fishery Radio |
| 1 | 27.500 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 2 | 27.525 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 3 | 27.550 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 4 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 5 | 27.600 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 6 | 27.625 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 7 | 27.650 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 8 | 27.675 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 9 | 27.725 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 10 | 27.750 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 11 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 12 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 13 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 14 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 15 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 16 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 17 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 18 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 19 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 20 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 21 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 22 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 23 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 24 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 25 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 26 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 27 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 28 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 29 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 30 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 31 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 32 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 33 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 34 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 35 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 36 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 38 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 39 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 40 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 41 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 42 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 43 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 44 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 45 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 46 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 47 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 48 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 49 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 50 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 51 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 52 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 53 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 54 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 55 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 56 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 57 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 58 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 59 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 60 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 61 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 62 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 63 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 64 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 65 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 66 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 67 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 68 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 69 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 70 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 71 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 72 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 73 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 74 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 75 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 76 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 77 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 78 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 79 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 80 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 81 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 82 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 83 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 84 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 85 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 86 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 87 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 88 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 89 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 90 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 91 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 92 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 93 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 94 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 95 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 96 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 97 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 98 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 99 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 100 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 101 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 102 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 103 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 104 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 105 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 106 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 107 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 108 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 109 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 110 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 111 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 112 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 113 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 114 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 115 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 116 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 117 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 118 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 119 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 120 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 121 | 27.500 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 122 | 27.525 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 123 | 27.550 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 124 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 125 | 27.600 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 126 | 27.625 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 127 | 27.650 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 128 | 27.675 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 129 | 27.725 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 130 | 27.750 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 131 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 132 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 133 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 134 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 135 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 136 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 137 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 138 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 139 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 140 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 141 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 142 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 143 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 144 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 145 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 146 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 147 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 148 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 149 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 150 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 151 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 152 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 153 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 154 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 155 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 156 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 158 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 159 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 160 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 161 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 162 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 163 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 164 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 165 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 166 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 167 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 168 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 169 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 170 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 171 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 172 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 173 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 174 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 175 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 176 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 177 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 178 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 179 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 180 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 181 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 182 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 183 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 184 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 185 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 186 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 187 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 188 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 189 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 190 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 191 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 192 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 193 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 194 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 195 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 196 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 197 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 198 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 199 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 200 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 201 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 202 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 203 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 204 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 205 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 206 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 207 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 208 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 209 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 210 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 211 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 212 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 213 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 214 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 215 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 216 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 217 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 218 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 219 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 220 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 221 | 33.075 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 222 | 33.100 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 223 | 33.075 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 224 | 33.100 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 225 | 33.125 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 226 | 33.150 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 227 | 33.175 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 228 | 33.200 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 229 | 33.225 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 230 | 33.250 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 231 | 33.275 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 232 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 233 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 234 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 235 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 236 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 237 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 238 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 239 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 240 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 241 | 27.500 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 242 | 27.525 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 243 | 27.550 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 244 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 245 | 27.600 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 246 | 27.625 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 247 | 27.650 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 248 | 27.675 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 249 | 27.725 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 250 | 27.750 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 251 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 252 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 253 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 254 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 255 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 256 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 257 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 258 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 259 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 359 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 360 | 27.575 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 472 | 39.275 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 473 | 39.300 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 474 | 39.325 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 475 | 39.350 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 476 | 39.375 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 477 | 39.400 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 478 | 39.425 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 479 | 39.450 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
| 480 | 39.475 MHz | Fishery Radio - Ship to Ship/Ship to Shore Maritime Mobile Fixed |
- SPECIFICATIONS
- 20 channels
- AM modulation
- FEATURES
| CB Channel | Frequency |
| Channel 41 | 27.415 MHz |
| Channel 42 | 27.425 MHz |
| Channel 43 | 27.435 MHz |
| Channel 44 | 27.455 MHz |
| Channel 45 | 27.465 MHz |
| Channel 46 | 27.475 MHz |
| Channel 47 | 27.485 MHz |
| Channel 48 | 27.505 MHz |
| Channel 49 | 27.515 MHz |
| Channel 50 | 27.525 MHz |
| Channel 51 | 27.535 MHz |
| Channel 52 | 27.555 MHz |
| Channel 53 | 27.565 MHz |
| Channel 54 | 27.575 MHz |
| Channel 55 | 27.585 MHz |
| Channel 56 | 27.605 MHz |
| Channel 57 | 27.615 MHz |
| Channel 58 | 27.625 MHz |
| Channel 59 | 27.635 MHz |
| Channel 60 | 27.655 MHz |
| Channel 61 | 27.665 MHz |
| Channel 62 | 27.675 MHz |
| Channel 63 | 27.685 MHz |
| Channel 64 | 27.695 MHz |
| Channel 65 | 27.705 MHz |
| Channel 66 | 27.715 MHz |
| Channel 67 | 27.725 MHz |
| Channel 68 | 27.735 MHz |
| Channel 69 | 27.745 MHz |
| Channel 70 | 27.755 MHz |
| Channel 71 | 27.765 MHz |
| Channel 72 | 27.775 MHz |
| Channel 73 | 27.785 MHz |
| Channel 74 | 27.795 MHz |
| Channel 75 | 27.805 MHz |
| Channel 76 | 27.815 MHz |
| Channel 77 | 27.825 MHz |
| Channel 78 | 27.835 MHz |
| Channel 79 | 27.845 MHz |
| Channel 80 | 27.855 MHz |
| 27.600 MHz | 27.800 MHz | Jamaica, FM mode | Optional CTCSS PL 88.5 Hz - part of 4 linked FM Knight Patrol 11m repeaters with +200 kHz offset - likely off the air |
| 27.620 MHz | 27.820 MHz | Jamaica, FM mode | Optional CTCSS PL 88.5 Hz - part of 4 linked FM Knight Patrol 11m repeaters with +200 kHz offset - likely off the air |
| 27.640 MHz | 27.840 MHz | Jamaica, FM mode | Optional CTCSS PL 88.5 Hz - part of 4 linked FM Knight Patrol 11m repeaters with +200 kHz offset - likely off the air |
| 27.660 MHz | 27.860 MHz | Jamaica, FM mode | Optional CTCSS PL 88.5 Hz - part of 4 linked FM Knight Patrol 11m repeaters with +200 kHz offset - likely off the air |
| 26.575 MHz | Germany | ||
| 26.675 MHz | |||
| 26.915 MHz | |||
| 26.925 MHz | |||
| 26.935 MHz | Somewhere in the USA | Cross band repeater linked to FRS channel 3 - 462.6125 MHz FM | |
| 26.970 MHz | Lithuania | ||
| 27.110 MHz | Poland | ||
| 27.110 MHz | Russia | ||
| 27.150 MHz | Poland | ||
| 27.170 MHz | Poland | ||
| 27.185 MHz | Colorado, USA - possibly Arizona? | Remote location, either patched to 462.550 MHz or 462.5625 MHz (cross-band repeat) | |
| 27.190 MHz | |||
| 27.220 MHz | |||
| 27.230 MHz | |||
| 27.235 MHz | |||
| 27.250 MHz | Belarus | ||
| 27.255 MHz | Sochi, Russia | 27.255 MHz FM - "mid band 23" | |
| 27.290 MHz | Moscow, Russia | Northern Moscow - 27.290 MHz FM or 27.295 MHz FM | |
| 27.295 MHz | Moscow, Russia | Northern Moscow - 27.290 MHz FM or 27.295 MHz FM | |
| 27.300 MHz | |||
| 27.305 MHz | Western Europe | Belgium | |
| 27.325 MHz | |||
| 27.430 MHz | |||
| 27.450 MHz | |||
| 27.470 MHz | |||
| 27.675 MHz | Russia | ||
| 27.765 MHz | Germany | ||
| 27.840 MHz | Poland | ||
does AM radio still exist can you still buy CB radios do people still use CB radios CB radio for emergency emergencies prepper channels 26.96 - 27.41 MHz Citizen Radio Citizens Radio wikipedia CB frequencies on a Baofeng CB channels on a ham radio 26 MHz band what are the CB frequencies CB channel chart CB frequency chart UK USA UHF CB VHF CB HF CB AM CB SSB CB 120 channel CB channel range how far can a CB radio go CB antennas CB radio reviews do truckers still use CB radio 2018 2019 2020 today police CB radio frequencies channels 30 MHz band CB radio channels freeband channels freeband frequencies what is the best freeband radio CB radio police what CB channel do police use? they don't use CB radios and haven't for about 30 years...there are a lot of other users of CB radio though...freebanding frequencies channels prepper 25 MHz band 26 MHz band 27 MHz band 28 MHz 30 MHz band 30.555 MHz 30.105 MHz 25.615 MHz 27.405 MHz 26.955 MHz 26.505 MHz 26.515 MHz 26.510 MHz 26MHz taxi cab radio Uber radio Lyft radio two-way radio system taxicab radio dispatch YL Russia CADS UK 27/81 WPAS 120 channel mod frequency kit Lescomm DigiMax Lite Viagra board Cobra 29 channel kit 240 channel 360 channel 128 channel MB8719 RCI8719 cbradio.nl cbtricks.com EPT3600 board main board CB radio PCB 26.065 MHz 26.505 MHz 27500 kHz 27.500 MHz 27.5 MHz CB radio warfare RCI CRT EPT690010Z EPT6900 Uniden Cobra Galaxy Magnum SR-94C Galaxy DX radios 10kc 10kHz switch A channels secret channels phantom frequencies CB radio prepper frequencies hunting radios CB radio range 27 MHz RC transmitter PB010 PC879 PLL02A UPD858 MC145106 CB repeater CB VHF repeater CB MURS GMRS crossband cross-band GMRS MURS repeater 151.820 MHz 151.880 MHz 151.940 MHz 154.570 MHz 154.600 MHz 151.940 156.7 simplex repeater 27.205 MHz 462.550 - 467.7125 MHz radiobuoy fishnet beacon 26MHz 26.500 MHz 26500 kHz 26.450 MHz 26450 kHz 26MHz NZ CB UK FM 27/97 PR27 27 MHz FM CB can I use ham radio on CB frequencies what is 30 MHz band CB frequencies 10 meter intruders 11 meter taxi cab dispatch 26.285 USB 27.555 USB 27.185 AM 151.880 167.9 repeater 151.940 repeater simplex unlicensed illegal license free freebanders truckers on 25 MHz truckers on 10 meters unlicensed UHF frequencies MURS mobile CB mobile 25.615-30.105 MHz mobile radio handheld walkie talkie BF-888 Baofeng BF-888S BF-88A FRS on BF-888 B-888 work site radios Motorola Kenwood Icom BTECH unlicensed VHF frequencies MURS frequencies what are the CB channels police CB radio speed trap trucker talk CB radio HF truckers on CB channel 19 27.185 MHz 27185 kHz 27,185 27.180 MHz 27.635 MHz CADS WPAS Russian Taxis 24.715 MHz 25.165 MHz 25.615 MHz UK PO PL band 26.960 MHz 27.400 MHz what band is 30 MHz what frequency does military use CB radio channels what are the CB channels? 27.5 - 39.5 MHz 39.475 MHz HF radiotelephone fishery radio fisheries radio fisheries telephone radio 24.265 MHz 29.655 MHz 29.695 MHz 29.699 MHz 29.705 MHz 29.710 MHz bellscb rightchannelradios 26957 26.957 27120 27.120 MHz ISM band IoT bands 26-27 MHz data link transmitter 150 MHz truck radio hunting radio VHF CB radio 30.450 MHz 30.105 MHz 26-32 MHz 26-30 MHz 25-30 MHz 25.91 MHz 25.95 MHz 25.99 MHz 26.470 MHz marine radio CB RCI-2995 27.385 LSB ham radio gear on CB frequencies CB channels on a ham radio Anytone AT-5189 26-33 MHz 33-49 MHz 136-174 MHz 220-260 MHz 240-270 MHz 300-350 MHz 350-390 MHz 400-470 MHz 450-512 MHz 450-520 MHz 600 MHz band 700 MHz band 27.9 MHz 27.900 MHz 20-27.9 MHz 27-38.9 MHz 20-28 mc megacycle 27.8 MHz, 27.4 MHz, 27.41 MHz what are the freeband CB frequencies survivalist CB frequencies emergency frequencies near me emergency channels near me UHF emergency frequency VHF emergency frequency 4125 kHz 4417 kHz 6215 kHz 6200 kHz 6212 kHz 6516 kHz 8255 kHz 8779 kHz 12290 kHz 12359 kHz 11175 kHz 13200 kHz 13137 kHz 16420 kHz 16537 kHz 17302 kHz 18795 kHz 19770 kHz 22060 kHz 22756 kHz 25097 kHz 26.097 MHz R4002 26172 kHz 26.172 MHz 2045 kHz 2638 kHz 2003 kHz 6765 kHz 6770 kHz 2048 kHz 2635 kHz ship-to-shore international frequencies radiotelephone emergency calling frequencies GMDSS DSC 2182 kHz 2187.5 kHz 4207.5 kHz 6312 kHz 8414.4 kHz 12577 kHz 16804.5 kHz 156.525 MHz 156.3 MHz 156.8 MHz 156.800 MHz telegraphy distress safety narrow band direct printing 2174.5 kHz 4177.5 kHz 6268 kHz 8376.5 kHz 12520 kHz 16695 kHz 8291 kHz 16420 kHz 4125kHz 3023 kHz 5680 kHz 8364 kHz 10003 kHz 14993 kHz 19993 kHz 19.993 MHz 10.003 MHz 14.993 MHz 123.025 MHz 123.1 MHz 122.9 MHz 455.5 kHz 458.5 kHz 16805.5 kHz 16805 kHz 25208 kHz 25.208 MHz 26121 kHz 26122 kHz 26.840 MHz
