Revision as of 20:41, 22 June 2023 by R4002 (Talk | contribs)
FM voice bandwidth 25 kHz permitted under FCC regulations. Emission designators 20K0F3E and 16K0F3E are common for FM voice, 20K0F3D and 16K0F3D for DTMF and other tone-modulated signaling and alerting systems are also commonly found. The 25.02 MHz - 25.32 MHz band, 27.43 MHz - 27.53 MHz band and 29.71 MHz - 29.79 MHz band are shared with marine mobile, the fixed service, mobile service, land mobile, CB radio bands and 27 MHz marine radio, 29 MHz CB and marine services or fishery radio services (in other countries), paging systems, telemetry (fixed/mobile) systems. The 27.500 MHz to 39.475 MHz band (25 kHz steps, or in some implementations, 12.5 kHz steps, FM or NFM) is used throughout Asia for fishery radio communications, ship to ship and ship to shore. This service was originally designed in China but has spread throughout Asia. Usually referred to as "FM Fishery Radiotelephone" or "Dedicated Fishing Boat Radio-telephone" The 25 kHz step (480 channel) version is the most commonly used. No CTCSS or DCS tone squelch or coded squelch is uses on the "Dedicated Fishery Radio" or "Asian Fishery Radio" service. In other words, it is carrier squelch (CSQ) only. Due to the significant overlap (up to the 39 MHz band) that this service has with VHF low band, it is worthy of mentioning here.
25.160 MHz
25.200 MHz
25.240 MHz
25.280 MHz
25.320 MHz
27.430 MHz
27.450 MHz
27.470 MHz
27.490 MHz Itinerant use only
29.710 MHz
44.420 MHz
72.080 MHz
72.160 MHz
72.240 MHz
72.320 MHz
72.400 MHz
150.8225 MHz
150.8375 MHz
152.4725 MHz
154.4825 MHz
154.490 MHz
154.4975 MHz
154.540 MHz
154.5475 MHz
157.7325 MHz
158.4525 MHz
158.460 MHz
173.2375 MHz
173.250 MHz
173.2625 MHz
173.275 MHz
173.2875 MHz
173.300 MHz
173.3125 MHz
173.325 MHz
173.3375 MHz
173.350 MHz
173.3625 MHz
173.390 MHz
UHF Band 406-413 MHz
  • 451.18125 MHz
  • 451.1875 MHz
  • 451.19375 MHz
  • 451.28125 MHz
  • 451.2875 MHz
  • 451.29375 MHz
  • 451.30625 MHz
  • 451.3125 MHz
  • 451.31875 MHz
  • 451.35625 MHz
  • 451.3625 MHz
  • 451.36875 MHz
  • 451.38125 MHz
  • 451.3875 MHz
  • 451.39375 MHz
  • 451.40625 MHz
  • 451.41875 MHz
  • 451.45625 MHz
  • 451.4625 MHz
  • 451.46875 MHz
  • 451.48125 MHz
  • 451.4875 MHz
  • 451.49375 MHz
  • 451.50625 MHz
  • 451.5125 MHz
  • 451.51875 MHz
  • 451.55625 MHz
  • 451.5625 MHz
  • 451.56875 MHz
  • 451.58125 MHz
  • 451.5875 MHz
  • 451.59375 MHz
  • 451.60625 MHz
  • 451.6125 MHz
  • 451.61875 MHz
  • 451.65625 MHz
  • 451.6625 MHz
  • 451.66875 MHz
  • 451.68125 MHz
  • 451.6875 MHz
  • 451.69375 MHz
  • 451.70625 MHz
  • 451.7125 MHz
  • 451.71875 MHz
  • 451.73125 MHz
  • 451.7375 MHz
  • 451.74375 MHz
  • 451.75625 MHz
  • 451.7625 MHz
  • 451.76875 MHz
  • 452.03125 MHz
  • 452.0375 MHz
  • 452.04375 MHz
  • 452.05625 MHz
  • 452.0625 MHz
  • 452.06875 MHz
  • 452.08125 MHz
  • 452.0875 MHz
  • 452.09375 MHz
  • 452.10625 MHz
  • 452.1125 MHz
  • 452.11875 MHz
  • 452.13125 MHz
  • 452.1375 MHz
  • 452.14375 MHz
  • 452.15625 MHz
  • 452.1625 MHz
  • 452.16875 MHz
  • 452.18125 MHz
  • 452.1875 MHz
  • 452.19375 MHz
  • 452.28125 MHz
  • 452.2875 MHz
  • 452.29375 MHz
  • 452.48125 MHz
  • 452.4875 MHz
  • 452.49375 MHz
  • 452.53125 MHz
  • 452.5375 MHz
  • 452.54375 MHz
  • 452.63125 MHz
  • 452.6375 MHz
  • 452.64375 MHz
  • 452.65625 MHz
  • 452.6625 MHz
  • 452.66875 MHz
  • 452.68125 MHz
  • 452.6875 MHz
  • 452.69375 MHz
  • 452.70625 MHz
  • 452.7125 MHz
  • 452.71875 MHz
  • 452.78125 MHz
  • 452.7875 MHz
  • 452.79375 MHz
  • 452.80625 MHz
  • 452.8125 MHz
  • 452.81875 MHz
  • 452.83125 MHz
  • 452.8375 MHz
  • 452.84375 MHz
  • 452.88125 MHz
  • 452.8875 MHz
  • 452.89375 MHz
  • 452.98125 MHz
  • 452.9875 MHz
  • 452.99375 MHz
  • 456.18125 MHz
  • 456.1875 MHz
  • 456.19375 MHz
  • 456.28125 MHz
  • 456.2875 MHz
  • 456.29375 MHz
  • 456.30625 MHz
  • 456.3125 MHz
  • 456.31875 MHz
  • 456.35625 MHz
  • 456.3625 MHz
  • 456.36875 MHz
  • 456.38125 MHz
  • 456.3875 MHz
  • 456.39375 MHz
  • 456.40625 MHz
  • 456.41875 MHz
  • 456.45625 MHz
  • 456.4625 MHz
  • 456.46875 MHz
  • 456.48125 MHz
  • 456.4875 MHz
  • 456.49375 MHz
  • 456.50625 MHz
  • 456.5125 MHz
  • 456.51875 MHz
  • 456.55625 MHz
  • 456.5625 MHz
  • 456.56875 MHz
  • 456.58125 MHz
  • 456.5875 MHz
  • 456.59375 MHz
  • 456.60625 MHz
  • 456.6125 MHz
  • 456.61875 MHz
  • 456.65625 MHz
  • 456.6625 MHz
  • 456.66875 MHz
  • 456.68125 MHz
  • 456.6875 MHz
  • 456.69375 MHz
  • 456.70625 MHz
  • 456.7125 MHz
  • 456.71875 MHz
  • 456.73125 MHz
  • 456.7375 MHz
  • 456.74375 MHz
  • 456.75625 MHz
  • 456.7625 MHz
  • 456.76875 MHz
  • 457.03125 MHz
  • 457.0375 MHz
  • 457.04375 MHz
  • 457.05625 MHz
  • 457.0625 MHz
  • 457.06875 MHz
  • 457.08125 MHz
  • 457.0875 MHz
  • 457.09375 MHz
  • 457.10625 MHz
  • 457.1125 MHz
  • 457.11875 MHz
  • 457.13125 MHz
  • 457.1375 MHz
  • 457.14375 MHz
  • 457.15625 MHz
  • 457.1625 MHz
  • 457.16875 MHz
  • 457.18125 MHz
  • 457.1875 MHz
  • 457.19375 MHz
  • 457.28125 MHz
  • 457.2875 MHz
  • 457.29375 MHz
  • 457.48125 MHz
  • 457.4875 MHz
  • 457.49375 MHz
  • 457.63125 MHz
  • 457.6375 MHz
  • 457.64375 MHz
  • 457.65625 MHz
  • 457.6625 MHz
  • 457.66875 MHz
  • 457.68125 MHz
  • 457.6875 MHz
  • 457.69375 MHz
  • 457.70625 MHz
  • 457.7125 MHz
  • 457.71875 MHz
  • 457.78125 MHz
  • 457.7875 MHz
  • 457.79375 MHz
  • 457.80625 MHz
  • 457.8125 MHz
  • 457.81875 MHz
  • 457.83125 MHz
  • 457.8375 MHz
  • 457.84375 MHz
  • 457.88125 MHz
  • 457.8875 MHz
  • 457.89375 MHz
  • 457.98125 MHz
  • 457.9875 MHz
  • 457.99375 MHz
  • 462.18125 MHz
  • 462.1875 MHz
  • 462.19375 MHz
  • 462.45625 MHz
  • 462.4625 MHz
  • 462.46875 MHz
  • 462.48125 MHz
  • 462.4875 MHz
  • 462.49375 MHz
  • 462.50625 MHz
  • 462.5125 MHz
  • 462.51875 MHz
  • 467.18125 MHz
  • 467.1875 MHz
  • 467.19375 MHz
  • 467.45625 MHz
  • 467.4625 MHz
  • 467.46875 MHz
  • 467.48125 MHz
  • 467.4875 MHz
  • 467.49375 MHz
  • 467.50625 MHz
  • 467.5125 MHz
  • 467.51875 MHz
  • 451.23125 MHz
  • 451.2375 MHz
  • 451.24375 MHz
  • 451.33125 MHz
  • 451.3375 MHz
  • 451.34375 MHz
  • 451.43125 MHz
  • 451.4375 MHz
  • 451.44375 MHz
  • 451.53125 MHz
  • 451.5375 MHz
  • 451.54375 MHz
  • 451.63125 MHz
  • 451.6375 MHz
  • 451.64375 MHz
  • 452.30625 MHz
  • 452.3125 MHz
  • 452.31875 MHz
  • 452.40625 MHz
  • 452.4125 MHz
  • 452.41875 MHz
  • 452.50625 MHz
  • 452.5125 MHz
  • 452.51875 MHz
  • 452.75625 MHz
  • 452.7625 MHz
  • 452.76875 MHz
  • 452.85625 MHz
  • 452.8625 MHz
  • 452.86875 MHz
  • 456.23125 MHz
  • 456.2375 MHz
  • 456.24375 MHz
  • 456.33125 MHz
  • 456.3375 MHz
  • 456.34375 MHz
  • 456.43125 MHz
  • 456.4375 MHz
  • 456.44375 MHz
  • 456.53125 MHz
  • 456.5375 MHz
  • 456.54375 MHz
  • 456.63125 MHz
  • 456.6375 MHz
  • 456.64375 MHz
  • 457.30625 MHz
  • 457.3125 MHz
  • 457.31875 MHz
  • 457.40625 MHz
  • 457.4125 MHz
  • 457.41875 MHz
  • 457.50625 MHz
  • 457.5125 MHz
  • 457.51875 MHz
  • 457.75625 MHz
  • 457.7625 MHz
  • 457.76875 MHz
  • 457.85625 MHz
  • 457.8625 MHz
  • 457.86875 MHz
  • 462.20625 MHz
  • 462.2125 MHz
  • 462.21875 MHz
  • 462.23125 MHz
  • 462.2375 MHz
  • 462.24375 MHz
  • 462.25625 MHz
  • 462.2625 MHz
  • 462.26875 MHz
  • 462.28125 MHz
  • 462.2875 MHz
  • 462.29375 MHz
  • 462.30625 MHz
  • 462.3125 MHz
  • 462.31875 MHz
  • 462.33125 MHz
  • 462.3375 MHz
  • 462.34375 MHz
  • 462.35625 MHz
  • 462.3625 MHz
  • 462.36875 MHz
  • 462.38125 MHz
  • 462.3875 MHz
  • 462.39375 MHz
  • 462.40625 MHz
  • 462.4125 MHz
  • 462.41875 MHz
  • 462.43125 MHz
  • 462.4375 MHz
  • 462.44375 MHz
  • 467.20625 MHz
  • 467.2125 MHz
  • 467.21875 MHz
  • 467.23125 MHz
  • 467.2375 MHz
  • 467.24375 MHz
  • 467.25625 MHz
  • 467.2625 MHz
  • 467.26875 MHz
  • 467.28125 MHz
  • 467.2875 MHz
  • 467.29375 MHz
  • 467.30625 MHz
  • 467.3125 MHz
  • 467.31875 MHz
  • 467.33125 MHz
  • 467.3375 MHz
  • 467.34375 MHz
  • 467.35625 MHz
  • 467.3625 MHz
  • 467.36875 MHz
  • 467.38125 MHz
  • 467.3875 MHz
  • 467.39375 MHz
  • 467.40625 MHz
  • 467.4125 MHz
  • 467.41875 MHz
  • 467.43125 MHz
  • 467.4375 MHz
  • 467.44375 MHz
  • 461.03125 MHz
  • 461.0375 MHz
  • 461.04375 MHz
  • 461.05625 MHz
  • 461.0625 MHz
  • 461.06875 MHz
  • 461.08125 MHz
  • 461.0875 MHz
  • 461.09375 MHz
  • 461.10625 MHz
  • 461.1125 MHz
  • 461.11875 MHz
  • 461.13125 MHz
  • 461.1375 MHz
  • 461.14375 MHz
  • 461.15625 MHz
  • 461.1625 MHz
  • 461.16875 MHz
  • 461.18125 MHz
  • 461.1875 MHz
  • 461.19375 MHz
  • 461.20625 MHz
  • 461.2125 MHz
  • 461.21875 MHz
  • 461.23125 MHz
  • 461.2375 MHz
  • 461.24375 MHz
  • 461.25625 MHz
  • 461.2625 MHz
  • 461.26875 MHz
  • 461.28125 MHz
  • 461.2875 MHz
  • 461.29375 MHz
  • 461.30625 MHz
  • 461.3125 MHz
  • 461.31875 MHz
  • 461.33125 MHz
  • 461.3375 MHz
  • 461.34375 MHz
  • 461.35625 MHz
  • 461.3625 MHz
  • 461.36875 MHz
  • 462.7625 MHz
  • 462.7875 MHz
  • 462.8125 MHz
  • 462.8375 MHz
  • 462.8625 MHz
  • 462.8875 MHz
  • 462.9125 MHz
  • 464.4875 MHz
  • 464.48125 MHz
  • 464.5125 MHz
  • 464.51875 MHz
  • 464.53125 MHz
  • 464.5375 MHz
  • 464.5625 MHz
  • 464.56875 MHz
  • 466.03125 MHz
  • 466.0375 MHz
  • 466.04375 MHz
  • 466.05625 MHz
  • 466.0625 MHz
  • 466.06875 MHz
  • 466.08125 MHz
  • 466.0875 MHz
  • 466.09375 MHz
  • 466.10625 MHz
  • 466.1125 MHz
  • 466.11875 MHz
  • 466.13125 MHz
  • 466.1375 MHz
  • 466.14375 MHz
  • 466.15625 MHz
  • 466.1625 MHz
  • 466.16875 MHz
  • 466.18125 MHz
  • 466.1875 MHz
  • 466.19375 MHz
  • 466.20625 MHz
  • 466.2125 MHz
  • 466.21875 MHz
  • 466.23125 MHz
  • 466.2375 MHz
  • 466.24375 MHz
  • 466.25625 MHz
  • 466.2625 MHz
  • 466.26875 MHz
  • 466.28125 MHz
  • 466.2875 MHz
  • 466.29375 MHz
  • 466.30625 MHz
  • 466.3125 MHz
  • 466.31875 MHz
  • 466.33125 MHz
  • 466.3375 MHz
  • 466.34375 MHz
  • 466.35625 MHz
  • 466.3625 MHz
  • 466.36875 MHz
  • 467.8625 MHz
  • 467.8875 MHz
  • 467.9125 MHz
  • 469.4875 MHz
  • 469.48125 MHz
  • 469.5125 MHz
  • 469.51875 MHz
  • 469.53125 MHz
  • 469.5375 MHz
  • 469.5625 MHz
  • 469.56875 MHz
  • 460.90625 MHz
  • 460.9125 MHz
  • 460.91875 MHz
  • 460.93125 MHz
  • 460.9375 MHz
  • 460.94375 MHz
  • 460.95625 MHz
  • 460.9625 MHz
  • 460.96875 MHz
  • 460.98125 MHz
  • 460.9875 MHz
  • 460.99375 MHz
  • 461.00625 MHz
  • 461.0125 MHz
  • 461.01875 MHz
  • 465.90625 MHz
  • 465.9125 MHz
  • 465.91875 MHz
  • 465.93125 MHz
  • 465.9375 MHz
  • 465.94375 MHz
  • 465.95625 MHz
  • 465.9625 MHz
  • 465.96875 MHz
  • 465.98125 MHz
  • 465.9875 MHz
  • 465.99375 MHz
  • 466.00625 MHz
  • 466.0125 MHz
  • 466.01875 MHz
  • one set of 68 channel pairs
  • 160 available channel pairs
  • 22 available channel pairs
  • 151.5125 MHz - Itinerant
  • 151.6550 MHz
  • 151.6850 MHz
  • 151.7150 MHz
  • 151.7450 MHz
  • 151.7750 MHz
  • 151.8050 MHz
  • 151.8350 MHz
  • 151.8650 MHz
  • 151.8950 MHz
  • 151.9250 MHz
  • 151.9550 MHz - Purple Dot
  • 152.8850 MHz
  • 152.9000 MHz
  • 152.9150 MHz
  • 152.9450 MHz
  • 153.0050 MHz
  • 154.4900 MHz
  • 154.5150 MHz
  • 154.5400 MHz
  • 154.5475 MHz
  • 158.4000 MHz - Itinerant
  • 158.4075 MHz - Itinerant
  • 451.1875 MHz
  • 451.2375 MHz
  • 451.2875 MHz
  • 451.3125 MHz
  • 451.3375 MHz
  • 451.3625 MHz
  • 451.3875 MHz
  • 451.4375 MHz
  • 451.4625 MHz
  • 451.4875 MHz
  • 451.5125 MHz
  • 451.5375 MHz
  • 451.5625 MHz
  • 451.5875 MHz
  • 451.6125 MHz
  • 451.6375 MHz
  • 451.6625 MHz
  • 451.6875 MHz
  • 451.7125 MHz
  • 451.7375 MHz
  • 451.7625 MHz
  • 452.0375 MHz
  • 452.0625 MHz
  • 452.0875 MHz
  • 452.1125 MHz
  • 452.1375 MHz
  • 452.1625 MHz
  • 452.1875 MHz
  • 452.2875 MHz
  • 452.3125 MHz
  • 452.4125 MHz
  • 452.4875 MHz
  • 452.5125 MHz
  • 452.5375 MHz
  • 452.6375 MHz
  • 452.6625 MHz
  • 452.6875 MHz
  • 452.7125 MHz
  • 452.7625 MHz
  • 452.7875 MHz
  • 452.8125 MHz
  • 452.8375 MHz
  • 452.8625 MHz
  • 452.8875 MHz
  • 452.9875 MHz
  • 456.1875 MHz
  • 456.2375 MHz
  • 456.2875 MHz
  • 456.3125 MHz
  • 456.3375 MHz
  • 456.3625 MHz
  • 456.3875 MHz
  • 456.4375 MHz
  • 456.4625 MHz
  • 456.4875 MHz
  • 456.5125 MHz
  • 456.5375 MHz
  • 456.5625 MHz
  • 456.5875 MHz
  • 456.6125 MHz
  • 456.6375 MHz
  • 456.6625 MHz
  • 456.6875 MHz
  • 456.7125 MHz
  • 456.7375 MHz
  • 456.7625 MHz
  • 457.0375 MHz
  • 457.0625 MHz
  • 457.0875 MHz
  • 457.1125 MHz
  • 457.1375 MHz
  • 457.1625 MHz
  • 457.1875 MHz
  • 457.2875 MHz
  • 457.3125 MHz
  • 457.4125 MHz
  • 457.4875 MHz
  • 457.5125 MHz
  • 457.6375 MHz
  • 457.6625 MHz
  • 457.7125 MHz
  • 457.7375 MHz
  • 457.7625 MHz
  • 457.7875 MHz
  • 457.8125 MHz
  • 457.8375 MHz
  • 457.8625 MHz
  • 457.8875 MHz
  • 457.9875 MHz
  • 461.0375 MHz
  • 461.0625 MHz
  • 461.0875 MHz
  • 461.1125 MHz
  • 461.1375 MHz
  • 461.1625 MHz
  • 461.1875 MHz
  • 461.2125 MHz
  • 461.2375 MHz
  • 461.2625 MHz
  • 461.2875 MHz
  • 461.3125 MHz
  • 461.3375 MHz
  • 461.3625 MHz
  • 462.1875 MHz
  • 462.4625 MHz
  • 462.4875 MHz
  • 462.5125 MHz
  • 464.4875 MHz - Itinerant
  • 464.5125 MHz - Itinerant
  • 464.5375 MHz - Itinerant
  • 464.5625 MHz - Itinerant
  • 464.6000 MHz - Wireless clocks and 5 watt or 25 watt on-site paging systems (POCSAG)
  • 464.6250 MHz - Wireless clocks and 5 watt or 25 watt on-site paging systems (POCSAG)
  • 464.6500 MHz - Wireless clocks and 5 watt or 25 watt on-site paging systems (POCSAG)
  • 464.7000 MHz - Wireless clocks and 5 watt or 25 watt on-site paging systems (POCSAG)
  • 464.7250 MHz - Wireless clocks and 5 watt or 25 watt on-site paging systems (POCSAG)
  • 464.7500 MHz - Wireless clocks and 5 watt or 25 watt on-site paging systems (POCSAG)
  • 466.0375 MHz
  • 466.0625 MHz
  • 466.0875 MHz
  • 466.1125 MHz
  • 466.1375 MHz
  • 466.1625 MHz
  • 466.1875 MHz
  • 466.2125 MHz
  • 466.2375 MHz
  • 466.2625 MHz
  • 466.2875 MHz
  • 466.3125 MHz
  • 466.3375 MHz
  • 466.3625 MHz
  • 467.1875 MHz
  • 467.4625 MHz
  • 467.4875 MHz
  • 467.5125 MHz
  • 467.7875 MHz - 2 watts
  • 467.8375 MHz - 2 watts
  • 467.8875 MHz - 2 watts
  • 467.9125 MHz - 2 watts
  • 468.2125 MHz
  • 468.2625 MHz
  • 468.3125 MHz
  • 468.3375 MHz
  • 468.3625 MHz
  • 468.4125 MHz
  • 468.4625 MHz
  • 468.5125 MHz
  • 468.5625 MHz
  • 468.5875 MHz
  • 468.6125 MHz
  • 468.6375 MHz
  • 468.6625 MHz
  • 469.4875 MHz - Itinerant
  • 469.5125 MHz - Itinerant
  • 469.5375 MHz - Itinerant
  • 469.5625 MHz - Itinerant
  • 464.5500 MHz
  • 464.5000 MHz
  • 467.9250 MHz
  • 467.9000 MHz
  • 467.8750 MHz
  • 467.8500 MHz
  • 469.5500 MHz
  • 469.5000 MHz
  • 461.0375 MHz
  • 461.1125 MHz
  • 461.1375 MHz
  • 461.2375 MHz
  • 467.8125 MHz
  • 467.7625 MHz
  • 451.8000 MHz
  • 456.8000 MHz
  • 451.8125 MHz
  • 456.8125 MHz
  • 151.6250 MHz
  • 154.5700 MHz
  • 154.6000 MHz
  • 151.9550 MHz
  • 151.5125 MHz
  • 151.5050 MHz
  • 151.7000 MHz
  • 151.7600 MHz
  • 151.8200 MHz
  • 151.9400 MHz
  • 151.8800 MHz
  • 151.9250 MHz
  • 151.8050 MHz
  • 158.4000 MHz
  • 158.4075 MHz
  • 151.6550 MHz
  • 151.8650 MHz
  • 152.9000 MHz
  • Frequency 151.625 MHz
  • Frequency 151.655 MHz
  • Frequency 151.685 MHz
  • Freqyency 151.715 MHz
  • Frequency 151.775 MHz
  • Frequency 151.835 MHz
  • Frequency 151.895 MHz
  • Frequency 151.925 MHz
  • Frequency 151.955 MHz
  • Frequency 154.490 MHz
  • Frequency 154.515 MHz
  • Frequency 154.540 MHz
  • Frequency 154.570 MHz
  • Frequency 154.600 MHz
  • Frequency 158.400 MHz
  • Frequency - 462.5750 MHz
  • Frequency - 462.6250 MHz
  • Frequency - 462.6750 MHz
  • Frequency - 464.3250 MHz
  • Frequency - 464.5000 MHz
  • Frequency - 464.5500 MHz
  • Frequency - 464.8250 MHz
  • Frequency - 467.7625 MHz
  • Frequency - 467.8125 MHz
  • Frequency - 467.8500 MHz
  • Frequency - 467.8750 MHz
  • Frequency - 467.9000 MHz
  • Frequency - 467.9250 MHz
  • Frequency - 469.2625 MHz
  • Frequency - 469.5000 MHz
  • Frequency - 469.5500 MHz
Motorola Spirit-M VHF radio
Motorola Spirit-M UHF radio
Frequencies
Motorola Sport UHF GMRS radio
  • Channel 8 - 467.5625 MHz
  • Channel 9 - 467.5875 MHz
  • Channel 10 - 467.6125 MHz
  • Channel 11 - 467.6375 MHz
  • Channel 12 - 467.6625 MHz
  • Channel 13 - 467.6875 MHz
  • Channel 14 - 467.7125 MHz
  • Channel 15 - 462.5500 MHz
  • Channel 16 - 462.5750 MHz
  • Channel 17 - 462.6000 MHz
  • Channel 18 - 462.6250 MHz
  • Channel 19 - 462.6500 MHz
  • Channel 20 - 462.6750 MHz
  • Channel 21 - 462.7000 MHz
  • Channel 22 - 462.7250 MHz
This radio model is also sold under the names including the BF-888S family of 16 channel UHF radios and SEODON SED-8. Other brand names include Arcshell AR-6 Walkie Talkie, TIDRADIO UHF walkie talkies with USB charging capability. (other variants with different default frequencies have been noted, including some with 420-450 MHz 70cm amateur frequencies, 450-470 MHz land mobile frequencies and even 406-420 MHz Federal government frequencies as the defaults]. TIDRADIO Two Way Radio Long Range Walkie Talkies for Adults with USB Wall Charger Air Acoustic Earpiece 2 Pack. These radios are extremely similar to the Radioditty GA-2S walkie-talkies. Sold as "FCC walkie talkies" but they are actually only approved as receivers. There are FCC approved variants available too - such as the PO FUNG F-8 16 channel FRS walkie talkie (similar to the Baofeng 88 or BF-88A FRS walkie talkies), as well as Baofeng BF-88ST, Radtel RT-88 RT88 FRS radio, BF-T11, BTECH variants
Radioditty GA-2S
Retevis RT30
Default Channel Frequency
Retevis RT30
Retevis RT30M
  • Channel 15 - 460.3250 CSQ
Retevis RT1-UHF RT1 RT-1
Retevis RT1-VHF RT1 RT-1
  • Channel 1 - 400.1250 MHz
  • Channel 2 - 410.1250 MHz
  • Channel 3 - 420.1250 MHz
  • Channel 4 - 430.1250 MHz
  • Channel 5 - 440.1250 MHz
  • Channel 6 - 450.1250 MHz
  • Channel 7 - 460.1250 MHz
  • Channel 8 - 470.1250 MHz
  • Channel 9 - 480.1250 MHz
  • Channel 10 - 490.1250 MHz
  • Channel 11 - 500.1250 MHz
  • Channel 12 - 510.1250 MHz
  • Channel 13 - 519.9750 MHz
  • Channel 14 - 136.1250 MHz
  • Channel 15 - 145.1250 MHz
  • Channel 16 - 155.1250 MHz
  • Channel 17 - 165.1250 MHz
  • Channel 18 - 173.9750 MHz
  • Freq 9 - 461.0375 MHz
  • Freq 10 - 461.0625 MHz
  • Freq 11 - 461.0875 MHz
  • Freq 12 - 461.1125 MHz
  • Freq 13 - 461.1375 MHz
  • Freq 14 - 461.1625 MHz
  • Freq 15 - 461.1875 MHz
  • Freq 16 - 461.2125 MHz
  • Freq 17 - 461.2375 MHz
  • Freq 18 - 461.2625 MHz
  • Freq 19 - 461.2875 MHz
  • Freq 20 - 461.3125 MHz
  • Freq 21 - 461.3375 MHz
  • Freq 22 - 461.3625 MHz
  • Freq 23 - 462.7625 MHz
  • Freq 24 - 462.7875 MHz
  • Freq 25 - 462.8125 MHz
  • Freq 26 - 462.8375 MHz
  • Freq 27 - 462.8625 MHz
  • Freq 28 - 462.8875 MHz
  • Freq 29 - 462.9125 MHz
  • Freq 30 - 464.4875 MHz
  • Freq 31 - 464.5125 MHz
  • Freq 32 - 464.5375 MHz
  • Freq 33 - 464.5625 MHz
  • Freq 34 - 466.0375 MHz
  • Freq 35 - 466.0625 MHz
  • Freq 36 - 466.0875 MHz
  • Freq 37 - 466.1125 MHz
  • Freq 38 - 466.1375 MHz
  • Freq 39 - 466.1625 MHz
  • Freq 40 - 466.1875 MHz
  • Freq 41 - 466.2125 MHz
  • Freq 42 - 466.2375 MHz
  • Freq 43 - 466.2625 MHz
  • Freq 44 - 466.2875 MHz
  • Freq 45 - 466.3125 MHz
  • Freq 46 - 466.3375 MHz
  • Freq 47 - 466.3625 MHz
  • Freq 48 - 467.7875 MHz
  • Freq 49 - 467.8375 MHz
  • Freq 50 - 467.8625 MHz
  • Freq 51 - 467.8875 MHz
  • Freq 52 - 467.9125 MHz
  • Freq 53 - 469.4875 MHz
  • Freq 54 - 469.5125 MHz
  • Freq 55 - 469.5375 MHz
  • Freq 56 - 469.5625 MHz
  • Freq 9 - 462.5750 MHz
  • Freq 10 - 462.6250 MHz
  • Freq 11 - 462.6750 MHz
  • Freq 12 - 464.3250 MHz
  • Freq 13 - 464.8250 MHz
  • Freq 14 - 469.2625 MHz
  • Freq 15 - 469.5000 MHz
  • Freq 16 - 469.5500 MHz
  • Freq 17 - 462.7625 MHz
  • Freq 18 - 462.7875 MHz
  • Freq 19 - 462.8125 MHz
  • Freq 20 - 462.8375 MHz
  • Freq 21 - 462.8625 MHz
  • Freq 22 - 462.8875 MHz
  • Freq 23 - 462.9125 MHz
  • Freq 23 - 461.0375 MHz
  • Freq 25 - 461.0625 MHz
  • Freq 26 - 461.0875 MHz
  • Freq 27 - 461.1125 MHz
  • Freq 28 - 461.1375 MHz
  • Freq 29 - 461.1625 MHz
  • Freq 30 - 461.1875 MHz
  • Freq 31 - 461.2125 MHz
  • Freq 32 - 461.2375 MHz
  • Freq 33 - 461.2625 MHz
  • Freq 34 - 461.2875 MHz
  • Freq 35 - 461.3125 MHz
  • Freq 36 - 461.3375 MHz
  • Freq 37 - 461.3625 MHz
  • Freq 38 - 467.7875 MHz
  • Freq 39 - 467.8375 MHz
  • Freq 40 - 467.8625 MHz
  • Freq 41 - 467.8875 MHz
  • Freq 42 - 467.9125 MHz
  • Freq 43 - 464.4875 MHz
  • Freq 44 - 464.5125 MHz
  • Freq 45 - 464.5375 MHz
  • Freq 46 - 464.5625 MHz
  • Freq 47 - 466.0375 MHz
  • Freq 48 - 466.0625 MHz
  • Freq 49 - 466.0875 MHz
  • Freq 50 - 466.1125 MHz
  • Freq 51 - 466.1375 MHz
  • Freq 52 - 466.1625 MHz
  • Freq 53 - 466.1875 MHz
  • Freq 54 - 466.2125 MHz
  • Freq 55 - 466.2375 MHz
  • Freq 56 - 466.2625 MHz
  • Freq 1 - 151.6250 MHz
  • Freq 2 - 151.9550 MHz
  • Freq 3 - 154.5700 MHz
  • Freq 4 - 154.6000 MHz
  • Freq 5 - 151.7000 MHz
  • Freq 6 - 151.7600 MHz
  • Freq 7 - 151.8200 MHz
  • Freq 8 - 151.8800 MHz
  • Freq 9 - 151.9400 MHz
  • Freq 10 - 151.5125 MHz
  • Freq 11 - 151.6550 MHz
  • Freq 12 - 151.6850 MHz
  • Freq 13 - 151.7150 MHz
  • Freq 14 - 151.7450 MHz
  • Freq 15 - 151.7750 MHz
  • Freq 16 - 151.8650 MHz
  • Freq 17 - 151.8950 MHz
  • Freq 18 - 151.9250 MHz
  • Freq 20 - 154.4900 MHz
  • Freq 21 - 154.5150 MHz
  • Freq 22 - 154.5275 MHz
  • Freq 23 - 154.5400 MHz
  • Freq 24 - 154.6000 MHz
  • Freq 26 - 158.4000 MHz
  • Freq 27 - 158.4075 MHz
  • Freq 57 - 462.1875 MHz
  • Freq 58 - 462.4625 MHz
  • Freq 59 - 462.4875 MHz
  • Freq 60 - 462.5125 MHz
  • Freq 61 - 467.1875 MHz
  • Freq 62 - 467.4625 MHz
  • Freq 63 - 467.4875 MHz
  • Freq 64 - 467.5125 MHz
  • Freq 65 - 451.1875 MHz
  • Freq 66 - 451.2375 MHz
  • Freq 67 - 451.2875 MHz
  • Freq 68 - 451.3375 MHz
  • Freq 69 - 451.4375 MHz
  • Freq 70 - 451.5375 MHz
  • Freq 71 - 451.6375 MHz
  • Freq 72 - 452.3125 MHz
  • Freq 73 - 452.5375 MHz
  • Freq 74 - 452.4125 MHz
  • Freq 75 - 452.5125 MHz
  • Freq 76 - 452.7625 MHz
  • Freq 77 - 452.8625 MHz
  • Freq 78 - 456.1875 MHz
  • Freq 79 - 456.2375 MHz
  • Freq 80 - 456.2875 MHz
  • Freq 81 - 468.2125 MHz
  • Freq 82 - 468.2625 MHz
  • Freq 83 - 468.3125 MHz
  • Freq 84 - 468.3625 MHz
  • Freq 85 - 468.4125 MHz
  • Freq 86 - 468.4625 MHz
  • Freq 87 - 468.5125 MHz
  • Freq 88 - 468.5625 MHz
  • Freq 89 - 468.6125 MHz
  • Freq 90 - 468.6625 MHz
  • Freq 81 - 456.3375 MHz
  • Freq 82 - 456.4375 MHz
  • Freq 83 - 456.5375 MHz
  • Freq 84 - 456.6375 MHz
  • Freq 85 - 457.3125 MHz
  • Freq 86 - 457.4125 MHz
  • Freq 87 - 457.5125 MHz
  • Freq 88 - 457.7625 MHz
  • Freq 89 - 457.8625 MHz
  • Freq 3 - 152.8850 MHz
  • Freq 4 - 152.9150 MHz
  • Freq 7 - 152.9450 MHz
  • Freq 8 - 151.8350 MHz
  • Freq 9 - 151.8050 MHz
  • Freq 24 - 153.0050 MHz
  • Freq 0 - OFF (BLANK)
  • Code 1 - 67.0 Hz PL - XZ
  • Code 2 - 71.9 Hz PL - XA
  • Code 3 - 74.4 Hz PL - WA
  • Code 4 - 77.0 Hz PL - XB
  • Code 5 - 79.7 Hz PL - WB
  • Code 6 - 82.5 Hz PL - YZ
  • Code 7 - 85.4 Hz PL - YA
  • Code 8 - 88.5 Hz PL - YB
  • Code 9 - 91.5 Hz PL - ZZ
  • Code 10 - 94.8 Hz PL - ZA
  • Code 11 - 97.4 Hz PL - ZB
  • Code 12 - 100.0 Hz PL - 1Z
  • Code 13 - 103.5 Hz PL - 1A
  • Code 14 - 107.2 Hz PL - 1B
  • Code 15 - 110.9 Hz PL - 2Z
  • Code 16 - 114.8 Hz PL - 2A
  • Code 17 - 118.8 Hz PL - 2B
  • Code 18 - 123.0 Hz PL - 3Z
  • Code 19 - 127.3 Hz PL - 3A
  • Code 20 - 131.8 Hz PL - 3B
  • Code 21 - 136.5 Hz PL - 4Z
  • Code 22 - 141.3 Hz PL - 4A
  • Code 23 - 146.2 Hz PL - 4B
  • Code 24 - 151.4 Hz PL - 5Z
  • Code 25 - 156.7 Hz PL - 5A
  • Code 26 - 162.2 Hz PL - 5B
  • Code 27 - 167.9 Hz PL - 6Z
  • Code 28 - 173.8 Hz PL - 6A
  • Code 29 - 179.9 Hz PL - 6B
  • Code 30 - 186.2 Hz PL - 7Z
  • Code 31 - 192.8 Hz PL - 7A
  • Code 32 - 203.5 Hz PL - M1
  • Code 33 - 210.7 Hz PL - M2
  • Code 34 - 218.1 Hz PL - M3
  • Code 35 - 225.7 Hz PL - M4
  • Code 36 - 233.6 Hz PL - M5
  • Code 37 - 241.8 Hz PL - M6
  • Code 38 - 250.3 Hz PL - M7
  • Code 39 - 023 DPL D023N
  • Code 40 - 025 DPL D025N
  • Code 41 - 026 DPL D026N
  • Code 42 - 031 DPL D031N
  • Code 43 - 032 DPL D032N
  • Code 44 - 043 DPL D043N
  • Code 45 - 047 DPL D047N
  • Code 46 - 051 DPL D051N
  • Code 47 - 054 DPL D054N
  • Code 48 - 065 DPL D065N
  • Code 49 - 071 DPL D071N
  • Code 50 - 072 DPL D072N
  • Code 51 - 073 DPL D073N
  • Code 52 - 074 DPL D074N
  • Code 53 - 114 DPL D114N
  • Code 54 - 115 DPL D115N
  • Code 55 - 116 DPL D116N
  • Code 56 - 125 DPL D125N
  • Code 57 - 131 DPL D131N
  • Code 58 - 132 DPL D132N
  • Code 59 - 134 DPL D134N
  • Code 60 - 143 DPL D143N
  • Code 61 - 152 DPL D152N
  • Code 62 - 155 DPL D155N
  • Code 63 - 156 DPL D156N
  • Code 64 - 162 DPL D162N
  • Code 65 - 165 DPL D165N
  • Code 66 - 172 DPL D172N
  • Code 67 - 174 DPL D174N
  • Code 68 - 205 DPL D205N
  • Code 69 - 223 DPL D223N
  • Code 70 - 226 DPL D226N
  • Code 71 - 243 DPL D243N
  • Code 72 - 244 DPL D244N
  • Code 73 - 245 DPL D245N
  • Code 74 - 251 DPL D251N
  • Code 75 - 261 DPL D261N
  • Code 76 - 263 DPL D263N
  • Code 77 - 265 DPL D265N
  • Code 78 - 271 DPL D271N
  • Code 79 - 306 DPL D306N
  • Code 80 - 311 DPL D311N
  • Code 81 - 315 DPL D315N
  • Code 82 - 331 DPL D331N
  • Code 83 - 343 DPL D343N
  • Code 84 - 346 DPL D346N
  • Code 85 - 351 DPL D351N
  • Code 86 - 364 DPL D364N
  • Code 87 - 365 DPL D365N
  • Code 88 - 371 DPL D371N
  • Code 89 - 411 DPL D411N
  • Code 90 - 412 DPL D412N
  • Code 91 - 413 DPL D413N
  • Code 92 - 423 DPL D423N
  • Code 93 - 431 DPL D431N
  • Code 94 - 432 DPL D432N
  • Code 95 - 445 DPL D445N
  • Code 96 - 464 DPL D464N
  • Code 97 - 465 DPL D465N
  • Code 98 - 466 DPL D466N
  • Code 99 - 503 DPL D503N
  • Code 100 - 506 DPL D506N
  • Code 101 - 516 DPL D516N
  • Code 102 - 532 DPL D532N
  • Code 103 - 546 DPL D546N
  • Code 104 - 565 DPL D565N
  • Code 105 - 606 DPL D606N
  • Code 106 - 612 DPL D612N
  • Code 107 - 624 DPL D624N
  • Code 108 - 627 DPL D627N
  • Code 109 - 631 DPL D631N
  • Code 110 - 632 DPL D632N
  • Code 111 - 654 DPL D654N
  • Code 112 - 662 DPL D662N
  • Code 113 - 664 DPL D664N
  • Code 114 - 703 DPL D703N
  • Code 115 - 712 DPL D712N
  • Code 116 - 723 DPL D723N
  • Code 117 - 731 DPL D731N
  • Code 118 - 732 DPL D732N
  • Code 119 - 734 DPL D734N
  • Code 120 - 743 DPL D743N
  • Code 121 - 754 DPL D754N
  • DCS Code 1 - 023 DPL
  • DCS Code 2 - 025 DPL
  • DCS Code 3 - 026 DPL
  • DCS Code 4 - 031 DPL
  • DCS Code 5 - 032 DPL
  • DCS Code 6 - 043 DPL
  • DCS Code 7 - 047 DPL
  • DCS Code 8 - 051 DPL
  • DCS Code 9 - 054 DPL
  • DCS Code 10 - 065 DPL
  • DCS Code 11 - 071 DPL
  • DCS Code 12 - 072 DPL
  • DCS Code 13 - 073 DPL
  • DCS Code 14 - 074 DPL
  • DCS Code 15 - 114 DPL
  • DCS Code 16 - 115 DPL
  • DCS Code 17 - 116 DPL
  • DCS Code 18 - 125 DPL
  • DCS Code 19 - 131 DPL
  • DCS Code 20 - 132 DPL
  • DCS Code 21 - 134 DPL
  • DCS Code 22 - 143 DPL
  • DCS Code 23 - 152 DPL
  • DCS Code 24 - 155 DPL
  • DCS Code 25 - 156 DPL
  • DCS Code 26 - 162 DPL
  • DCS Code 27 - 165 DPL
  • DCS Code 28 - 172 DPL
  • DCS Code 29 - 174 DPL
  • DCS Code 30 - 205 DPL
  • DCS Code 31 - 223 DPL
  • DCS Code 32 - 226 DPL
  • DCS Code 33 - 243 DPL
  • DCS Code 34 - 244 DPL
  • DCS Code 35 - 245 DPL
  • DCS Code 36 - 251 DPL
  • DCS Code 37 - 261 DPL
  • DCS Code 38 - 263 DPL
  • DCS Code 39 - 265 DPL
  • DCS Code 40 - 271 DPL
  • DCS Code 41 - 306 DPL
  • DCS Code 42 - 311 DPL
  • DCS Code 43 - 315 DPL
  • DCS Code 44 - 331 DPL
  • DCS Code 45 - 343 DPL
  • DCS Code 46 - 346 DPL
  • DCS Code 47 - 351 DPL
  • DCS Code 48 - 364 DPL
  • DCS Code 49 - 365 DPL
  • DCS Code 50 - 371 DPL
  • DCS Code 51 - 411 DPL
  • DCS Code 52 - 412 DPL
  • DCS Code 53 - 413 DPL
  • DCS Code 54 - 423 DPL
  • DCS Code 55 - 431 DPL
  • DCS Code 56 - 432 DPL
  • DCS Code 57 - 445 DPL
  • DCS Code 58 - 464 DPL
  • DCS Code 59 - 465 DPL
  • DCS Code 60 - 466 DPL
  • DCS Code 61 - 503 DPL
  • DCS Code 62 - 506 DPL
  • DCS Code 63 - 516 DPL
  • DCS Code 64 - 532 DPL
  • DCS Code 65 - 546 DPL
  • DCS Code 66 - 565 DPL
  • DCS Code 67 - 606 DPL
  • DCS Code 68 - 612 DPL
  • DCS Code 69 - 624 DPL
  • DCS Code 70 - 627 DPL
  • DCS Code 71 - 631 DPL
  • DCS Code 72 - 632 DPL
  • DCS Code 73 - 654 DPL
  • DCS Code 74 - 662 DPL
  • DCS Code 75 - 664 DPL
  • DCS Code 76 - 703 DPL
  • DCS Code 77 - 712 DPL
  • DCS Code 78 - 723 DPL
  • DCS Code 79 - 731 DPL
  • DCS Code 80 - 732 DPL
  • DCS Code 81 - 734 DPL
  • DCS Code 82 - 743 DPL
  • DCS Code 83 - 754 DPL
  • DCS Code 84 - 036 DPL
  • DCS Code 85 - 053 DPL
  • DCS Code 86 - 122 DPL
  • DCS Code 87 - 145 DPL
  • DCS Code 88 - 212 DPL
  • DCS Code 89 - 225 DPL
  • DCS Code 90 - 246 DPL
  • DCS Code 91 - 252 DPL
  • DCS Code 92 - 255 DPL
  • DCS Code 93 - 266 DPL
  • DCS Code 94 - 274 DPL
  • DCS Code 95 - 325 DPL
  • DCS Code 96 - 332 DPL
  • DCS Code 97 - 356 DPL
  • DCS Code 98 - 446 DPL
  • DCS Code 99 - 452 DPL
  • DCS Code 100 - 454 DPL
  • DCS Code 101 - 455 DPL
  • DCS Code 102 - 462 DPL
  • DCS Code 103 - 523 DPL
  • DCS Code 104 - 526 DPL
  • CTCSS Code 1 - 67.0 Hz
  • CTCSS Code 2 - 69.3 Hz
  • CTCSS Code 3 - 71.9 Hz
  • CTCSS Code 4 - 74.4 Hz
  • CTCSS Code 5 - 77.0 Hz
  • CTCSS Code 6 - 79.7 Hz
  • CTCSS Code 7 - 82.5 Hz
  • CTCSS Code 8 - 85.4 Hz
  • CTCSS Code 9 - 88.5 Hz
  • CTCSS Code 10 - 91.5 Hz
  • CTCSS Code 11 - 94.8 Hz
  • CTCSS Code 12 - 97.4 Hz
  • CTCSS Code 13 - 100.0 Hz
  • CTCSS Code 14 - 103.5 Hz
  • CTCSS Code 15 - 107.2 Hz
  • CTCSS Code 16 - 110.9 Hz
  • CTCSS Code 17 - 114.8 Hz
  • CTCSS Code 18 - 118.8 Hz
  • CTCSS Code 19 - 123.0 Hz
  • CTCSS Code 20 - 127.3 Hz
  • CTCSS Code 21 - 131.8 Hz
  • CTCSS Code 22 - 136.5 Hz
  • CTCSS Code 23 - 141.3 Hz
  • CTCSS Code 24 - 146.2 Hz
  • CTCSS Code 25 - 151.4 Hz
  • CTCSS Code 26 - 156.7 Hz
  • CTCSS Code 27 - 159.8 Hz
  • CTCSS Code 28 - 162.2 Hz
  • CTCSS Code 29 - 165.5 Hz
  • CTCSS Code 30 - 167.9 Hz
  • CTCSS Code 31 - 171.3 Hz
  • CTCSS Code 32 - 173.8 Hz
  • CTCSS Code 33 - 177.3 Hz
  • CTCSS Code 34 - 179.9 Hz
  • CTCSS Code 35 - 183.5 Hz
  • CTCSS Code 36 - 186.2 Hz
  • CTCSS Code 37 - 189.9 Hz
  • CTCSS Code 38 - 192.8 Hz
  • CTCSS Code 39 - 196.6 Hz
  • CTCSS Code 40 - 199.5 Hz
  • CTCSS Code 41 - 203.5 Hz
  • CTCSS Code 42 - 206.5 Hz
  • CTCSS Code 43 - 210.7 Hz
  • CTCSS Code 44 - 218.1 Hz
  • CTCSS Code 45 - 225.7 Hz
  • CTCSS Code 46 - 229.1 Hz
  • CTCSS Code 47 - 233.6 Hz
  • CTCSS Code 48 - 241.8 Hz
  • CTCSS Code 49 - 250.3 Hz
  • CTCSS Code 50 - 254.1 Hz
  • CTCSS (T-CTCS and R-CTCS)
  • OFF
  • 67.0HZ
  • 69.3HZ
  • 71.9HZ
  • 74.4HZ
  • 77.0HZ
  • 79.7HZ
  • 82.5HZ
  • 85.4HZ
  • 88.5HZ
  • 91.5HZ
  • 94.8HZ
  • 97.4HZ
  • 100.0HZ
  • 103.5HZ
  • 107.2HZ
  • 110.9HZ
  • 114.8HZ
  • 118.8HZ
  • 123.0HZ
  • 127.3HZ
  • 131.8HZ
  • 136.5HZ
  • 141.3HZ
  • 146.2HZ
  • 151.4HZ
  • 156.7HZ
  • 159.8HZ
  • 162.2HZ
  • 165.5HZ
  • 167.9HZ
  • 171.3HZ
  • 173.8HZ
  • 177.3HZ
  • 179.9HZ
  • 183.5HZ
  • 186.2HZ
  • 189.9HZ
  • 192.8HZ
  • 196.6HZ
  • 199.5HZ
  • 203.5HZ
  • 206.5HZ
  • 210.7HZ
  • 218.1HZ
  • 225.7HZ
  • 229.1HZ
  • 233.6HZ
  • 241.8HZ
  • 250.3HZ
  • 254.1HZ
  • DCS (T-DCS and R-DCS)
  • OFF
  • D023N
  • D025N
  • D026N
  • D031N
  • D032N
  • D036N
  • D043N
  • D047N
  • D051N
  • D053N
  • D054N
  • D065N
  • D071N
  • D072N
  • D073N
  • D074N
  • D114N
  • D115N
  • D116N
  • D122N
  • D125N
  • D131N
  • D132N
  • D134N
  • D143N
  • D145N
  • D152N
  • D155N
  • D156N
  • D162N
  • D165N
  • D172N
  • D174N
  • D205N
  • D212N
  • D223N
  • D225N
  • D226N
  • D243N
  • D244N
  • D245N
  • D246N
  • D251N
  • D252N
  • D255N
  • D261N
  • D263N
  • D265N
  • D266N
  • D271N
  • D274N
  • D306N
  • D311N
  • D315N
  • D325N
  • D331N
  • D332N
  • D343N
  • D346N
  • D351N
  • D356N
  • D364N
  • D365N
  • D371N
  • D411N
  • D412N
  • D413N
  • D423N
  • D431N
  • D432N
  • D445N
  • D446N
  • D452N
  • D454N
  • D455N
  • D462N
  • D464N
  • D465N
  • D466N
  • D503N
  • D506N
  • D516N
  • D523N
  • D526N
  • D532N
  • D546N
  • D564N
  • D606N
  • D612N
  • D624N
  • D627N
  • D631N
  • D632N
  • D645N
  • D654N
  • D662N
  • D664N
  • D703N
  • D712N
  • D723N
  • D731N
  • D732N
  • D734N
  • D743N
  • D754N
*Ace Hardware
  • 464.5000 MHz - 67.0 Hz PL
  • 464.5500 MHz - 67.0 Hz PL
  • 467.9000 MHz - 85.4 Hz PL
*BJ's Wholesale Club
  • 469.4875 MHz - 413 DPL
*Chick-Fil-A
  • 462.5500 MHz - 127.3 Hz PL
  • 462.5625 MHz - 67.0 Hz PL
  • 462.5750 MHz - 654 DPL
  • 462.5875 MHz - 118.8 Hz PL
  • 462.6000 MHz - 455 DPL
  • 462.6125 MHz - 127.3 Hz PL
  • 462.6250 MHz - 127.3 Hz PL
  • 462.6375 MHz - 131.8 Hz PL
  • 462.6500 MHz - 351 DPL
  • 462.6625 MHz - 136.5 Hz PL
  • 462.6750 MHz - 606 DPL
  • 462.6875 MHz - 141.3 Hz PL
  • 462.7000 MHz - 192.8 Hz PL
  • 462.7000 MHz - 155 DPL
  • 462.7125 MHz - 146.2 Hz PL
  • 462.7250 MHz - 136.5 Hz PL
  • 462.7250 MHz - 252 DPL
  • 462.7250 MHz - 461 DPL
  • 462.7250 MHz - 462 DPL
  • VHF:
  • 151.6550 MHz
  • 151.6850 MHz
  • 151.7150 MHz
  • 151.7450 MHz
  • 151.7750 MHz
  • 151.8650 MHz
  • 151.8950 MHz
  • 151.9250 MHz
  • 151.9550 MHz
  • 151.9850 MHz
  • 152.8850 MHz
  • 152.9150 MHz
  • 153.0050 MHz
  • 154.4900 MHz
  • 154.5150 MHz
  • 154.5400 MHz
  • 468.2125 MHz
  • 468.2625 MHz
  • 468.3125 MHz
  • 468.3625 MHz
  • 468.4125 MHz
  • 468.4625 MHz
  • 468.5125 MHz
  • 468.5625 MHz
  • 468.6125 MHz
  • 468.6625 MHz
  • 451.4125 MHz
  • 451.5125 MHz
  • 451.5375 MHz
  • 451.5875 MHz
  • 451.6375 MHz
  • 451.6625 MHz
  • 451.6875 MHz
  • 452.7625 MHz
  • 456.4125 MHz
  • 456.5125 MHz
  • 456.6125 MHz
  • 456.6875 MHz
  • 457.7625 MHz
  • 467.7625 MHz
  • 467.8125 MHz
  • 467.8500 MHz
  • 467.8750 MHz
  • 467.9000 MHz
  • 467.9250 MHz
  • 461.0375 MHz 445 DPL
  • 467.7625 MHz 743 DPL
  • 467.9000 MHz 743 DPL
*Carmax
  • 462.6750 MHz - 071 DPL
  • 462.7250 MHz - 026 DPL
  • 464.3250 MHz - 026 DPL
  • 464.8250 MHz - 026 DPL
  • 467.8500 MHz - 071 DPL
  • 467.8750 MHz - 026 DPL
  • 467.8750 MHz - 071 DPL
  • 467.9250 MHz - 071 DPL
  • 467.8500 MHz Channel 1
  • 467.8750 MHz Channel 2
  • 467.9000 MHz Channel 3
  • 467.9250 MHz Channel 4
  • 468.6625 MHz - 127.3 Hz PL
  • 467.8500 MHz
  • 467.8750 MHz
  • 467.9000 MHz
  • 467.9250 MHz
  • 467.7625 MHz - 107.2 Hz PL
  • 467.8125 MHz
  • 467.8750 MHz - 343 DPL
  • 467.8750 MHz - 411 DPL
  • 467.9250 MHz - 67.0 Hz PL
  • 467.9250 MHz
  • 467.8500 MHz 146.2 Hz PL
  • 467.8750 MHz - 100.0 Hz PL
  • 467.9000 MHz - 100.0 Hz PL
  • 467.9250 MHz - 100.0 Hz PL
  • 151.9400 MHz - 110.9 Hz PL
  • 154.5700 MHz - 110.9 Hz PL
  • 154.6000 MHz - 110.9 Hz PL
  • 461.0375 MHz
  • 461.1125 MHz
  • 461.2125 MHz
  • 462.7625 MHz
  • 462.8125 MHz
  • 464.5375 MHz
  • 464.5625 MHz
  • 466.0375 MHz
  • 466.1125 MHz
  • 466.1375 MHz
  • 469.4875 MHz
  • 469.5375 MHz
*Northern Tool + Equipment
  • 462.5500 MHz 71.9 Hz
  • 462.6000 MHz 241.8 Hz
  • 462.6500 MHz 218.1 Hz
  • 467.9000 MHz - 131 DPL
  • 464.5000 MHz - 162.2 Hz PL
  • 464.5500 MHz - 162.2 Hz PL
*Regal Cinemas
  • 464.8250 MHz - 100.0 Hz PL - Primary
  • 464.3250 MHz - 100.0 Hz PL
  • 464.5500 MHz - 413 DPL
  • 467.9000 MHz - 225.7 Hz PL
  • 467.9250 MHz - 225.7 Hz PL
  • 151.6250 MHz 179.9 Hz PL
  • 151.9550 MHz 179.9 Hz PL
  • 151.9250 MHz 506 DPL
  • 151.8950 MHz 506 DPL
*Whole Foods
  • 464.5500 MHz 466 DPL
  • 151.5050 MHz
  • 151.6250 MHz
  • 151.7000 MHz
  • 151.8200 MHz
  • 151.9250 MHz
  • 154.5700 MHz
  • 154.6000 MHz
  • 158.4000 MHz
  • 451.8000 MHz
  • 451.8125 MHz
  • 456.8125 MHz
  • 154.5700 MHz - Primary
  • 154.6000 MHz - Primary
  • 151.8200 MHz
  • 151.8800 MHz
  • 151.9400 MHz
  • 151.6250 MHz
  • 151.7600 MHz
  • 151.7750 MHz
  • 151.8200 MHz
  • 151.8350 MHz
  • 151.8650 MHz
  • 151.9550 MHz
  • 461.0375 MHz 172 DPL
  • 461.0875 MHz 223 DPL
  • 461.1125 MHz 172 DPL
  • 461.1875 MHz 172 DPL
  • 461.3625 MHz 172 DPL
  • 464.5000 MHz 172 DPL
  • 469.5000 MHz 172 DPL
