FRS
Family Radio Service
22-channel UHF short-distance two-way radio service walkie-talkie service operating in the 462/467 MHz bands - 462.5500 MHz to 462.7250 MHz and 467.5625 MHz to 467.7125 MHz bands, license free replacement (or rather supplement) to the CB radio service for personal, family, business or really any other use. Shares frequencies with the GMRS service.
FM voice (narrow FM or NFM, see specifics below). All of the 22 FRS channels are shared with the GMRS service (GMRS requires a license, FRS does not). FRS is regulated as a license free personal radio service and all users must share all channels with one another.
FRS regulations do permit use of data modes for data transmissions (GPS location coordinates, requests for location data from other FRS units and/or GMRS units, in-range location "ping" transmissions to verify that a radio is still within range of another radio or automatic range transponder capability, text messages, requests for text or chat messages from another radio or group of radios, a group chat over FRS radios, for example is available on some Motorola FRS radios) but digital voice modes are not permitted on FRS or GMRS.
Short range walkie talkie radios.
Power limits shown are for unlicensed (simplex) use. GMRS license holders are permitted higher transmit power on channels 1-7 and 15-22, use of removable antennas and use of repeaters. Licensed GMRS users are limited to 500mW (0.5 watt, 0.5w) output on channels 8-14 just like unlicensed FRS users are.
All 22 simplex frequencies listed below are shared frequencies. Licensed GMRS users share all channels with unlicensed FRS users, even channels 15-22 (GMRS license holders may use any of the 22 channels below for simplex use, including simplex communications with an unlicensed FRS user. Channels 15-22 are shared with GMRS repeater outputs (again, licensed GMRS users - simplex and repeater users, share the 8 GMRS repeater output channels with unlicensed FRS users). This is why using CTCSS and/or DCS is so important.
- FRS Channel 01 - 462.5625 MHz - 2 watt power limit
- FRS Channel 02 - 462.5875 MHz - 2 watt power limit
- FRS Channel 03 - 462.6125 MHz - 2 watt power limit
- FRS Channel 04 - 462.6375 MHz - 2 watt power limit
- FRS Channel 05 - 462.6625 MHz - 2 watt power limit
- FRS Channel 06 - 462.6875 MHz - 2 watt power limit
- FRS Channel 07 - 462.7125 MHz - 2 watt power limit
- FRS Channel 08 - 467.5625 MHz - 0.5 watt (500mW) power limit
- FRS Channel 09 - 467.5875 MHz - 0.5 watt (500mW) power limit
- FRS Channel 10 - 467.6125 MHz - 0.5 watt (500mW) power limit
- FRS Channel 11 - 467.6375 MHz - 0.5 watt (500mW) power limit
- FRS Channel 12 - 467.6625 MHz - 0.5 watt (500mW) power limit
- FRS Channel 13 - 467.6875 MHz - 0.5 watt (500mW) power limit
- FRS Channel 14 - 467.7125 MHz - 0.5 watt (500mW) power limit
- FRS Channel 15 - 462.5500 MHz - 2 watt power limit
- FRS Channel 16 - 462.5750 MHz - 2 watt power limit
- FRS Channel 17 - 462.6000 MHz - 2 watt power limit
- FRS Channel 18 - 462.6250 MHz - 2 watt power limit
- FRS Channel 19 - 462.6500 MHz - 2 watt power limit
- FRS Channel 20 - 462.6750 MHz - 2 watt power limit
- FRS Channel 21 - 462.7000 MHz - 2 watt power limit
- FRS Channel 22 - 462.7250 MHz - 2 watt power limit
- Do you need a license to use the 22 FRS channels?
- Are the "color dot" frequencies license free or part of FRS?
No.
The old White Dot (462.575 MHz, FRS channel 16), Black Dot (462.625 MHz, FRS channel 18) and Orange Dot (462.675 MHz, FRS channel 20) are now part of the FRS and GMRS services. Use of those three frequencies is legal without a license for business purposes under the FRS rules. Other color dot channels (151.625 MHz, 151.955 MHz, 464.550 MHz, 464.500 MHz, etc.) require FCC licensing. The 154.570 MHz (Blue Dot/MURS channel 4) and 154.600 MHz (Green Dot/MURS channel 5) MURS channels were previously color dot channels as well - and those are license free under the MURS service.
- Are Baofeng radios illegal? or Are Baofeng radios legal?
- My FRS radios claim 18 mile range or 22 mile range or 26 mile range 28 mile range or 32 mile range or 36 mile range or 40 mile range but mine only work within a 2-3 mile radius - how come my FRS walkie talkies aren't working at the advertised range? OR - What range can I expect with my FRS radios?
On top of tall peaks, very impressive range is possible with FRS handheld radios - as long as there aren't any obstructions between you and the person you're communicating with (this includes other mountain peaks). On the other hand, if you're down in a valley surrounded by mountains/hills, don't expect to be able to communicate with somebody on the other side of the mountain/hill. In urban areas, steel, concrete, brick, etc. block and absorb radio waves very well. Get up as high as possible (ideally above the obstructions) and move around. Often moving 5-10 feet in one direction or another can mean the difference between poor or no signal to a quality readable signal.
Most FRS radios have a high/low power setting - remember that channels 8 through 14 are low power only. Channels 1 through 7 and 15 through 22 may be used on high or low power. Check your transmit power setting. If you're using channel 8, 9, 10, 11, 12, 13 or 14, switch to one of the channels where high power is permitted (channels 1-7 and 15-22) and make sure all radios in your group are set to high power. However, if reliable communications are possible on the low power setting, use low power. Using low power mode unless you absolutely need to use high power will improve battery life significantly.
- Are FRS channels part of the CB radio service?
- Can I talk to CB radios with my FRS radio?
- What are the FRS channels? I want to program them in my Baofeng, Hytera, Retevis, BTECH, TYT, QYT, Motorola, Kenwood, Icom, etc.
- Should I program the FRS frequencies or channels FM deviation in wide or narrow mode?
- I live in an urbanized area with lots of activity on the FRS channels, how do I avoid annoying interference from other groups on the same channel?
- I'm programming a set of radios with the FRS frequencies - which CTCSS PL or DCS DPL DTCS tones or codes should I avoid?
- CTCSS Tones To Avoid
- FRS Channel 1 - 67.0 Hz, 69.3 Hz, 100.0 Hz, 107.2 Hz, 110.9 Hz, 114.8 Hz, 136.5 Hz, 162.2 Hz, 165.5 Hz, 186.2 Hz, 250.3 Hz
- FRS Channel 2 - 67.0 Hz, 69.3 Hz, 100.0 Hz, 110.9 Hz, 114.8 Hz, 118.8 Hz, 136.5 Hz, 162.2 Hz, 165.5 Hz, 186.2 Hz
- FRS Channel 3 - 67.0 Hz, 69.3 Hz, 97.4 Hz, 100.0 Hz, 110.9 Hz, 114.8 Hz, 127.3 Hz, 136.5 Hz, 162.2 Hz, 165.5 Hz, 186.2 Hz, 225.7 Hz
- FRS Channel 4 - 67.0 Hz, 69.3 Hz, 77.0 Hz, 110.9 Hz, 114.8 Hz, 131.8 Hz, 136.5 Hz, 162.2 Hz, 165.5 Hz
- FRS Channel 5 - 67.0 Hz, 69.3 Hz, 79.7 Hz, 88.5 Hz, 110.9 Hz, 114.8 Hz, 136.5 Hz, 162.2 Hz, 165.5 Hz, 186.2 Hz, 203.5 Hz
- FRS Channel 6 - 67.0 Hz, 69.3 Hz, 110.9 Hz, 114.8 Hz, 136.5 Hz, 141.3 Hz, 162.2 Hz, 165.5 Hz, 186.2 Hz
- FRS Channel 7 - 67.0 Hz, 69.3 Hz, 97.4 Hz, 110.9 Hz, 114.8 Hz, 136.5 Hz, 146.2 Hz, 159.8 Hz, 162.2 Hz, 165.5 Hz, 179.9 Hz, 186.2 Hz
- FRS Channel 8 - 110.9 Hz, 114.8 Hz, 136.5 Hz, 186.2 Hz
- FRS Channel 9 - 110.9 Hz, 114.8 Hz, 136.5 Hz, 186.2 Hz
- FRS Channel 10 - 110.9 Hz, 114.8 Hz, 136.5 Hz, 186.2 Hz
- FRS Channel 11 - 110.9 Hz, 114.8 Hz, 136.5 Hz, 186.2 Hz
- FRS Channel 12 - 114.8 Hz, 136.5 Hz, 186.2 Hz
- FRS Channel 13 - 114.8 Hz, 136.5 Hz, 186.2 Hz
- FRS Channel 14 - 114.8 Hz, 136.5 Hz, 186.2 Hz
- FRS Channel 15 - 71.9 Hz, 110.9 Hz, 114.8 Hz, 123.0 Hz, 162.2 Hz
- FRS Channel 16 - 114.8 Hz
- FRS Channel 17 - 110.9 Hz, 136.5 Hz, 146.2 Hz, 186.2 Hz, 241.8 Hz
- FRS Channel 18 - 110.9 Hz, 127.3 Hz, 136.5 Hz, 186.2 Hz
- FRS Channel 19 - 110.9 Hz, 131.8 Hz, 136.5 Hz, 186.2 Hz
- FRS Channel 20 - 110.9 Hz, 136.5 Hz, 186.2 Hz
- FRS Channel 21 - 110.9 Hz, 118.8 Hz, 136.5 Hz, 186.2 Hz, 192.8 Hz
- FRS Channel 22 - 110.9 Hz, 136.5 Hz, 186.2 Hz
- DCS Codes To Avoid
- FRS Channel 1 - 023 DCS (023N), 026 DCS (026N), 261 DCS (261N)
- FRS Channel 2 - 023 DCS (023N), 025 DCS (025N), 731 DCS (731N), 732 DCS (732N), 734 DCS (734N), 743 DCS (743N), 754 DCS (754N)
- FRS Channel 3 - 731 DCS (731N), 732 DCS (732N), 734 DCS (734N), 743 DCS (743N), 754 DCS (754N)
- FRS Channel 4 - 032 DCS (032N), 731 DCS (731N), 732 DCS (732N), 734 DCS (734N), 743 DCS (743N), 754 DCS (754N)
- FRS Channel 5 - 731 DCS (731N), 732 DCS (732N), 734 DCS (734N), 743 DCS (743N), 754 DCS (754N)
- FRS Channel 6 - 047 DCS (047N), 731 DCS (731N), 732 DCS (732N), 734 DCS (734N), 743 DCS (743N), 754 DCS (754N)
- FRS Channel 7 - 734 DCS (734N), 743 DCS (743N), 754 DCS (754N)
- FRS Channel 8 - 026 DCS (026N), 065 DCS (065N), 243 DCS (243N), 734 DCS (734N), 743 DCS (743N), 754 DCS (754N)
- FRS Channel 9 - 032 DCS (032N), 734 DCS (734N), 743 DCS (743N), 754 DCS (754N)
- FRS Channel 10 - 047 DCS (047N), 073 DCS (073N), 627 DCS (627N), 734 DCS (734N), 743 DCS (743N), 754 DCS (754N)
- FRS Channel 11 - 051 DCS (051N)
- FRS Channel 12 - 053 DCS (053N), 115 DCS (115N)
- FRS Channel 13 - 065 DCS (065N)
- FRS Channel 14 - 116 DCS (116N), 131 DCS (131N), 734 DCS (734N), 743 DCS (743N), 754 DCS (754N)
- FRS Channel 15 - 023 DCS (023N), 731 DCS (731N), 723 DCS (743N), 743 DCS (743N)
- FRS Channel 16 - 143 DCS (143N), 654 DCS (731I), 731 DCS (731N), 723 DCS (743N), 743 DCS (743N)
- FRS Channel 17 - 455 DCS (332I)
- FRS Channel 18 - 023 DCS (023N), 156 DCS (156N)
- FRS Channel 19 - 351 DCS (243I)
- FRS Channel 20 - 172 DCS (172N), 606 DCS (606N)
- FRS Channel 21 - 155 DCS (731I), 743 DCS (743N)
- FRS Channel 22 - 223 DCS (223N), 734 DCS (734N), 743 DCS (743N), 754 DCS (754N)
- I have a GMRS license, can I transmit more than 2 watts on channels 1-7 and 15-22 or more than 0.5 watts on channels 8-14? GMRS license holders may transmit up to 5 watts on FRS channels 1 through 7. GMRS license holders may transmit up to 50 watts on FRS channels 15-22. FRS channels 1-7 and 15-22 are shared with the GMRS service. However, even if you have a GMRS license, you are still limited to the 0.5 watt or 500mW power limit for FRS channels 8-14. GMRS repeaters may transmit on the original GMRS frequencies, which are also FRS channels 15-22. FRS users may not use repeaters, but may operate simplex on the shared channels.
- My FRS radio has something called privacy codes - what are these and how do they work?
- My Midland FRS radio has more than 22 channels? How is this possible?
- FRS Channel 01 - 462.5625 MHz - 2 watt power limit, shared with simplex GMRS
- FRS Channel 02 - 462.5875 MHz - 2 watt power limit, shared with simplex GMRS
- FRS Channel 03 - 462.6125 MHz - 2 watt power limit, shared with simplex GMRS
- FRS Channel 04 - 462.6375 MHz - 2 watt power limit, shared with simplex GMRS
- FRS Channel 05 - 462.6625 MHz - 2 watt power limit, shared with simplex GMRS
- FRS Channel 06 - 462.6875 MHz - 2 watt power limit, shared with simplex GMRS
- FRS Channel 07 - 462.7125 MHz - 2 watt power limit, shared with simplex GMRS
- FRS Channel 08 - 467.5625 MHz - 0.5 watt 500mW power limit
- FRS Channel 09 - 467.5875 MHz - 0.5 watt 500mW power limit
- FRS Channel 10 - 467.6125 MHz - 0.5 watt 500mW power limit
- FRS Channel 11 - 467.6375 MHz - 0.5 watt 500mW power limit
- FRS Channel 12 - 467.6625 MHz - 0.5 watt 500mW power limit
- FRS Channel 13 - 467.6875 MHz - 0.5 watt 500mW power limit
- FRS Channel 14 - 467.7125 MHz - 0.5 watt 500mW power limit
- FRS Channel 15 - 462.5500 MHz - 0.5 watt 500mW power limit
- FRS Channel 16 - 462.5750 MHz - 2 watt power limit, shared with simplex GMRS and GMRS repeater output
- FRS Channel 17 - 462.6000 MHz - 2 watt power limit, shared with simplex GMRS and GMRS repeater output
- FRS Channel 18 - 462.6250 MHz - 2 watt power limit, shared with simplex GMRS and GMRS repeater output
- FRS Channel 19 - 462.6500 MHz - 2 watt power limit, shared with simplex GMRS and GMRS repeater output
- FRS Channel 20 - 462.6750 MHz - 2 watt power limit, shared with simplex GMRS and GMRS repeater output
- FRS Channel 21 - 462.7000 MHz - 2 watt power limit, shared with simplex GMRS and GMRS repeater output
- FRS Channel 22 - 462.7250 MHz - 2 watt power limit, shared with simplex GMRS and GMRS repeater output
Up to date as of April 2021. FRS is licensed by rule (no individual license required) under Part 95 of the FCC rules 47 CFR 95 (Subpart B - Family Radio Service). It is considered a Personal Radio Service (PRS) under FCC regulations, just like the CB Radio Service (CB Radio or CBRS), Multi Use Radio Service (MURS), the General Mobile Radio Service, the Radio Control Radio Service (RCRS) and others.
§ 95.587 FRS additional requirements. Each FRS transmitter type must be designed to meet the following additional requirements. (a) Transmit frequency capability. FRS transmitter types must not be capable of transmitting on any frequency or channel other than those listed in § 95.563. (b) Antenna. The antenna of each FRS transmitter type must meet the following requirements. (1) The antenna must be a non-removable integral part of the FRS transmitter type. (2) The gain of the antenna must not exceed that of a half-wave dipole antenna. (3) The antenna must be designed such that the electric field of the emitted waves is vertically polarized when the unit is operated in the normal orientation. (c) Digital data transmissions. FRS transmitter types having the capability to transmit digital data must be designed to meet the following requirements. (1) FRS units may transmit digital data containing location information, or requesting location information from one or more other FRS or GMRS units, or containing a brief text message to another specific FRS or GMRS unit or units. (2) Digital data transmissions must be initiated by a manual action or command of the operator, except that FRS units may be designed to automatically respond with location data upon receiving an interrogation request from another FRS unit or a GMRS unit. (3) Digital data transmissions must not exceed one second in duration. (4) Digital data transmissions must not be sent more frequently than one digital data transmission within a thirty-second period, except that an FRS unit may automatically respond to more than one interrogation request received within a thirty-second period. (d) Packet mode. FRS transmitter types must not be capable of transmitting data in the store-and-forward packet operation mode. (e) Effective September 30, 2019, no person shall manufacture or import hand-held portable radio equipment capable of operating under this subpart (FRS) and other licensed or licensed-by-rule services in this chapter (part 15 unlicensed equipment authorizations are permitted if consistent with part 15 rules).
- 462.5625 MHz - FRS 1 - FRS Nationwide Calling Channel - general calling use (set transmit CTCSS to 67.0 Hz)
- 462.5875 MHz - FRS 2 - Sovereign Citizen Freeman Primary Patriot Radio Channel
- 462.6125 MHz - FRS 3 - UHF Primary/Calling FRS 3 - AmRRON - also MURS 3, CB 3
- 462.6375 MHz - FRS 4 - Patriot Regional Channel/Secondary Tactical, Vehicle Coordination
- 462.6625 MHz - FRS 5
- 462.6875 MHz - FRS 6
- 462.7125 MHz - FRS 7
- 467.5625 MHz - FRS 8 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.5875 MHz - FRS 9 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.6125 MHz - FRS 10 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.6375 MHz - FRS 11 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.6625 MHz - FRS 12 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.6875 MHz - FRS 13 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.7125 MHz - FRS 14 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 462.5500 MHz - FRS 15
- 462.5750 MHz - FRS 16 - Patriot Tactical, Vehicle Coordination (see also: FRS ch. 4)
- 462.6000 MHz - FRS 17
- 462.6250 MHz - FRS 18 - Tactical (set transmit CTCSS to 127.3 Hz)
- 462.6500 MHz - FRS 19 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 462.6750 MHz - FRS 20 - GMRS Calling Channel - general calling use (set transmit CTCSS to 141.3 Hz)
- 462.7000 MHz - FRS 21 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 462.7250 MHz - FRS 22 - Tactical (set transmit CTCSS to 136.5 Hz)
Channels 8-14 are low power only. This makes them ideal for short range inter squad radio (low probability of intercept) applications.
- Channel 1 - 462.5625 MHz
- Channel 2 - 462.5875 MHz
- Channel 3 - 462.6125 MHz
- Channel 4 - 462.6375 MHz
- Channel 5 - 462.6625 MHz
- Channel 6 - 462.6875 MHz
- Channel 7 - 462.7125 MHz
- Channel 8 - 467.5625 MHz
- Channel 9 - 467.5875 MHz
- Channel 10 - 467.6125 MHz
- Channel 11 - 467.6375 MHz
- Channel 12 - 467.6625 MHz
- Channel 13 - 467.6875 MHz
- Channel 14 - 467.7125 MHz
- Channel 15 - 462.5500 MHz
- Channel 16 - 462.5750 MHz
- Channel 17 - 462.6000 MHz
- Channel 18 - 462.6250 MHz
- Channel 19 - 462.6500 MHz
- Channel 20 - 462.6750 MHz
- Channel 21 - 462.7000 MHz
- Channel 22 - 462.7250 MHz
- Code 1 - 67.0 Hz
- Code 2 - 71.9 Hz
- Code 3 - 74.4 Hz
- Code 4 - 77.0 Hz
- Code 5 - 79.7 Hz
- Code 6 - 82.5 Hz
- Code 7 - 85.4 Hz
- Code 8 - 88.5 Hz
- Code 9 - 91.5 Hz
- Code 10 - 94.8 Hz
- Code 11 - 97.4 Hz
- Code 12 - 100.0 Hz
- Code 13 - 103.5 Hz
- Code 14 - 107.2 Hz
- Code 15 - 110.9 Hz
- Code 16 - 114.8 Hz
- Code 17 - 118.8 Hz
- Code 18 - 123.0 Hz
- Code 19 - 127.3 Hz
- Code 20 - 131.8 Hz
- Code 21 - 136.5 Hz
- Code 22 - 141.3 Hz
- Code 23 - 146.2 Hz
- Code 24 - 151.4 Hz
- Code 25 - 156.7 Hz
- Code 26 - 162.2 Hz
- Code 27 - 167.9 Hz
- Code 28 - 173.8 Hz
- Code 29 - 179.9 Hz
- Code 30 - 186.2 Hz
- Code 31 - 192.8 Hz
- Code 32 - 203.5 Hz
- Code 33 - 210.7 Hz
- Code 34 - 218.1 Hz
- Code 35 - 225.7 Hz
- Code 36 - 233.6 Hz
- Code 37 - 241.8 Hz
- Code 38 - 250.3 Hz
- Code 39 - D023
- Code 40 - D025
- Code 41 - D026
- Code 42 - D031
- Code 43 - D032
- Code 44 - D043
- Code 45 - D047
- Code 46 - D051
- Code 47 - D054
- Code 48 - D065
- Code 49 - D071
- Code 50 - D072
- Code 51 - D073
- Code 52 - D074
- Code 53 - D114
- Code 54 - D115
- Code 55 - D116
- Code 56 - D125
- Code 57 - D131
- Code 58 - D132
- Code 59 - D134
- Code 60 - D143
- Code 61 - D152
- Code 62 - D155
- Code 63 - D156
- Code 64 - D162
- Code 65 - D165
- Code 66 - D172
- Code 67 - D174
- Code 68 - D205
- Code 69 - D223
- Code 70 - D226
- Code 71 - D243
- Code 72 - D244
- Code 73 - D245
- Code 74 - D251
- Code 75 - D261
- Code 76 - D263
- Code 77 - D265
- Code 78 - D271
- Code 79 - D306
- Code 80 - D311
- Code 81 - D315
- Code 82 - D331
- Code 83 - D343
- Code 84 - D346
- Code 85 - D351
- Code 86 - D364
- Code 87 - D365
- Code 88 - D371
- Code 89 - D411
- Code 90 - D412
- Code 91 - D413
- Code 92 - D423
- Code 93 - D431
- Code 94 - D432
- Code 95 - D445
- Code 96 - D464
- Code 97 - D465
- Code 98 - D466
- Code 99 - D503
- Code 100 - D506
- Code 101 - D516
- Code 102 - D532
- Code 103 - D546
- Code 104 - D565
- Code 105 - D606
- Code 106 - D612
- Code 107 - D624
- Code 108 - D627
- Code 109 - D631
- Code 110 - D632
- Code 111 - D654
- Code 112 - D662
- Code 113 - D664
- Code 114 - D703
- Code 115 - D712
- Code 116 - D723
- Code 117 - D731
- Code 118 - D732
- Code 119 - D734
- Code 120 - D743
- Code 121 - D754
- Code 1 - 67.0 Hz
- Code 2 - 69.3 Hz
- Code 3 - 71.9 Hz
- Code 4 - 74.4 Hz
- Code 5 - 77.0 Hz
- Code 6 - 79.7 Hz
- Code 7 - 82.5 Hz
- Code 8 - 85.4 Hz
- Code 9 - 88.5 Hz
- Code 10 - 91.5 Hz
- Code 11 - 94.8 Hz
- Code 12 - 97.4 Hz
- Code 13 - 100.0 Hz
- Code 14 - 103.5 Hz
- Code 15 - 107.2 Hz
- Code 16 - 110.9 Hz
- Code 17 - 114.8 Hz
- Code 18 - 118.8 Hz
- Code 19 - 123.0 Hz
- Code 20 - 127.3 Hz
- Code 21 - 131.8 Hz
- Code 22 - 136.5 Hz
- Code 23 - 141.3 Hz
- Code 24 - 146.2 Hz
- Code 25 - 151.4 Hz
- Code 26 - 156.7 Hz
- Code 27 - 159.8 Hz
- Code 28 - 162.2 Hz
- Code 29 - 165.5 Hz
- Code 30 - 167.9 Hz
- Code 31 - 171.3 Hz
- Code 32 - 173.8 Hz
- Code 33 - 177.3 Hz
- Code 34 - 179.9 Hz
- Code 35 - 183.5 Hz
- Code 36 - 186.2 Hz
- Code 37 - 189.9 Hz
- Code 38 - 192.8 Hz
- Code 39 - 196.6 Hz
- Code 40 - 199.5 Hz
- Code 41 - 203.5 Hz
- Code 42 - 206.5 Hz
- Code 43 - 210.7 Hz
- Code 44 - 218.1 Hz
- Code 45 - 225.7 Hz
- Code 46 - 229.1 Hz
- Code 47 - 233.6 Hz
- Code 48 - 241.8 Hz
- Code 49 - 250.3 Hz
- Code 50 - 254.1 Hz
*See also: default/factory radio settings for Business Radio, popular and commonly heard CTCSS (PL) and DCS (DPL) tones/codes on the popular business radio channels, MURS as well as the militia radio frequencies page.
Were you looking for the factory default Retevis walkie talkie frequencies, the Baofeng FRS channel plan, programming list, tones and codes factory default Baofeng Retevis etc. list? See here. Note that the list is quite exhaustive and due to the many variants of these radios sold previous and sold now, your radio may not match the first default factory frequency plan you see. Be sure to scroll down and look at all the various channel plans.
- Commonly heard / encountered tones/codes - by FRS channel and frequency:
- FRS channel 1 - 462.5625 MHz CSQ - FRS recommended calling channel along it is often the busiest calling - National SOS Radio Network
- FRS Channel 1 - 462.5625 MHz CSQ - Unofficial FRS Calling/Emergency Channel
- FRS Channel 1 - 462.5625 MHz CSQ - Default out of the box channel for many FRS handhelds
- FRS Channel 1 - 462.5625 MHz CSQ - Patriot Militia Prepper Radio Neighborhood Watch Channel/Standby Channel
- FRS channel 1 - 462.5625 MHz CSQ - Patriot Radio - Neighborhood Watch Channel
- FRS channel 1 - 462.5625 MHz CSQ - Militia, self-defense and security forces common interagency inter-group tactical coordination mutual aid channel (alternate)
- FRS Channel 1 - 462.5625 MHz 67.0 Hz - Default out of the box channel/privacy code for many FRS handhelds, including Motorola
- FRS Channel 1 - 462.5625 MHz 67.0 Hz - Retevis FRS radios default channel 1
- FRS Channel 1 - 462.5625 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 1, group code 3
- FRS Channel 1 - 462.5625 MHz 67.0 Hz - Calford NCT688 wireless intercom channel 1, group code A
- FRS Channel 1 - 462.5625 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 1, group code 2
- FRS Channel 1 - 462.5625 MHz 69.3 Hz - Calford NTC688 wireless intercom channel 1, group code B
- FRS Channel 1 - 462.5625 MHz 107.2 Hz - Midland FRS extra channel channel 42
- FRS Channel 1 - 462.5625 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 13, group code A
- FRS Channel 1 - 462.5625 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 1
- FRS Channel 1 - 462.5625 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 13, group code B
- FRS Channel 1 - 462.5625 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 1, group code 1
- FRS Channel 1 - 462.5625 MHz 165.5 Hz - Calford NTC688 wireless intercom channel 1, group code C
- FRS Channel 1 - 462.5625 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 13, group code C
- FRS Channel 1 - 462.5625 MHz 250.3 Hz - Midland FRS extra channel channel 23
- FRS Channel 1 - 462.5625 MHz 026 DCS - Retevis RT-27 IC FRS radios default channel 15
- FRS Channel 1 - 462.5625 MHz 261 DCS - Baofeng UV-B5 Pofung UV-B5 default channel 7
- FRS channel 2 - 462.5875 MHz CSQ - Prepper/militia secondary channel (tactical channel)
- FRS channel 2 - 462.5875 MHz CSQ - Patriot Radio - Sovereign Citizens Freeman Channel
- FRS channel 2 - 462.5875 MHz CSQ - Militia, self-defense and security forces common interagency inter-group tactical coordination mutual aid channel (primary)
- FRS Channel 2 - 462.5875 MHz CSQ - Patriot Militia Prepper Radio - FRS Calling Channel - Sovereign Citizens Ops Tactical
- FRS Channel 2 - 462.5875 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 2, group code 3
- FRS Channel 2 - 462.5875 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 2, group code 2
- FRS Channel 2 - 462.5875 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 12, group code A
- FRS Channel 2 - 462.5875 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 2
- FRS Channel 2 - 462.5875 MHz 118.8 Hz - Retevis FRS radios default channel 2
- FRS Channel 2 - 462.5875 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 12, group code B
- FRS Channel 2 - 462.5875 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 2, group code 1
- FRS Channel 2 - 462.5875 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 12, group code C
- FRS Channel 2 - 462.5875 MHz 023 DCS - Midland FRS extra channel channel 31
- FRS Channel 2 - 462.5875 MHz 025 DCS - Midland FRS extra channel channel 50
- FRS Channel 2 - 462.5875 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 3
- FRS Channel 2 - 462.5875 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 2
- FRS Channel 2 - 462.5875 MHz 734 DCS - Wuloo WL666 wireless intercom channel 2, group code C
- FRS Channel 2 - 462.5875 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 1
- FRS Channel 2 - 462.5875 MHz 743 DCS - Wuloo WL666 wireless intercom channel 2, group code B
- FRS Channel 2 - 462.5875 MHz 754 DCS - Wuloo WL666 wireless intercom channel 2, group code A
- FRS channel 3 - 462.6125 MHz CSQ - Patriot Radio - Patriot Preppers Primary (see above)
- FRS Channel 3 - 462.6125 MHz CSQ - Patriot Militia Prepper Radio - FRS Calling Channel - AmRRON CH3
- FRS Channel 3 - 462.6125 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 3, group code 3
- FRS Channel 3 - 462.6125 MHz 67.0 Hz - Calford NCT688 wireless intercom channel 2, group code A
- FRS Channel 3 - 462.6125 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 3, group code 2
- FRS Channel 3 - 462.6125 MHz 69.3 Hz - Calford NCT688 wireless intercom channel 2, group code B
- FRS Channel 3 - 462.6125 MHz 97.4 Hz - Midland FRS extra channel channel 43
- FRS Channel 3 - 462.6125 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 11, group code A
- FRS Channel 3 - 462.6125 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 3
- FRS Channel 3 - 462.6125 MHz 118.8 Hz - HOSMART HY806 / HY810 wireless intercom channel 0
- FRS Channel 3 - 462.6125 MHz 127.3 Hz - Retevis FRS radios default channel 3
- FRS Channel 3 - 462.6125 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 11, group code B
- FRS Channel 3 - 462.6125 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 3, group code 1
- FRS Channel 3 - 462.6125 MHz 165.5 Hz - HOSMART HY777 / HY787 wireless intercom group call channel
- FRS Channel 3 - 462.6125 MHz 165.5 Hz - Calford NCT688 wireless intercom channel 2, group code C
- FRS Channel 3 - 462.6125 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 11, group code C
- FRS Channel 3 - 462.6125 MHz 225.7 Hz - Midland FRS extra channel channel 24
- FRS Channel 3 - 462.6125 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 3, group code 3
- FRS Channel 3 - 462.6125 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 3, group code 2
- FRS Channel 3 - 462.6125 MHz 734 DCS - Wuloo WL666 wireless intercom channel 3, group code C
- FRS Channel 3 - 462.6125 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 3, group code 1
- FRS Channel 3 - 462.6125 MHz 743 DCS - Wuloo WL666 wireless intercom channel 3, group code B
- FRS Channel 3 - 462.6125 MHz 754 DCS - Wuloo WL666 wireless intercom channel 3, group code A
- FRS channel 4 - 462.6375 MHz CSQ - Jeep 4x4 Clubs
- FRS Channel 4 - 462.6375 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 4, group code 3
- FRS Channel 4 - 462.6375 MHz 67.0 Hz - Calford NCT688 wireless intercom channel 3, group code A
- FRS Channel 4 - 462.6375 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 4, group code 2
- FRS Channel 4 - 462.6375 MHz 69.3 Hz - Calford NCT688 wireless intercom channel 3, group code B
- FRS Channel 4 - 462.6375 MHz 77.0 Hz - Jeep and 4x4 Club channel (may be used with CSQ/no tone or 114.8 Hz. see also: CB channels 4 and 16)
- FRS Channel 4 - 462.6375 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 10, group code A
- FRS Channel 4 - 462.6375 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 4
- FRS Channel 4 - 462.6375 MHz 114.8 Hz - Jeep and 4x4 Club channel (may be used with CSQ/no tone or 77.0 Hz)
- FRS Channel 4 - 462.6375 MHz 131.8 Hz - Retevis FRS radios default channel 4
- FRS Channel 4 - 462.6375 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 10, group code B
- FRS Channel 4 - 462.6375 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 4, group code 1
- FRS Channel 4 - 462.6375 MHz 165.5 Hz - Calford NCT688 wireless intercom channel 3, group code C
- FRS Channel 4 - 462.6375 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 10, group code C
- FRS Channel 4 - 462.6375 MHz 032 DCS - Midland FRS extra channel channel 32
- FRS Channel 4 - 462.6375 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 4, group code 3
- FRS Channel 4 - 462.6375 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 4, group code 2
- FRS Channel 4 - 462.6375 MHz 734 DCS - Wuloo WL666 wireless intercom channel 4, group code C
- FRS Channel 4 - 462.6375 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 4, group code 1
- FRS Channel 4 - 462.6375 MHz 743 DCS - Wuloo WL666 wireless intercom channel 4, group code B
- FRS Channel 4 - 462.6375 MHz 754 DCS - Wuloo WL666 wireless intercom channel 4, group code A
- FRS Channel 5 - 462.6625 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 5, group code 3
- FRS Channel 5 - 462.6625 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 5, group code 2
- FRS Channel 5 - 462.6625 MHz 88.5 Hz - Midland FRS extra channel channel 44
- FRS Channel 5 - 462.6625 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 0, group code A
- FRS Channel 5 - 462.6625 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 5
- FRS Channel 5 - 462.6625 MHz 136.5 Hz - Retevis FRS radios default channel 5
- FRS Channel 5 - 462.6625 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 0, group code B
- FRS Channel 5 - 462.6625 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 5, group code 1
- FRS Channel 5 - 462.6625 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 0, group code C
- FRS Channel 5 - 462.6625 MHz 203.5 Hz - Midland FRS extra channel channel 25
- FRS Channel 5 - 462.6625 MHz 225 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 0, group code A (new version)
- FRS Channel 5 - 462.6625 MHz 332 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 0, group code B (new version)
- FRS Channel 5 - 462.6625 MHz 464 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 0, group code C (new version)
- FRS Channel 5 - 462.6625 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 5, group code 3
- FRS Channel 5 - 462.6625 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 5, group code 2
- FRS Channel 5 - 462.6625 MHz 734 DCS - Wuloo WL666 wireless intercom channel 5, group code C
- FRS Channel 5 - 462.6625 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 5, group code 1
- FRS Channel 5 - 462.6625 MHz 743 DCS - Wuloo WL666 wireless intercom channel 5, group code B
- FRS Channel 5 - 462.6625 MHz 754 DCS - Wuloo WL666 wireless intercom channel 5, group code A
- FRS Channel 6 - 462.6875 MHz 67.0 Hz - HOSMART HY777 / HY787 wireless intercom channel 6, group code 3
- FRS Channel 6 - 462.6875 MHz 69.3 Hz - HOSMART HY777 / HY787 wireless intercom channel 6, group code 2
- FRS Channel 6 - 462.6875 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 9, group code A
- FRS Channel 6 - 462.6875 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 6
- FRS Channel 6 - 462.6875 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 9, group code B
- FRS Channel 6 - 462.6875 MHz 141.3 Hz - Retevis FRS radios default channel 8
- FRS Channel 6 - 462.6875 MHz 162.2 Hz - HOSMART HY777 / HY787 wireless intercom channel 6, group code 1
- FRS Channel 6 - 462.6875 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 9, group code C
- FRS Channel 6 - 462.6875 MHz 047 DCS - Midland FRS extra channel channel 33
- FRS Channel 6 - 462.6875 MHz 731 DCS - HOSMART HY810 wireless intercom channel 6, group code 3
- FRS Channel 6 - 462.6875 MHz 732 DCS - HOSMART HY810 wireless intercom channel 6, group code 2
- FRS Channel 6 - 462.6875 MHz 734 DCS - Wuloo WL666 wireless intercom channel 6, group code C
- FRS Channel 6 - 462.6875 MHz 743 DCS - HOSMART HY810 wireless intercom channel 6, group code 1
- FRS Channel 6 - 462.6875 MHz 743 DCS - Wuloo WL666 wireless intercom channel 6, group code B
- FRS Channel 6 - 462.6875 MHz 754 DCS - Wuloo WL666 wireless intercom channel 6, group code A
- FRS Channel 6 - 462.6875 MHz 261 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 9, group code A (new version)
- FRS Channel 6 - 462.6875 MHz 412 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 9, group code B (new version)
- FRS Channel 6 - 462.6875 MHz 546 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 9, group code C (new version)
- FRS Channel 7 - 462.7125 MHz 79.7 Hz - Midland FRS extra channel channel 45
- FRS Channel 7 - 462.7125 MHz 97.4 Hz - Channel "7-11" - commonly used channel
- FRS Channel 7 - 462.7125 MHz 110.9 Hz - Airshow and Milcom Hobbyist and Monitors Intercept Backup Channel
- FRS channel 7 - 462.7125 MHz 110.0 Hz - Airshow/milcom hobbyist recommended channel (secondary to 14-38 CH14 250.3 Hz)
- FRS Channel 7 - 462.7125 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 8, group code A
- FRS Channel 7 - 462.7125 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 7
- FRS Channel 7 - 462.7125 MHz 118.8 Hz - HOSMART HY777 / HY787 wireless intercom channel 7
- FRS Channel 7 - 462.7125 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 8, group code B
- FRS Channel 7 - 462.7125 MHz 146.2 Hz - Retevis FRS radios default channel 9
- FRS Channel 7 - 462.7125 MHz 179.9 Hz - Midland FRS extra channel channel 26
- FRS Channel 7 - 462.7125 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 8, group code C
- FRS Channel 7 - 462.7125 MHz 255 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 8, group code A (new version)
- FRS Channel 7 - 462.7125 MHz 411 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 8, group code B (new version)
- FRS Channel 7 - 462.7125 MHz 532 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 8, group code C (new version)
- FRS Channel 7 - 462.7125 MHz 734 DCS - Wuloo WL666 wireless intercom channel 7, group code C
- FRS Channel 7 - 462.7125 MHz 743 DCS - Wuloo WL666 wireless intercom channel 7, group code B
- FRS Channel 7 - 462.7125 MHz 754 DCS - Wuloo WL666 wireless intercom channel 7, group code A
- FRS Channel 8 - 467.5625 MHz 88.5 Hz - Patriot Militia Prepper Radio - FRS Operations/Tactical "88" or "8-8"
- FRS Channel 8 - 467.5625 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 7, group code A
- FRS Channel 8 - 467.5625 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 8
- FRS Channel 8 - 467.5625 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 7, group code B
- FRS Channel 8 - 467.5625 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 7, group code C
- FRS Channel 8 - 467.5625 MHz 026 DCS - Retevis RT-27 IC FRS radios default channel 16
- FRS Channel 8 - 467.5625 MHz 065 DCS - Midland FRS extra channel channel 34
- FRS Channel 8 - 467.5625 MHz 243 DCS - Retevis RT40 Retevis RT-40 RT-40B RR22 RT27 RT47 RT48 (many other Retevis) FRS radios default channel 8
- FRS Channel 8 - 467.5625 MHz 252 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 7, group code A (new version)
- FRS Channel 8 - 467.5625 MHz 306 DCS - Retevis RT30 default frequency, Retevis RT30M default frequency and code (other Retevis, etc. radios)
- FRS Channel 8 - 467.5625 MHz 371 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 7, group code B (new version)
- FRS Channel 8 - 467.5625 MHz 526 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 7, group code C (new version)
- FRS Channel 8 - 467.5625 MHz 734 DCS - Wuloo WL666 wireless intercom channel 8, group code C
- FRS Channel 8 - 467.5625 MHz 743 DCS - Wuloo WL666 wireless intercom channel 8, group code B
- FRS Channel 8 - 467.5625 MHz 754 DCS - Wuloo WL666 wireless intercom channel 8, group code A
- FRS Channel 9 - 467.5625 MHz 97.4 Hz - Patriot Militia Prepper Radio - FRS Operations/Tactical "911" or "9-11"
- FRS Channel 9 - 467.5875 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 6, group code A
- FRS Channel 9 - 467.5875 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 9
- FRS Channel 9 - 467.5875 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 6, group code B
- FRS Channel 9 - 467.5875 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 6, group code C
- FRS Channel 9 - 467.5875 MHz 032 DCS - Retevis RT22 RT27 RT47 RT48 (and many others) Retevis FRS radios default channel 9 code
- FRS Channel 9 - 467.5875 MHz 251 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 6, group code A (new version)
- FRS Channel 9 - 467.5875 MHz 365 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 6, group code B (new version)
- FRS Channel 9 - 467.5875 MHz 523 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 6, group code C (new version)
- FRS Channel 9 - 467.5875 MHz 734 DCS - Wuloo WL666 wireless intercom channel 9, group code C
- FRS Channel 9 - 467.5875 MHz 743 DCS - Wuloo WL666 wireless intercom channel 9, group code B
- FRS Channel 9 - 467.5875 MHz 754 DCS - Wuloo WL666 wireless intercom channel 9, group code A
- FRS Channel 10 - 467.6125 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 5, group code A
- FRS Channel 10 - 467.6125 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 10
- FRS Channel 10 - 467.6125 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 5, group code B
- FRS Channel 10 - 467.6125 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 5, group code C
- FRS Channel 10 - 467.6125 MHz 047 DCS - Retevis RT22 RT27 RT47 RT48 (and many others) Retevis FRS radios default channel 10 code
- FRS Channel 10 - 467.6125 MHz 073 DCS - Midland FRS extra channel channel 35
- FRS Channel 10 - 467.6125 MHz 246 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 5, group code A (new version)
- FRS Channel 10 - 467.6125 MHz 364 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 5, group code B (new version)
- FRS Channel 10 - 467.6125 MHz 516 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 5, group code C (new version)
- FRS Channel 10 - 467.6125 MHz 627 DCS - HOSMART HY806 / HY810 wireless intercom group call channel
- FRS Channel 10 - 467.6125 MHz 734 DCS - Wuloo WL666 wireless intercom channel 0, group code C
- FRS Channel 10 - 467.6125 MHz 743 DCS - Wuloo WL666 wireless intercom channel 0, group code B
- FRS Channel 10 - 467.6125 MHz 754 DCS - Wuloo WL666 wireless intercom channel 0, group code A
- FRS Channel 11 - 467.6375 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 4, group code A
- FRS Channel 11 - 467.6375 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 11
- FRS Channel 11 - 467.6375 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 4, group code B
- FRS Channel 11 - 467.6375 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 4, group code C
- FRS Channel 11 - 467.6375 MHz 051 DCS - Retevis RT22 RT27 RT47 RT48 (and many others) Retevis FRS radios default channel 11 code
- FRS Channel 11 - 467.6375 MHz 245 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 4, group code A (new version)
- FRS Channel 11 - 467.6375 MHz 356 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 4, group code B (new version)
- FRS Channel 11 - 467.6375 MHz 506 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 4, group code C (new version)
- FRS Channel 11 - 467.6375 MHz 731 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 3
- FRS Channel 11 - 467.6375 MHz 732 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 2
- FRS Channel 11 - 467.6375 MHz 743 DCS - HOSMART HY806 / HY810 wireless intercom channel 2, group code 1
- FRS Channel 12 - 467.6625 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 3, group code A
- FRS Channel 12 - 467.6625 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 12
- FRS Channel 12 - 467.6625 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 3, group code B
- FRS Channel 12 - 467.6625 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 3, group code C
- FRS Channel 12 - 467.6625 MHz 053 DCS - Retevis RT22 RT27 RT47 RT48 (and many others) Retevis FRS radios default channel 12 code
- FRS Channel 12 - 467.6625 MHz 115 DCS - Midland FRS extra channel channel 36
- FRS Channel 12 - 467.6625 MHz 244 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 3, group code A (new version)
- FRS Channel 12 - 467.6625 MHz 351 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 3, group code B (new version)
- FRS Channel 12 - 467.6625 MHz 503 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 3, group code C (new version)
- FRS Channel 13 - 467.6875 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 2, group code A
- FRS Channel 13 - 467.6875 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 13
- FRS Channel 13 - 467.6875 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 2, group code B
- FRS Channel 13 - 467.6875 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 2, group code C
- FRS Channel 13 - 467.6875 MHz 065 DCS - Retevis RT22 RT27 RT47 RT48 (and many others) Retevis FRS radios default channel 13 code
- FRS Channel 13 - 467.6875 MHz 243 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 2, group code A (new version)
- FRS Channel 13 - 467.6875 MHz 346 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 2, group code B (new version)
- FRS Channel 13 - 467.6875 MHz 466 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 2, group code C (new version)
- FRS channel 14 - 467.7125 MHz 250.3 Hz - Airshow/milcom hobbyist recommended channel (primary)
- FRS Channel 14 - 467.7125 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 1, group code A
- FRS Channel 14 - 467.7125 MHz 114.8 Hz - Retevis RT-27 IC FRS radios default channel 14
- FRS Channel 14 - 467.7125 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 1, group code B
- FRS Channel 14 - 467.7125 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 1, group code C
- FRS Channel 14 - 467.7125 MHz 250.3 Hz - Airshow and Milcom Hobbyist and Monitors Intercept Primary Channel
- FRS Channel 14 - 467.7125 MHz 116 DCS - Retevis RT22 RT27 RT47 RT48 (and many others) Retevis FRS radios default channel 14 code
- FRS Channel 14 - 467.7125 MHz 131 DCS - Midland FRS extra channel channel 37
- FRS Channel 14 - 467.7125 MHz 226 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 1, group code A (new version)
- FRS Channel 14 - 467.7125 MHz 343 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 1, group code B (new version)
- FRS Channel 14 - 467.7125 MHz 465 DCS - SAMCOM / SANZUCO 10 channel wireless intercom channel 1, group code C (new version)
- FRS Channel 14 - 467.7125 MHz 731 DCS - HOSMART HY810 wireless intercom channel 7, group code 3
- FRS Channel 14 - 467.7125 MHz 732 DCS - HOSMART HY810 wireless intercom channel 7, group code 2
- FRS Channel 14 - 467.7125 MHz 743 DCS - HOSMART HY810 wireless intercom channel 7, group code 1
- FRS Channel 14 - 467.7125 MHz 743 DCS - Wuloo 22 channel 100 code wireless intercom group call channel code
- FRS Channel 15 - 462.5500 MHz 71.9 Hz - Midland FRS extra channel channel 46
- FRS Channel 15 - 462.5500 MHz 123.0 Hz - Retevis FRS radios default channel 10
- FRS Channel 15 - 462.5500 MHz 162.2 Hz - Midland FRS extra channel channel 27
- FRS Channel 15 - 462.5500 MHz 731 DCS - HOSMART HY810 wireless intercom channel 8, group code 3
- FRS Channel 15 - 462.5500 MHz 732 DCS - HOSMART HY810 wireless intercom channel 8, group code 2
- FRS Channel 15 - 462.5500 MHz 743 DCS - HOSMART HY810 wireless intercom channel 8, group code 1
- FRS channel 16 - 462.5750 MHz CSQ - Jeep 4x4 Clubs, see also, FRS channel 4, MURS channel 4, CB channel 4
- FRS Channel 16 - 462.5750 MHz Various - White Dot Itinerant Business Band - old color dot star channel designation
- FRS Channel 16 - 462.5750 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business frequency
- FRS Channel 16 - 462.5750 MHz 023 DCS - BlackBox Bantam radio default channel 9
- FRS Channel 16 - 462.5750 MHz 143 DCS - Midland FRS extra channel channel 38
- FRS Channel 16 - 462.5750 MHz 654 DCS - Retevis FRS radios default channel 11 (inverted 743 DCS, D743I - D654N)
- FRS Channel 16 - 462.5750 MHz 731 DCS - HOSMART HY810 wireless intercom channel 9, group code 3
- FRS Channel 16 - 462.5750 MHz 732 DCS - HOSMART HY810 wireless intercom channel 9, group code 2
- FRS Channel 16 - 462.5750 MHz 743 DCS - HOSMART HY810 wireless intercom channel 9, group code 1
- FRS channel 17 - 462.6000 MHz CSQ - Patriot Radio Patriot Militia Tactical
- FRS Channel 17 - 462.6000 MHz CSQ - Patriot Militia Prepper Radio - FRS/GMRS Operations Tactical Channel 17
- FRS Channel 17 - 462.6000 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 19, group code A
- FRS Channel 17 - 462.6000 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 19, group code B
- FRS Channel 17 - 462.6000 MHz 146.2 Hz - Midland FRS extra channel channel 28
- FRS Channel 17 - 462.6000 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 19, group code C
- FRS Channel 17 - 462.6000 MHz 241.8 Hz - Midland FRS extra channel channel 47
- FRS Channel 17 - 462.6000 MHz 455 DCS - Retevis FRS radios default channel 12 (inverted 332 DCS, D332I - D455N)
- FRS Channel 18 - 462.6250 MHz Various - Black Dot Itinerant Business Band - old color dot star channel designation
- FRS Channel 18 - 462.6250 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business frequency
- FRS Channel 18 - 462.6250 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 18, group code A
- FRS Channel 18 - 462.6250 MHz 127.3 Hz - Baofeng BF-888S, B-888, BF-666S, etc. channel 6
- FRS Channel 18 - 462.6250 MHz 127.3 Hz - Retevis FRS radios default channel 6
- FRS Channel 18 - 462.6250 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 18, group code B
- FRS Channel 18 - 462.6250 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 18, group code C
- FRS Channel 18 - 462.6250 MHz 023 DCS - BlackBox Bantam radio default channel 10
- FRS Channel 18 - 462.6250 MHz 156 DCS - Midland FRS extra channel channel 39
- FRS Channel 19 - 462.6500 MHz CSQ - Patriot Militia Prepper Radio - FRS/GMRS Operations Tactical Channel 19
- FRS channel 19 - 462.6500 MHz CSQ - Militia, self-defense and security forces common interagency inter-group tactical coordination mutual aid channel (secondary, backup channel)
- FRS Channel 19 - 462.6500 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 17, group code A
- FRS Channel 19 - 462.6500 MHz 131.8 Hz - Midland FRS extra channel channel 29
- FRS Channel 19 - 462.6500 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 17, group code B
- FRS Channel 19 - 462.6500 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 17, group code C
- FRS Channel 19 - 462.6500 MHz 218.1 Hz - Midland FRS extra channel channel 48
- FRS Channel 19 - 462.6500 MHz 351 DCS - Retevis FRS radios default channel 13 (inverted 243 DCS, D243I - D351N)
- FRS Channel 20 - 462.6750 MHz Various - Orange Dot Itinerant Business Band - old color dot star channel designation
- FRS Channel 20 - 462.6750 MHz 67.0 Hz - Motorola / Kenwood on-site business radios old default business frequency
- FRS Channel 20 - 462.6750 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 16, group code A
- FRS Channel 20 - 462.6750 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 16, group code B
- FRS Channel 20 - 462.6750 MHz 141.3 Hz - GMRS Calling / Travel Channel "GMRS 675"
- FRS Channel 20 - 462.6750 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 16, group code C
- FRS Channel 20 - 462.6750 MHz 023 DCS - Blackbox Bantam radio default channel 11
- FRS Channel 20 - 462.6750 MHz 172 DCS - Midland FRS extra channel channel 40
- FRS Channel 20 - 462.6750 MHz 606 DCS - Retevis FRS radios default channel 14 - D606N
- FRS Channel 21 - 462.7000 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 15, group code A
- FRS Channel 21 - 462.7000 MHz 118.8 Hz - Midland FRS extra channel channel 30
- FRS Channel 21 - 462.7000 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 15, group code B
- FRS Channel 21 - 462.7000 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 15, group code C
- FRS Channel 21 - 462.7000 MHz 192.8 Hz - Midland FRS extra channel channel 49
- FRS Channel 21 - 462.7000 MHz 155 DCS - Retevis FRS radios default channel 15 (inverted 731 DCS, D731I - D155N)
- FRS Channel 21 - 462.7000 MHz 743 DCS - HOSMART (and others) 10 channel wireless intercom group call channel
- FRS Channel 21 - 462.7000 MHz 743 DCS - Wuloo WL666 wireless intercom group call channel
- FRS Channel 22 - 462.7250 MHz 110.9 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 14, group code A
- FRS Channel 22 - 462.7250 MHz 136.5 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 14, group code B
- FRS Channel 22 - 462.7250 MHz 136.5 Hz - Baofeng BF-888S, B-888, BF-666S, etc. channel 7
- FRS Channel 22 - 462.7250 MHz 136.5 Hz - Retevis FRS radios default channel 7
- FRS Channel 22 - 462.7250 MHz 186.2 Hz - SAMCOM 20 channel FTAN20A wireless intercom channel 14, group code C
- FRS Channel 22 - 462.7250 MHz 250.3 Hz - Highest channel/privacy code combination possible (on CTCSS only radios)
- FRS Channel 22 - 462.7250 MHz 026 DCS - Default Business Band Radios (using GMRS frequencies)
- FRS Channel 22 - 462.7250 MHz 223 DCS - Midland FRS extra channel channel 41
- FRS Channel 22 - 462.7250 MHz 252 DCS - Retevis FRS radios default channel 16 (inverted 462 DCS, D462I - D252N)
- FRS Channel 22 - 462.7250 MHz 734 DCS - Wuloo WL666 wireless intercom channel 1, group code C
- FRS Channel 22 - 462.7250 MHz 743 DCS - Wuloo WL666 wireless intercom channel 1, group code B
- FRS Channel 22 - 462.7250 MHz 754 DCS - Wuloo WL666 wireless intercom channel 1, group code A
- FRS Channel 22 - 462.7250 MHz 754 DCS - Highest channel/privacy code combination possible (on radios with DCS)
CTCSS (PL) and DCS (DPL) Tones and Codes To Avoid on FRS and GMRS Channels
Listing by channel. Note that many radios default to either carrier squelch (no tone) or "code 1", which is 67.0 Hz. Below are the most commonly found CTCSS and DCS tones and codes by channel.
CTCSS is also known as PL, QT or CTCS (as in T-CTCS and R-CTCS). DCS (as in T-DCS or R-DCS) is also known as DPL, DQT or DTCS.
Using DCS may cause a some receivers set to 136.5 Hz or 131.8 Hz tone squelch to open due to DCS using a digital sub audible tone at 134 Hz. This is why a receiver set to CTCSS decode or PL decode may decode a transmission using DCS as using 136.5 Hz CTCSS.
Note that this listing includes regular DCS and inverted DCS. Due to issues with systems decoding inverted DCS incorrectly, I have included the "companion" regular DCS code with the inverted DCS, as many receivers will decode the "mirror image" DCS code when inverted DCS is used. For regular DCS, DxxxN is used, for inverted DCS, the code is shown as DxxxI. For example, 023 DCS would be indicated as D023N, whereas 464I DCS (inverted DCS code 464) would be shown as D464I.
*FRS Channel 1 - 462.5625 MHz - 67.0 Hz, 69.3 Hz, 107.2 Hz, 110.0 Hz, 114.8 Hz, 136.5 Hz, 141.3 Hz, 146.2 Hz, 162.2 Hz, 165.5 Hz, 186.2 Hz, 250.3 Hz, D023N, D025N, D026N, D261N
*FRS Channel 2 - 462.5875 MHz - 67.0 Hz, 69.3 Hz, 71.9 Hz, 97.4 Hz, 110.9 Hz, 114.8 Hz, 136.5 Hz, 141.3 Hz, 146.2 Hz, 162.2 Hz, 186.2 Hz, D023N, D025N, D026N, D731N, D732N, D734N, D743, D754N
*FRS Channel 3 - 462.6125 MHz - 67.0 Hz, 69.3 Hz, 74.4 Hz, 97.4 Hz, 100.0 Hz, 103.5 Hz, 107.2 Hz, 110.9 Hz, 114.8 Hz, 118.8 Hz, 127.3 Hz, 136.5 Hz, 162.2 Hz, 165.5 Hz, 186.2 Hz, 210.7 Hz, 218.1 Hz, 225.7 Hz, D731N, D732N, D734N, D743N, D754N
*FRS Channel 4 - 462.6375 MHz - 67.0 Hz, 69.3 Hz, 74.4 Hz, 77.0 Hz, 85.4 Hz, 88.5 Hz, 110.9 Hz, 114.8 Hz, 131.8 Hz, 136.5 Hz, 156.7 Hz, 162.2 Hz, 165.5 Hz, 186.2 Hz, D032N, D731N, D732N, D734N, D743N, D754N
*FRS Channel 5 - 462.6625 MHz - 67.0 Hz, 69.3 Hz, 79.7 Hz, 82.5 Hz, 100.0 Hz, 103.5 Hz, 107.2 Hz, 110.9 Hz, 114.8 Hz, 136.5 Hz, 141.3 Hz, 162.2 Hz, 167.9 Hz, 186.2 Hz, 203.5 Hz, D023N, D225N, D332N, D464N, D731N, D732N, D734N, D743N, D754N
*FRS Channel 6 - 462.6875 MHz - 67.0 Hz, 69.3 Hz, 82.5 Hz, 100.0 Hz, 110.9 Hz, 114.8 Hz, 136.5 Hz, 141.3 Hz, 162.2 Hz, 186.2 Hz, 233.6 Hz, D047N, D261N, D412N, D546N, D731N, D732N, D734N, D743N, D754N
*FRS Channel 7 - 462.7125 MHz - 67.0 Hz, 79.7 Hz, 82.5 Hz, 85.4 Hz, 94.8 Hz, 97.4 Hz, 110.9 Hz, 114.8 Hz, 118.8 Hz, 136.5 Hz, 146.2 Hz, 159.8 Hz, 162.2 Hz, 167.9 Hz, 179.9 Hz, 186.2 Hz, 189.9 Hz, 233.6 Hz, 241.8 Hz, D255N, D411N, D532N, D734N, D743N, D754N
*FRS Channel 8 - 467.5625 MHz - 67.0 Hz, 85.4 Hz, 88.5 Hz, 107.2 Hz, 110.9 Hz, 114.8 Hz, 136.5 Hz, 162.2 Hz, 173.8 Hz, 186.2 Hz, 192.8 Hz, 233.6 Hz, 241.8 Hz, 250.3 Hz, D026N, D065N, D252N, D371N, D526N, D743N, D743N, D754N
*FRS Channel 9 - 467.5875 MHz - 67.0 Hz, 88.5 Hz, 91.5 Hz, 94.8 Hz, 97.4 Hz, 110.9 Hz, 114.8 Hz, 118.8 Hz, 123.0 Hz, 127.3 Hz, 136.5 Hz, 186.2 Hz, D251N, D261N, D365N, D523N, D734N, D743N, D754N
*FRS Channel 10 - 467.6125 MHz - 67.0 Hz, 74.4 Hz, 77.0 Hz, 91.5 Hz, 94.8 Hz, 97.4 Hz, 110.9 Hz, 114.8 Hz, 136.5 Hz, 186.2 Hz, D073N, D246N, D364N, D516N, D627N, D732N, D734N, D743N, D754N
*FRS Channel 11 - 467.6375 MHz - 67.0 Hz, 94.8 Hz, 97.4 Hz, 100.0 Hz, 114.8 Hz, 136.5 Hz, 186.2 Hz, D245N, D356N, D506N, D731N, D732N, D743N
*FRS Channel 12 - 467.6625 MHz - 67.0 Hz, 74.4 Hz, 77.0 Hz, 88.5 Hz, 97.4 Hz, 100.0 Hz, 103.5 Hz, 110.9 Hz, 114.8 Hz, 136.5 Hz, D115N, D244N, D351N, D503N
*FRS Channel 13 - 467.6875 MHz - 67.0 Hz, 77.0 Hz, 100.0 Hz, 103.5 Hz, 110.9 Hz, 114.8 Hz, 136.5 Hz, 162.2 Hz, 186.2 Hz, 192.8 Hz, D243N, D346N, D466N
*FRS Channel 14 - 467.7125 MHz - 67.0 Hz, 103.5 Hz, 107.2 Hz, 110.9 Hz, 114.8 Hz, 136.5 Hz, 186.2 Hz, 250.3 Hz, 254.1 Hz, DD131N, D226N, D343N, D465N, D731N, D732N, D743N
*FRS Channel 15 - 462.5500 MHz - 67.0 Hz, 71.9 Hz, 107.2 Hz, 110.9 Hz, 123.0 Hz, 136.5 Hz, 162.2 Hz, D731N, D732N, D743N
*FRS Channel 16 - 462.5750 MHz - 67.0 Hz, 110.9 Hz, 114.8 Hz, 118.8 Hz, 136.5 Hz, 203.5 Hz, D023N, D143N, D654N, D731N, D732N, D743N, D743I
*FRS Channel 17 - 462.6000 MHz - 67.0 Hz, 110.9 Hz, 114.8 Hz, 118.8 Hz, 136.5 Hz, 186.2 Hz, 241.8 Hz, D455N, D332I
*FRS Channel 18 - 462.6250 MHz - 67.0 Hz, 110.9 Hz, 123.0 Hz, 127.3 Hz, 136.5 Hz, 186.2 Hz, D023N, D156N
*FRS Channel 19 - 462.6500 MHz - 67.0 Hz, 110.9 Hz, 127.3 Hz, 136.5 Hz, 186.2 Hz, 218.1 Hz, 225.7 Hz, D023N, D025N, D351N, D243I
*FRS Channel 20 - 462.6750 MHz - 67.0 Hz, 110.9 Hz, 127.3 Hz, 131.8 Hz, 136.5 Hz, 141.3 Hz, 146.2 Hz, 186.2 Hz, 199.5 Hz, D023N, D172N, D606N
*FRS Channel 21 - 462.7000 MHz - 67.0 Hz, 100.0 Hz, 118.8 Hz, 131.8 Hz, 136.5 Hz, 186.2 Hz, 192.8 Hz, 206.5 Hz, D155N, D743N, D731I
*FRS Channel 22 - 462.7250 MHz - 67.0 Hz, 110.9 Hz, 136.5 Hz, 186.2 Hz, 250.3 Hz, 254.1 Hz, D223N, D252N, D734N, D743N, D754N, D461I, D462I
Which CTCSS and DCS tones codes should I avoid using on the FRS Family Radio Service channels GMRS frequencies commonly used default factory frequencies most often heard most popular CTCSS tones most popular tones.
This section is included for historical and reference purposes only.
500mW 14-channel walkie talkies, the original FRS specification. RadioShack Radio Shack heavily lobbied the FCC heavily in the 1990s to create a new license-free Part 95 radio service with more range and less interference than Part 15 49 MHz FM walkie talkies and without the interference problems that plague the 27 MHz AM CB radio band. Motorola quickly entered the market with their Talkabout series FRS walkie talkies, followed by Kenwood, Icom, Maxon, Midland and numerous other consumer electronics companies.
These radios are still permitted under FCC rules, but have largely been replaced by 22-channel FRS walkie talkies once the FCC updated the FRS and GMRS regulations to allow simplex (non-repeater) operation on all 22 frequencies (7 FRS/GMRS shared simplex only channels [FRS channels 1-7] + FRS only simplex only channels [FRS channels 8-14] + 8 originally GMRS only simplex/repeater output channels [FRS/GMRS "combination radio" channels 15-22] became FRS channels 1-22, meaning that the original FRS channels 1-14 match up with the current FRS channels 1-14.
Older style 14 channel FRS radios are backward compatible with current 22 channel FRS radios.
This section is included for historical and reference purposes only. It includes channel number conversions to make using the older GMRS-only 15 channel radios easier to use with modern 22 channel radios.
The 15 channel GMRS only radios usually transmitted between 2 and 5 watts on the 462 MHz GMRS channels.
- Channel 8 - 462.5500 MHz - Now channel 15
- Channel 9 - 462.5750 MHz - Now channel 16
- Channel 10 - 462.6000 MHz - Now channel 17
- Channel 11 - 462.6250 MHz - Now channel 18
- Channel 12 - 462.6500 MHz - Now channel 19
- Channel 13 - 462.6750 MHz - Now channel 20
- Channel 14 - 462.7000 MHz - Now channel 21
- Channel 15 - 462.7250 MHz - Now channel 22
Numerous intercom systems, including doorbell intercom systems, use the FRS frequencies, often with DCS (DPL) and CTCSS (PL) codes and tones to make different "groups" in combination with frequencies/channels. Several of these devices offer a monitor, transmit lock, baby monitor or open-mic option, with time out timers that turn the transmitter off after a certain amount of time (usually 8 hours or 10 hours). While some intercoms only transmit in the 200mW to 300mW range, higher-end versions transmit close to 500mW with efficient antennas.
486.4mw (nominally <500mw) power output, 9K90F3E emission
- CHANNEL 0 - 462.6125 MHz 118.8 Hz CTCSS
- CHANNEL 1 - 467.6375 MHz
- CHANNEL 2 - 462.5875 MHz
- CHANNEL 3 - 462.6125 MHz
- CHANNEL 4 - 462.6375 MHz
- CHANNEL 5 - 462.6625 MHz
- CHANNEL 6 - 462.6875 MHz
- CHANNEL 7 - 467.7125 MHz
- CHANNEL 8 - 462.5500 MHz
- CHANNEL 9 - 462.5750 MHz
- Code 1 - 162.2 Hz CTCSS
- Code 2 - 69.3 Hz CTCSS
- Code 3 - 67.0 Hz CTCSS
- All intercoms in a given system must be set to the same code (3-position switch on the back of the unit).
484.2mw (nominally <500mw) power output, 9K80F3E emission, the HY787 wireless FM intercom uses the same channel and code plan
- GROUP CALL - 462.6125 MHz 165.5 Hz CTCSS
- CHANNEL 1 - 462.5625 MHz
- CHANNEL 7 - 467.7125 MHz 118.8 Hz CTCSS
- Group call channel is hard programmed to 165.5 Hz CTCSS tone
- Channel 7 is hard programmed to 118.8 Hz CTCSS tone
- CHANNEL 0 - 462.6125 MHz 118.8 Hz PL tone
- Code 1 - 743 DCS / 743 DPL
- Code 2 - 732 DCS / 732 DPL
- Code 3 - 731 DCS / 731 DPL
- Group call channel is hard programmed to 627 DPL / 627 DCS or D627N
- Channel 0 is hard programmed to 118.8 Hz CTCSS tone
- GROUP CALL - 467.6125 MHz 627 DCS / 627 DPL (or D627N)
- Group call channel is hard programmed to 627 DPL / 627 DCS (or D627N)
- CHANNEL 2 - 462.6125 MHz
- CHANNEL 3 - 462.6375 MHz
- Code A - 67.0 Hz CTCSS tone
- Code B - 69.3 Hz CTCSS tone
- Code C - 165.5 Hz CTCSS tone
215mw power output, 11K0F3E emission. 3 different CTCSS (or DCS?) code settings A, B and C. Tones are unconfirmed at this time.
- Calford Technology Ltd. AF388 9 channel FM wireless intercom
215mw power output, 11K0F3E emission. FCC ID: 2AAYF-AF388. 3 different CTCSS or DCS code settings A, B and C. Tones are unconfirmed.
- CHANNEL 7 - 462.7125 MHz
- CHANNEL 8 - 467.5625 MHz
- CHANNEL 9 - 467.5875 MHz
234mw power output, 11K0F3E emission. 3 different CTCSS code settings A, B and C. Tones are unconfirmed.
- CHANNEL A - 462.5625 MHz
- CHANNEL B - 462.5875 MHz
- CHANNEL C - 462.6125 MHz
- CHANNEL D - 462.6375 MHz
- SAMCOM FTAN10A 10 channel wireless intercom - older version
205mw - 213 mw power output, 11K0F3E emission SAMCOM intercoms are sold under numerous brand names including SANZUCO and several others. SANZUCO 10 channel wireless intercom. Various "updates" and "versions" exist, including some listed under the FTAN40A model number. FCC ID 2AS5R-FTAN40A 10-channel wireless intercom with 3 digital codes. Note that even though the term "digital code" is used, some variants use CTCSS tones and others use DCS codes.
- CHANNEL 0 - 462.6625 MHz
- CHANNEL 1 - 467.7125 MHz
- CHANNEL 2 - 467.6875 MHz
- CHANNEL 3 - 467.6625 MHz
- CHANNEL 4 - 467.6375 MHz
- CHANNEL 5 - 467.6125 MHz
- CHANNEL 6 - 467.5875 MHz
- CHANNEL 7 - 467.5625 MHz
- CHANNEL 8 - 462.7125 MHz
- CHANNEL 9 - 462.6875 MHz
- Code A - 110.9 Hz CTCSS
- Code B - 136.5 Hz CTCSS
- Code C - 186.2 Hz CTCSS
- Channels 0-9 will use code A, code B or code C. All intercoms in a given system must be set to the same code. GROUP CALL channel is set to channel 0. However, end-user may assign any channel to as the GROUP channel (except for a channel already assigned to any unit in their network).
- SAMCOM FTAN40A 10 channel wireless intercom - newer version
- CHANNEL 0 - 462.6625 MHz - Code A: 225 DCS Code B: 332 DCS Code C: 464 DCS
- CHANNEL 1 - 467.7125 MHz - Code A: 226 DCS Code B: 343 DCS Code C: 465 DCS
- CHANNEL 2 - 467.6875 MHz - Code A: 243 DCS Code B: 346 DCS Code C: 466 DCS
- CHANNEL 3 - 467.6625 MHz - Code A: 244 DCS Code B: 351 DCS Code C: 503 DCS
- CHANNEL 4 - 467.6375 MHz - Code A: 245 DCS Code B: 356 DCS Code C: 506 DCS
- CHANNEL 5 - 467.6125 MHz - Code A: 246 DCS Code B: 364 DCS Code C: 516 DCS
- CHANNEL 6 - 467.5875 MHz - Code A: 251 DCS Code B: 365 DCS Code C: 523 DCS
- CHANNEL 7 - 467.5625 MHz - Code A: 252 DCS Code B: 371 DCS Code C: 526 DCS
- CHANNEL 8 - 462.7125 MHz - Code A: 255 DCS Code B: 411 DCS Code C: 532 DCS
- CHANNEL 9 - 462.6875 MHz - Code A: 261 DCS Code B: 412 DCS Code C: 546 DCS
- Channels 0-9 will use code A, code B or code C. Each intercom can only be set to one code at a time. All intercoms in a given system must be set to the same code. GROUP CALL channel is set to channel 0. However, end-user may assign any channel to as the GROUP channel (except for a channel already assigned to any unit in their network). All intercoms must be set to the same code A, B or C and must have the same channel 0-9 assigned as the GROUP or GROUP CALL channel set (if the user decides to switch from the default group channel setting).
As of 2021, the manufacturer or vendor is alternating so 2-packs and 4-packs of intercoms sold as ready-to-use systems may be set to Code A, Code B or Code C. Out of the box intercoms will be programmed on channel 1 or subnetwork 1 with channel 0 as the group channel. A user may assign as many intercoms to each channel as they wish, or may assign one intercom per channel (for one-to-one communication) and use the group call function to broadcast a message to all intercoms (one-to-many broadcasts).
The newer versions of these intercoms use different A/B/C DCS (DPL) codes for each channel (see above).
- SAMCOM FTAN20A 10 channel wireless intercom
225mw - 235 mw power output, 11K0F3E emission SAMCOM intercoms are sold under numerous brand names including SANZUCO and several others. SANZUCO 20 channel wireless intercom.
- CHANNEL 10 - 462.6375 MHz
- CHANNEL 11 - 462.6125 MHz
- CHANNEL 12 - 462.5875 MHz
- CHANNEL 13 - 462.5625 MHz
- CHANNEL 14 - 462.7250 MHz
- CHANNEL 15 - 462.7000 MHz
- CHANNEL 16 - 462.6750 MHz
- CHANNEL 17 - 462.6500 MHz
- CHANNEL 18 - 462.6250 MHz
- CHANNEL 19 - 462.6000 MHz
- Channels 0-19 will use code A, code B or code C. All intercoms in a given system must be set to the same group code. As with the FTAN40A and FTAN10A...more recent versions may use different sets of CTCSS tones or DCS codes for anti-interference codes A, B and C. Newer versions also appear to alternate between anti-interference codes for each channel.
- CHANNEL 0 - 467.6125 MHz
- CHANNEL 1 - 462.7250 MHz
- Code A - 754 DCS / 754 DPL
- Code B - 743 DCS / 743 DPL
- Code C - 734 DCS / 734 DPL
- GROUP CALL - 467.7125 MHz 743 DCS / 743 DPL - systemwide calling frequency and code (FRS channel 14)
- CHANNEL 10 - 467.6125 MHz
- CHANNEL 11 - 467.6375 MHz
- CHANNEL 12 - 467.6625 MHz
- CHANNEL 13 - 467.6875 MHz
- CHANNEL 14 - 467.7125 MHz
- CHANNEL 15 - 462.5500 MHz
- CHANNEL 16 - 462.5750 MHz
- CHANNEL 17 - 462.6000 MHz
- CHANNEL 19 - 462.6500 MHz
- CHANNEL 20 - 462.6750 MHz
- CHANNEL 21 - 462.7000 MHz
- CHANNEL 22 - 462.5625 MHz
- Code 01 - 754 DCS / 754 DPL
- Code 02 - 743 DCS / 743 DPL
- Code 03 - 734 DCS / 734 DPL
- Code 04 - 77.0 Hz PL
- Code 05 - 79.7 Hz PL
- Code 06 - 82.5 Hz PL
- Code 07 - 85.4 Hz PL
- Code 08 - 88.5 Hz PL
- Code 09 - 91.5 Hz PL
- Code 10 - 94.8 Hz PL
- Code 11 - 97.4 Hz PL
- Code 12 - 100.0 Hz PL
- Code 13 - 103.5 Hz PL
- Code 14 - 107.2 Hz PL
- Code 15 - 110.9 Hz PL
- Code 16 - 114.8 Hz PL
- Code 17 - 118.8 Hz PL
- Code 18 - 123.0 Hz PL
- Code 19 - 127.3 Hz PL
- Code 20 - 131.8 Hz PL
- Code 21 - 136.5 Hz PL
- Code 22 - 141.3 Hz PL
- Code 23 - 146.2 Hz PL
- Code 24 - 151.4 Hz PL
- Code 25 - 156.7 Hz PL
- Code 26 - 162.2 Hz PL
- Code 27 - 167.9 Hz PL
- Code 28 - 173.8 Hz PL
- Code 29 - 179.9 Hz PL
- Code 30 - 186.2 Hz PL
- Code 31 - 192.8 Hz PL
- Code 32 - 203.5 Hz PL
- Code 33 - 210.7 Hz PL
- Code 34 - 218.1 Hz PL
- Code 35 - 225.7 Hz PL
- Code 36 - 233.6 Hz PL
- Code 37 - 241.8 Hz PL
- Code 38 - 250.3 Hz PL
- Code 39 - 023 DCS
- Code 40 - 025 DCS
- Code 41 - 026 DCS
- Code 42 - 031 DCS
- Code 43 - 032 DCS
- Code 44 - 043 DCS
- Code 45 - 047 DCS
- Code 46 - 051 DCS
- Code 47 - 054 DCS
- Code 48 - 065 DCS
- Code 49 - 071 DCS
- Code 50 - 072 DCS
- Code 51 - 073 DCS
- Code 52 - 074 DCS
- Code 53 - 114 DCS
- Code 54 - 115 DCS
- Code 55 - 116 DCS
- Code 56 - 125 DCS
- Code 57 - 131 DCS
- Code 58 - 132 DCS
- Code 59 - 143 DCS
- Code 60 - 143 DCS
- Code 61 - 152 DCS
- Code 62 - 155 DCS
- Code 63 - 156 DCS
- Code 64 - 162 DCS
- Code 65 - 165 DCS
- Code 66 - 172 DCS
- Code 67 - 174 DCS
- Code 68 - 205 DCS
- Code 69 - 223 DCS
- Code 70 - 226 DCS
- Code 71 - 243 DCS
- Code 72 - 244 DCS
- Code 73 - 245 DCS
- Code 74 - 251 DCS
- Code 75 - 261 DCS
- Code 76 - 263 DCS
- Code 77 - 265 DCS
- Code 78 - 271 DCS
- Code 79 - 306 DCS
- Code 80 - 311 DCS
- Code 81 - 315 DCS
- Code 82 - 331 DCS
- Code 83 - 343 DCS
- Code 84 - 346 DCS
- Code 85 - 351 DCS
- Code 86 - 364 DCS
- Code 87 - 365 DCS
- Code 88 - 371 DCS
- Code 89 - 411 DCS
- Code 90 - 412 DCS
- Code 91 - 413 DCS
- Code 92 - 423 DCS
- Code 93 - 431 DCS
- Code 94 - 432 DCS
- Code 95 - 445 DCS
- Code 96 - 464 DCS
- Code 97 - 465 DCS
- Code 98 - 466 DCS
- Code 99 - 503 DCS
- MaxTone 4 channel FM wireless intercom
FCC ID: 2AOXE-SK1204 - Heyuan SunKeungFung Technology LTD
340mw power output, 6K00F3E / 6K01F3E emission. User must set all intercoms to Group Code A, Group Code B or Group Code C
- MaxTone 8 channel FM wireless intercom
FCC ID: 2AOXE-SK1208 - Heyuan SunKeungFung Technology LTD
- MaxTone 6 channel FM wireless intercom
FCC ID: 2AOXE-SK12V6 - Heyuan SunKeungFung Technology LTD
365mw power output, 9K39F3E emission. User must set all intercoms to Group Code A, Group Code B or Group Code C
FRS and GMRS In Canada
The FRS frequencies are legal to use in Canada as well. Canadian regulations specifically permit use of CTCSS, DCS and similar selective calling and anti-interference systems. Audio tone transmissions are allowed, but may not transmit for periods exceeding 15 seconds. Mirroring US regulations, digital data transmissions are allowed on FRS in Canada. Data transmissions may not exceed 1 second and shall be limited to one transmission within a given 30 second period, unless a FRS/GMRS unit is responding to more than one interrogation request ("ping") from another FRS/GMRS unit within a given 30 second period. Digital transmissions on the FRS frequencies may consist of text messages, chat messages, GPS location information or requests for text messages, GPS location information and/or in-range "pings" (transponder function) to automatically verify that another FRS/GMRS unit is within range.
Just like with the FRS service in the United States, the antenna must be fixed to the FRS unit itself. Effective radiated power (ERP) is limited to 2 watts on channels 1-7 and 15-22. ERP is limited to 0.5 W (500mW) on channels 8-14 (just like the FRS regulations in the USA).
5 kHz deviation (16K0F3E emission or regular land mobile FM) is permitted on channels 1-7 and 15-22. NFM (2.5 kHz deviation) is permitted on all 22 FRS channels in Canada just like in the United States.
2.5 kHz deviation (11K0F3E emission or narrowband narrow mode NFM) is required on channels 8-14.
FRS/GMRS frequencies in Canada:
- Military Intra-Squad Radio - intended to be the "military FRS" - identical except using military frequencies in the 380-400 MHz band
- Taiwan FRS - Variant of the FRS service (467 MHz only) only legal in Taiwan
![](/wiki/images/thumb/6/6c/FRS.jpeg/400px-FRS.jpeg)
